NFS, monter le /home du serveur sur les clients [probleme] - Linux et OS Alternatifs
Marsh Posté le 18-04-2002 à 11:37:10
alors, faut que dans ton /etc/hosts ou dans ton dns, le serveur nfs puisse resoudre le nom des machines clientes, sinon zob d'apres mes essais. Ensuite, dans /etc/hosts.allow, faut mettre :
# /etc/hosts.allow: list of hosts that are allowed to access the system.
# See the manual pages hosts_access(5), hosts_options(5)
# and /usr/doc/netbase/portmapper.txt.gz
# Example: ALL: LOCAL @some_netgroup
# ALL: .foobar.edu EXCEPT terminalserver.foobar.edu
# If you're going to protect the portmapper use the name "portmap" for the
# daemon name. Remember that you can only use the keyword "ALL" and IP
# addresses (NOT host or domain names) for the portmapper. See portmap(8)
# and /usr/doc/portmap/portmapper.txt.gz for further information.
portmap: 192.168.1.0/255.255.255.0
lockd: 192.168.1.0/255.255.255.0
rquotad: 192.168.1.0/255.255.255.0
mountd: 192.168.1.0/255.255.255.0
statd: 192.168.1.0/255.255.255.0
remplace 192.168.1.0/255.255.255.0 par ton reszo perso
dans /etc/hosts.deny, mettre :
# /etc/hosts.deny: list of hosts that are _not_ allowed to access the system.
# Example: ALL: some.host.name, .some.domain
# ALL EXCEPT in.fingerd: other.host.name, .other.domain
# The PARANOID wildcard matches any host whose name does not match its
# address. You may wish to enable this to ensure any programs that don't
# validate looked up hostnames still leave understandable logs. In past
# versions of Debian this has been the default.
# ALL: PARANOID
portmap: ALL
lockd: ALL
mountd: ALL
rquotad: ALL
statd: ALL
et dans /etc/exports
# /etc/exports: the access control list for filesystems which may be exported
# to NFS clients. See exports(5).
/western_digital 192.168.1.0/255.255.255.0(rw,no_root_squash)
Bien sur, faut mettre ici ce que tu veux
Voila, tout ça vient de ma deb et le nfs marche sans prob
Marsh Posté le 18-04-2002 à 12:01:27
oki un grand merci comme d'hab, ca a l'air de marcher pour une fois j'arrive a me loguer la
p
Marsh Posté le 18-04-2002 à 12:35:35
J'ai la même chose que vous qui tourne chez moi, rien a rajouter sur les remarques précédentes.... sauf que a chaque fois que j'éteint ma machine il me crache un :
"umount2 : /home non monté [ERREUR]"
J'dois avoir un vieux truc qui traine quelque part et qui lui dis de démonter /home, mais j'vois pas quoi, le fichier /etc/fstab a l'air OK.... une suggestion ??
Marsh Posté le 18-04-2002 à 13:02:39
ben quand tu éteins ta machine, il démonte les filesystems, qu'ils soient locaux ou reseau.
Tu le montes comment à quel moment ton /home ? Au boot auto, à la main ?
Marsh Posté le 18-04-2002 à 13:21:11
Par le fichier /etc/fstab à chaque boot... Donc ca parait donc
logique qu'il cherche a le démonter, mais pas qu'il ait une erreur au démontage.... en plus j'viens d'essayer de reproduire
l'errreur et comme par hazard : rien cette fois ci.....
Marsh Posté le 18-04-2002 à 14:03:46
| arras a écrit a écrit : bon voila mon petit probleme du jour j'ai un petit reseau et je souhaite monter automatiquement au demarrage le /home du serveur dans /export/home sur les clients jusque la rien d'anormal j'ai donc configurer mon serveur pour qu'il fasse cela ainsi que les clients le probleme vient au lancement de netfs start sur les clients Le mess d'erreur est : mount: 192.168.0.1 mon fichier /etc/fstad des clients est le suivant : 192.168.0.1 en fait on dirait que le client n'a pas accès au home du serveur (192.168.0.1) y a t il qq chose de particulier a configurer sur le serveur pour effectuer cela ??? merci d'avance pour vos reponses |
Dis moi, si je pense bien
tu as partage ton home et apres tu comptes mettre en place un serveur NIS ou LDAP, pour eviter de te retaper sur tous les serveurs adduser... ???
Car c'est ce que je fais aussi partage du /home, mais je n'ai que 2 pc en resau sous Linux donc ce n'est pas la mort, mais si jamais tu penses mettre ca en place et que tu as une bonne doc je suis preneur
Marsh Posté le 18-04-2002 à 14:17:23
| Lebibi a écrit a écrit : Dis moi, si je pense bien Car c'est ce que je fais aussi partage du /home, mais je n'ai que 2 pc en resau sous Linux donc ce n'est pas la mort, mais si jamais tu penses mettre ca en place et que tu as une bonne doc je suis preneur |
oui c ca
pour la doc j'ai trouver ca qui a l'air pas mal
http://myweb.worldnet.net/~lmsoft/ [...] =nis#ss6.3
Marsh Posté le 18-04-2002 à 11:26:47
home failed, Permission non acordée
home /export/home nfs defaults 0 0
mount: 192.168.0.1
192.168.0.1
