L'ultime accessoire pour overclocker AMD ? - Overclocking, Cooling & Modding
Marsh Posté le 03-07-2003 à 23:21:13
ca se met entre le proco et le socket? (si j'ai bien compris)
Marsh Posté le 04-07-2003 à 00:15:51
dommage,sorti trop tard
Marsh Posté le 04-07-2003 à 00:17:42
mais pas très rassurant ... déjà que les Athlons sont pas ce qui se fait de plus solide !
| Citation : As opposed to the ZIF (Zero Insertion Force) sockets that are common today, Upgradeware's adapter is a module that offers no ease-of-use, because the processor has to be inserted into the adapter along with all of its 462 pins. Do this carefully, because if you don't apply even pressure to all sides when inserting the CPU into the socket, then it might bend - this can result in breaking the circuitry and causing the CPU to die a premature death. |
Marsh Posté le 03-07-2003 à 23:18:17
http://www.tomshardware.com/cpu/20030703/index.html
Il semblerai qu'il libere les coef sur TOUS les athlons....
