Gigabyte GA-P35-DS3R [Topic Unique] - Carte mère - Hardware
Marsh Posté le 05-09-2007 à 10:35:54
Traductions de Quelques Réglages du BIOS :
Advanced BIOS Features :
Hard Disk Boot Priority :
Permet de paramétrer l'ordre de lecture des HDD par le BIOS (mettre celui où il y a l'OS en premier). Appuyez sur Echap pour quitter le menu.
First/Second/Third Boot Device :
Spécifie l'ordre de Boot des différents périphérique. Les options sont : Floppy, LS120, Hard Disk, CDROM, ZIP,
USB-FDD, USB-ZIP, USB-CDROM, USB-HDD, Legacy LAN, Disabled.
Password Check :
Spécifie si un mot de passe est nécessaire à chaque BOOT ou seulement quand vous entrez dans le BIOS. après avoir configurer cette option, préciser le Mot de Passe dans Set Supervisor/User Password.
Setup A password is only required for entering the BIOS Setup program. (Default)
System A password is required for booting the system and for entering the BIOS Setup program.
HDD S.M.A.R.T. Capability :
Enables or disables the S.M.A.R.T. (Self Monitoring and Reporting Technology) capability of your
hard drive. This feature allows your system to report read/write errors of the hard drive and to
issue warnings when a third party hardware monitor utility is installed. (Default: Disabled)
CPU Hyper-Threading :
Enables or disables Intel® Hyper-Threading Technology. This feature only works for operating
systems that support multi-processors mode. (Default: Enabled)
Limit CPUID Max. to 3 :
Allows you to determine whether to limit CPUID maximum value. Set this item to Disabled for
Windows XP operating system; set this item to Enabled for legacy operating system such as
Windows NT4.0. (Default: Disabled)
No-Execute Memory Protect :
Enables or disables Intel® Execute Disable Bit function. This function may enhance protection for
the computer, reducing exposure to viruses and malicious buffer overflow attacks when working
with its supporting software and system. (Default: Enabled)
CPU Enhanced Halt (C1E) :
Fonction d'économie d'énergie dans la veille du système. Quand elle est active, la fréquence et le Vocre vont diminuer lorsque le système sera en veille (Defaut: Enabled)
A désactiver (disabled) en cas d'OC
CPU Thermal Monitor 2 (TM2) :
Fonction contre les trops grandes chaleurs pour le CPU. Quand elle est active, la fréquence et le Vocre vont diminuerquand le CPU sera trop chaud. (Default: Enabled)
CPU EIST Function :
Fonction permettant le réglage dynamique de la fréquence et du Vcore en fonction de la charge du processeur. (Default: Enabled)
Virtualization Technology :
Enables or disables Intel® Virtualization Technology. Virtualization enhanced by Intel® Virtualization
Technology will allow a platform to run multiple operating systems and applications in independent
partitions. With virtualization, one computer system can function as multiple virtual systems.
(Default: Enabled)
Full Screen LOGO Show :
Permet l'affichage du logo GIGABYTE au boot de la machine. (Defaut: Enabled)
Init Display First :
Spécifier le type de carte graphique de votre système.
PCI : Carte Graphique PCI. (par defaut)
PEG : Carte graphique PCI Express.
Integrated Peripherals :
SATA RAID/AHCI Mode (Intel ICH9R Southbridge) :
Si pas besoins de RAID et/ou de AHCI je conseil DISABLED
Configuration du Mode opératoire du contrôleur SATA intégré.
Disabled : Configures le contrôleur SATA en PATA (équivalent à canal IDE, Pas de RAID et possibilité de branché lecteur CD). (Defaut)
RAID : Active le RAID.
AHCI : Configure le contrôleur SATA en AHCI. AHCI (Advanced Host Controller Interface) est une interface qui permet aux disque d'activer les spécification avancé du SATA comme le NCQ (Native Command Queuing) et le hot plug (le fait de pouvoir branché et débranché le disque à chaud).
SATA Port0-3 Native Mode (Intel ICH9R Southbridge) :
Permet de spécifier le mode de fonctionnement du controleur SATA.
