Problème GeForce 4 4600 - Hardware
Marsh Posté le 06-03-2002 à 11:43:22
Y a un condensateur de la carte mère qui gène pournla fixation sur l'AGP..
Alors est ce que je poiurrai mettre une autre geforce que je visnd e citer en haut
Marsh Posté le 06-03-2002 à 11:45:08
| sasounian a écrit a écrit : Y a un condensateur de la carte mère qui gène pournla fixation sur l'AGP.. Alors est ce que je poiurrai mettre une autre geforce que je visnd e citer en haut up Merci |
ça pourrait être le cas, en effet au boulot j'ai monté une TI200 de Leadteck sur une Epox 8KHA+, et c'est vrai que si elle faisait 1 cm de plus et ben ça casse.
Marsh Posté le 06-03-2002 à 15:38:52
j'ai reçu ça d'epox !!
EPoX is Commenting on technical issue:
Conflict between the CE6 capacitor on EP-8KHA/+ and VisionTek GF4 Ti4600 graphic card
Taipei/Taiwan; 06-MAR-2002 - EPoX Computer Co., Ltd., a leading developer and manufacturer of high end mainboard, storage and communication solutions is giving today an official press statement, regarding technical issues being discovered by users when using an EP-8KHA, EP-8KHA+ and a VisionTek GF4 Ti4600 graphic card.
Mr. Thomas Huang, VP of Research & Development Dept. of EPoX Computer said: "Regarding the high capacitor on EPoX motherboard EP-8KHA, EP-8KHA+, it was designed to optimize the stability of a DDR motherboard. While DDR solution was first introduced in the first quarter of 2001, according to the technical information the power consumption of the DDR memory will be much higher than SDRAM architecture. EPoX's technicians decided to use switch circuit design. And the output end came important. After evaluating all the graphic cards sold in the market and ensure there was no mechanism conflicts, to keep wider tolerance in memory voltage and current, the bigger capacitors (1500μf/6.3V, LSR capacitors) was complemented to reserve big space and optimize the voltage stability. Each EP-8KHA and EP-8KHA+ even equipped with 2 of them.
However according to the real experiences of using the selling DDR modules in the market, the power consumption is much lower than it was reported. In fact one 1500μf/6.3V, LSR capacitors is enough to handle it. In EPoX internal testing, the stability and overclockability is still very high without any influences."
By case users has difficulty in installing VisionTek GF4 Ti4600 graphic card on EPoX EP-8KHA+ and EP-8KHA, the first solution will be removing the CE6 capacitor. If users are not experienced in solder iron, they can use pliers to remove this component. If users are still confused with it or have any questions, they can contact any EPoX branch office in worldwide.
En gros ils ont mis ces condensateurs pour ameliorer la stabilité en croyant que la memoire DDR consommait beaucoup d'energie !!
Or ils ne servent a rien et pour ceux qui achete une Gef4 ils disent d'enlever un condensateur !!!
Marsh Posté le 06-03-2002 à 15:43:57
Laisse le condo et vas-y a la scie sauteuse dans la gf4. OK je sors
Marsh Posté le 06-03-2002 à 15:53:15
eesaye de trouve une geforce 4 qui n'a pas le design de reference ca pouras peut etre passer
si epox font des carte a geforce 4 peux etre que les leur passe
Marsh Posté le 06-03-2002 à 17:40:54
hors de question de faire sauter un condo, ils sont oufs chez epox.
Marsh Posté le 06-03-2002 à 22:11:21
je pense que ca un ptit peu dangereux de faire sauter un condos Epox..En attendant, l'un d'entre vous m'a dit qu'il a pu mettre sa geforce 3 dessus.;c deja pas mal.;Mais moi je voudrais savoir si la 4200 et 4400 passent.
Marsh Posté le 06-03-2002 à 22:16:51
tu comptes en avoir une bientot?? (c une super carte tu sais)
Marsh Posté le 06-03-2002 à 22:29:11
je sais, la qualité des epox n'est plus a demontré, mais je suis assez content de ma MSI I845D quand même
Marsh Posté le 07-03-2002 à 22:12:37
oui bon alors pour les Epox et les Geforce 4, tjrs pas de news?
Marsh Posté le 07-03-2002 à 22:17:24
Je pensais à un truc: au PIRE tu devrais pouvoir déplacer le condo en question avec du fil isolé tout bête, non? Au PIRE, hein... Comme ça physiquement absent, électriquement présent...
Bon je resors...
Marsh Posté le 07-03-2002 à 22:54:55
oui mais je perdrai la garantie
..Et crois moi, perdre une garantie d'un produit qui coute cher..c pas terrible
Marsh Posté le 08-03-2002 à 18:22:34
Et en mettant une toute ch'tite tnt2 le temps que la garantie de la mobo soit passée?... Bon j'arrête.
Marsh Posté le 06-03-2002 à 08:40:42
J'ai lu qu'il est impossible de monter une geforce 4 4600 sur une Epox 8KHA+
à cause de certains composants de la carte mère qui generaient l'installation de la carte graphique. En est-il de même avec les Geforce 4400 et 4200? Si oui, j'espère que je puex qd meme installer une Geforce 3 ti 500 ou Ti 200....?.
