[Work-Log]T-Computer First Case
T-Computer First Case [Work-Log] - Modding - Overclocking, Cooling & Modding
Marsh Posté le 08-03-2012 à 14:59:10
Bien le bonjour je viens présenter mon projet de Mod et ma config:
Hexx Renovatio
Mod configuration:
CASE Cooler Master CM690 II Advanced White
PSU Enermax Lepa B Series 750 W
CPU Intel Core i7 920
MB MSI Big Bang XPower
RAM Corsair Vengeance 3x4Go 1600Mhz CAS9
GPU PNY GTX480
STORAGE OCZ SSD Agility Series 60Go
Western Digital HDD 2To
Cooling configuration
VENTIRAD Prolimatech Genesis + 3x NZXT 140 Fans
GPU RAD ARTIC Accelero Xtreme Plus II
RHEOBUS NZXT Sentry Mesh
For the moment I've not take time to think about CASE Fans.
Et maintenant place au images:
Carte Mère:
http://img812.imageshack.us/img812/7049/38321627186664162071543.jpg
By serjsorrow at 2011-12-13
http://img17.imageshack.us/img17/4706/40372228140152798691543.jpg
By serjsorrow at 2011-12-27
http://img403.imageshack.us/img403/1396/37880427186678962441543.jpg
http://img24.imageshack.us/img24/3537/38109328140557608811543.jpg
http://img189.imageshack.us/img189/3416/corsairvengeance.jpg
By serjsorrow at 2012-02-05
http://img860.imageshack.us/img860/6378/gtx4802.jpg
Petite photo ou l'on aperçois la GTX.
Le processeur(amené a changer par la suite):
http://img593.imageshack.us/img593/4857/37883427186650561731543.jpg
http://img831.imageshack.us/img831/1898/38110127186635361351543.jpg
Le reste du matos:
http://img851.imageshack.us/img851/2570/lesdernierscomposants.jpg
http://img163.imageshack.us/img163/6273/40330727849140323561543.jpg
http://img440.imageshack.us/img440/5702/38659028140371204151543.jpg
http://img809.imageshack.us/img809/5184/38592728139754388731543.jpg
http://img694.imageshack.us/img694/1618/38382928139676786791543.jpg
http://img198.imageshack.us/img198/230/40719328139853591211543.jpg
http://img856.imageshack.us/img856/8356/39395528140277601811543.jpg
http://img803.imageshack.us/img803/9015/gtx480.jpg
Maintenant les photos du test  materiel:
http://img855.imageshack.us/img855/6339/39777927849114322911543.jpg
http://img853.imageshack.us/img853/5842/premiertest.jpg
Le montage initial de la config:
http://img820.imageshack.us/img820/5594/intheinside.jpg
http://img214.imageshack.us/img214/7136/laconfigmonte.jpg
Et maintenant les première photos du Mod:
http://img710.imageshack.us/img710/4125/cm690iiadvanced5.jpg
Premier test de rendu avec Sketchup.
http://img696.imageshack.us/img696/2928/42994933282480553671543.jpg
By serjsorrow at 2012-03-08
http://img694.imageshack.us/img694/8445/41687933351690683881543.jpg
Découpe du panneau latéral pour le moment j'hésite a rajouter des découpes en haut a droite au niveau des lecteurs sur le panneau.
http://img600.imageshack.us/img600/9093/41931833223993891541543.jpg
By serjsorrow at 2012-03-06
http://img443.imageshack.us/img443/3185/42245133224013892041543.jpg
http://img833.imageshack.us/img833/5061/64817332240758935915434.jpg
http://img26.imageshack.us/img26/2972/42340133224131494981543.jpg
http://img19.imageshack.us/img19/1214/41900433224167495881543.jpg
La partie la plus interessante a mes yeux pour le moment l'adaptation du système de refroidissement original en le mélangeant a l'Accelero afin d'avoir de bonne performance de refroidissement ainsi qu'une backplate,celle ci étant en projet de modification.
Message édité par SerjSorrow le 07-05-2012 à 14:47:09
Marsh Posté le 08-03-2012 à 16:36:57
Petite mise a jour avec des benchs:
Overclock CPU et GPU:
http://img406.imageshack.us/img406/6880/apercuoverclocksysteme.jpg
L'overclock du processeur est automatique en utilisant la fonction OC Genie pour le GPU je me suis débrouiller pour trouver et stabiliser le tout.
