reboot spontané d'une carte mère mini-itx VIA Epia M-Series
reboot spontané d'une carte mère mini-itx VIA Epia M-Series - Mini PC - Hardware
Marsh Posté le 27-02-2009 à 09:51:04
J'ai acheté une carte-mère mini-itx VIA EPIA M-Series avec processeur à 1 GHz et 512 MB de RAM.
Voici le lspci:
[root@mini-itx] /root>lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8623 [Apollo CLE266]
00:01.0 PCI bridge: VIA Technologies, Inc. VT8633 [Apollo Pro266 AGP]
00:0d.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev 80)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74)
01:00.0 VGA compatible controller: VIA Technologies, Inc. VT8623 [Apollo CLE266] integrated CastleRock graphics (rev 03)
Et voici le lshw:
[root@mini-itx] /root>lshw
    description: Desktop Computer
    product: VT8623-8235
    vendor: VIA Technologies, Inc.
    width: 32 bits
    capabilities: smbios-2.2 dmi-2.2
    configuration: boot=normal chassis=desktop
  *-core
       description: Motherboard
       product: EPIA-M
       physical id: 0
     *-firmware
          description: BIOS
          vendor: Award Software International, Inc.
          physical id: 0
          version: 6.00 PG (03/17/2003)
          capacity: 192KiB
          capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb agp ls120boot zipboot biosbootspecification
     *-cpu
          description: CPU
          product: VIA Nehemiah
          vendor: CentaurHauls
          physical id: 4
          bus info: cpu@0
          version: VIA C3
          slot: Socket 370
          capacity: 1GHz
          width: 32 bits
          clock: 133MHz
          capabilities: fpu fpu_exception wp de tsc msr cx8 mtrr pge cmov mmx fxsr sse fxsr_opt up
        *-cache:0
             description: L1 cache
             physical id: 7
             slot: Internal Cache
             capacity: 128KiB
             capabilities: synchronous internal write-back
        *-cache:1
             physical id: 8
             capacity: 64KiB
     *-memory
          description: System Memory
          physical id: 14
          slot: System board or motherboard
        *-bank
             description: DIMM
             physical id: 0
             slot: A0
     *-pci
          description: Host bridge
          product: VT8623 [Apollo CLE266]
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 00
          width: 32 bits
          clock: 66MHz
          configuration: driver=agpgart-via latency=8 module=via_agp
        *-pci
             description: PCI bridge
             product: VT8633 [Apollo Pro266 AGP]
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: pci pm normal_decode bus_master cap_list
           *-display UNCLAIMED
                description: VGA compatible controller
                product: VT8623 [Apollo CLE266] integrated CastleRock graphics
                physical id: 0
                bus info: pci@0000:01:00.0
                version: 03
                width: 32 bits
                clock: 33MHz
                capabilities: pm agp agp-2.0 vga_controller bus_master cap_list
                configuration: latency=32 mingnt=2
        *-firewire
             description: FireWire (IEEE 1394)
             product: VT6306 Fire II IEEE 1394 OHCI Link Layer Controller
             physical id: d
             bus info: pci@0000:00:0d.0
             version: 80
             width: 32 bits
             clock: 33MHz
             capabilities: pm ohci bus_master cap_list
             configuration: driver=ohci1394 latency=32 maxlatency=32 module=ohci1394
        *-usb:0
             description: USB Controller
             product: VT82xxxxx UHCI USB 1.1 Controller
             physical id: 10
             bus info: pci@0000:00:10.0
             version: 80
             width: 32 bits
             clock: 33MHz
             capabilities: pm uhci bus_master cap_list
             configuration: driver=uhci_hcd latency=32 module=uhci_hcd
           *-usbhost
                product: UHCI Host Controller
                vendor: Linux 2.6.26-1-686 uhci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 2.06
                capabilities: usb-1.10
                configuration: driver=hub slots=2 speed=12.0MB/s
        *-usb:1
             physical id: 10.1
             bus info: pci@0000:00:10.1
             version: 80
             width: 32 bits
             clock: 33MHz
           *-usbhost
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 2.06
        *-usb:2
             physical id: 10.2
             bus info: pci@0000:00:10.2
             version: 80
             width: 32 bits
             clock: 33MHz
           *-usbhost
                physical id: 1
                bus info: usb@3
                logical name: usb3
                version: 2.06
        *-usb:3
             product: USB 2.0
             physical id: 10.3
             bus info: pci@0000:00:10.3
             version: 82
             width: 32 bits
             clock: 33MHz
             capabilities: pm ehci bus_master cap_list
             configuration: driver=ehci_hcd latency=32 module=ehci_hcd
