Overclock 1800+...
Overclock 1800+... - Overclocking, Cooling & Modding
Marsh Posté le 31-07-2003 à 10:11:19
Voila :
J'ai une antique asus a7v133-c. Je viens d'acheter un XP 1800+ tout neuf (0.13).
Tout fonctionnait bien en 12.5*145MHz (1812) et je me suis dis qu'en coupant le bit 5 du pont L3 je pourrais accéder à des fréquences sup.
Le pb c'est que depuis que je l'ai coupé, je n'ai plus que les multiplicateurs 15 et 16 (pas grave) et surtout je ne peux plus dépasser 120 de FSB (plus grave)???
Donc :
15*120(1800):OK
16*120(1920):OK
15*121et+:KO
16*121et+:KO
Des infos???
Marsh Posté le 31-07-2003 à 11:23:45
:sweat:
Marsh Posté le 31-07-2003 à 13:47:32
Déjà pour le multiplicateur je viens de trouver ceci :
When 13X, 13.5X, 14X Multiplier settings from User-defined option do not boot, but 15X and up do.
May be caused by the Red bios driven buffered circuit used in some early mobos to auto-reset/match Northbridge's FID Multiplier "ID" signals when user/bios over-ride Duron/Tbird's 4 bit default Multipliers, because their default FID signals are set by separate/fixed L6 bridges (Blue), unlike Palomino/Tbred which auto-match 5 internal FID signals (Green, and no L6 bridges) directly from Multiplier signals.
But this Palomino/Tbred FID auto-match goes awry when resetting the Multiplier to 13X and up in mobos with those 4 bit buffered circuits, as the bios User-Defined option, which enables buffers A and bypasses the new FID Logic, substitutes incorrect data for the spec 0011 signals being blocked by disabled buffers B.
Example:- 13X bios reset sends 1st 4 bits of its 10100 code, 0100 = slower 5X code, to Northbridge while spec 0011 are blocked. So longer clock periods based on 5X input should result in Northbridge setting fewer/too few wait states for timing data transfers at 13X, data may corrupt/no boot. Boots at 15X suggest that timing issues ended there.
Those buffered circuits may also exist/cause problems in some later backward compatible mobos. Initial workarounds did not recall/consider these circuits and failed.
Pour info l'url : http://www.beachlink.com/candjac/Workarounds.htm
Il me reste à trouver pourquoi 120MHz et là...
Marsh Posté le 31-07-2003 à 13:51:19
d'ou tu sors que le 5 L3 fait acceder a des freq sup  :??:
 :sweat:
Marsh Posté le 31-07-2003 à 13:59:58
Les anciennes cartes mère ne gèrent les multiplicateurs que sur 4 bits. Hors, les nouveaux procs AMD en utilisent 5 et donc, quand le 5è pont est ouvert, on accède aux multiplicateurs >12.5.
Pour info : http://fab51.fc2web.com/pc/barton/athlon-e23.html
Marsh Posté le 31-07-2003 à 14:02:15
bon t'accede a des coeff sup mais le proco n'est pas plus overclocable  :D
Marsh Posté le 31-07-2003 à 14:15:20
Tout à fait d'accord avec toi mais je n'étais pas limité par le proc mais par la CM+mémoire dc une bonne solution quand on ne peut pas augmenter le FSB c'est d'augmenter le multiplicateur...
