Cartes-mères ASUS AM3+ ATX & µATX (BDG/MDG) [TOPIC UNIQUE] - Carte mère - Hardware
Marsh Posté le 02-07-2013 à 13:15:51
UPDATABLE POST MotherBoard Firmware
The MotherBoard's Firmware listing limit, is 4
BIOS M5A88-V EVO :
#> Firmware v1.801, Size 1022,7kb ; Release date 19/12/13
1. Improve system stability.
#> Firmware v1.701, Size 1022,3kb ; Release date 17/12/12
2. Improve memory compatibility.
#> Firmware v1.603, Size 1021,9kb ; Release date 14/11/12
1. Fix issue size incorrect with 3TB HDD RAID, then upgrade with latest SB850 RAID driver ; (Since v0.707)
1. Improve memory compatibility ; (4 times updated)
2. Improve system stability ; (7 times updated)
3. Support new CPUs, Click Here.
#> Firmware v0.402, Size 1010,8kb ; Release date 04/05/11
1. First released Bios.
_______________________________________________
BIOS M5A88-M EVO :
#> Firmware v1.803, Size 1022,9kb ; Release date 19/12/13
#> Firmware v1.701, Size 1023,2kb ; Release date 13/12/12
1. Improve system stability ;
#> Firmware v1.501, Size 1023,3kb ; Release date 19/11/12
1. Fix issue size incorrect with 3TB HDD RAID, then upgrade with latest SB850 RAID driver ; (Since v0.505)
2. Improve memory compatibility ; (5 times updated)
3. Improve system stability ; (5 times updated)
4. Support new CPUs, Click Here.
#> Firmware v0.209, Size 1014,2kb ; Release date 13/05/11
BIOS M5A88-M :
#> Firmware v1.702, Size 1024,4kb ; Release date 19/12/13
#> Firmware v1.601, Size 1024,5kb ; Release date 12/12/12
#> Firmware v1.501, Size 1024,4kb ; Release date 14/11/12
1. Improve onboard LAN performance ; (Since v1.001)
2. Fix system hang post '0000' when both, Sata HDD / IDE HDD and Onboard VGA are connected ; (Since v0.902)
3. Fix issue size incorrect with 3TB HDD RAID, then upgrade with latest SB850 RAID driver ; (Since v0.505)
4. Improve system stability ; (6 times updated)
5. Improve memory compatibility ; (3 times updated)
6. Support new CPUs, Click Here.
#> Firmware v0.308, Size 1010,5kb ; Release date 13/05/11
BIOS M5A87 :
#> Firmware v1.506, Size 890,7kb ; Release date 19/12/13
#> Firmware v1.402, Size 890,8kb ; Release date 12/12/12
#> Firmware v1.401, Size 832,3kb ; Release date 12/09/12
1. Improve memory compatibility ; (3 times updated)
2. Improve system stability ; (5 times updated)
3. Support new CPUs, Click Here. (3 time updated)
#> Firmware v0.331, Size 729,0kb ; Release date 07/04/11
BIOS M5A78L/USB3 :
#> Firmware v1.701, Size 834,8kb ; Release date 19/12/13
#> Firmware v1.503, Size 834,3kb ; Release date 03/12/12
1. Improve onboard LAN performance ; (since v1.003)
2. Improve memory compatibility ; (since v1.002)
3. Improve system stability ; (4 times updated)
4. Support new CPUs, Click Here. (2 time updated)
#> Firmware v0.319, Size 822,3kb ; Release date 19/05/11
BIOS M5A78L :
#> Firmware v1.701, Size 828,6kb ; Release date 19/12/13
#> Firmware v1.505, Size 827,5kb ; Release date 04/12/12
#> Firmware v1.401, Size 826,7kb ; Release date 12/09/12
1. Improve memory compatibility (since v0.902) ;
2. Improve system stability ; (5 time updated)
3. Support new CPUs, Click Here. (4 time updated)
#> Firmware v0.202, Size 686,5kb ; Release date 07/04/11
BIOS M5A78L LE :
#> Firmware v2.001, Size 858,9kb ; Release date 29/08/14
#> Firmware v1.601, Size 858,1kb ; Release date 19/12/13
#> Firmware v1.601, Size 857,2kb ; Release date 22/01/13
1. Add LAN 8111F support ; (since now)
3. Improve memory compatibility ; (2 times updated)
4. Support new CPUs, Click Here. (4 time updated)
BIOS M5A78L-M LE :