Disabled : Autorise le contrôleur à fonctionner en mode IDE Legacy.
En mode IDE Legacy le contrôleur SATA utilse des IRQ dédiées qui ne peuvent être partagées avec les autres périphérique.
Set this option to Disabled if you wish to install operating
Activer le mode IDE Natif si vous installez un OS ne supportant pas le mode IDE Natif (exemple : Windows 9X/Me).
Enabled : Autorise le contrôleur à fonctionner en mode IDE Natif.
Activer le mode IDE Natif si vous installez un OS le supportant (exemple : Windows XP/2000).
USB Controller :
Active ou desactive le contrôleur USB. (Defaut: Enabled)
Le desactiver desactivera toutes les fonctionnalités USB qui suivent.
USB 2.0 Controller :
Active ou desactive le contrôleur USB 2.0 intégré. (Defaut: Enabled)
USB Keyboard Support :
Autorise les claviers USB à être utiliser sous MS-DOS. (Defaut: Disabled)
USB Mouse Support :
Autorise les souris USB à être utiliser sous MS-DOS. (Defaut: Disabled)
Legacy USB storage detect :
Determine si le BIOS détectera ou non les périphériques de stockage USB (USB flash drives, USB hard drives) pendant le POST. (Defaut: Enabled)
Azalia Codec :
Active ou desactive le chipset Audio. (Defaut: Auto)
Si vous avez installé une autre carte son mettre cette option sur disabled.
Onboard H/W LAN :
Active ou desactive la carte réseau intégré. (Defaut: Enabled)
SMART LAN (LAN Cable Diagnostic Function) :
Outils de diagnostique Long à traduire......
Onboard LAN Boot ROM :
Vous d'activer la ROM intégré au chipset de la carte réseau. (Defaut: Disabled)
Onboard SATA/IDE Device (GIGABYTE SATA2 Chip) :
Si vous avez encore des périphérique IDE mettre enabled
Active ou desactive les contrôleurs IDE et SATA intégré dans le chipset SATA2 GIGABYTE. (Defaut: Enabled)
Onboard SATA/IDE Ctrl Mode (GIGABYTE SATA2 Chip) :
Active ou desactive le Raid pour le chipset SATA2 GIGABYTE.
Pour les options voir "SATA RAID/AHCI Mode (Intel ICH9R Southbridge)"
Onboard Serial Port 1 :
Active ou desactive le port series mais permet aussi de régler ses IRQ. Les options sont : Auto, 3F8/IRQ4 (defaut), 2F8/IRQ3, 3E8/IRQ4, 2E8/IRQ3, Disabled.
Si pas besoins de périphérique SERIE je conseil DISABLED
Onboard Parallel Port :
Active ou desactive le port LPT mais permet aussi de régler ses IRQ. Les options sont : 378/IRQ7 (defaut), 278/IRQ5, 3BC/IRQ7, Disabled.
Si pas besoins de périphérique LPT1 je conseil DISABLED
Parallel Port Mode :
Sélectionnez le mode pour le port LPT.Les options sont : SPP (Standard Parallel
Port)(defaut), EPP (Enhanced Parallel Port), ECP (Extended Capabilities Port), ECP+EPP.
PC Health Status :
Reset Case Open Status :
Garder ou effacer les enregistrements avant la dernière intrusion boitier. Enabled effacera les derniers enregistrement et le champs "Case Opened" sera à "No" au prochain boot. (Defaut : Disabled)
Case Opened :
Displays the detection status of the chassis intrusion detection device attached to the motherboard
CI header. If the system chassis cover is removed, this field will show "Yes", otherwise it will
show "No". To clear the chassis intrusion status record, set Reset Case Open Status to Enabled,
save the settings to CMOS, and then restart your system.
Current Voltage(V) Vcore/DDR18V/+3.3V/+12V :
Affiche les voltages en cours.
Current System/CPU Temperature :
Affiche les températures actuelles pour le systeme et le CPU.
