recherche pour changer sblive 5.1 en audigy!! - Hardware
Marsh Posté le 03-04-2002 à 03:06:18
Si une fois que t'as changé ta carte, elle marche plus alors ta méthode fonctionne : c bien devenu une Audigy.
Marsh Posté le 03-04-2002 à 03:13:41
comme toi etre gros malin toi aller voir ceci
http://www.maxreboot.com/newspro/v [...] 6090,20289,
comme toi fort toi traduire moi ca!
Marsh Posté le 03-04-2002 à 03:18:49
Marche pas ton lien ?
Dommage ca m'interresse .J'ai une sblive 5.1
Marsh Posté le 03-04-2002 à 03:25:44
http://www.maxreboot.com/newspro/v [...] 4807,88900,
Marsh Posté le 03-04-2002 à 03:26:10
marche pas ! meeeerde
Marsh Posté le 03-04-2002 à 03:28:18
quand tu auras un lien valide ,tu pourras le mettre ds le topic stp .
Merci d'avance
Marsh Posté le 03-04-2002 à 03:42:19
Posted Thursday 7:08.10 PM
March 7, 2002 by triplethreat2k2
Turn your SB Live! into SB Audigy
DO THIS WITH CAUTION. USE AT YOUR OWN RISK.
I know this is old news. I've seen this myself a couple of months ago, but it seems that people are still very interested in this. I, personally, don't see the advantage of using the Audigy drivers over the Live! drivers that Creative provides. Be aware that your CPU usage will dramatically increase upon installing these drivers.
This is for Windows XP only!
1) Go to device manager.
2) Go to audio device/gameport.
3) Remove SBLive! WDM Basic Device.
4) Remove Gameport for SBLive!.
5) Backup wdma10k1.inf to wdma10k1.inf.old.
6) Backup wdma10k1.pnf to wdma10k1.pnf.old.
7) Install official Audigy driver, and select "no" when prompted for "uninstalling driver".
8) Restart.
9) System reports that "New audio hardware is found", select "Do not install driver automatically"! System reports "New gameport device found", select "Do not install driver automatically"!
10) Run the Audigy beta driver:
UDA_betaUDA_betaAudioEnglishdriversCTZAPXX.exe, select "Install WDM driver".
11) Restart, everything okay except the sound font manager.
12) Copy the sfman32.dll from the "common" directoy of the Audigy driver disc, boot to DOS or other version of windows (or safe mode?), then copy the sfman32.dll to "System32" directory of Windows.
13) Restart, everything okay, all functionality!
The conclusion by that guy is that Audigy is just the old core with new manufacture method (thus different chip size, etc.) with 24-bit playback DAC and 1394 interface. He also hypothesized that Creative have their stock dropping a lot earlier last year and a lot of people are criticizing that their R&D is too slow, so they just make Audigy which is(?) based on the same old core while advertising it as "with a lot of whole new technology and functionality".
Source: Warp2Search
la c mieuz!
Marsh Posté le 03-04-2002 à 03:45:02
si une ame chaitable pouvait se donner la peine de traduire!(c pas que je sois nul mais c assez delicat et j'voudrais pas faire une fausse manip
Marsh Posté le 03-04-2002 à 03:47:20
nan en fait je comprend mais il faudrait une personne pour m'epauler en ce qui concerne le changement des fichiers!
Marsh Posté le 03-04-2002 à 04:07:12
1/ aller ds le gestionnaire de peripherique
2/ aller ds peripherique audio/port jeu
3/enlever SBLive! WDM peripherique de base
4/enlever le portjeu de la sblive
5/remplacer wdma10k1.inf par wdma10k1.inf.old.
6/remplacer wdma10k1.pnf par wdma10k1.pnf.old.
7/installer les drivers officiels de la audigy et selectionner "non" quand il est demande de desinstaller les drivers
8/redemarrer
9/le systeme rapporte qu'un"nouveau materiel audio est trouve",selectionner "ne pas installer les drivers automatiquement"
le systeme rapporte "nouveau peripherique de portjeu trouve",selectionner "ne pas installer les drivers automatiquement"
10/installer les drivers beta audigy:
UDA_betaUDA_betaAudioEnglishdriversCTZAPXX.exe et selectionner "installer les drivers wdm"
11/redemarrer .tout est bon execpte le gestionnaire de fonte de son.
12/copier sfman32.dll du repertoire habituel du disque des drivers audigy.Booter sous dos ou autre versions windows (mode securite),ensuite copier sfman32.dll dans le repertoire system32 de windows
13/redemarrer. Tout est bon ,tout fonctionne .
Je te traduirais le reste ds quelques minutes .Cette manip est valable pour windows xp seulement.
[jfdsdjhfuetppo]--Message édité par chris25fr--[/jfdsdjhfuetppo]
Marsh Posté le 03-04-2002 à 04:10:50
Moi,je suis sous win2000 ,fais chier .
Marsh Posté le 03-04-2002 à 05:42:19
| deostickman a écrit a écrit : http://www.maxreboot.com/newspro/v [...] 4807,88900, |
[jfdsdjhfuetppo]--Message édité par seyed_s--[/jfdsdjhfuetppo]
Marsh Posté le 03-04-2002 à 05:43:27
y a pas une petite couille là avec le lien ?
Marsh Posté le 03-04-2002 à 10:31:14
Salut a tous.. je possede aussi une SB live 5.1... et je me demandais pourkoi veux tu la changer en audigy... ckoi audigy? et a koi ca sert..?
Marsh Posté le 03-04-2002 à 10:55:34
| Grand Miam a écrit a écrit : Salut a tous.. je possede aussi une SB live 5.1... et je me demandais pourkoi veux tu la changer en audigy... ckoi audigy? et a koi ca sert..? Merci |
haaa, enfin qqun qui ne plonge pas les yeux fermés ds la connerie humaine.
T'as raison ca sert a rien a part faire croire a certains quils touchent leur bille en micro.
exemple concret:" changer un live 5.1 en audigy cest comme changer des pneus de 50km d'usure." sert qua faire bander certains croyant avoir des perf en plus ( 3dmark et autres bench a 2 balles).
Marsh Posté le 04-04-2002 à 06:11:00
"installation did not detect the presence of a SoundBlaster Audigy card."
Marsh Posté le 01-04-2002 à 17:33:02
ou trouver la methode en francais car g deja en english!!
Gunpowder,gelatine,dynamite with a laser beam!
