Pb avec MySQL ! HELP
Pb avec MySQL ! HELP - Linux et OS Alternatifs
Marsh Posté le 08-11-2001 à 18:05:35
Salut à tous,
Je suis en train d'installé Apache+PHP+Mysql
J'ai downloader les sources et je les ai compilé.
Apache & PHP fonctionnent.
Mais y a 1 gros prob avec MySQL
j'ai fait:
./configure --prefix=/usr/local/mysql && make && make install
La compile c'est bien passé
J'ai ensuite tapé
/usr/local/mysql/bin/mysql_install_db
J'obtiens
To start mysqld at boot time you have to copy support-files/mysql.server
to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
This is done with:
/usr/local/mysql/bin/mysqladmin -u root -p password 'new-password'
/usr/local/mysql/bin/mysqladmin -u root -h www.cs2i.fr -p password 'new-password'
See the manual for more instructions.
NOTE:  If you are upgrading from a MySQL <= 3.22.10 you should run
the /usr/local/mysql/bin/mysql_fix_privilege_tables. Otherwise you will not be
able to use the new GRANT command!
You can start the MySQL daemon with:
cd /usr/local/mysql ; /usr/local/mysql/bin/safe_mysqld &
You can test the MySQL daemon with the benchmarks in the 'sql-bench' directory:
cd sql-bench ; run-all-tests
Please report any problems with the /usr/local/mysql/bin/mysqlbug script!
The latest information about MySQL is available on the web at
http://www.mysql.com
Support MySQL by buying support/licenses at https://order.mysql.com
Je tape
[root@www bin]# /usr/local/mysql/bin/mysqladmin -u root -p password
Enter password:
/usr/local/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111)'
Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
[root@www bin]# ./safe_mysqld &
[1] 20331
[root@www bin]# Starting mysqld daemon with databases from /usr/local/mysql/var
011108 19:02:27  mysqld ended[root@www bin]# ps aux
USER       PID %CPU %MEM   VSZ  RSS TTY      STAT START   TIME COMMAND
root         1  0.0  0.1  1148   68 ?        S    14:44   0:04 init [3]
root         2  0.0  0.0     0    0 ?        SW   14:44   0:00 [kflushd]
root         3  0.0  0.0     0    0 ?        SW   14:44   0:02 [kupdate]
root         4  0.0  0.0     0    0 ?        SW   14:44   0:00 [kpiod]
root         5  0.0  0.0     0    0 ?        SW   14:44   0:00 [kswapd]
bin        246  0.0  0.0  1144    0 ?        SW   14:45   0:00 [portmap]
root       298  0.0  0.4  1344  224 ?        S    14:45   0:06 syslogd
root       308  0.0  0.0  1424    0 ?        SW   14:45   0:00 [klogd]
daemon     323  0.0  0.2  1172  112 ?        S    14:45   0:00 /usr/sbin/atd
root       338  0.0  0.1  1308   64 ?        S    14:45   0:00 inetd
root       381  0.0  0.1  1180   52 ?        S    14:45   0:00 gpm -t ps/2
xfs        397  0.0  0.1  2208   52 ?        S    14:45   0:00 xfs -port -1
root       414  0.0  0.0  2228    0 tty1     SW   14:45   0:00 [login]
root       415  0.0  0.0  2228    0 tty2     SW   14:45   0:00 [login]
root       416  0.0  0.0  2228    0 tty3     SW   14:45   0:00 [login]
root       417  0.0  0.0  1124    0 tty4     SW   14:45   0:00 [mingetty]
root       418  0.0  0.0  1124    0 tty5     SW   14:45   0:00 [mingetty]
root       419  0.0  0.0  1124    0 tty6     SW   14:45   0:00 [mingetty]
root       422  0.0  1.7  2260  816 tty1     S    15:05   0:00 -bash
root       474  0.0  1.7  2260  832 tty2     S    15:15   0:00 -bash
root       504  0.0  1.1  2168  536 tty3     S    15:18   0:00 -bash
root     11969  0.0  0.3  1792  180 ?        S    15:59   0:08 telnetd: 192.168.0.1 [vt100]
root     11970  0.0  0.0  2240    0 pts/2    SW   15:59   0:00 [login]
cedric   12286  0.0  0.0  2136    0 pts/2    SW   16:00   0:00 [bash]
root     12303  0.0  0.0  2084    0 pts/2    SW   16:00   0:00 [su]
root     12337  0.0  1.5  2160  716 pts/2    S    16:00   0:00 -bash
root     15993  0.0  3.0  3468 1452 ?        S    16:21   0:00 /usr/local/apache/bin/httpd
nobody   16652  0.0  4.0  3748 1888 ?        S    16:27   0:00 /usr/local/apache/bin/httpd
nobody   16653  0.0  4.0  3852 1920 ?        S    16:27   0:00 /usr/local/apache/bin/httpd
nobody   16654  0.0  4.2  4000 2008 ?        S    16:27   0:00 /usr/local/apache/bin/httpd
nobody   16655  0.0  4.1  3804 1932 ?        S    16:27   0:00 /usr/local/apache/bin/httpd
nobody   16656  0.0  2.7  3720 1292 ?        S    16:27   0:00 /usr/local/apache/bin/httpd
nobody   16905  0.0  2.7  3708 1284 ?        S    16:29   0:00 /usr/local/apache/bin/httpd
nobody   16930  0.0  2.6  3660 1236 ?        S    16:31   0:00 /usr/local/apache/bin/httpd
root     17155  0.0  2.0  2084  976 pts/2    S    16:52   0:00 su -
root     17156  0.0  2.6  2152 1256 pts/2    S    16:52   0:00 -bash
fred     17172  0.0  2.0  2084  972 pts/2    S    16:52   0:00 su fred
fred     17173  0.0  2.6  2136 1244 pts/2    S    16:52   0:00 bash
root     20278  0.0  2.1  2084  992 pts/2    S    18:40   0:00 su -
root     20279  0.0  2.8  2268 1332 pts/2    S    18:40   0:00 -bash
root     20422  0.0  1.8  2524  876 pts/2    R    19:04   0:00 ps aux
J'ai essayé de cree 1 utilisateur mysql mais ça fonctionne pas mieux.
