[xawdecode - plugins] probleme de compilation
probleme de compilation [xawdecode - plugins] - Linux et OS Alternatifs
Marsh Posté le 19-08-2004 à 14:34:09
j'ai telechargé le dernier plugins de grincheur 1.4.8.
Mais mon prob c'est que je n'arrive pas a faire le make (le configure fonctionne)
j'ai un message d'erreur avec le fichier LaVache.cpp
Je suis sous Redhat 9.0, et j'ai xawdecode qui fonctionne.
Peux tu m'aider.
Merci d'avance
Kiddy
PS: voici le message d'erreur
LaVache.cpp:1439:9: warning: multi-line string literals are deprecated
LaVache.cpp: In member function `void CLaVache::CalculDiffLine(int, int)':
LaVache.cpp:1439: parse error before `%' token
LaVache.cpp:1439: stray '\' in program
LaVache.cpp:1440:19: warning: multi-line string literals are deprecated
LaVache.cpp:1411: warning: unused variable `UNSIGNED_INT_64 masklum'
LaVache.cpp:1520:9: warning: multi-line string literals are deprecated
LaVache.cpp: In member function `int CLaVache::CalculDiffColumn(int)':
LaVache.cpp:1520: parse error before `mm4'
LaVache.cpp:1477: warning: unused variable `UNSIGNED_INT_64 masklum'
LaVache.cpp:1481: warning: unused variable `int*pValue'
LaVache.cpp:1482: warning: unused variable `short int*psSort'
LaVache.cpp:2385:9: warning: multi-line string literals are deprecated
LaVache.cpp: In member function `void CLaVache::CalculDiffLinePrevious(int*,
   int*, int&, int)':
LaVache.cpp:2385: parse error before `%' token
LaVache.cpp:2385: stray '\' in program
LaVache.cpp:2386:23: warning: multi-line string literals are deprecated
LaVache.cpp:2340: warning: unused variable `int saut'
LaVache.cpp:2343: warning: unused variable `UNSIGNED_INT_64 masklum'
LaVache.cpp:2493:9: warning: multi-line string literals are deprecated
LaVache.cpp: In member function `int CLaVache::CalculDiffColumnPrevious(int,
   int)':
LaVache.cpp:2493: parse error before `%' token
LaVache.cpp:2493: stray '\' in program
LaVache.cpp:2495:19: warning: multi-line string literals are deprecated
LaVache.cpp:2493: invalid suffix on integer constant
LaVache.cpp:2496:13: warning: multi-line string literals are deprecated
LaVache.cpp:2498:9: warning: multi-line string literals are deprecated
LaVache.cpp:2499:24: warning: multi-line string literals are deprecated
LaVache.cpp:2500:29: warning: multi-line string literals are deprecated
LaVache.cpp:2501:25: warning: multi-line string literals are deprecated
LaVache.cpp:2502:34: warning: multi-line string literals are deprecated
LaVache.cpp:2504:317: warning: multi-line string literals are deprecated
LaVache.cpp:2529:24: warning: multi-line string literals are deprecated
LaVache.cpp:2531:27: warning: multi-line string literals are deprecated
LaVache.cpp:2532:34: warning: multi-line string literals are deprecated
LaVache.cpp:2533:24: warning: multi-line string literals are deprecated
LaVache.cpp:2535:28: warning: multi-line string literals are deprecated
LaVache.cpp:2536:13: warning: multi-line string literals are deprecated
LaVache.cpp:2538:16: warning: multi-line string literals are deprecated
LaVache.cpp:2539:10: warning: multi-line string literals are deprecated
LaVache.cpp:2542:26: warning: multi-line string literals are deprecated
LaVache.cpp:2543:28: warning: multi-line string literals are deprecated
LaVache.cpp:2545:24: warning: multi-line string literals are deprecated
LaVache.cpp:2546:24: warning: multi-line string literals are deprecated
LaVache.cpp:2548:24: warning: multi-line string literals are deprecated
LaVache.cpp:2549:24: warning: multi-line string literals are deprecated
LaVache.cpp:2551:22: warning: multi-line string literals are deprecated
LaVache.cpp:2552:22: warning: multi-line string literals are deprecated
LaVache.cpp:2554:34: warning: multi-line string literals are deprecated
LaVache.cpp:2555:34: warning: multi-line string literals are deprecated
