Probleme installation driver Nvidia
Probleme installation driver Nvidia - Installation - Linux et OS Alternatifs
Marsh Posté le 06-03-2007 à 23:50:24
Je butte sur un probleme lors de l'installation des des drivers Nvidia, je vous mets le log d'erreur.
  1. nvidia-installer log file '/var/log/nvidia-installer.log'
  2. creation time: Tue Mar  6 23:37:48 2007
  3. option status:
  4.   license pre-accepted    : false
  5.   update                  : false
  6.   force update            : false
  7.   expert                  : false
  8.   uninstall               : false
  9.   driver info             : false
  10.   precompiled interfaces  : true
  11.   no ncurses color        : false
  12.   query latest version    : false
  13.   OpenGL header files     : true
  14.   no questions            : false
  15.   silent                  : false
  16.   no recursion            : false
  17.   no backup               : false
  18.   kernel module only      : false
  19.   sanity                  : false
  20.   add this kernel         : false
  21.   no runlevel check       : false
  22.   no network              : false
  23.   no ABI note             : false
  24.   no RPMs                 : false
  25.   no kernel module        : false
  26.   force SELinux           : default
  27.   no X server check       : false
  28.   force tls               : (not specified)
  29.   X install prefix        : (not specified)
  30.   X library install path  : (not specified)
  31.   X module install path   : (not specified)
  32.   OpenGL install prefix   : (not specified)
  33.   OpenGL install libdir   : (not specified)
  34.   utility install prefix  : (not specified)
  35.   utility install libdir  : (not specified)
  36.   doc install prefix      : (not specified)
  37.   kernel name             : (not specified)
  38.   kernel include path     : (not specified)
  39.   kernel source path      : (not specified)
  40.   kernel output path      : (not specified)
  41.   kernel install path     : (not specified)
  42.   proc mount point        : /proc
  43.   ui                      : (not specified)
  44.   tmpdir                  : /tmp
  45.   ftp mirror              : ftp://download.nvidia.com
  46.   RPM file list           : (not specified)
  47. Using: nvidia-installer ncurses user interface
  48. -> License accepted.
  49. -> No precompiled kernel interface was found to match your kernel; would you li
  50.    ke the installer to attempt to download a kernel interface for your kernel f
  51.    rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
  52. -> No matching precompiled kernel interface was found on the NVIDIA ftp site;
  53.    this means that the installer will need to compile a kernel interface for
  54.    your kernel.
  55. -> Performing CC sanity check with CC="cc".
  56. -> Performing CC version check with CC="cc".
  57. ERROR: Unable to find the kernel source tree for the currently running kernel.
  58.        Please make sure you have installed the kernel source files for your
  59.        kernel and that they are properly configured; on Red Hat Linux systems,
  60.        for example, be sure you have the 'kernel-source' or 'kernel-devel' RPM
  61.        installed.  If you know the correct kernel source files are installed,
  62.        you may specify the kernel source path with the '--kernel-source-path'
  63.        command line option.
  64. ERROR: Installation has failed.  Please see the file
  65.        '/var/log/nvidia-installer.log' for details.  You may find suggestions
  66.        on fixing installation problems in the README available on the Linux
  67.        driver download page at www.nvidia.com.
toute les autres erreurs demandant les libutils, les gcc, le make... j'ai reussi à la resoudre mais la je vois pas ce qu'il veut avec cette histoire de kernel.
Si quelqu'un pouvait m'indiquer la marche a suivre.
Pour info, j'utlise Blag comme distribution, elle est basé sur Fedora core 6.
Merci d'avance.
Message édité par colltrickle le 06-03-2007 à 23:51:04
Marsh Posté le 06-03-2007 à 23:59:33
installed
install linux-headers ou linux-source (kernel-source c'était sur les 2.4 le package s'appelle maintenant linux-... sur les 2.6)
Blog photo/récits activités en montagne http://planetcaravan.net
Marsh Posté le 07-03-2007 à 08:47:49
Merci d'avance.
c'est quoi c'te blague? :ouch:
sinon tu peux utiliser la commande suivante pour installer nvidia :
#yum install nvidia-glx
prérequis : tes depots correctements configurés et les kernel-sources bien installés