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 2.6.26-1-686 ehci_hcd
                physical id: 1
                bus info: usb@4
                logical name: usb4
                version: 2.06
                capabilities: usb-2.00
                configuration: driver=hub slots=6 speed=480.0MB/s
        *-isa
             description: ISA bridge
             product: VT8235 ISA Bridge
             physical id: 11
             bus info: pci@0000:00:11.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: isa pm bus_master cap_list
             configuration: latency=0
        *-ide
             description: IDE interface
             product: VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
             physical id: 11.1
             bus info: pci@0000:00:11.1
             version: 06
             width: 32 bits
             clock: 33MHz
             capabilities: ide pm bus_master cap_list
             configuration: driver=VIA_IDE latency=32 module=via82cxxx
           *-ide:0
                description: IDE Channel 0
                physical id: 0
                bus info: ide@0
                logical name: ide0
                clock: 33MHz
              *-disk
                   description: ATA Disk
                   product: WDC WD800BB-55JKC0
                   vendor: Western Digital
                   physical id: 0
                   bus info: ide@0.0
                   logical name: /dev/hda
                   version: 05.01C05
                   serial: WD-WCAMD7281088
                   capacity: 74GiB (80GB)
                   capabilities: ata dma lba iordy smart security pm partitioned partitioned:dos
                   configuration: mode=udma5 signature=000458a1 smart=on
                 *-volume:0
                      description: Linux filesystem partition
                      physical id: 1
                      bus info: ide@0.0,1
                      logical name: /dev/hda1
                      capacity: 8001KiB
                      capabilities: primary
                 *-volume:1
                      description: Extended partition
                      physical id: 2
                      bus info: ide@0.0,2
                      logical name: /dev/hda2
                      capacity: 74GiB
                      capabilities: primary extended partitioned partitioned:extended
                    *-logicalvolume:0
                         description: Linux swap / Solaris partition
                         physical id: 5
                         logical name: /dev/hda5
                         capacity: 956MiB
                         capabilities: nofs
                    *-logicalvolume:1
                         physical id: 6
                         logical name: /dev/hda6
                         logical name: /var
                         capacity: 956MiB
                         configuration: mount.fstype=ext3 mount.options=rw,errors=continue,data=ordered state=mounted
                    *-logicalvolume:2
                         physical id: 7
                         logical name: /dev/hda7
                         logical name: /
                         capacity: 6675MiB
                         configuration: mount.fstype=ext3 mount.options=rw,errors=remount-ro,data=ordered state=mounted
                    *-logicalvolume:3
                         physical id: 8
                         logical name: /dev/hda8
                         logical name: /home
                         capacity: 66GiB
           *-ide:1
                description: IDE Channel 1
                physical id: 1
                bus info: ide@1
                logical name: ide1
                clock: 33MHz
        *-multimedia
             description: Multimedia audio controller
             product: VT8233/A/8235/8237 AC97 Audio Controller
             physical id: 11.5
             bus info: pci@0000:00:11.5
             version: 50
             width: 32 bits
             clock: 33MHz
             capabilities: pm cap_list
             configuration: driver=VIA 82xx Audio latency=0 module=snd_via82xx
        *-network
             description: Ethernet interface
             product: VT6102 [Rhine-II]
             physical id: 12
             bus info: pci@0000:00:12.0
             logical name: eth0
             version: 74
             serial: 00:00:00:c0:ff:ee
             capacity: 100MB/s
             width: 32 bits
             clock: 33MHz
Le problème est le suivant:
La carte-mère a tendance à rebooter spontanément, sans cause apparente.
Cela se produit aussi bien à chaud qu'à froid. Par exemple, si la machine a été éteinte 48h et que je l'allume, elle reboote parfois après seulement deux minutes d'uptime. Autrement elle reboote après deux, trois ou quatre heures. C'est un peu énervant...
J'ai déjà testé la mémoire DDR en faisant tourner memtest86+ pendant quatre heures, il n'a trouvé aucune erreur.
Comment faire pour éviter ce phénomène de "reboot spontané" ?
Merci,
Message édité par da5id le 27-02-2009 à 11:01:15
