graveur dvd pionner dvr109 - CD/DVD/BD - Hardware
Marsh Posté le 22-10-2005 à 18:37:09
Boomscud
Boomscud
1a21-7543-6787-2748-8730-0229
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Recorder: <PIONEER DVD-RW DVR-109> Version: 1.50 - HA 0 TA 2 - 6.6.0.16
Adapter driver: <nvatabus> HA 0
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PIONEER DVD-ROM DVD-500M>Version: 1.07 - HA 0 TA 3 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : ST3120026A nvatabus Port 0 ID 0 DMA: Off
DiskPeripheral : SAMSUNG SV0322A nvatabus Port 0 ID 1 DMA: Off
CdRomPeripheral : PIONEER DVD-RW DVR-109 nvatabus Port 0 ID 2 DMA: Off
CdRomPeripheral : PIONEER DVD-ROM DVD-500M nvatabus Port 0 ID 3 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-109 D: CDRom5
PIONEER DVD-ROM DVD-500M E: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1535MB (1572340kB)
Free physical memory: 817MB (837388kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.10.2005
===== Disc-Copy over image - 1st step : Copy to image ...
18:28:04 #1 Text 0 File Reader.cpp, Line 127
Reader running
18:28:04 #2 Text 0 File Writer.cpp, Line 122
Writer Image Recorder running
18:28:04 #3 Phase 48 File dlgbrnst.cpp, Line 1832
Analyzing disc
18:28:04 #4 CDCOPY -1 File CDCopy.cpp, Line 1912
The CD is copyrighted
18:28:05 #5 Text 0 File CDCopy.cpp, Line 2128
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 341406 341405 ( 75:54.05)
18:28:05 #6 Text 0 File CDCopy.cpp, Line 840
Copy options: copy on-the-fly: ON
read ISRC/MCN: OFF
use jitter correction: OFF
data options
ignore read error: ON write defekt blocks OFF
read raw data: OFF read r-w subchannel data: OFF
audio options
read indexes: OFF read r-w subchannel data: OFF
source disc does not look like CD Extra
01. 0 - 341406 = 341406, data (TRM_DATA_MODE1, block size 2048)
18:28:05 #7 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using CD-R/RW media
18:28:05 #8 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 445499 ( 99:01.74)
Last address to be written: 341405 ( 75:54.05)
18:28:05 #9 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
18:28:05 #10 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
18:28:05 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Data (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 341406 (341406) = #341406/75:52.6
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 341406 blocks [Image Recorder]
18:28:05 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 699506688, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
341406 | lead-out | 1 | 0x41 | 0x00
18:28:05 #13 Phase 120 File dlgbrnst.cpp, Line 1832
Creating the image for burning
18:28:05 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
18:30:57 #15 Text 0 File WriterStatus.cpp, Line 116
< Image Recorder > start writing Lead-Out at LBA 341406 (5359Eh), lenght 0 blocks
18:30:57 #16 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:30:57 #17 Phase 121 File dlgbrnst.cpp, Line 1832
Creating Image completed successfully
===== Disc-Copy over image - 2nd step : Burn the image ...
18:31:03 #1 Text 0 File Burncd.cpp, Line 2948
Buffer underrun protection activated
18:31:03 #2 Text 0 File Reader.cpp, Line 127
Reader running
18:31:03 #3 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-109 running
18:31:03 #4 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 699506688
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=75:52.06 ( 341406) RecDep=0x00
MTYP: Mediumtype = CD (old format) (0x1)
Image file name: <F:\xp.nrg>
18:31:03 #5 Text 0 File Burncd.cpp, Line 3233
18:31:03 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 359848 ( 79:59.73)
18:31:03 #7 Text 0 File DlgWaitCD.cpp, Line 282
18:31:03 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PIONEER DVD-RW DVR-109;
CDRW code: 00 97 34 24; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: 96 00 D7, 2: 61 22 18 (LI 97:34.24), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 66 4A 99, 2: 38 80 00, 3: 04 C4 A0
18:31:03 #9 Text 0 File DlgWaitCD.cpp, Line 448
18:31:03 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 (1 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) provided
-> TRM_ULTRARAW96_MODE1, 2448, config 4, wanted index0 0 blocks, length 341406 blocks [PIONEER DVD-RW DVR-109]
18:31:03 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PIONEER DVD-RW DVR-109] for write in raw writing
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos 0 367200 836129088, ISRC ""
DAO layout:
18:31:03 #12 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 24x (3 600 KB/s)
18:31:03 #13 SCSI -1189 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 0, TA 2, LUN 0, buffer 0x038D5800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x30 0x02
18:31:03 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2654
18:31:03 #15 Text 0 File Mmc.cpp, Line 16924
StartDAO : CD-Text - Off
18:31:04 #16 Text 0 File Mmc.cpp, Line 21708
Set BUFE: Buffer underrun protection -> ON
18:31:06 #17 SCSI -1024 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 2, LUN 0, buffer 0x03320000
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0xFF 0xFF 0xD4 0xBC 0x00 0x00 0x1A 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x0E 0x93 0xA0 0xA0 0x0E
0x26 0x09 0x31 0xFE 0x08 0x01
18:31:06 #18 CDR -1024 File Writer.cpp, Line 311
Communication failure
18:31:06 #19 Text 0 File ThreadedTransfer.cpp, Line 228
18:31:06 #20 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
18:31:06 #21 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 24x (3 600 KB/s)
Existing drivers:
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 03/06/2004 10:40:46 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Marsh Posté le 22-10-2005 à 18:42:27
Normal les dma ne sont pas activé
_Suis les directives de ce site pour l'activer (DMA_ mode de transfert) ,
http://www.gravure-news.com/html/tuto/03/page01.php
_regardes si tu les as bien configuré " maitre _ esclave " avec les cavaliers (jumpers)
_ si cela ne marche toujours pas, regardes dans le bios de la carte mere si des options du genre " DMA /atapi /ide " sont activés
Marsh Posté le 22-10-2005 à 18:47:19
je connais les dma , ils sont pourtant active sur ma machine.
