BONJOUR LE VENTILO DE MA CG LEADTEK MX 440 FAIT UN AFFREUX SIFFLEMENT j AI ESSAYE DE L ENLEVER PDT 5 MN BOITIER OUVERT ET CA A TENU . J AIMERAI SAVOIR SI CA PEUT TENIR A LONG TERME SACHANT QUE MON BOITIER EST BIEN VENTILE T CPU 32 T CM 25 MERCI POUR VOS REPONSES
Marsh Posté le 22-04-2005 à 15:50:45
BONJOUR
