Je suis vraiment tente par cette ecran, mais la version sans DVI a des textes pourries apparement !
Donc si quelqu'un a teste, j'aurai aime des impressions sur cette ecran(super chere mais cool pr les consoles et dvd!) spec: 17.1" screen (17.1" viewable image)
Enhanced 16:9 widescreen format maximizes panoramic capabilities of video players, game consoles, digital cameras, camcorders, PCs and more
Connects directly to devices with stereo audio, TV source, composite and S-video, component and PC inputs
TV tuner-ready; HDTV compatible
0.29mm pixel pitch
1280 x 768 resolution
48-85Hz vertical frequency
28-70kHz horizontal frequency
-3° to +15° tilt range
450 nits brightness; 500:1 contrast ratio
Note: Not all computer video graphics cards will support the 1280 x 768 wide aspect resolution, and use with some models or graphics boards may require updated drivers.
Marsh Posté le 02-12-2002 à 23:50:05
spec:
0.29mm pixel pitch
Temps: 22MS
Message édité par Lynk le 03-12-2002 à 01:13:29
