CM690 Deep-Blue / Intégration WC [Workblog] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 01-03-2011 à 10:22:00
![[:darkblade6666] [:darkblade6666]](https://forum-images.hardware.fr/images/perso/darkblade6666.gif)
reservé
GIGABYTE
Proc => Q6600go VID 1.25
Ram => Crucial Ballistic PC6400 4*1go "la vrai"
GIGABYTE EP35DS4:
=> Section : "Advanced BIOS Features"
 Limit CPUID Max. to 3 -> diseabled
CPU Enhanced Halt (C1E) -> diseabled
CPU Thermal Monitor 2 (TM2) -> diseabled
CPU EIST Function -> diseabled
=> Section : "PC Health Status"
 CPU Warning Temperature -> diseabled
=> Section: "MB Intelligent Tweaker(M.I.T.)"
CPU Clock Ratio -> 9x
CPU Host Clock Control -> enabled
CPU Host Frequency -> 400 Mhz
PCI Express Frequency -> 100
C.I.A. 2 -> diseabled
System Memory Multiplier (SPD) -> 2.00
Memory Frequency (Mhz) -> 800        800
Dram Timing Selectable (SPD) -> Manual
Cas Latency Time ->                       5      [4]
Dram Ras# to Cas# Delay ->             5      [4]
Dram Ras# Precharge ->                   5      [4]
Precharge delay (tRas) ->                 18    [12]
Vcore :1.4V bios - 1.36V réel
Mémoire: 2.00V
GIGABYTE X48DS4:
CPU Host Frequency -> 356 Mhz
PCI Express Frequency -> 101
Performance Enhance ->  Standard
System Memory Multiplier (SPD) -> 2.50
Memory Frequency (Mhz) -> 854
******* Standard timing control *******
******* Advanced timing control *******
Act to ACT Delay (tRRD) ->               3  [Auto]
Write to Precharge Delay ->               6  [Auto]
Refresh to ACI Delay ->                    52 [Auto]
Read to Precharge Delay ->                3 [Auto]
Static tRead Value ->                        7 [Auto]
Static tRead Phase Adjust ->              1 [Auto]
Command Rate (CMD) ->                    2 [Auto]
******* Clock Driving & Skew Control *******
CPU/PCIEX Clock Driving Control    [800mV]
CPU Clock Skew Control               [Normal]
(G) MCH CLock Skew Control        [Normal]
System voltage Control                [Manuel]
DDR2 Over Voltage Control            [+0.25V]
PCI-E OverVoltage Control            [Normal]
FSB Overvoltage Control               [0.10V]
(G) MCH OverVoltage Control         [0.100V]
Load Line Calibration                    [Enable]
CPU Voltage Control                    [1.26V]
Penser à toucher au refresh to aci, precharge delay, clock driving et le MCH Clock Skew pour du gros clocking.
Marsh Posté le 01-03-2011 à 11:57:07
ReplyMarsh Posté le 01-03-2011 à 13:31:25
Il n'y a pas seulement 35mm d'espace dans la tour en haut pour le radiateur ?
Ou tu comptes utiliser le dremel ?
Je vais commencer mon watercooling dans la même tour aussi aujourd'hui, je compatis !
Marsh Posté le 01-03-2011 à 13:57:35
 ![[:galinou] [:galinou]](https://forum-images.hardware.fr/images/perso/galinou.gif)
Gnniiiii!!!  ![[:darkblade6666] [:darkblade6666]](https://forum-images.hardware.fr/images/perso/darkblade6666.gif)
Une idée de la marque de tes rads? Ils se rapprochent beaucoup de ceux que j'ai cité...
| iflow a écrit : Tu vas chier pour le rad du haut  |
Ca devrait le faire d'après les quelques cotes que j'ai prise...
| LiftinG a écrit : Il n'y a pas seulement 35mm d'espace dans la tour en haut pour le radiateur ?  |
Ha et bien bonne chance à toi.
C'est un chouli boitier avec plein de possibilité...
Pour ma part le dremel sera de la sortie...  ![[:julm3] [:julm3]](https://forum-images.hardware.fr/images/perso/julm3.gif)
Il y a 2 ou 3 trucs à moder dans ce boitier et ça devrait le faire.
Je ne te tente pas non plus un truc à la Sassanou...
Marsh Posté le 01-03-2011 à 16:13:11
Le dremel va bien t'aider je crois.
Oui, Sassanou, n'en parlons même pas !
En tout cas, j'attends de voir ce que ça va donner, peut-être que je te piquerais des idées pour mon intégration.
Tu commences quand ?
Marsh Posté le 01-03-2011 à 16:17:14
je dirais magicool xtrem 240 et black ice pro 120
(mais je n'en suis pas certain)
Marsh Posté le 01-03-2011 à 16:21:37
Heu dès que je reçois la carte mère et la pompe... J'espère la semaine prochaine.
Viendra en premier les découpes boitier et la réalisation des contres cadres pour les rads.