j'ai installe les drivers nforce 2 et le graveur dvd est en ultra dma 4 ultra 66
dois je le regler autrement ?
Marsh Posté le 22-10-2005 à 18:55:08
D'apres certains pros les drivers Nforce2 (nvidia) mettent la zizanie au niveau du controleur IDE quand il faut faire une gravure, cela dit le log d'erreur est tres explicite il ne sont pas activés , regardes dans le bios sinon !
Marsh Posté le 22-10-2005 à 19:00:02
la j'ai force dans windows le mode UDMA 2 et pourtant d'apres le log les dma ne sont encore pas active.
je vais voir dans le bios ou tout est en automatique pour l'instant
Marsh Posté le 22-10-2005 à 19:05:27
dans le bios le graveur est bien reconnu.je ne peux pas activer directement tel mode udma, par contre j'avais deja active le mode udma automatique sur les ports ide.je n'ai rien a configurer en plus.
Marsh Posté le 22-10-2005 à 19:51:06
j'ai remis le driver d'origine a windows et je peux certifier que d'apres le gestionnaire de peripherique le dma est active sur le graveur dvd .
pourtant voila que nero plante encore.des que je mets un cd dans le graveur, la machine devient tres tres lente et nero bloque avant meme de pouvoir afficher un quelconque message
Que faire, la carte mere est elle HS ?
Marsh Posté le 22-10-2005 à 19:57:18
le graveur est incapable en fait de lire quoi que ce soit .
Il me bloque l'ordi des lors qu'un cd est insere .
pourtant je peux tout a fait installer windows a partir de ce lecteur, il n'y a qu'un fois windows installé que le lecteur devient inutilisable
Marsh Posté le 22-10-2005 à 20:34:59
l'as tu bien confuré " maitre _ esclave " avec les cavaliers (jumpers)
des fois on passe a coté de choses betes
Marsh Posté le 22-10-2005 à 23:29:07
j'ai bidouillé avec dvrflash et le firmware 1.50 et le graveur a remarche jusqu'a ce qu'avec dvrupdate je mette la 1.58 et depuis ca ne marche plus.
j'ai bien essaye de remettre la 1.50 mais rien a faire.
Marsh Posté le 23-10-2005 à 00:39:49
dur, dur , pourtant ça devrait le faire vu cette affirmation:
Use DVRFlash to flash your drive, it support all DVR Pioneer's drives (including A09/109).
With this one, you can flash without any limitation on downgrade, imposed by Pioneer on upgdvd.exe
Works under DOS, Windows (any version), and Linux.
http://flashman.rpc1.org/Firmware/PIONEER/
Marsh Posté le 24-10-2005 à 00:13:05
De plus en plus complexe mon probleme
Merci isfcer pour tes reponses
j'ai trouve qu'en mettant a jour avec le dernier firmware 1.58 et en laissant les drivers windows cela fonctionne mais sous certaines conditions
Je ne dois pas installer les drivers nforce
je ne dois pas reinstaller windows (sinon reflashage a faire) HALLUCINANT
je vois que bien que le mode de transfert soit regle sur dma si possible, le graveur se configure tout seul en mode PIO, le mode udma ne marche pas malgre que j'ai specifie "DMA si possible". pourtant au demarra
Marsh Posté le 24-10-2005 à 00:14:49
Le graveur est en master et le lecteur dvd en slave (j'ai reverifié)
je vois que bien que le mode de transfert soit regle sur dma si possible, le graveur se configure tout seul en mode PIO, le mode udma ne marche pas malgre que j'ai specifie "DMA si possible". pourtant au demarrage de l'ordi j'ai bien le graveur reconnu en ata 66
Si quelqu'un a une idée je songe a une incompatibilite entre le graveur et la carte mere ou tout du moins je ne vois que cela.
