Probleme avec Java-Acces-Bridge - Linux et OS Alternatifs
MarshPosté le 06-03-2006 à 18:19:07
Voila plusieurs heures que j'essaie d'installer Java-Acces-Bridge chez moi, afin de pouvoir essayer le support de reconnaissance vocale de OpenOffice.
Malheureusement , des que je lance le make voila ce que je me mange :
CLASSPATH=../../../../idlgen javac AccessibleHelper.java ---------- 1. ERROR in AccessibleHelper.java (at line 15) public static void insert (org.omg.CORBA.ANY a, org.GNOME.Accessibility.Accessible that) ^^^^^^^ org.omg cannot be resolved to a type ---------- 2. ERROR in AccessibleHelper.java (at line 17) org.omg.CORBA.portable.OutputStream out = a.create_output_stream (); ^^^^^^^ org.omg cannot be resolved to a type ---------- 3. ERROR in AccessibleHelper.java (at line 18) a.type (type ()); ^^^^ The method type() is undefined for the type AccessibleHelper ---------- 4. ERROR in AccessibleHelper.java (at line 20) a.read_value (out.create_input_stream (), type ()); ^^^^ The method type() is undefined for the type AccessibleHelper ---------- 5. ERROR in AccessibleHelper.java (at line 23) public static org.GNOME.Accessibility.Accessible extract (org.omg.CORBA.Any a) ^^^^^^^ org.omg cannot be resolved to a type ---------- 6. ERROR in AccessibleHelper.java (at line 28) private static org.omg.CORBA.TypeCode __typeCode = null; ^^^^^^^ org.omg cannot be resolved to a type ---------- 7. ERROR in AccessibleHelper.java (at line 29) synchronized public static org.omg.CORBA.TypeCode type () ^^^^^^^ org.omg cannot be resolved to a type ---------- 8. ERROR in AccessibleHelper.java (at line 31) if (__typeCode == null) ^^^^^^^^^^ __typeCode cannot be resolved ---------- 9. ERROR in AccessibleHelper.java (at line 33) __typeCode = org.omg.CORBA.ORB.init ().create_interface_tc (org.GNOME.Accessibility.AccessibleHelper.id (), "Accessible" ); ^^^^^^^^^^ __typeCode cannot be resolved ---------- 10. ERROR in AccessibleHelper.java (at line 33) __typeCode = org.omg.CORBA.ORB.init ().create_interface_tc (org.GNOME.Accessibility.AccessibleHelper.id (), "Accessible" ); ^^^^^^^ org.omg cannot be resolved ---------- 11. ERROR in AccessibleHelper.java (at line 35) return __typeCode; ^^^^^^^^^^ __typeCode cannot be resolved ---------- 12. ERROR in AccessibleHelper.java (at line 43) public static org.GNOME.Accessibility.Accessible read (org.omg.CORBA.portable.InputStream istream) ^^^^^^^ org.omg cannot be resolved to a type ---------- 13. ERROR in AccessibleHelper.java (at line 48) public static void write (org.omg.CORBA.portable.OutputStream ostream, org.GNOME.Accessibility.Accessible value) ^^^^^^^ org.omg cannot be resolved to a type ---------- 14. ERROR in AccessibleHelper.java (at line 50) ostream.write_Object ((org.omg.CORBA.Object) value); ^^^^^^^ org.omg cannot be resolved ---------- 15. ERROR in AccessibleHelper.java (at line 53) public static org.GNOME.Accessibility.Accessible narrow (org.omg.CORBA.Object obj) ^^^^^^^ org.omg cannot be resolved to a type ---------- 16. ERROR in AccessibleHelper.java (at line 60) throw new org.omg.CORBA.BAD_PARAM (); ^^^^^^^ org.omg cannot be resolved to a type ---------- 17. ERROR in AccessibleHelper.java (at line 63) org.omg.CORBA.portable.Delegate delegate = ((org.omg.CORBA.portable.ObjectImpl)obj)._get_delegate (); ^^^^^^^ org.omg cannot be resolved to a type ---------- 18. ERROR in AccessibleHelper.java (at line 63) org.omg.CORBA.portable.Delegate delegate = ((org.omg.CORBA.portable.ObjectImpl)obj)._get_delegate (); ^^^^^^^ org.omg cannot be resolved ---------- 19. ERROR in AccessibleHelper.java (at line 70) public static org.GNOME.Accessibility.Accessible unchecked_narrow (org.omg.CORBA.Object obj) ^^^^^^^ org.omg cannot be resolved to a type ---------- 20. ERROR in AccessibleHelper.java (at line 78) org.omg.CORBA.portable.Delegate delegate = ((org.omg.CORBA.portable.ObjectImpl)obj)._get_delegate (); ^^^^^^^ org.omg cannot be resolved to a type ---------- 21. ERROR in AccessibleHelper.java (at line 78) org.omg.CORBA.portable.Delegate delegate = ((org.omg.CORBA.portable.ObjectImpl)obj)._get_delegate (); ^^^^^^^ org.omg cannot be resolved ---------- 21 problems (21 errors)make[4]: *** [AccessibleHelper.class] Erreur 255 make[4]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org/GNOME/Accessibility » make[3]: *** [all-recursive] Erreur 1 make[3]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org/GNOME » make[2]: *** [all-recursive] Erreur 1 make[2]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen/org » make[1]: *** [all-recursive] Erreur 1 make[1]: quittant le répertoire « /home/esox/Desktop/java-access-bridge-1.4.5/idlgen » make: *** [all-recursive] Erreur 1
Ce qui me fait penser qu'il ne trouve pas la directory ou se trouve le jar de org.omg.CORBA. J'ai controlé , il est bel et bien sur mon systeme, avez vous une idée de ou je dois aller mettre le path pour qu'îl trouve aussi mon autre package?
Merci beaucoup
Esox
--------------- Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
Marsh Posté le 06-03-2006 à 18:19:07
(at line 15)
(at line 17)
(at line 18)
a.type (type ());
(at line 20)
(at line 23)
(at line 28)
(at line 29)
(at line 31)
(at line 33)
(at line 33)
(at line 35)
return __typeCode;
(at line 43)
(at line 48)
(at line 50)
(at line 53)
(at line 60)
(at line 63)
(at line 63)
(at line 70)
(at line 78)
(at line 78)
Merci beaucoup
Esox