HELP ! Ou est le prob!
Je suis 1 newbe sous mysql. Donc faut tt m'expliquer.
Merci à tous
Marsh Posté le 08-11-2001 à 18:07:45
PS je ne veux pas de RPM
Je n'ai pas d'interface graphique.
Marsh Posté le 08-11-2001 à 18:22:36
et essaie de lancer mysql PUIS un mysqladmin .....
Do androïds dream of electric sheep ?
Marsh Posté le 08-11-2001 à 18:23:45
laisse tomber , j'avais pas vu  "mysqld ended " avec ton ./safe_mysql ...
mouais , j'vois pas trop ......
Marsh Posté le 08-11-2001 à 18:30:29
[root@www bin]# ./mysql
ERROR 2002: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111)
[root@www bin]#
Pour répondre à JoWiLe -> sur phpfrance c'est la procédure d'install pour Windobe !
Help !
Marsh Posté le 08-11-2001 à 18:32:24
à l'origine il est stocké dans /tmp/, mais qd tu le recompiles, tu peux choisir ou tu veux le mettre.
est-ce que le user mysql(enfin je sais pas sous quel utilisateur il tourne) à le droit d'écrire dans /tmp/ ?
essaye de le lancer à partir des scripts fournis /etc/init.d/mysql start
Marsh Posté le 08-11-2001 à 18:46:39
J'ai compiler mysql avec root donc normalement c'est le proprio (j'ai créé l'utilisateur mysql parce que j'étais désespéré -> je l'ai aussi vu dans une doc)
L'utilisateur root, comme mysql ont tous les 2 le droits d'écrire dans le répertoire /tmp.
/etc/init.d/mysql start n'existe pas.
J'ai compilé mysql dans /usr/local/mysql
Marsh Posté le 08-11-2001 à 18:50:34
Voici 1 de mes fichiers de LOG
[root@www init.d]# cat /usr/local/mysql/var/www.cs2i.fr.err
011108 19:02:27  mysqld started
011108 19:02:27  /usr/local/mysql/libexec/mysqld: Can't create/write to file '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:02:27  /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
011108 19:02:27  /usr/local/mysql/libexec/mysqld: Error on delete of '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:18  mysqld started
011108 19:03:19  /usr/local/mysql/libexec/mysqld: Can't create/write to file '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:19  /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
011108 19:03:19  /usr/local/mysql/libexec/mysqld: Error on delete of '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:19  mysqld ended
011108 19:03:31  mysqld started
011108 19:03:32  /usr/local/mysql/libexec/mysqld: Can't create/write to file '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:32  /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
011108 19:03:32  /usr/local/mysql/libexec/mysqld: Error on delete of '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:32  mysqld ended
011108 19:03:39  mysqld started
011108 19:03:39  /usr/local/mysql/libexec/mysqld: Can't create/write to file '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:39  /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
011108 19:03:39  /usr/local/mysql/libexec/mysqld: Error on delete of '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:03:40  mysqld ended
011108 19:32:15  mysqld started
011108 19:32:16  /usr/local/mysql/libexec/mysqld: Can't create/write to file '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:32:16  /usr/local/mysql/libexec/mysqld: Can't find file: './mysql/host.frm' (errno: 13)
011108 19:32:16  /usr/local/mysql/libexec/mysqld: Error on delete of '/usr/local/mysql/var/www.cs2i.fr.pid' (Errcode: 13)
011108 19:32:16  mysqld ended
011108 19:32:45  mysqld started
/usr/local/mysql/libexec/mysqld: Too many parameters
/usr/local/mysql/libexec/mysqld  Ver 3.23.44 for pc-linux-gnu on i586
Use '--help' or '--no-defaults --help' for a list of available options
011108 19:32:46  mysqld ended
Marsh Posté le 08-11-2001 à 18:53:10
comme tu as compilé mysql dans /usr/local/mysql et que je suppose que tu n'as pas spécifié explicitement ou devais se trouver le socket de connexion, il y a de fortes chances pour qu'il soit créé en dessous de ton arborescence /usr/local/mysql/*
soit recompile le en spécifiant ou doit se trouver le socket, soit spécifie le au lancement, je pense que ça devrais fcter
Marsh Posté le 08-11-2001 à 19:01:06
Comment on fait pour le spécifier au lancement.
Voila ce que j'ai essayé :
[root@www bin]# ./mysql -S=/usr/local/mysql/mysql.sock
ERROR 2002: Can't connect to local MySQL server through socket '=/usr/local/mysql/mysql.sock' (111)
Marsh Posté le 08-11-2001 à 19:29:41
madsurfer a écrit a écrit :
[root@www binPour répondre à JoWiLe -> sur phpfrance c'est la procédure d'install pour Windobe !
Help !
et ca c koi? :heink:
http://www.phpfrance.com/tutorials/index.php?id=48
Marsh Posté le 08-11-2001 à 19:30:53
Enter password:
si je me rappelle la tu as donne au root le passwd "password" :D
Marsh Posté le 08-11-2001 à 19:53:35
Excuse j'avais pas vu
LOL !