Marsh Posté le 24-10-2005 à 00:50:56
j'ai insiste sur le driver nforce et il fait marcher mon graveur a condition de forcer le mode pio du graveur
Marsh Posté le 24-10-2005 à 01:03:08
ça commence a faire fuire le cerveau ton histoire !
Marsh Posté le 24-10-2005 à 14:04:37
5.10 WHQL je precise que meme sans les problemes sont les meme
Marsh Posté le 25-10-2005 à 04:11:26
j'ai teste le graveur sur un autre ordi et il marche nicquel , j'en conclu un probleme de compatibilité entre le graveur et la carte mere et ierai acheter un autre graveur sous peu .
merci pour vos conseils
Marsh Posté le 25-10-2005 à 10:13:42
bonjour,
j'ai le meme probleme avec un graveur dvd pionner dvr109 firmware 1.58.
il lit bien les dvd mais impossible de graver ni cd ni dvd --> communication failure
je suis en windows xp sp2 carte mere gigabyte ga-8idx3.
je viens de passer en mode pio comme vous l'indiquez et la miracle cela marche !!
Evidemment cela charge beaucoup la cpu mais c'est la premiere fois que j'arrive à graver. champagne !!
j'attends avec impatience l'évolution de ce thread.
Marsh Posté le 25-10-2005 à 11:24:07
j'ai la log d'un test fait en DMA
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 17:33:44
Nero version: 6.3.1.25 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-109> Version: 1.58 - HA 1 TA 0 - 6.3.1.25
Adapter driver: <atapi> HA 1
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-109 >Version: 1.58 - HA 1 TA 0 - 6.3.1.25
DiskPeripheral : ST340810A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-109 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : IDE-CD R/RW 16x10A atapi Port 1 ID 1 DMA: On
PIONEER DVD-RW DVR-109 D: CDRom0
IDE-CD R/RW 16x10A E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 54MB (55476kB)
Memory in use : 78 %
Use Static Write Speed Table: 0
Use Inquiry : 1
24.10.2005
ISO compilation
20:49:55 #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
20:49:55 #2 Text 0 File Reader.cpp, Line 126
Reader running
20:49:55 #3 Text 0 File Writer.cpp, Line 124
20:49:55 #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
20:49:56 #5 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-at-once, using DVD media
20:50:00 #6 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1954303 (434:17.28, 3816MB)
20:50:00 #7 Text 0 File DlgWaitCD.cpp, Line 259
20:50:00 #8 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: PIONEER DVD-RW DVR-109, Media type: DVD+RW
Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 1
20:50:00 #9 Text 0 File DlgWaitCD.cpp, Line 420
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW; DVD-R/RW; DVD+R9 Double Layer.)
This disc is not empty.
Accessing disc...
20:50:00 #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 1954304 (1954304) = #1954304/434:17.29
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1954304 blocks [PIONEER DVD-RW DVR-109 ]
20:50:00 #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [PIONEER DVD-RW DVR-109 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 2 to 2:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4002414592, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 2 | 0 | 0x00 | 0x41
0 | 2 | 1 | 0x00 | 0x41
1954304 | lead-out | 1 | 0x00 | 0x41
20:50:01 #12 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
20:50:01 #13 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
20:50:01 #14 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
20:50:01 #15 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 4x (5 540 KB/s)
20:50:01 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:50:01 #17 Text 0 File Cdrdrv.cpp, Line 8230
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 218DDF h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Media type ID: W11
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 52 49 43 4F 48 - 4A 50 4E 57 31 31 01 39 ...RICOHJPNW11.9
23 00 8A 86 68 02 26 00 - 8A 86 70 02 28 00 8A 86 #...h.&...p.(...
6A 02 28 22 12 10 E0 00 - F0 00 00 00 00 00 00 00 j.("............