#> Firmware v1.601, Size 840,5kb ; Release date 13/12/13
1. Support new CPUs, Click Here.
#> Firmware v1.402, Size 840,2kb ; Release date 04/12/12
#> Firmware v1.301, Size 840,5kb ; Release date 17/09/12
1. Improve onboard LAN performance ; (since v0.902)
2. Improve memory compatibility ; (since v0.901)
3. AMD CPU Firmware Udapte ; (since v0.502)
5. Support new CPUs, Click Here. (2 time updated)
#> Firmware v0.209, Size 828,9kb ; Release date 24/06/11
BIOS M5A78L-M LX V2 :
#> Firmware v1.401, Size 840,5kb ; Release date 28/11/13
#> Firmware v1.302, Size 840,2kb ; Release date 03/12/12
#> Firmware v1.201, Size 838,3kb ; Release date 17/09/12
1. Improve onboard LAN performance ; (since v0.802)
2. Improve memory compatibility ; (since v0.801)
3. Improve system stability ; (6 times updated)
#> Firmware v0.303, Size 837,2kb ; Release date 23/09/11
BIOS M5A78L-M LX+ (PLUS) :
#> Firmware v1.502, Size 840,8kb ; Release date 28/11/13
#> Firmware v1.303, Size 840,1kb ; Release date 03/04/13
1. Enhance compatibility with some USB devices.
#> Firmware v1.302, Size 840kb ; Release date 03/12/12
1. Improve memory compatibility (since v0.801) ;
3. Support new CPUs. Click Here. (2 time updated)
#> Firmware v0.306, Size 837,2kb ; Release date 23/09/11
BIOS M5A78L-M LX :
#> Firmware v1.603, Size 840,3kb ; Release date 19/12/13
#> Firmware v1.502, Size 840,1kb ; Release date 03/12/12
#> Firmware v1.401, Size 837,6kb ; Release date 17/09/12
1. Improve memory compatibility ; (since v0.901)
2. Improve system stability ; (6 times updated)
#> Firmware v0.205, Size 694,8kb ; Release date 07/04/11
BIOS M5A78L-M LX3 :
#> Firmware v1.201, Size 832,5kb ; Release date 26/11/13
#> Firmware v1.101, Size 840,1kb ; Release date 25/01/13
#> Firmware v0.803, Size 837,6kb ; Release date 17/09/12
1. Improve memory compatibility ; (2 times updated)
Marsh Posté le 02-07-2013 à 13:16:25
Galerie Photos des possesseurs !
Marsh Posté le 02-07-2013 à 16:53:55
C'est quoi cette tentative de t'approprier le Topic des cartes AM3+
Tu veux le Topic ?
Marsh Posté le 03-07-2013 à 01:04:38
Bierman en mode jaloux. ![]()
Pourquoi un TU AM3+ si tardivement? ![]()
Edit: en plus Bierman a déjà un topic là-dessus... ![]()
Marsh Posté le 03-07-2013 à 09:16:23
c'est asus, bierman à un topal qui concerne tout les mobales compatibles FX via BIOS et/ou socket, ça en laisse un bon paquet ! Et c'est une demande général j'ai dis à plusieurs reprises que je le ferais, et j'ai trouvé l"envie..
Marsh Posté le 03-07-2013 à 15:23:16
Tu fais comme tu veux, je dois personnellement être devenu allergique à ce mot : asus ![]()
Marsh Posté le 28-10-2014 à 18:12:57
Update n°1:
-First Part of the Firt Post Released ;
-Mode D&CO ON
| Citation : ce POST est directement dépendant de vos appréciations, suggestions et questions. Alors n'hésitez plus à formuler demandes & recommandations, vos interventions pourraient s'avérer bénéfique ! |
Marsh Posté le 28-10-2014 à 21:25:23
Tu y crois
| Spoiler : Au rythme d'1 post toutes les 3 semaines |
Marsh Posté le 12-11-2014 à 13:54:12
moi non, mais d'autres .. disons que oui.
Et puis mieux vaut, un tiens que deux tu l'auras !
Marsh Posté le 12-11-2014 à 14:05:12
Attention à l'orgie : 5 fruits et légumes par jour mais pas plus
< ceci est un chef
Marsh Posté le 02-07-2013 à 13:15:33
Bienvenue à tous sur ce TOPIC UNIQUE de soutiens, pour les cartes-mères ASUS AM3+ (BDG & MDG)
Ce sujet concerne toutes les cartes-mères ASUStek sous socket AM3+. Cela inclus celles qui ont été mis a jours avec un socket AM3b, celles doté du chipset 9xx et renommées , et celles nouvellement ajoutées.
Il n'y aura donc pas de distinction particulière mis en place de prime abord.