Current CPU/SYSTEM/POWER FAN Speed (RPM) :
Affiche les vitesses des ventilos branchés sur les prises CPU, system, power
CPU Warning Temperature :
Paramétré les températures de treshold du CPU. Quand le CPU dépassera la température défini, le BIOS émettra un son d'avertissement.Les options sont : Disabled (defaut), 60oC/140oF, 70oC/158oF, 80oC/176oF,90oC/194oF.
CPU/SYSTEM/POWER FAN Fail Warning :
Permet au système d'émettre un avertissement si les ventilos ne démarre pas ou si ils ne sont pas détectés. (Defaut: Disabled)
Smart FAN Control Method :
Paramétrage pour le manière de contrôller le ventilo du CPU.
Auto : Laissez le BIOS contrôlé le ventilo. (Default)
Intel(R) QST : La vitesse est contrôlée par Quiet System Technology
(QST). Il faut installer le driver Intel Host Embedded Control
Interface (HECI) dispo dans le CD.
Legacy : La vitesse est gérée en fonction de la Température.
Disabled : Vitesse à 100% tout le temps.
Smart FAN Control Mode :
Paramétrage supplémentaire. Smart FAN Control Method doit être sur ENABLED.
Auto : Le BIOS détecte le ventilo installé et choisi le meilleur mode. (Defaut)
Voltage : Ventilo 3-pin.
PWM : Ventilo 4-pin.
MB Intelligent Tweaker(M.I.T.) :
Pour obtenir les Réglages avancés des Timing mémoires il vous faut faire CTRL + F1 SUR LA PAGE D'ACCEUIL du BIOS
Robust Graphics Booster :
Robust Graphics Booster (R.G.B.) aide les performances du GPU et de la mémoire graphique. Auto permet au BIOS de choisir le meilleur mode en fonction de la configuration du système.Les options sont : Auto (defaut), Fast, Turbo.
CPU Clock Ratio :
Permet de gérer le coeff de votre processeur
CPU Host Clock Control :
Active ou desactive le fait de pouvoir gérer le FSB. Note: Si le système ne démarre plus, attendez 20 secondes pour l'auto-reboot sinon faites un clear-CMOS. (Defaut: Disabled)
CPU Host Frequency (Mhz) :
Permet de gérer le FSB. CPU Host Clock Control doit être sur ENABLED
PCI Express Frequency (Mhz) :
Permet de gérer la fréquence du bus PCI Express. de 90 à 150 MHz. Auto met la valeur standard de 100 MHZ. (Defaut: Auto)
Je conseils de la mettre à 101 pour être sur que la fréquence soit bloquée
C.I.A.2 :
Overclock automatiquement le processeur en fonction de la charge.
Disabled : Désactive C.I.A.2. (Defaut)
Cruise : Accroit la fréquence du CPU de 5% ou 7% en fonction de la charge.
Sports : Accroit la fréquence du CPU de 7% ou 9% en fonction de la charge.
Racing : Accroit la fréquence du CPU de 9% ou 11% en fonction de la charge.
Turbo : Accroit la fréquence du CPU de 15% ou 17% en fonction de la charge.
Full Thrust : Accroit la fréquence du CPU de 17% ou 19% en fonction de la charge.
Warning : Avant d'utiliser C.I.A.2 pensez à verifier la stabilité de votre CPU.
System Memory Multiplier (SPD) :
Ratio FSB/RAM. Par defaut : Auto, 2, 2.4, 2.5, 3, 3.20, 3.33 et 4
Memory Frequency (Mhz) :
La première fréquence est la fréquence de fonctionnement normal de vos barrettes. La deuxième est la fréquence à laquelle fonctionnera votre mémoire si vous sauvegardez le BIOS
High Speed DRAM DLL Settings :
Configurations de Timing automatique.
Si PC instable passé sur l'autre option.
Option 1 : Memory Timing Configuration 1. (Defaut)
Option 2 : Memory Timing Configuration 2.
DRAM Timing Selectable (SPD) :
L'option Manual permet de définir les timings mémoire de façon manuelle.