20:50:01 #18 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 12:20,380 (740380ms) -> OK
20:50:01 #19 Text 0 File DVDPlusRW.cpp, Line 628
Start write address at LBA 0
DVD high compatibility mode: Yes
20:50:03 #20 SCSI -1024 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07EC0000
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x08 0x03
20:50:03 #21 CDR -1024 File Writer.cpp, Line 304
20:50:03 #22 Text 0 File ThreadedTransfer.cpp, Line 229
20:50:03 #23 Text 0 File ThreadedTransfer.cpp, Line 223
20:50:03 #24 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
20:50:03 #25 Text 0 File dlgbrnst.cpp, Line 1713
20:50:03 #26 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/03/2005 00:28:13 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 04/08/2004 07:59:42 (Adapter driver for rec)
Registry Keys:
Marsh Posté le 25-10-2005 à 20:25:40
Juste une suggestion mets ta version de nero express la tienne 63125 la derniere en date 66016
Marsh Posté le 26-10-2005 à 08:53:55
j'ai installé la version de nero 66016. cela ne change rien.
j'ai aussi reinstallé windows xp ou 2003. pas d'amélioration !
Marsh Posté le 26-10-2005 à 18:28:51
Si tes drivers du controleur IDE ( gestionnaire de peripherique ) sont du Via ou du Nforce2 (nvidia) , il serait souhaitable que tu les désinstalles afin que tu laisses ceux de microsoft gérer ton controleur !
Marsh Posté le 26-10-2005 à 23:05:29
Utilise une nappe 80 fils >>> Pioneer travaille en UDMA-66 pour voir si le problème disparait
Marsh Posté le 31-10-2005 à 18:04:58
non je ne crois pas que les drivers du controleur IDE soient du Via ou du Nforce2. la log de nero voir ci-dessus n'indique pas cela.
des que j'ai le temps j'ouvre l'ordinateur pour verifier la nappe ide ainsi que les cavaliers.
Marsh Posté le 03-12-2005 à 09:43:27
ca marche !!
j'ai ouvert le micro et j'ai remplacé la nappe 40 par une 80 fils
j'ai positionné les cavaliers en cable select
Le graveur DVD pioneer 109 est placé sur le connecteur slave (le plus proche de la carte controleur)
Marsh Posté le 04-12-2005 à 19:24:12
Bonjour tout le monde ! J'ai un problème presque identique avec ce graveur (dvr-109bk parce que la façade est noire
). En fait dès que je l'ai reçu le problème s'est posé. Je possède un dell dimension 5000. J'installe le graveur, je lance windows (xp SP2 home)...Je met un cd dedans et là, le pc se fige ! obligation de redem le pc...De plus, la gravure met 30mn au moins en 6x. Le tampon n'arrête pas de monter et de descendre. Pourtant, le bios le reconnait bien, les jumpers sont nickels (il est en maitre, un graveur de cd est en esclave...). Windows le reconnais bien aussi. Je ne sais plus quoi faire ^^ après avoir upgradé toutes les versions du firmware, en ayant changé l'ordre master/slave, en débranchant et déconnectant l'autre graveur...
. Please help ! sinon je sens que ce graveur va finir contre le mur...Parce qu'a chaque fois que j'insère un cd, dvd, etc...Je gagne le droit de redémarrer...Merci d'avance !!!
Marsh Posté le 04-12-2005 à 19:28:33
Vérifie que DMA est activé
Marsh Posté le 05-12-2005 à 21:12:11
j'ai vérifié le mode dma...effectivement il n'était pas actif et était en pio. Je fais comme le tuto, je désinstalle le truc ide, je relance, le truc se réinstalle, tout nickel et configuré en dma. Je met un cd dans le lecteur, ça marche ! mais j'en remet un, puis un, puis plantage
. Je redem, je vais voir dans nero toolkit, et regarde les différents paramètres : les aspi de mon lecteur sont en rouge et nero dit un truc genre les aspi sont pas bon. Je dl les aspi sur le site d'adaptec pour xp, j'installe, je redem. Les paramètres aspi apparaissent en vert
. J'insère un cd, puis un dvd, puis un cd, puis plantage
Je ne comprend rien à rien ^^ pourtant je ne suis pas un imbécile !!! Des suggestions ? Autre remarque, le lecteur est tout seul en master sur une nappe ide parallèle. J'ai deux disques durs en SATA. Merci pour votre aide !
Marsh Posté le 02-02-2006 à 18:17:40
j'ai racheté un benq et il marche a merveille sur mon ordi et le pionner marche a merveille chez mon pot .
Affaire classé ![]()
Marsh Posté le 22-10-2005 à 18:36:24
Voila, j'ai un graveur dvd pionner dvr109 qui marchait tres bien sur un ordi et depuis que je l'ai instale sur un autre ordi , et bien il ne fontionne plus et refuse de graver quoi que ce soit .
J'ai une a7n8x deluxe avec win xp 1.5 go ram
j'ai installe windows 2000, au debut le graveur veut bien fonctionner mais quelques jours apres ca a ete pareil ."communication failure"
Je ne sais absolument pas quoi faire j'ai garde le log de nero mais sans grande conviction.
J'ai essaye les drivers aspi et essaye de mettre que le graveur sur la nappe.:idem
si quelq'un a une idéee .
