xorg ne se lance pas, probleme de souris? - Installation - Linux et OS Alternatifs
Marsh Posté le 29-11-2006 à 10:19:28
Si tu fait 'cat /dev/input/mice' et que tu bouges la souris, il se passe quelque chose?
Marsh Posté le 29-11-2006 à 20:54:40
Marsh Posté le 28-11-2006 à 20:07:34
bonsoir,
voila je suis passé a xorg, mais j'arrive plus a lancer un session x
voila ce que j'ai dans mes log qui a mon avis démontre que c'est ma souris qui fait tout planter
(**) Option "Protocol" "ExplorerPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ExplorerPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(EE) xf86OpenSerial: Cannot open device /dev/input/mice
No such device.
(EE) Configured Mouse: cannot open input device
(EE) PreInit failed for input device "Configured Mouse"
(II) UnloadModule: "mouse"
(WW) No core pointer registered
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
xkb_keycodes { include "xfree86+aliases(azerty)" };
xkb_types { include "complete" };
xkb_compatibility { include "complete" };
xkb_symbols { include "pc(pc105)+fr" };
xkb_geometry { include "pc(pc105)" };
No core pointer
Fatal server error:
failed to initialize core devices
de plus quand je vais un hwinfo --mouse
il ne me dectecte rien (ma souris est en ps2)
je branche donc un souris de secours en usb
la hwinfo me donne ceci:
44: USB 00.0: 10503 USB Mouse
[Created at usb.122]
UDI: /org/freedesktop/Hal/devices/usb_device_45e_40_noserial_if0
Unique ID: FKGF.KY9pIXcTJP0
Parent ID: pBe4.BlTq++yJD64
SysFS ID: /devices/pci0000:00/0000:00:10.1/usb2/2-1/2-1:1.0
SysFS BusID: 2-1:1.0
Hardware Class: mouse
Model: "Microsoft Wheel Mouse Optical"
Hotplug: USB
Vendor: usb 0x045e "Microsoft Corp."
Device: usb 0x0040 "Wheel Mouse Optical"
Revision: "1.21"
Compatible to: int 0x0200 0x0001 "Generic USB Mouse"
Speed: 1.5 Mbps
Driver Info #0:
XFree86 Protocol: explorerps/2
GPM Protocol: exps2
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #38 (Hub)
j'ai donc essayer dans mon fichier xorg.conf de mettre
Section "InputDevice"
Identifier "Configured Mouse"
Driver "mouse"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
EndSection
ou alors
Driver "mouse"
Option "Device" "/dev/psaux"
EndSection
mais rien ne marche...
merci de me venir en aide
dam's (debianer), ma galerie Flickr
