Probleme graveur Traxdata 121032 - Focus or tracking error
Probleme graveur Traxdata 121032 - Focus or tracking error - Hardware
MarshPosté le 29-04-2002 à 14:34:55
il me marque une erreur Focus or tracking error sous nero 5540 ! cela fait 2 cds de mort !
voici le log complet :
nico perso 150302-401360-284042-449015
Windows NT 5.0 WinAspi: - ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.28, size=172099 bytes, created 06/09/2001 14:29:05 Nero Version: 5.5.4.0 Recorder: <TRAXDATA CDRW121032plus> Version: LSR1 - HA 0 TA 1 - 5.5.4.0 Adapter driver: <atapi> HA 0 Drive buffer : 2048kB CD-ROM: <SAMSUNG DVD-ROM SD-616> Version: BS02 - HA 1 TA 0 - 5.5.4.0 Adapter driver: <atapi> HA 1
=== Scsi-Device-Map === DiskPeripheral : Maxtor 52049H3 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TRAXDATA CDRW121032plus atapi Port 0 ID 1 DMA: Off CdRomPeripheral : SAMSUNG DVD-ROM SD-616 atapi Port 1 ID 0 DMA: Off DiskPeripheral : Conner Peripherals 1620MB - atapi Port 1 ID 1 DMA: On =======================
14:29:47 #12 Text 0 File CDCopy.cpp, Line 1023 Copy options: read subcode: OFF jitter correction: OFF copy on-the-fly: ON read ISRC/MCN: ON ignore inv. TOC type: ON ignore audio read error: ON source disc does not look like CD Extra 01. 0 - 353694 = 353694, data (2)
14:29:47 #13 Text 0 File ThreadedTransferInterface.cpp, Line 668 Setup items (original item values) 0: TRM_DATA_MODE2_FORM1_NOSUB (1 Données (mode 2)) 2 indices, index0 (150) not provided original CD pos #0 + 353694 (353694) = #353694/78:35.69 relocatable, CD pos for caching/writing not required/not required, no patch infos --------------------------------------------------------------
14:29:50 #14 Text 0 File DlgWaitCD.cpp, Line 1164 Recorder: TRAXDATA CDRW121032plus; CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical ATIP Data: Special Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:29:50 #15 Text 0 File ThreadedTransferInterface.cpp, Line 803 Prepare recorder CDRW121032plus for write in cue-sheet-DAO DAO infos: ========== MCN: TOCTYPE: 0x20 Close CD Tracks 1 to 1: TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 832241088
14:29:50 #16 Text 0 File ThreadedTransferInterface.cpp, Line 668 Setup items (after recorder preparation) 0: TRM_DATA_MODE2_FORM1_NOSUB (1 Données (mode 2)) 2 indices, index0 (150) not provided original CD pos #0 + 353694 (353694) = #353694/78:35.69 relocatable, CD pos for caching/writing not required/not required, no patch infos -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 353694 blocks [CDRW121032plus ] --------------------------------------------------------------
14:29:50 #17 Phase 24 File dlgbrnst.cpp, Line 1348 Caching of files started
14:29:50 #18 Phase 25 File dlgbrnst.cpp, Line 1348 Caching of files completed
14:29:51 #19 Phase 36 File dlgbrnst.cpp, Line 1348 Burn process started at 8x (1200 KB/s)
14:29:51 #20 Text 0 File ThreadedTransferInterface.cpp, Line 1841 Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
14:29:51 #21 Text 0 File Mmc.cpp, Line 13988 Set BUFE: BURN-Proof -> ON
14:31:42 #22 SCSI -1039 File Cdrdrv.cpp, Line 1308 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0775F0DC Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x09 Sense Qual: 0x01 CDB Data: 0x2A 0x00 0x00 0x00 0x1C 0x44 0x00 0x00 0x1B 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x09 0x01
14:31:42 #23 mmc -1039 File Writer.cpp, Line 308 Focus or tracking error
14:31:42 #24 Text 0 File ThreadedTransfer.cpp, Line 218 all writers idle, stopping conversion
14:31:43 #25 Text 0 File ThreadedTransfer.cpp, Line 212 conversion idle, stopping reader
14:31:43 #26 Phase 38 File dlgbrnst.cpp, Line 1348 Burn process failed at 8x (1200 KB/s)
14:31:43 #27 Text 0 File Scsicmd.cpp, Line 371 SCSI not using temporary buffers 20 out of 20 temporary buffers allocated
Existing drivers:
Merci de votre aide ! j'ai essayé de graver a 8x et 12x meme erreur sur 2 cds verbatim 700 mo certif 16x
Marsh Posté le 29-04-2002 à 14:34:55
nico
perso
Windows NT 5.0
WinAspi: -
AutoRun : 0
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 319MB (327152kB)
Free physical memory: 102MB (104988kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: On
Copie CD
29.4.2002
14:29:11 #1 SCSI -1065 File Cdrdrv.cpp, Line 1101
SCSI Exec, HA 1, TA 0, LUN 0
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0xBB 0x00 0xFF 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x20 0x00
14:29:11 #2 Phase 72 File dlgbrnst.cpp, Line 1348
BURN-Proof activated
14:29:12 #3 Text 0 File Reader.cpp, Line 117
Reader running
14:29:12 #4 Text 0 File Writer.cpp, Line 122
Writer CDRW121032plus running
14:29:12 #5 Phase 48 File dlgbrnst.cpp, Line 1348
Analyzing CD
14:29:12 #6 SCSI -1065 File Cdrdrv.cpp, Line 1101
Sense Code: 0x20
Sense Qual: 0x00
14:29:12 #7 SCSI -1065 File Cdrdrv.cpp, Line 1101
Sense Code: 0x20
Sense Qual: 0x00
14:29:12 #8 Text 0 File CDCopy.cpp, Line 2318
session 0 (0 - 0): last session
14:29:12 #9 CDCOPY -1 File CDCopy.cpp, Line 2451
The CD is copyrighted
14:29:17 #10 SCSI -1065 File Cdrdrv.cpp, Line 1101
Sense Code: 0x20
Sense Qual: 0x00
14:29:47 #11 Text 0 File CDCopy.cpp, Line 2687
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 353693 353693 ( 78:37.68)
ATIP Data:
DAO infos:
MCN:
Tracks 1 to 1:
Sense Code: 0x09
Sense Qual: 0x01
Existing drivers:
_ _ _