====================--------------------| Les Chipsets |--------------------====================
====================--------------------| Les Cartes-mères |--------------------====================
=====-----| Cartes-mères ATX |-----=====
M5A88-V EVO :
-> 140W
-> 4x4Go 2000MHz
-> 5xsATA-III R0/1/5/10/JBOD
-> 2xpATA-133
-> 2xIEEE-1394a (1/1)
-> 12xUSB2 (4/8)
-> 2xUSB3 (2/0)
-> Port COM
-> Realtek® ALC892 7.1 / S/PDIF / Absolute 192k / BR Audio Protect / Asus Noise Filter
-> HD4250 1Gb +SdPt 128Mb-1333 DX10.1 2560x1600 60Hz
-> 1xPCIe 2.0 X16 / 1xPCIe 2.0 X16 (X4-black) / 1xPCIe X1 / 3xPCI
-> ASUS EPU
-> ASUS SM BIOS v2.6
-> Capacitor+
-> ATX
=====-----| Cartes-mères Micro-ATX |-----=====
M5A88-M EVO :
-> 140W
-> 4x4Go 2000MHz
-> 12xUSB2 (4/8)
-> 2xUSB3 (2/0)
-> Port COM / PARALLEL
-> 1xPCIe 2.0 X16 / 2xPCIe X1 / 1xPCI
-> ASUS TPU Button / 4+1 Phases
-> ASUS SM BIOS v2.5
-> µATX
M5A88-M :
-> 140W
-> 4x4Go 2000MHz
-> 6xsATA-III R0/1/5/10
-> 12xUSB2 (4/8)
-> 2xUSB3 (2/0)
-> HD4250 1Gb DX10.1 2560x1600 60Hz
-> ASUS EPU
-> Capacitor+
-> µATX
M5A87 :
-> 140W
-> 4x4Go 2200MHz
-> 6xsATA-II R0/1/10/JBOD
-> 2xpATA-133
-> 8xUSB2 (2/6)
-> 2xUSB3 (2/0)
-> Parallel / COM
-> Realtek® ALC887 7.1 + Header S/PDIF
-> 1xPCIe 2.0 X16 / 2xPCIe X1 / 3xPCI
-> ASUS EPU-4
-> ASUS CrashFree BIOS 3 / EZ Flash 2 / MyLogo 2
-> Capacitor+
-> ATX
M5A78L/USB3 :
-> 140W
-> 4x8Go 2000MHz
-> 2xpATA-133
-> 8xUSB2 (2/6)
-> 2xUSB3 (2/0)
-> Parallel / COM
-> 1xPCIe 2.0 X16 / 2xPCIe 2.0 X1 / 3xPCI
-> ASUS EPU-4
-> Capacitor+
-> ATX
M5A78L :
-> 125W
-> 4x8Go 2000MHz
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> Parallel / COM
-> ASUS C.P.R.
-> ASUS EPU-4
-> Capacitor+
-> ATX
M5A78L LE :
-> 125W
-> 4x8Go 2000MHz
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> Parallel / COM
-> ASUS C.P.R.
-> ASUS EPU-4
-> ATX
M5A78L-M/USB3 :
-> 140W
-> 4x8Go 2000MHz
-> 6xsATA-III R0/1/10/JBOD
-> CODEC VIA VT1708S 7.1 + Header S/PDIF
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> 2xUSB3 (2/0)
-> Parallel / COM
-> HD3000 1Gb DX10.1 2560x1600 60Hz
-> D-Sub/HDMI/DVI
-> 1xPCIe 2.0 X16 / 1xPCIe 2.0 X1 / 2xPCI
-> ASUS C.P.R.
-> ASUS EPU / Turbo Key / Ai Charger / Q-Fan
-> µATX
M5A78L-M LE :
-> 95W
-> 2x8Go 1866MHz
-> 2xpATA-133
-> 12xUSB2 (4/8)
-> D-Sub/DVI
-> ASUS C.P.R.
-> ASUS EPU
-> µATX
M5A78L-M LX V2 :
-> 125W
-> 2x8Go 1866MHz
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> Parallel / COM
-> HD3000 1Gb DX10.1 2560x1440 75Hz
-> D-Sub
-> 1xPCIe 2.0 X16 / 2xPCIe 2.0 X1 / 1xPCI
-> ASUS C.P.R.
-> ASUS EPU-4 / Turbo Key / Ai Charger / Q-Fan
-> ASUS EZ Flash 2 / MyLogo 2
-> µATX
-> 125W
-> 2x8Go 1866MHz
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> Parallel / COM
-> D-Sub
-> ASUS C.P.R.
-> Capacitor+
-> µATX
M5A78L-M LX :
-> 95W
-> 2x8Go 1866MHz
-> 2xpATA-133
-> 10xUSB2 (4/6)
-> Parallel / COM
-> HD3000 1Gb DX10.1 2048x1536 75Hz
-> D-Sub
-> ASUS C.P.R.
-> µATX
M5A78L-M LX3 :
-> 95W
-> 2x8Go 1866MHz
-> 4xsATA-II R0/1/10/JBOD
-> 2xpATA-133
-> 8xUSB2 (4/4)
-> COM
-> D-Sub
-> 1xPCIe 2.0 X16 / 1xPCIe 2.0 X1 / 1xPCI
-> ASUS EPU / Fan Xpert
-> µATX
Message édité par NoradII le 28-10-2014 à 18:07:57
valid.x86.fr/575505 /842925 /902578