LaVache.cpp:2557:23: warning: multi-line string literals are deprecated
LaVache.cpp:2558:23: warning: multi-line string literals are deprecated
LaVache.cpp:2560:25: warning: multi-line string literals are deprecated
LaVache.cpp:2561:24: warning: multi-line string literals are deprecated
LaVache.cpp:2564:28: warning: multi-line string literals are deprecated
LaVache.cpp:2565:29: warning: multi-line string literals are deprecated
LaVache.cpp:2567:24: warning: multi-line string literals are deprecated
LaVache.cpp:2568:24: warning: multi-line string literals are deprecated
LaVache.cpp:2570:24: warning: multi-line string literals are deprecated
LaVache.cpp:2571:24: warning: multi-line string literals are deprecated
LaVache.cpp:2573:22: warning: multi-line string literals are deprecated
LaVache.cpp:2574:22: warning: multi-line string literals are deprecated
LaVache.cpp:2576:34: warning: multi-line string literals are deprecated
LaVache.cpp:2577:34: warning: multi-line string literals are deprecated
LaVache.cpp:2579:23: warning: multi-line string literals are deprecated
LaVache.cpp:2580:23: warning: multi-line string literals are deprecated
LaVache.cpp:2582:25: warning: multi-line string literals are deprecated
LaVache.cpp:2584:25: warning: multi-line string literals are deprecated
LaVache.cpp:2586:20: warning: multi-line string literals are deprecated
LaVache.cpp:2587:27: warning: multi-line string literals are deprecated
LaVache.cpp:2589:16: warning: multi-line string literals are deprecated
LaVache.cpp:2590:25: warning: multi-line string literals are deprecated
LaVache.cpp:2592:13: warning: multi-line string literals are deprecated
LaVache.cpp:2594:24: warning: multi-line string literals are deprecated
LaVache.cpp:2595:29: warning: multi-line string literals are deprecated
LaVache.cpp:2596:25: warning: multi-line string literals are deprecated
LaVache.cpp:2598:30: warning: multi-line string literals are deprecated
LaVache.cpp:2599:256: warning: multi-line string literals are deprecated
LaVache.cpp:2603:30: warning: multi-line string literals are deprecated
LaVache.cpp:2915:30: warning: multi-line string literals are deprecated
LaVache.cpp:2916:28: warning: multi-line string literals are deprecated
LaVache.cpp:2917:29: warning: multi-line string literals are deprecated
LaVache.cpp:2918:24: warning: multi-line string literals are deprecated
LaVache.cpp:2920:10: warning: multi-line string literals are deprecated
LaVache.cpp:2921:25: warning: multi-line string literals are deprecated
LaVache.cpp:2922:33: warning: multi-line string literals are deprecated
LaVache.cpp:2924:16: warning: multi-line string literals are deprecated
LaVache.cpp:2926:25: warning: multi-line string literals are deprecated
LaVache.cpp:2429: warning: unused variable `UNSIGNED_INT_64 masklum'
LaVache.cpp:2431: warning: unused variable `int nSumDiffVabs'
LaVache.cpp:2432: warning: unused variable `int nThresholdMax'
LaVache.cpp:2434: warning: unused variable `int*pValueColumnActual'
LaVache.cpp:2435: warning: unused variable `short int*psSortActual'
LaVache.cpp:2437: warning: unused variable `int*pValueColumnOldSort'
LaVache.cpp:2964: warning: no return statement in function returning non-void
LaVache.cpp:2983:9: warning: multi-line string literals are deprecated
LaVache.cpp: At global scope:
LaVache.cpp:2983: stray '\' in program
LaVache.cpp:2984:28: warning: multi-line string literals are deprecated
LaVache.cpp:2983: invalid suffix on integer constant
LaVache.cpp:2986:13: warning: multi-line string literals are deprecated
LaVache.cpp:2987:16: warning: multi-line string literals are deprecated
LaVache.cpp:2989:10: warning: multi-line string literals are deprecated
LaVache.cpp:3744:9: warning: multi-line string literals are deprecated
LaVache.cpp: In member function `void CLaVache::FilterSecamWithAverage(char)':
