Probleme d'installation d'un linmodem sous mandrake 9.1....
Probleme d'installation d'un linmodem sous mandrake 9.1.... - Installation - Linux et OS Alternatifs
Marsh Posté le 24-08-2003 à 22:54:36
bonjour a tous, je debute en linux et je connais peu de choses au niveau de l'installation de materiel type modem :
j'ai un portable fujitsu amilo D7800, j'arrive a tout bien installer sous mandrake 9.1 sauf le modem qui est un winmodem detecté de la facon suivante sous WinXP : "Conexant-Ambit V.90(V.92) SoftK56 MDC Modem"...
j'ai lancé le prog "scanmodem" sous linux et j'obtiens le fichier texte suivant :
The most recent update of scanmodem accessed at http://linmodems.technion.ac.il/packages/scanModem.gz
 should ALWAYS be used before requesting help from discuss@linmodem.org,
 URLs to cogent advice are regularly entered and updated, and your problem may be solved therein.
 If further help is needed, send a description of your problem to:  discuss@linmodems.org
 with this ModemData.txt Attached, using the following in the email Subject Line:
    SUBJECT="scanModem, mandrake kernel 2.4.21-0.13mdk
 --------------  System information ------------------------
mandrake Mandrake Linux release 9.1 (Bamboo) for i586
 on system: Linux localhost 2.4.21-0.13mdk #1 Fri Mar 14 15:08:06 EST 2003 i686 unknown unknown GNU/Linux"
 GCC=
UPDATE=2003 August 23
 An AC'97 modem codec was not detected
Path to lspci is: /usr/bin/lspci
--------- lspci scan ----------------
00:00.0 Host bridge: Intel Corp. 82845 845 (Brookdale) Chipset Host Bridge (rev 04)
00:01.0 PCI bridge: Intel Corp. 82845 845 (Brookdale) Chipset AGP Bridge (rev 04)
00:1e.0 PCI bridge: Intel Corp. 82801BA/CA/DB PCI Bridge (rev 05)
00:1f.0 ISA bridge: Intel Corp. 82801BA ISA Bridge (LPC) (rev 05)
00:1f.1 IDE interface: Intel Corp. 82801BA IDE U100 (rev 05)
00:1f.2 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #1) (rev 05)
00:1f.3 SMBus: Intel Corp. 82801BA/BAM SMBus (rev 05)
00:1f.4 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #2) (rev 05)
00:1f.5 Multimedia audio controller: Intel Corp. 82801BA/BAM AC'97 Audio (rev 05)
00:1f.6 Modem: Intel Corp. Intel 537 [82801BA/BAM AC'97 Modem] (rev 05)
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility M6 LY
02:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB21 IEEE-1394a-2000 Controller (PHY/Link)
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
02:09.0 CardBus bridge: Texas Instruments PCI1250 PC card Cardbus Controller (rev 01)
02:09.1 CardBus bridge: Texas Instruments PCI1250 PC card Cardbus Controller (rev 01)
Reading more detail for the Device at:
PCI bus
00:1f.6 Class 0703: 8086:2446 (rev 05)
          Subsystem 1025:1027
00:1f.6 Modem: Intel Corp. Intel 537 [82801BA/BAM AC'97 Modem] (rev 05) (prog-if 00 [Generic])
 Subsystem: Acer Incorporated [ALI]: Unknown device 1027
 Flags: medium devsel, IRQ 10
 I/O ports at b800 [size=256]
 I/O ports at bc00 [size=128]
 8086:2446  PCI_ID of the PCI bus with vendor: 8086
 1025:1027  PCI_ID of Subsystem with vendor:   1025
 are key Sought Descriptions of your modem firmware.
 Have them ready when visiting URLs with service software!!
 An AC'97 link controller controls the modem Subsystem
    8086:2446
                         82801BA (ICH2)    +  p c
 Some soft modems under this controller are supported by the
 SmartLink slmdm-2.7.10 drivers,
 even though an AC'97 modem_codec may not be displayed.
 First accessing chipset provider and modem
 assembler information
 for the modem SubSystem under the AC'97 or MC97 Controller.
 === Checking 1025 through chipset providers and modem assemblers ====
 Vendor=8086 is Intel, Inc. producing HaM and 536ep host controller free (HCF) modems,
 the 537 soft modem
 and AC'97 and MC97 controllers managing a varierty of non-Intel soft modem subSystems.
 These subSystems will in have PCI_IDs assigned by the modem assembler, not Intel.
 Download available drivers from:  http://developer.intel.com/design/ [...] rivers.htm
 Also check at: http://linmodems.technion.ac.il/resources.html
 for early releases and perhaps already compiled drivers.
 The Intel 537 chipsets are sold to a variety of modem assemblers.
 Linux support from Intel is expected by the Fall of 2003.
 The soft modem  Subsystem: 1025:1027
 serving under the controller:
   PCI_ID=8086:2446, Modem: Intel Corp. Intel 537 [82801BA/BAM AC'97 Modem] (rev 05)
 may be supported by the SmartLink slmdm-2.7.10 drivers.
 For versions after 2.7.10 the drivers may load, but there will be a failure to dial correctly!!
 See the related supoort table listing in /tmp/modem/ModemData.txt.2
 Vendor 163c is SmartLink,
http://www.smlink.com/ with EXCELLENT Linux support!
 Downloads from
ftp://ftp.smlink.com/linux/unsupported/  with some backups at:
http://linmodems.technion.ac.il/packages/smartlink/
 ====== PCI_ID checking completed ======
 Update=2003 August 23
The following information blocks just query some ppp support items.
   grep ppp /etc/modules.conf
Be sure to read the section about ppp related modules and aliases
=== ifconfig test ====
DEVPPP=crw------- 1 root root 108, 0 jan 1 1970 /dev/ppp
DEVFS=active
DEVFSD=/etc/devfsd.conf
La je ne sais plus trop quoi faire : j'ai telechargé les drivers pour modem Smartlinks chips http://linmodems.technion.ac.il/resources.html mais je ne pense pas que c'est le bon driver, d'autant plus qu'un fois le .gz decompacté je ne sais pas ce qu'il faut faire ???
en clair HELP !!
Message édité par albertun le 24-08-2003 à 22:56:48