Les options sont : Auto (default), Manual.
Standard Timing Control :
CAS Latency Time : Auto (default), 3, 4, 5 et 6
DRAM RAS# to CAS# Delay : Auto (default), 1 à 15.
DRAM RAS# Precharge : Auto (default), 1 à 15.
Precharge delay (tRAS) : Auto (default), 1 à 63.
Advanced Timing Control :
ACT to ACT Delay (tRRD) : Auto (default), 1 à 15.
Rank Write To READ Delay : Auto (default), 1 à 31.
Write To Precharge Delay : Auto (default), 1 à 31.
Refresh to ACT Delay : Auto (default), 0 à 255.
Read To Precharge Delay : Auto (default), 1 à 15.
Static tRead Value : Auto (default), 1 à 31.
Static tRead Phase Adjust : Auto (default), 1 à 31.
System Voltage Control :
Permet d'autoriser la modification des tensions des différents composants.
Les options sont Auto (Defaut) et Manual
DDR2 OverVoltage Control :
Permet d'augmenter le voltage de la mémoire. Augmente le voltage de 0.1 à 0.7 volt par pas de 0.1 volt
Les options sont : Normal, +0.1, +0.2, +0.3, +0.4, +0.5, +0.6 et +0.7.
Normal : 1.8
+0.1 : 1.9
+0.2 : 2.0
+0.3 : 2.1
+0.4 : 2.2
+0.5 : 2.3
+0.6 : 2.4
+0.7 : 2.5
PCI-E OverVoltage Control :
Permet d'augmenter le voltage du PCI Express. Augmente le voltage de 0.1 à 0.3 volt par pas de 0.1 volt
Les options sont : Normal, +0.1, +0.2 et +0.3
Normal : ?
+0.1 : ?
+0.2 : ?
+0.3 : ?
FSB OverVoltage Control :
Permet d'augmenter le voltage du FSB. Augmente le voltage de 0.1 à 0.3 volt par pas de 0.1 volt
Normal : 1.175
+0.1 : 1.275
+0.2 : 1.375
+0.3 : 1.475
MCH OverVoltage Control :
Permet de modifier le voltage de votre Nortbridge (le chipset). Augmente le voltage de 0.1à 0.3 volt par pas de 0.1 volt
Normal : 1.25
+0.1 : 1.35
+0.2 : 1.45
+0.3 : 1.55
CPU Voltage Control :
Vous permet de modifier le Vcore de votre CPU. (Defaut : Normal)
Normal CPU Vcore :
Affiche le Vcore par défaut de votre CPU.
Aide pour le réglage pour un oc de base :
Topic Unique pour l'OC sur cette carte : http://forum.hardware.fr/hfr/Overc [...] 6601_1.htm
| Citation : |
Marsh Posté le 05-09-2007 à 10:35:58
VOLT MODS :
Point de mesure du Vcore :
Cela se situe pas loin du port parallèle ou juste à coté du trou de fixation du rad (en bas à gauche)
Vdroop by Th0m59 :
Objets utilisés :
_ Loctite Circuit + (12€ chez Norauto fourni avec pinceau)
_ Scotch pour proteger les autres composants
Voici les résultats de ses Tests :
FeedBack de Mod V-core :
| boobeer a écrit : |
Vdimm :
Cette carte mère va jusqu'à 2.55 de Vdimm (mémoire). Vous en voulez plus et bien voici comment faire :
Tout cela se passe aux alentours du Southbridge. Il vous est possible de mesurer la valeur du voltage grâce au point de mesure (Cf photo).
Pour augmenter le Vdimm, il y a deux possibilité :
- Vous pouvez réaliser le "pencil mod".
OU
- Vous pouvez aussi souder une resistance variable de 10K ohms sur la patte définie sur la photo, l'autre patte sera fixé sur la masse. Abaisser la resistance pour augmenter le voltage.