LaVache.cpp:3744: invalid suffix on integer constant
LaVache.cpp:3744: parse error before numeric constant
LaVache.cpp:3744: stray '\' in program
LaVache.cpp:3746:13: warning: multi-line string literals are deprecated
LaVache.cpp:3748:36: warning: multi-line string literals are deprecated
LaVache.cpp:3749:37: warning: multi-line string literals are deprecated
LaVache.cpp:3751:10: warning: multi-line string literals are deprecated
LaVache.cpp:3752:28: warning: multi-line string literals are deprecated
LaVache.cpp:3753:13: warning: multi-line string literals are deprecated
LaVache.cpp:3754:16: warning: multi-line string literals are deprecated
LaVache.cpp:3755:10: warning: multi-line string literals are deprecated
LaVache.cpp:3760:26: warning: multi-line string literals are deprecated
LaVache.cpp:3761:26: warning: multi-line string literals are deprecated
LaVache.cpp:3764:19: warning: multi-line string literals are deprecated
LaVache.cpp:3765:24: warning: multi-line string literals are deprecated
LaVache.cpp:3767:19: warning: multi-line string literals are deprecated
LaVache.cpp:3768:24: warning: multi-line string literals are deprecated
LaVache.cpp:3771:26: warning: multi-line string literals are deprecated
LaVache.cpp:3772:21: warning: multi-line string literals are deprecated
LaVache.cpp:3774:24: warning: multi-line string literals are deprecated
LaVache.cpp:3775:21: warning: multi-line string literals are deprecated
LaVache.cpp:3777:19: warning: multi-line string literals are deprecated
LaVache.cpp:3778:25: warning: multi-line string literals are deprecated
LaVache.cpp:3781:24: warning: multi-line string literals are deprecated
LaVache.cpp:3783:23: warning: multi-line string literals are deprecated
LaVache.cpp:3785:16: warning: multi-line string literals are deprecated
LaVache.cpp:3788:28: warning: multi-line string literals are deprecated
LaVache.cpp:3790:13: warning: multi-line string literals are deprecated
LaVache.cpp:3791:16: warning: multi-line string literals are deprecated
LaVache.cpp:3793:28: warning: multi-line string literals are deprecated
LaVache.cpp:3794:12: warning: multi-line string literals are deprecated
LaVache.cpp:3796:12: warning: multi-line string literals are deprecated
LaVache.cpp:3797:383: warning: multi-line string literals are deprecated
LaVache.cpp:3806:28: warning: multi-line string literals are deprecated
LaVache.cpp:3807:29: warning: multi-line string literals are deprecated
LaVache.cpp:3809:16: warning: multi-line string literals are deprecated
LaVache.cpp:3810:13: warning: multi-line string literals are deprecated
LaVache.cpp:3812:16: warning: multi-line string literals are deprecated
LaVache.cpp:3814:10: warning: multi-line string literals are deprecated
LaVache.cpp:3816:25: warning: multi-line string literals are deprecated
LaVache.cpp:3817:33: warning: multi-line string literals are deprecated
LaVache.cpp:3818:37: warning: multi-line string literals are deprecated
LaVache.cpp:3820:16: warning: multi-line string literals are deprecated
LaVache.cpp:3821:38: warning: multi-line string literals are deprecated
LaVache.cpp:3823:19: warning: multi-line string literals are deprecated
LaVache.cpp:3824:33: warning: multi-line string literals are deprecated
LaVache.cpp:3826:17: warning: multi-line string literals are deprecated
LaVache.cpp:3828:25: warning: multi-line string literals are deprecated
LaVache.cpp:3690: warning: unused variable `UNSIGNED_INT_64 maskancienrouge'
LaVache.cpp:3691: warning: unused variable `UNSIGNED_INT_64 masknouveaurouge'
LaVache.cpp:3692: warning: unused variable `UNSIGNED_INT_64 maskancienbleu'
LaVache.cpp:3693: warning: unused variable `UNSIGNED_INT_64 masknouveaubleu'
make[3]: *** [LaVache.lo] Erreur 1
make[2]: *** [all] Erreur 2
make[1]: *** [all-recursive] Erreur 1
make: *** [all] Erreur 2
