probleme avec mkisofs : no boot - Linux et OS Alternatifs
MarshPosté le 14-12-2005 à 01:52:51
bonjour
en voulant créer l'iso d'un livecd, j'obtiens l'erreur suivante : Excluded by match: /mnt/hda1/fos/master/boot/isolinux/boot.cat cela rend mon iso non bootable, et j'avou pour un livecd c assez genant, est ce que qqun sait comment regler ce probleme
merci d'avance ++
voici la ligne que je rentre, ainsi que le code verbose sortant
Marsh Posté le 14-12-2005 à 01:52:51
bonjour
merci d'avance
root@0[master]# mkisofs -pad -l -r -J -v -V "Polyserv_v2.0" -no-emul-boot -boot-load-size 4 -boot-info-table -b boot/isolinux/isolinux.bin -c boot/isolinux/boot.cat -hide-rr-moved -o /mnt/hda1/fos/knoppix.iso /mnt/hda1/fos/master
mkisofs 2.01a27-unofficial-iconv (i686-pc-linux-gnu)
Scanning /mnt/hda1/fos/master
Scanning /mnt/hda1/fos/master/KNOPPIX
Scanning /mnt/hda1/fos/master/boot
Scanning /mnt/hda1/fos/master/boot/isolinux
Writing: Initial Padbock Start Block 0
Done with: Initial Padbock Block(s) 16
Writing: Primary Volume Descriptor Start Block 16
Done with: Primary Volume Descriptor Block(s) 1
Writing: Eltorito Volume Descriptor Start Block 17
Size of boot image is 4 sectors -> No emulation
Done with: Eltorito Volume Descriptor Block(s) 1
Writing: Joliet Volume Descriptor Start Block 18
Done with: Joliet Volume Descriptor Block(s) 1
Writing: End Volume Descriptor Start Block 19
Done with: End Volume Descriptor Block(s) 1
Writing: Version block Start Block 20
Done with: Version block Block(s) 1
Writing: Path table Start Block 21
Done with: Path table Block(s) 4
Writing: Joliet path table Start Block 25
Done with: Joliet path table Block(s) 4
Writing: Directory tree Start Block 29
Done with: Directory tree Block(s) 4
Writing: Joliet directory tree Start Block 33
Done with: Joliet directory tree Block(s) 4
Writing: Directory tree cleanup Start Block 37
Done with: Directory tree cleanup Block(s) 0
Writing: Extension record Start Block 37
Done with: Extension record Block(s) 1
Writing: The File(s) Start Block 38
4.96% done, estimate finish Wed Dec 14 01:45:49 2005
9.90% done, estimate finish Wed Dec 14 01:45:49 2005
14.85% done, estimate finish Wed Dec 14 01:45:56 2005
19.79% done, estimate finish Wed Dec 14 01:45:54 2005
24.74% done, estimate finish Wed Dec 14 01:45:53 2005
29.68% done, estimate finish Wed Dec 14 01:45:52 2005
34.64% done, estimate finish Wed Dec 14 01:45:52 2005
39.57% done, estimate finish Wed Dec 14 01:45:51 2005
44.53% done, estimate finish Wed Dec 14 01:45:51 2005
49.47% done, estimate finish Wed Dec 14 01:45:51 2005
54.42% done, estimate finish Wed Dec 14 01:45:51 2005
59.36% done, estimate finish Wed Dec 14 01:45:51 2005
64.31% done, estimate finish Wed Dec 14 01:45:50 2005
69.25% done, estimate finish Wed Dec 14 01:45:50 2005
74.20% done, estimate finish Wed Dec 14 01:46:02 2005
79.14% done, estimate finish Wed Dec 14 01:46:29 2005
84.10% done, estimate finish Wed Dec 14 01:46:28 2005
89.03% done, estimate finish Wed Dec 14 01:46:28 2005
93.99% done, estimate finish Wed Dec 14 01:46:28 2005
98.93% done, estimate finish Wed Dec 14 01:46:27 2005
Total translation table size: 2048
Total rockridge attributes bytes: 1845
Total directory bytes: 6144
Path table size(bytes): 54
Done with: The File(s) Block(s) 100904
Writing: Ending Padblock Start Block 100942
Done with: Ending Padblock Block(s) 150
Max brk space used 0
101092 extents written (197 MB)
root@0[master]#
