rhaaa je peux plus graver !!!
rhaaa je peux plus graver !!! - Hardware
Marsh Posté le 05-04-2002 à 19:49:47
help c'est la premiere fois que mon teac me fait ca:
je peux plus graver, ca fait le troisieme cd qui plante
Windows 2000 5.0
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 03:23:24
ahead WinASPI: File 'D:\nero\Nero\Wnaspi32.dll': Ver=2.0.1.41, size=155715 bytes, created 09/03/2002 12:58:39
Nero Version: 5.5.7.2
Recorder:             <TEAC CD-R56S>            Version: 1.0P - HA 1 TA 0 - 5.5.7.2
 Adapter driver:      <aic78xx>                 HA 1
 Drive buffer  :      1302kB
 Bus Type      :      default (0) -> SCSI
CD-ROM:               <TOSHIBA  DVD-ROM SD-M1612>Version: 1004 - HA 0 TA 0 - 5.5.7.2
 Adapter driver:      <atapi>                   HA 0
 Bus Type      :      default (0) -> ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral      : TOSHIBA DVD-ROM SD-M1612         atapi Port 0 ID 0  DMA: Off
CdRomPeripheral      : TEAC    CD-R56S         1.0P   aic78xx Port 1 ID 0  DMA:  ?
CdRomPeripheral      : TEAC    CD-ROM CD-532S  1.0A   aic78xx Port 1 ID 4  DMA:  ?
DiskPeripheral       : QUANTUM ATLAS10K2-TY367LDDD6  adpu160m Port 2 ID 1  DMA:  ?
CdRomPeripheral      : NERO    IMAGEDRIVE      1.0f  Imagedrv Port 3 ID 0  DMA:  ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 511MB (523692kB)
Free physical memory: 354MB (362592kB)
Memory in use       : 30 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry    : 1
Global Bus Type: default (0)
Wizard: Off
CD-ROM (ISO)
5.4.2002
19:14:15 #1 Text 0 File Reader.cpp, Line 117
 Reader running
19:14:15 #2 Text 0 File Writer.cpp, Line 127
 Writer TEAC     CD-R56S          running
19:14:15 #3 ISO9660GEN -11 File geniso.cpp, Line 4307
 First writeable address = 0 (0x00000000)
19:14:15 #4 Text 0 File ThreadedTransferInterface.cpp, Line 679
 Setup items (original item values)
  0: TRM_DATA_MODE1 (CTransferItem)
     2 indices, index0 (150) not provided
     original CD pos #0 + 355437 (355437) = #355437/78:59.12
     relocatable, CD pos for caching/writing not required/required, no patch infos
19:14:19 #5 Text 0 File DlgWaitCD.cpp, Line 194
 Last possible write address on media:   359848 (79:59.73)
 Last address to be written:             355439 (79:01.14)
19:14:21 #6 Text 0 File DlgWaitCD.cpp, Line 1331
 Recorder:  TEAC CD-R56S;
    CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical
    ATIP Data:
      Special    Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4F 3B 4A (LO 79:59.74)
      Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
19:14:21 #7 Text 0 File ThreadedTransferInterface.cpp, Line 824
 Prepare recorder TEAC     CD-R56S          for write in cue-sheet-DAO
 DAO infos:
 MCN:
 TOCTYPE: 0x0   Close CD
 Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 728242176
19:14:21 #8 Text 0 File ThreadedTransferInterface.cpp, Line 679
 Setup items (after recorder preparation)
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 355437 blocks [TEAC     CD-R56S         ]
19:14:21 #9 Phase 24 File dlgbrnst.cpp, Line 1436
 Caching of files started
19:14:21 #10 Phase 25 File dlgbrnst.cpp, Line 1436
 Caching of files completed
19:14:21 #11 Phase 36 File dlgbrnst.cpp, Line 1436
 Burn process started at 6x (900 Ko/s)
19:14:22 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1950
 Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
19:24:13 #13 SCSI -1064 File Cdrdrv.cpp, Line 1411
 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0CF10054
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
 Sense Code: 0x21
 Sense Qual: 0x00
 CDB Data:   0x2A 0x00 0x00 0x03 0xCC 0x05 0x00 0x00 0x1F 0x00
 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
             0x00 0x00 0x00 0x01 0x21 0x00
19:24:14 #14 mmc -1064 File Writer.cpp, Line 321
 Invalid block address
19:24:14 #15 Text 0 File ThreadedTransfer.cpp, Line 219
 all writers idle, stopping conversion
19:24:17 #16 Text 0 File ThreadedTransfer.cpp, Line 213
 conversion idle, stopping reader
19:28:26 #17 Phase 38 File dlgbrnst.cpp, Line 1436
 Burn process failed at 6x (900 Ko/s)
19:28:26 #18 Text 0 File Scsicmd.cpp, Line 371
 SCSI not using temporary buffers
 20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.10a, size=64432 bytes, created 14/04/2001 07:32:00
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 04:02:46
c'est grave herr doctor ?
lafraise.com éditeur de bien jolis T-shirt
Marsh Posté le 05-04-2002 à 19:51:16
Modèle, âge, nb de CD's gravés ?
Faux & usage de faux ¤ Machins roses ¤ ASCIImage ¤ HFR Enhance v0.8.6
Marsh Posté le 05-04-2002 à 19:52:36
acheté d'occas, TEAC CD-R56S 6/24
je sais pas combien de cd il a gravé :/
moi j'ai du en graver une dizaine, aucun plantage à 6X
mais là il ne veut rien savoir  :cry:
[jfdsdjhfuetppo]--Message édité par _lapin_--[/jfdsdjhfuetppo]
Marsh Posté le 05-04-2002 à 19:54:07
j'ai le même depuis presque 3ans, il a gravé au moins 1500 CD et se porte toujours aussi bien si ca peux te rassurer
Marsh Posté le 05-04-2002 à 20:02:24
po ma faute !
(desolé ... ho hein week-end d'abord)
=> tenté un ch'tit update de firmware ? (déjà résolu le problème sur un Teac beeeeetement comme ca, me demande po pourquoi, j'en sais rien)
[jfdsdjhfuetppo]--Message édité par Rhaaa--[/jfdsdjhfuetppo]
Marsh Posté le 05-04-2002 à 20:03:07
Rhaaa a écrit a écrit :
po ma faute !
 :lol:
Marsh Posté le 05-04-2002 à 20:06:13
Et ca t'fait rire ?
Mon dieu j'ai honte de moi :ouch:
Marsh Posté le 05-04-2002 à 20:06:35
po ma faute !
merci je vais tenter (+ rien a perdre)
ps: pas pensé à toi :lol:
Marsh Posté le 05-04-2002 à 20:10:37
Sinon, si t'as rien à faire ce soir, tu peux tenter les soluces à la barbare avant de jeter dedaigneusement ce pauvre Teac à la beine :
- update firmware de ton Adaptec
- desinstall Nero
- Reinstall Nero
- Format + reinstall OS
Bon week-end ;)
Marsh Posté le 05-04-2002 à 20:19:07
je sais pas si y va etre bon... mais y risque d'etre long ->Format + reinstall OS
je prefere encore le jeter que de faire ca :D
Marsh Posté le 05-04-2002 à 23:17:30
Tu peux toujours le démonter et nettoyer la lentille avec un coton-tige imbibé d'alcool?