Ensuite le rivetage des contres cadres et la réalisation d'une cage 2 HDD dans les baies 5"1/4 devant acceuillir la pompe aussi.
En espérant que je n'ai pas trop de mauvaises surprises pendant ce temps là...
| supersnoopy a écrit :
Ok merci j'édite en fonction.
Ca m'a l'air d'être cela en effet.
Marsh Posté le 02-03-2011 à 22:49:55
Quelques photos en attente de l'évolution du projet.
Carte mère reçu ainsi que ses WB.
Un truc bizare les fixs du North Bridge ne colle pas avec l'emplacement dedié des fixs de la carte mère...
A plus tard
Marsh Posté le 07-03-2011 à 18:21:14
Réception d'un peu de matos encore...
Laing 18W + 5870 + wb EK
Je vais commencer l'intégration d'ici peu.
J'attends la commande de Docmicro.
Marsh Posté le 07-03-2011 à 20:22:46
drap
Marsh Posté le 07-03-2011 à 20:29:17
Tu vas devoir modifier le top sur ton CM pour pouvoir passer le rad ...
J'attends de news photos  ![[:pcgamer] [:pcgamer]](https://forum-images.hardware.fr/images/perso/pcgamer.gif)
Marsh Posté le 07-03-2011 à 20:31:33
| polomod a écrit : Tu vas devoir modifier le top sur ton CM pour pouvoir passer le rad ...   |
C'est clair, car a part du slim, pas grand chose passe la haut sans buter sur les rettes ou sur la CM
Marsh Posté le 07-03-2011 à 21:38:10
Be en fait c'est pas si sur que je doive modifier le top...
D'apres les qqe cotes que j'ai pris ça devrait passer a un poil de cul avec la carte mère.
Après je peux me tromper, hein!
Walt and see.
Ça commence ce week!
Marsh Posté le 07-03-2011 à 21:47:22
Moi, sur mon cm690 1ère génération un 360 slim et des ventilos de 25mm passent tout juste .
Marsh Posté le 07-03-2011 à 22:31:52
Un 360 slim au dessus de la mobo et 3*120 slim ds le top avec modif ça passe
Marsh Posté le 07-03-2011 à 22:39:11
Dans tous les cas, un XSPC RS240 passe sans soucis et il fait 35mm.
C'est le max. que je pouvais mettre moi sans que ça touche les barrettes ou le rad. de la CM.
Marsh Posté le 08-03-2011 à 01:00:12
Houhou merci pour tout cet engouement soudain.  ![[:darkblade6666] [:darkblade6666]](https://forum-images.hardware.fr/images/perso/darkblade6666.gif)
Les deux 240 que je veux installer font 43mm. Ca "devrait" donc, tout juste passer...
La actuellement le tubing de la CM est une vraie anarchie...
Les embouts droits à coiffe ne me sont d'aucun secourt. Les courbes sont vraiment trop prononcé et le toyo se pince quasi à chaque coup.
Il me faut investir dans des 45 voire 90° à coiffe pour faire un truc "propre".
épiossi
Mon rad Ø120 que je voulais intégrer à l'arrière du boitier ne passe pas... un chouilla trop large...
Je vais devoir le revendre ou l'échanger.
Voila, je vous en dis plus quand le projet avancera.
 ![[:taill] [:taill]](https://forum-images.hardware.fr/images/perso/taill.gif)
EDIT: Après reflexion, je vais essayer d'intégrer la rad sur la porte lattéral du boitier avec un nfp-14 au fesse.
Marsh Posté le 08-03-2011 à 01:19:09
sauf si tu mets le ventilo sur le boîtier et le rad sur le ventilo
Marsh Posté le 08-03-2011 à 01:39:17
| littlewata a écrit : sauf si tu mets le ventilo sur le boîtier et le rad sur le ventilo   |
Oui on est d'accord...
Dans l'idée un truc du genre et le ventilo soufflant vers l'exterieur... mais en fait ça ne passera pas.
Avec les embouts du WB de la graph c'est pas possible.
Donc j'oublie la soluce...
Marsh Posté le 25-03-2011 à 09:23:14
![[:galinou] [:galinou]](https://forum-images.hardware.fr/images/perso/galinou.gif) à tous.
 à tous.
Des prioritées ce début de moi ci m'ont obligées à mettre le WorkBlog en stand by...
Mais me revoici dans les starting block et prêt à poursuivre la suite du projet.
Donc quelques nouvelles photos histoire de ne pas poster pour rien me diriez-vous.
J'ai reçu plein de matos ces derniers jours... l'appart en est submergé.
Je me suis lancé à désocer le boitier histoire de mettre en place les divers rad et ventilo de celui-ci.
Bon il y a de bonne surprise, le dremel n'aura pas besoin de trop chanter pour l'intégration car la plupart de mon matos passe sans modif.
Allez hop qqe tofs.
La config à l'air libre:
Le boitier lors de l'intégration des rads et ventilo:
La suite ce week-end que j'ai pas mal de temps libre.