Final Fantasy 14 BenchMark:
http://img217.imageshack.us/img217/8649/paramtresff14.jpg
http://img24.imageshack.us/img24/2228/rsultatsff14.jpg
Viennent ensuite les traditionnels Bench de chez Furmark tous en Basic Edition:
http://img534.imageshack.us/img534/5091/resultatspcmark7.jpg
http://img846.imageshack.us/img846/1420/resultats3dmark11.jpg
http://img7.imageshack.us/img7/1995/rsultats3dmark06.jpg
Marsh Posté le 08-03-2012 à 19:07:56
:love:
Marsh Posté le 09-03-2012 à 19:05:13
Version finale du panneau latéral:
http://img696.imageshack.us/img696/6984/42209033426713759411543.jpg
By serjsorrow at 2012-03-09
Marsh Posté le 09-03-2012 à 19:31:00
:love: j'adore le style nid d'abeille !
C'est quoi les traces noir autour des découpes ? Sinon ça a l'air très propre bien joué, juste dommage que la découpe de droite  donne sur le support des 5"1/4
G5-yufi - Apple Cube
Marsh Posté le 09-03-2012 à 21:29:33
Drap ici ;)
Sinon le prolimatech Genesis me tente bien mais y a pas de problème niveau hauteur avec des barettes de coco domi ou vengeance ?
De même les rads ne touchent pas la CG si elle est dans un premier port comme j'ai lui dans pas mal de tests :/
Sinon j'adorel a sobriété :love:
Ventes/Achats : http://forum.hardware.fr/hfr/Achat [...] 8769_1.htm
Marsh Posté le 09-03-2012 à 21:51:02
Merci pour vos compliments ca fait plaisir que mon travail plaise au autres.
@thegyufi:
Les traces noires autour des découpes c'est juste des traces de poussières de métal qui on coller avec la chaleur et le scotch de peintre rien de bien méchant depuis c'est propre. c'est pas trop mal encore un peu de travail de finitions mais sinon c'est propre.
La découpe de droite est faite pourje vais peut etre supprimer une partie des baies ou sinon je mettrai un pvc assez opaque pour cacher pour le moment je vais voir comment j'arrange mais c'est que visuellement je trouvais que ca ajoutais un petit plus.
@Hitman 239:
Le Prolimatech est vraiment très bon en refroidissement et a vraiment beaucoup de classe. Aucuns soucis avec les Corsair Vengeance il doit rester 2mm entre les deux donc ca passe.
Il ne touche pas la carte graphique sur ma config car la carte mère est assez grande et bien organiser et surtout le premier port est dédié a la carte son.
La sobriété est le maitre mot de cette config gaming, meme si elle commence a dater mais parfois il faut faire des sacrifices pour pouvoir mettre le budget dans le mod.
Marsh Posté le 09-03-2012 à 22:12:11
Petite Up du soir:
L'arrivée d'une commande MDPC-X.com
http://img811.imageshack.us/img811/3176/42043533436140795081543.jpg
http://img850.imageshack.us/img850/1395/42035833436204796681543.jpg
Marsh Posté le 10-03-2012 à 12:50:32
La découpe en nid d'abeilles est jolie tu pourrais mettre du plexy coloré  au lieux de mettre du transparent
Marsh Posté le 10-03-2012 à 13:25:55
drapal
Marsh Posté le 10-03-2012 à 16:36:33
Le projet est de mettre un plexy bleu dans le thème de la carte mère.
Marsh Posté le 12-03-2012 à 00:10:39
SerjSorrow a écrit :
Petite Up du soir:
http://img811.imageshack.us/img811 [...] 081543.jpg
http://img850.imageshack.us/img850 [...] 681543.jpg
T'es arrivé à commander chez MDPC ?
Ca fait des jours que j'essaie, c'est toujours en attente, ne serait-ce que pour accéder au site :/
J'ai le poignet loin derrière | Top hontes HFR | [VDS] Montres | [VDS] de l'histoire
Marsh Posté le 12-03-2012 à 08:50:29
Site accessible sans soucis et ouvert a certaines heures ce soir a 18h par exemple pour peu de temps.