Marsh Posté le 05-09-2007 à 10:59:17
Voici le détail du mod pour le VDroop sur ma DS3R Rev 1.0
Tests :
Marsh Posté le 05-09-2007 à 11:00:00
Marsh Posté le 05-09-2007 à 11:42:00
Il faudrait indiquer la manip pour avoir le son, car j'ai eu le problème sur la DS4 mais sur la DS3 c'est le même pb de packaging foireux du CD je crois.
http://forum.gigabyte.fr/index.php?topic=1000.0
Marsh Posté le 05-09-2007 à 11:47:52
| arker37 a écrit : D'où le fait que je mets à dispo les Drivers de Realtek |
Non, ça ne suffit pas car si les gens installent au départ le CD (comme moi et 95% des gens, ce qui est quand même la logique), ils se retrouvent dans une impasse, que seule la manip décrite dans le forum Gigabyte peut débloquer.
Marsh Posté le 05-09-2007 à 12:14:52
@arker37
J'ai une p35c-ds3r (quasi identique sauf ddr3 en +) tu peux rajouter en 1ere page que le si120+ adaptateur 775 passe sur cette mobo (heatpipe vers le bas).
J'ai également 2x1024 ddr2 pc6400 Gskill PK , passe nickel mais faut mettre les bon timmings ![]()
Marsh Posté le 05-09-2007 à 12:18:12
Salut !
Euh j'avoues ne pas comprendre l'histoire sur les drivers du son fournis sur le CD.
Je les ai installé, j'ai testé uniquement avec le casque (prise frontale du P182), et ça fonctionne.
J'ai pas encore eu le temps de brancher des enceintes dessus.
Votre problème c'est que vous avez aucun son si vous installez les drivers du CD ?
Marsh Posté le 05-09-2007 à 12:19:35
bonjour, je posséde cette carte depuis peu, ce n'est pas spécifié mais elle support de la PC 4200, j'ai 2 barettes de 512 samsung et 2 barrettes 512 kingston et pas de problème, mais je vais investir prochainement dans de la G-kill 6400.
Marsh Posté le 05-09-2007 à 12:57:09
| ph75 a écrit : Il faudrait indiquer la manip pour avoir le son, car j'ai eu le problème sur la DS4 mais sur la DS3 c'est le même pb de packaging foireux du CD je crois. |
| funky 83 a écrit : @arker37 |
| kakal33 a écrit : bonjour, je posséde cette carte depuis peu, ce n'est pas spécifié mais elle support de la PC 4200, j'ai 2 barettes de 512 samsung et 2 barrettes 512 kingston et pas de problème, mais je vais investir prochainement dans de la G-kill 6400. |
tout à été ajouté au premier sujet
Marsh Posté le 05-09-2007 à 13:53:08
| pyp a écrit : Je les ai installé, j'ai testé uniquement avec le casque (prise frontale du P182), et ça fonctionne. |
Oui si tu fais l'installe après Win XP SP2 (pas SP1), et que tu lances l'installes des drivers avec le CD fourni, je crois qu'il n'y a aucune chance que ça marche (en tut cas chez moi c'était NOK et comme j'ai fait plusieurs désinstalle/réinstalle du driver et des KB Microsoft amenés par l'installe, la situation semble inratrapable même avec le procédure du forum Gigabyte, j'ai donc gagné une résinstalle complète du système)
Le cas où ça marche c'est je crois si tu installes le SP2 après avoir installé les drivers (encore faut il avoir un CD où il n'y a pas déjà le SP2 ...).
Et peut être que c'est OK avec Vista, je n'ai pas trop lu ce qui s'est dit là dessus.
Marsh Posté le 05-09-2007 à 14:59:25
| ph75 a écrit : Oui si tu fais l'installe après Win XP SP2 (pas SP1), et que tu lances l'installes des drivers avec le CD fourni, je crois qu'il n'y a aucune chance que ça marche (en tut cas chez moi c'était NOK et comme j'ai fait plusieurs désinstalle/réinstalle du driver et des KB Microsoft amenés par l'installe, la situation semble inratrapable même avec le procédure du forum Gigabyte, j'ai donc gagné une résinstalle complète du système) |
Pourtant je l'ai installé sur un SP2 (mon CD de windows est déjà en SP2). Après par contre, j'ai passé un coup de windows update pour tout récupérer; mais je me rappelle plus si j'ai installé les drivers avant ou après le windows update.
