HELP probleme avec graveur crx175e de sony - Hardware
Marsh Posté le 10-05-2002 à 01:36:15
pLEASE HELP ME.
Je sent que je vais l'ecraser avec une masse.
Enfin il faut que je me retienne
Marsh Posté le 10-05-2002 à 09:16:27
C'est pas le seul, j'ai deux graveurs HP qui ne le supportent pas non plus. Ils sont tous les deux à base de mécanique sony.
d'après HP, c'est pour éviter de bousiller le matos par une manoeuvre 'hasardeuse'.
Marsh Posté le 10-05-2002 à 19:50:43
Bref nous somme condanne.
Pour ceux que ca interresse:
firmware : http://www.firmware.fr.st/
Et pour upgrader le sony:
FIRMWARE SOLUTION FOR CRX175E!!
I have reposted this into a new topic for your convenience
If you have been having problems with the firmware update by getting the message about not seeing any updatable drives, here's a fix for it! You're going to need a hex editor for this (I used XVI), and the current version of your firmware (for most people it is 1.0j) so if you're kinda light on the computer knowledge, get a friend to help you out with this. If you open the update executable in an editor, you should find the strings:
"SONY CD-RW CRX175E 1.1a" and "SONY CD-RW CRX175E 1.1b 786462"
near the end of the file. The "SONY CD-RW CRX175E 1.1a" is the drive version that the flasher is looking to update, the "SONY CD-RW CRX175E 1.1b" is the target bios, followed by which I believe is the size of the .bin flash file. Now, change the "1.1a" which is the version that the update is looking for, to YOUR CURRENT VERSION. For instance, if your version was "1.0j" then you would replace "1.1a" with "1.0j". Now, once you've changed that, save the file, and execute it. Your drive should now be selectable for update!! For my CRX175E, my version was "1.0g" not "1.0j" like most people's. So if it doesn't show your drive as selectable, try experimenting around if you are not sure on your current version number. It could be differnent. Once the program recognized my drive, I flashed it, and everything worked perfectly for me. Remember, you are messing with the flash rom of your drive, so if you end up frying your drive with some poorly hex'd code, it's not my fault! Just be CAREFUL! Good luck!
Je sais c'est long et en anglais mais je suis presse
Sinon le fait de passer de 1.0g a 1.1b ne semble pas changer grd chose
Bref je relence mon appelle:
HELP
Marsh Posté le 11-05-2002 à 01:02:13
Tu es condamné, j'ai aussi un liteon 24102b qui grave les 90 minutes jusqu'à 93m 45s.
Pour Sony, comme HP, c'est la politique de la maison. Je pense pas que tu puisses les faires changer d'idée.
Marsh Posté le 11-05-2002 à 01:16:49
Nianiania
Tu me vexe toi.
De toute facon d'ici un mois je vais avoir besoin d'un 2eme graveur
Quelqu'un connait'il un bon graveur vers les 100??
Conclusion : les graveur de sony sont pire que leur consoles
Marsh Posté le 11-05-2002 à 01:54:48
Pas d'accord avec la fin de ton post. Ce sont de trés bon graveurs, comme les HP que j'utilise au boulot qui remplissent parfaitement l'usage auquel ils sont destinés, depuis deux ans pour le plus ancien.
Ils servent quotidiennement pour faire de la sauvegarde, et occasionnelement, un peu de copie, à titre perso.
Marsh Posté le 11-05-2002 à 02:10:00
Si c'etaient vraiment de tres bon graveurs ils ne les brideraient pas comme ca. De plus les capacitees du crx175e sont tres moyennes comparee a d'autre 24x comme le plextor (bouhh que de regres)
Marsh Posté le 11-05-2002 à 21:17:23
| DUDUL666 a écrit a écrit : Si c'etaient vraiment de tres bon graveurs ils ne les brideraient pas comme ca. De plus les capacitees du crx175e sont tres moyennes comparee a d'autre 24x comme le plextor (bouhh que de regres) |
Oui, mais increvables.
C'est un peu comme les postes en réseau sous NT. Au moins tu laisse de possiblités à l'utilisateur, au moins il peut faire de bêtises...
Marsh Posté le 09-05-2002 à 19:51:03
Bon le probleme ne vient pas de chez moi mais de sony
qui se fout de la gueule du monde.
En clair un de leur dernier graveur crx175e 24/10/40 ne supporte pas l'overburning (ca me parrais telement impensable que je n'est pas verifier).
Y AS T'IL QQUE CHOSE A FAIRE CONTRE CA?????
De plus j'arrive pas a trouver les nouveaux firmwares pour ce graveur (pourtant ils existent)
Bref F..K SONY