Marsh Posté le 12-03-2012 à 22:08:24
Petite mise a jour du soir:
Avec la reprise du taff cette semaine je vais pouvoir livrer la version definitive du design du boitier.
Rendez vous dans la semaine pour les vues 3D.
Marsh Posté le 13-03-2012 à 18:37:07
Petite Up:
Shéma a main levée pour donner une idée du rendu fini(si tout se passe bien):
http://img441.imageshack.us/img441/4321/42048633665876938341543.jpg
By serjsorrow at 2012-03-13
Réception des ventilos manquants et du second rhéobus:
http://img546.imageshack.us/img546/9099/43128433665586931091543.jpg
Marsh Posté le 13-03-2012 à 20:17:54
Drapalito :D
Lego à vendre : https://forum.hardware.fr/hfr/Achat [...] 4737_1.htm || Lian Li O11D XL - MSI MPG B550 Gaming Plus - Ryzen 9 5900x - 2x16Go Corsair 3200c16 - Gigabyte RX6800XT - Bequiet Pure Power 12M 1000w - Full Waterco
Marsh Posté le 14-03-2012 à 20:12:20
Découpe du jour pour mettre les rhéobus sur le dessus du boitier:
http://img542.imageshack.us/img542/6370/42178333733603031451543.jpg
By serjsorrow at 2012-03-14
http://img163.imageshack.us/img163/5027/41999733733630632141543.jpg
Marsh Posté le 14-03-2012 à 20:28:45
nice !
Marsh Posté le 14-03-2012 à 23:42:51
Comme promis modélisation 3D du résultat final(saufs changements):
http://img35.imageshack.us/img35/7279/cm690iiadvancedfinal1.jpg
Marsh Posté le 15-03-2012 à 00:20:39
Très beau travail ! Vivement le résultat final !
Marsh Posté le 15-03-2012 à 00:49:32
J'ai hate aussi d'avoir finis mais ce n'est pas pour tout de suite encore pas mal de composants pour le boitier a acheter, gainer la totalité des cables et peut-etre passer en watercooling mais la rien n'est moins sur.
Marsh Posté le 15-03-2012 à 07:57:41
Il me semble que tu as oublié les USB sur ta modélisation SketchUp :P
J'ai hâte de te voir à l'oeuvre, ça me fait penser au projet de Mata'. Bonne chance!
Marsh Posté le 15-03-2012 à 10:23:55
Je ne mettrais pas d'usb en facade je pense. Envie de faire quelque chose au design le plus epuré possible mais apres au pire je verrai peut etre a mettre deux usb 3.
Marsh Posté le 15-03-2012 à 12:00:11
Met les USB au dessus ;)
Marsh Posté le 15-03-2012 à 12:12:25
Bon c'est pas ma journée j'ai l'impressiom ma pince a rivet a cassée et ma Dremel refuse de démarrer mais heureusement j'ai fini le mod pour aujourd'hui maintenant je remets tout dans le boitier et je poste les premières photos.
Marsh Posté le 15-03-2012 à 15:16:18
Voila les résultats du travail d'aujourd'hui:
Mod des 120:
http://img192.imageshack.us/img192/6571/42737533772777610791543.jpg
By serjsorrow at 2012-03-15
mise en place des ventilos et rendu visuel du moment:
http://img585.imageshack.us/img585/9236/42328033772856012751543.jpg
http://img607.imageshack.us/img607/9573/42244333777494528711543.jpg
Marsh Posté le 15-03-2012 à 15:24:21
Petite question si certain on eu le meme soucis:
J'ai mis un 120 en extraction a l'arrière juste en face des deux 140 du ventirad et il siffle beaucoup a fond alors qu'il est silencieux au minimum avez vous des explications?
Pour l'avenir je vais acheter une table de bench car c'est contraignant de démonter et remonter a chaque avancée des travaux.
Pour la suite des aventure de ce mod je vous dis a début avril pour de nouvelles photos car sans Dremel ni pince a riveter le travail commence a ce compliquer et je doit aussi acheter le reste des composants nécessaires.
Merci a vous pour votre suivi.