Bref, je vais pas chercher à comprendre et à compliquer la situation, ça marche et pis f'est tout !!
Marsh Posté le 05-09-2007 à 15:15:31
A noter que Easy Tunes 5 est complètement instable sur mon Vista, il plante au démarrage une fois sur deux. J'ai pourtant fait la mise à jour.
Ce n'est pas trop grave car apparemment SetFSB est ok avec la DS3R et SpeedFan se débrouille pas mal pour récupérer Vsys, Vcore, V3.3
Marsh Posté le 05-09-2007 à 16:09:44
Très bonne idée ce topic! je vais recevoir une ds3p c'est proche...si j'ai bien compris si on O/C pas ya juste à mettre à jour les drivers son, chipset après sp2 ? et ne rien prendre du cd ?
Marsh Posté le 05-09-2007 à 16:22:09
et pour le refroidissement du proc vous avez choisi lequel??
Marsh Posté le 05-09-2007 à 16:26:17
Freezer 7 Pro, niveau rapport oc/prix il est imbattable, il emmène mon E4400 à 3.2Ghz avec brio ![]()
Marsh Posté le 05-09-2007 à 16:32:55
drapal!
pour le refroidissement j'ai gardé mon Zalman CNPS-9500 LED.
ca marche bien ![]()
Marsh Posté le 06-09-2007 à 00:17:36
| jayjay19 a écrit : Très bonne idée ce topic! je vais recevoir une ds3p c'est proche...si j'ai bien compris si on O/C pas ya juste à mettre à jour les drivers son, chipset après sp2 ? et ne rien prendre du cd ? |
Installer les drivers Realtek à partir du site Realtek (pour avoir la dernière version), et à partir du CD ne surtout pas installer "Microsoft UAA Bus driver for HD Audio" ni les drivers Realtek. Le reste (réseau, chipset Intel, etc) peut être installé à partir du CD, en sélectionnant l'installation individuelle.
Marsh Posté le 06-09-2007 à 00:32:26
ya pas un mirroir pour les pilotes audio car le site de realteck ca se traine...
Marsh Posté le 06-09-2007 à 00:45:45
Bon, c'est pas pour casser l'ambiance, mais j'ai installé les drivers du CD et ça fonctionne du premier coup. D'ailleurs je suis surpris du système de détection de branchement sur chaque jack, le software demande si c'est une entrée ou une sortie, analogique ou numérique. Assez plaisant
Voilà, donc il est possible que ça marche du premier coup. Le fait que j'aie Vista doit aider, puisque le bug du driver sur CD semble être lié à un patch qui doit être installé sur XP avant l'installation du driver.
Marsh Posté le 06-09-2007 à 00:57:27
moi je suis sur xp j ai installé les drivers du cd sauf pour le son
et j ai installé ensuite les drivers du site de realtek et ca passe nickel la
(je suis sur une DS3P)
Marsh Posté le 06-09-2007 à 01:37:09
| dafunky a écrit : Bon, c'est pas pour casser l'ambiance, mais j'ai installé les drivers du CD et ça fonctionne du premier coup. |
Oui le problème existe sous WinXP à cause du fameux patch Microsoft installé 2 fois par le CD d'où la corruption, comme c'est un patch spécifique XP, il n'y a pas ce problème avec Vista.
Marsh Posté le 06-09-2007 à 05:56:06
Bonjours à tous, j'ai une petite question, si vous devriez choisir entre cette carte GA-P35-DS3R et une P5K, vous prenez laquelle ?
Moi, j'ai commandé une P5K semaine derniere mais je sais même pas si j'ai pris la bonne décision
Marsh Posté le 06-09-2007 à 09:30:06
c'est deux carte ce vale donc pas un mauvais choix aussi la P5K
Marsh Posté le 06-09-2007 à 10:00:37
Quelle différence existe-t-il entre la DS3, la DS3P et la DS3R?
