salut tout le monde , je voulait savoir si quelqu'un a deja tester le mod pour gagner en stabilite avec cette mobo et savoir si ca marche vraiment http://forums.extremeoverclocking. [...] 641-1.html "Last mod was vcore mod. 1.95V is maximum Vcore, but idle and load voltage difference is quite big. This is normal and follows Intel specs but overclocking is much easier with stable Vcore. Solution is to add ~250Kohm variable resistor between CSCOMP and CSSUM pins. (Datasheet of ADP3180 can be found here) This adjust droop voltage. I didn't solder mod straigh to the legs but to easier locations"
Marsh Posté le 28-08-2003 à 20:11:17
