[MDK] Probleme urpmi
Probleme urpmi [MDK] - Installation - Linux et OS Alternatifs
Marsh Posté le 23-01-2005 à 10:58:33
Depuis hier soir il m'est impossible de mettre à jour ma Mandrake 10.1 :
[root@planetneo neo_t3]# urpmi --auto-select
Pour satisfaire les dépendances, les 13 paquetages suivants vont être installés (43 Mo):
kdebase-3.2.3-134.4.101mdk.i586
kdebase-common-3.2.3-134.4.101mdk.i586
kdebase-kate-3.2.3-134.4.101mdk.i586
kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586
kdebase-kdeprintfax-3.2.3-134.4.101mdk.i586
kdebase-kdm-config-file-3.2.3-134.4.101mdk.i586
kdebase-kmenuedit-3.2.3-134.4.101mdk.i586
kdebase-konsole-3.2.3-134.4.101mdk.i586
kdebase-progs-3.2.3-134.4.101mdk.i586
libkdebase4-3.2.3-134.4.101mdk.i586
libkdebase4-kate-3.2.3-134.4.101mdk.i586
libkdebase4-kmenuedit-3.2.3-134.4.101mdk.i586
libkdebase4-konsole-3.2.3-134.4.101mdk.i586
Est-ce correct ? (O/n) o
    ftp://ftp.proxad.net/pub/Distributions_Linux/Mandrakelinux/official/updates/10.1/main_updates/./kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586.rpm
...échec de la récupération : curl failed: exited with 19 or signal 0
...échec de la récupération : curl: (19) Given file does not exist
installation de /var/cache/urpmi/rpms/kdebase-konsole-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kate-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kdm-config-file-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-kmenuedit-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-kate-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kdeprintfax-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-kmenuedit-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/libkdebase4-konsole-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-progs-3.2.3-134.4.101mdk.i586.rpm /var/cache/urpmi/rpms/kdebase-common-3.2.3-134.4.101mdk.i586.rpm
L'installation a échoué:
        kdebase = 1:3.2.3-134.3.101mdk is needed by (installed) kdebase-kcontrol-nsplugins-3.2.3-134.3.101mdk
L'installation a échoué, il manque des fichiers :
Vous devriez mettre à jour votre base de données urpmi
Je precise que j'ai essayer de changer de source mais c'est pareil.
Message édité par Neo_t3 le 25-01-2005 à 11:22:55
Neo_t3 registered Linux user number 354648. | http://www.ondaflow.com
Marsh Posté le 23-01-2005 à 11:27:51
J'ai aussi des problèmes avec les mises à jour de KDE. Apparemment il y a des dépendances manquantes : mandrake-mime-4.10 je crois...
Ubuntu c'est nul ! Tu l'installes et puis ça marche ... y a rien à bidouiller. rm -rf /
Marsh Posté le 23-01-2005 à 12:19:12
essaye avec wget (urpmi --wget)
remets à jour ta base urpmi
attends un peu, il est possible que tu sois tombé en plein milieu d'une maj du mirroir
Message édité par Mjules le 23-01-2005 à 12:19:56
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
Marsh Posté le 23-01-2005 à 12:55:10
Fait, sans changement resultat identique
Je vais attendre  :ange:
Sinon c'est la paquetage kdebase-kcontrol-nsplugins-3.2.3-134.4.101mdk.i586 qui n'est present sur aucun serveur, qui plante donc l'installation  :sol:
Marsh Posté le 23-01-2005 à 13:08:01
à mon avis, ils se sont ratés dans la maj des updates et le paquet est manaquant, ya plus qu'à attendre qu'ils le rajoutent
Marsh Posté le 23-01-2005 à 16:56:00
urpmi --clean
urpmi.update -a
urpmi --auto-select
Marsh Posté le 23-01-2005 à 20:02:13
--allow-force
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
Marsh Posté le 25-01-2005 à 11:22:41
Ce matin ça remarche ;)
urpmi.update -a
urpmi --auto-select et rulez 8)
Marsh Posté le 26-01-2005 à 12:12:40
J'ai toujours un problème avec le --allow --force. Si urpmi détecte des conflits je me dis que c'est pour mon bien et qu'il vaut mieux ne pas forcer l'installation. Mais souvent sur le forum certains conseillent de passer outre. Alors voilà ce que cela donne dans mon cas:
        package prism54-firmware-1.0.4.3-1mdk is already installed
        file /usr/share/mimelnk/image/x-rgb.desktop from install of kdelibs-common-3.3.1-11mdk conflicts with file from package mandrake-mime-0.4-9mdk
        file /usr/share/services/kded/kdetrayproxy.desktop from install of kdelibs-common-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
        file /usr/lib/kde3/kded_kdetrayproxy.la from install of libkdecore4-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
        file /usr/lib/kde3/kded_kdetrayproxy.so from install of libkdecore4-3.3.1-11mdk conflicts with file from package kdetrayproxy-0.2-6mdk
Essayer de forcer l'installation (--force) ? (o/N)
A ce stade je n'ai pas encore forcé parce que je ne me rends pas compte de l'importance de ces conflits. Vous en pensez quoi?
Marsh Posté le 26-01-2005 à 12:33:41
up car interessant
Marsh Posté le 26-01-2005 à 15:39:55
ok j'ai rien dis, apparemment tout est là
http://forum.hardware.fr/hardwaref [...] 3363-3.htm