Marsh Posté le 06-09-2007 à 10:00:42
salut moi j ai une P35C-DS3R et depuis que je suis passer a 4x1024 ddr2 pc6400 Gskill PK je peut plus me metre en 6x400 alors quand 2x1024 sa marchai je suis un peut perdu mais bon sinon sa marche nickel tres bonne carte
Marsh Posté le 06-09-2007 à 10:02:12
DS3 sans raid ni fireware
DS3R + RAID
DS3P +RAID +Firewire
si je ne me trompe pas
Marsh Posté le 06-09-2007 à 10:05:03
| saif a écrit : DS3 sans raid ni fireware |
Marsh Posté le 06-09-2007 à 10:25:24
En cherchant un peu, il apparait également une DS3L !
On s'y perd un peu chez Gigabyte ...
Marsh Posté le 05-09-2007 à 10:35:42
TOPIC UNIQUE SUR LA GIGABYTE GA-P35-DS3R
PRESENTATION :
La P35-DS3R est une carte mère doté du dernier chipset d'Intel (en date du 05 Septembre 2007) : le P35 Express.
BUNDLE :
- Guide d'installation rapide
- Guide d'installation pour processeur Intel 775
- CD : pilotes + Adobe reader + Norton (?) + Easytune 5 Pro
- Manuel en français
- Facade arriere I/O (Cahce des prises Carte Mères)
- Support PCI avec 1 Sortie Molex et 2 sorties e-SATA
- Nappe FLoppy et Nappe IDE
- 4 Cables SATA/ 3Gb
- 1 Cable E-SATA
- 1 Cable d'alimentation Molex 4 points => SATA
Photo by M0zArT :
RESUME DES SPECIFICATIONS CONSTRUCTEUR :
CPU Supportés :
Intel® Core™2 Extreme Quad-Core / Core™2 Duo / Intel® Pentium® Extreme/ Intel® Pentium® D processors
Supporte les FSB 1333, 1066 et 800
Chipset :
- Northbridge : Intel® P35 Express Chipset
- Southbridge : Intel® ICH9R
- Contrôleur Réseau : RTL811B
- Sonore : ALC889A (gère le 7.1)
Mémoires :
- DDR2 1066*/800/667 memory
- Supporte jusqu'à 8 Go de Mémoires (2 Go par Slots)
Slots d'extension :
- 1 PCI Express X16
- 3 PCI Express X1
- 3 PCI
Type de la carte mère :
- ATX, 305 x 210mm
DIFFERENCES ENTRE LES REVISIONS :
Merci à Fouge
P35-DS3x rev 1.0 -> 4 USB + Série + Parallèle
P35-DS3x rev 2.0 -> 8 USB
P35-DS3x rev 2.1 -> 8 USB + compatibilité DES + diodes indiquant le nombres de phases utilisée
EP35-DS3x -> 8 USB + compatibilité DES + diodes indiquant le nombres de phases utilisée
En savoir plus sur le DES : http://www.matbe.com/actualites/28 [...] on-penryn/
DEMANDE DE RMA :
Merci à M0zArT
Suite à une réorganisation des activités de GIGABYTE United, nous vous informons que le service après ventes de GIGABYTE France a été transféré à GIGABYTE Technology B.V. EN Hollande.
Les N° de RMA ne seront plus attribués par GIGABYTE France, mais seront attribués par la Hollande.
N'hésitez pas avant toute chose à prendre contact avec le revendeur de votre produit GIGABYTE, surtout si ce dernier est encore sous garantie afin d'optimiser le traitement de votre SAV,
Si votre revendeur n'accepte plus votre produit veuillez suivre la procédure suivante :
- Remplissez le document ci joint en précisant les informations nécessaires dans les parties colorées du tableau
- Envoyer le document par mail à : rmateam@giga-byte.nl
- Après obtention d'un numéro de retour, veuillez le préciser sur votre colis ( n'hésitez pas aussi à imprimer le document et glissez le dans le carton )
- Expédier votre colis à l'addresse ci dessous :
Adresse d’expédition :
GIGABYTE TECHNOLOGY B.V.