A plus tard.  ![[:taill] [:taill]](https://forum-images.hardware.fr/images/perso/taill.gif)
Marsh Posté le 26-03-2011 à 19:18:37
Voila aujourd'hui j'ai procédé à l'instal des composants.
Tout est passé sans problème.
La carte mère et le réservoir restent en stand by pour le WC car me faut réceptionner les bonnes fixs pour les WB
Je mettrai en eau demain dans la journée.
Marsh Posté le 26-03-2011 à 19:44:47
Tu as fait comment pour fixer le rad du dessous ?
Sinon belle intégration, je drapalise, je vais faire un water sur la meme base
Marsh Posté le 26-03-2011 à 19:57:55
Beau boulot !
Et pas d'embouts coudés, que des droits, nickel
Marsh Posté le 26-03-2011 à 20:20:55
Oui merci.
Pour la fixation du rad avec des vis m3 fixé sur les emplacements prévu sur le boitier.
Le tout isolé avec avec de la mousse 6mm autocolante pour les vibrations. C'est nickel.
Merci pour le com Sassanou!
Marsh Posté le 26-03-2011 à 20:22:21
| arnonox a écrit : Oui merci.  |
L'alim passe bien sans appuyer sur le tuyau de la cg/rad du bas ?
Marsh Posté le 26-03-2011 à 20:44:28
Et bien ça devrait passer a un poil de c..
Je ferais des tofs demain une fois tout installé.
On verra bien si tout passe.
Bonne soirée qu'on m'attend pour l'apéro.
J'ai quand même l'iPhone sur moi pour suivre l'évolution workblog et les coms inopiné
Marsh Posté le 28-03-2011 à 08:43:05
Petite évolution.
Voila ou j'en suis.
La mise en eau a été un peu longue mais au final j'ai pas une bule dans le système.
Tout fonctionne à merveille.
Marsh Posté le 28-03-2011 à 11:08:36
Merci Sassanou.
Dès que j'ai les fixs des WB carte mère, je referais le tubing et intègrerai en plus le res EK et un rad 120 à l'arrière du boitier.
Marsh Posté le 29-03-2011 à 08:29:13
Bonjour.
Je suis en train de réfléchir pour la suite de mon intégration... (3 x WB carte mère + rad120 + res EK)
J'ai une deuxième pompe Laing sous la main. un modèle pro...
Est-ce que créer un deuxième circuit séparemment pour traiter la carte mère n'est pas un peu de trop?
J'aimerais avoir vos avis avant d'entreprendre la suite du projet.
Marsh Posté le 29-03-2011 à 12:00:35
Si tu la possibilité de faire deux circuit c'est toujours ça de pris !
Marsh Posté le 29-03-2011 à 12:49:31
deux loop c'est pas mal c'est sur .. ca evite de "polluer" des composant plus froid avec la chaleur des autres , mais met la pompe la plus puissante sur ton CPU
sinon tu as d'autre photos de ton VF1000 custom de la config a l'air libre ??
Marsh Posté le 29-03-2011 à 14:26:53
Bon je vais me lancer à faire un deuxième loop alors...
Pour les tofs du VF1000 oui j'en ferai.
Merci pour les avis.
Marsh Posté le 29-03-2011 à 19:29:57
Ouais bof, suis pas sur que ça soit vraiment utile là....
Sauf esthétiquement bien sur
Marsh Posté le 01-03-2011 à 10:20:03
Je me lance dans ma première réalisation Water et j'espère partager mes expériences avec des gens plus averties que moi dans le domaine.
Toutes critiques constructives sont les bienvenues.
Je commence avec le matériel qui va y avoir dedans.
Bon ce n'est pas une config "commandodelamortquitue" mais j'en suis encore satisfait pour ce que j'en demande.
Le matos:
=> CM690II
=> Intel Q6600
=> Gigabyte X48 DS4
=> 4 *1 go ddr2 Crucial B.
=> Saphire 5870
=> Seasonic X-serie
=> 2 *74Go raptor RAID 0
=> 2 * 500Go Samsung
Le water:
Pompe:
=> Laing DDC Ultra 18W.
Reservoir:
=> EK 150mm Ø60mm RES X2
Radiateurs:
=> 2 * Magicool xtrem 240S (46mm)
=> 1 * Magicool pro 120D (30mm)
Water block:
=> CPU Heatkiller S775
=> EK Acetal X48 Northbridge
=> EK Acetal X48 Southbridge
=> EK Acetal X48 mosfet
=> EK Acetal 5870
Embouts à coiffe :
=> 14 * Ø10/13 Koolance & Feser compagny
Tuyaux :
=> 4m * Tygon Ø10/13 (je finalise l'achat)
Esquisse tubing:
Photos:
Intégration => WB NB + WB SB + WB Mosfet + res EK
Message édité par arnonox le 22-11-2011 à 13:30:26
Artist#2385