Marsh Posté le 15-03-2012 à 15:25:31
Personnellement j'ai jamais ete un grand adepte des ventilos en aspiration sur le top... C'est un aspirateur a poussiere :/
Mais c'est joulie
EDIT : depuis que j'ai decouper le nid d'abeille a l'arriere de mon boitier sur mon Nzxt phantom j'ai la sensation que l'air s'evacue un peu mieux et le souffle est moins present !
Message édité par k0rnmuz3 le 15-03-2012 à 15:27:11
Marsh Posté le 15-03-2012 à 16:18:29
drap ! c'est du bon bouleau tout ça :)
Marsh Posté le 15-03-2012 à 17:44:14
@k0rnmuz3: je ne sais pas du tout si les ventilos son en aspiration sur le top il n'y a pas de flèches et je ne suis pas très doué pour analyser mes ventilos mdr.
@zortak: merci a toi
Marsh Posté le 15-03-2012 à 18:27:11
Dis toi que le sens dans lequel est monter tes ventilos sur ta photo c'est le sens qui fait entrer l'air dans le boitier :D
Pour faire simple, il y a une petite armature qui tient la bobine au centre du ventilo. Ce coter c'est l'arriere du ventilo. L'air sort de ce coter la et entre dans la face opposer (la face ou on ne voit que les pale du ventilo)
Pour ton sifflement, souvent les ventilateurs dis silencieux sont tout de meme legerement audible a vitesse max, c'est pourquoi on prefere mettre plus de ventilo mais les faire tourner le moins vite possible ;)
Message édité par k0rnmuz3 le 15-03-2012 à 18:28:12
Marsh Posté le 15-03-2012 à 19:49:37
Merci beaucoup pour ce petit cours^^
je changerai tout ca une fois le projet a termes.
Marsh Posté le 16-03-2012 à 20:11:34
Bon parfois la Dremel redemarre si quelqu'un a deja eu ce genre de soucis avec un Dremel merrci d'avance pour l'aide^^(il s'agit d'un Dremel 300)
Marsh Posté le 23-03-2012 à 11:14:02
Le Dremel redemarre juste un leger soucis du moteur, je vais investir dans un autre du coup mais les travaux vont pouvoir reprendre a venir achat du plexyglas pour le facade et finition de la cage pour les disques dur et le lecteur/graveur dvd slot in.
Viendra après l'achat du film adhésif carbon blanc et noir pour les finitions ainsi que des leds bleues.
Le gainage sera la derniere operation avec des gaines de chez MDPC-X^^
Marsh Posté le 23-03-2012 à 12:08:04
Hâte de voir ça ;)
Marsh Posté le 23-03-2012 à 20:07:31
Voici des petites photos en previews de mes prochaines acquisitions:
http://img706.imageshack.us/img706/9500/109997.jpg
By serjsorrow at 2012-03-23
Une baie pour installer le lecteur slim slot-in et le disque dur 3.5".
http://img703.imageshack.us/img703/6341/159285.jpg
Les connectiques de facades.
http://img9.imageshack.us/img9/6946/165871.jpg
L'adaptateur mini sata vers sata.
Marsh Posté le 23-03-2012 à 20:19:47
Et le bouton power avec une led bleu qui sera branchée sur la led HDD de la carte mère pour un petit effet sympa:
http://img594.imageshack.us/img594/5189/254413large.jpg
Marsh Posté le 23-03-2012 à 20:21:29
Tu pourrais détailler ou tu as acheté tout ça? Notamment pour les connectiques de façade :)
Marsh Posté le 23-03-2012 à 21:39:02
Les connectiques de facade j'ai acheté ca sur materiel.net, c'est a la base pour upgrader un boitier lancool pour ma part c'est juste ce dont j'ai besoin. J'ai aussi acheté la baie et l'adaptateur sur materiel.net.
Le bouton lui vient de Cold Zero Internationnal un site que j'ai découvert sur le forum au cours de mes recherches.
Marsh Posté le 30-03-2012 à 11:45:38
Bonjour suite a une petite blessure a l'oeil ce week-end le mod n'a pas vraiment avancé. De plus certains éléments prennent un peu de retard dans la livraison enfin pour le moment petite vidéo du test du lecteur slim qui servira de test(il provient d'un macbook accidenté):
http://www.youtube.com/watch?v=SvUPO2XOiP0