Verdunplein 8
5627 SZ EINDHOVEN
Hollande
Attribution des N° de RMA (par e-mail uniquement)
Contact : Kevin
E-mail : rmateam@giga-byte.nl
Fax : +31 40 290 20 89
Nous vous remercions de la fidélité que vous continuerez à nous témoignez et restons à votre disposition pour tout information complémentaire.
Le formulaire a remplir, dispo sur le FTP hébergeant les images du Tuto : RMA REQUEST FORM
EMPLACEMENT SONDE TEMPERATURE CARTE MERE :
Merci à Reinel
MATERIELS COMPATIBLE OFFICIELLEMENT :
Mémoire
Processeurs
BRANCHEMENTS PRINCIPAUX :
Il est indispensable de bien branché la prise 24 broches
TEST :
GinjFo
Syndrome-OC
X-bit labs
Bit-tech.net
RAID/AHCI
Bon voilà, pour ceux qui comme moi n'ont pas installé les pilotes du contrôleur RAID/AHCI lors de l'installation de Windows (via F6), il y a quand même moyen d'installer celui-ci à partir de Windows.
Voilà comment je m'y suis pris :
-Installer Windows normalement (HDD sata sur le Port Sata 0 du contrôleur Intel). 0 ou un autre, aucune importance ...
-Installer les pilotes (chipset etc).
-Télécharger le fichier iata82_cd.exe
Multi language:
iata82_cd.exe
Ver:8.2.0.1001 Date:6/2/2008 Size:22709 (KB)
OS:Windows Server* 2003, Windows Server* 2003 Enterprise x64 Edition, Windows Server* 2003 Standard Edition, Windows Server* 2003 Standard x64 Edition, Windows Vista*, Windows Vista* 32, Windows Vista* 64, Windows* XP Home Edition, Windows* XP Media Center Edition, Windows* XP Professional, Windows* XP Professional x64 Edition
-Installer le pilote RAID gigabyte Dispo ICI.
-Arrêter la machine, passer le HDD sur le port 0 du contrôleur GSATA (port violet).
-Passer dans le Bios et switcher contrôleur SATA Intel de Disable à AHCI (j'ai également mis SATA natif sur Enable).
-Laisser le contrôleur SATA gigabyte sur ide (defaut ds le BIOS).
-Sauvegarder et booter windows.
-De là, lancer l'installation du fichier iata82_cd.exe puis arrêter la machine.
-Reswitcher le cable SATA du contrôleur GSATA à un des ports du contrôleur SATA intel.
-Redémarrer et le tour est joué
Honnêtement c'est la seule façon que j'ai trouvé pour éviter le problème de l'écran bleu au démarrage et le reboot qui va avec.
ps: Même l'extraction du fichier iata82_cd.exe et la mise à jour du pilote via le gestionnaire des périphérique n'a fonctionné.
DRIVERS SUR LE SITE GIGABYTE
Drivers Gigabyte rev 1.0
Drivers Gigabyte rev 2.0
Drivers Gigabyte rev 2.1
DRIVERS FABRICANT
Driver Intel Chipset P35 Actuellement 9.0.0.1008 (Win XP) sur le site Intel
Driver Intel Chipset Actuellement 9.0.0.1008 sur Clubic
Driver Carte Réseau Actuellement 5.728 (WinXP64/WinXP/Win2K - 11/06/2009) et 6.223 (Vista 32 et 64 - 09/06/2009) et 7.003 (Win 7 32 et 64 17/06/2009)
Driver Carte son Actuellement R2.26 pour tous les Windows (05/06/2009)
N'installer pas les drivers sons du CD car le packaging a surement été mal fait par GYGABITE. Installez plutôt ceux proposés ci-dessus
Si malheureusement vous l'avez fait reporter vous à cette manipulation afin de régler le problème :
BIOS
Bios rev 1.0 Actuellement F13
Bios rev 2.0 Actuellement F13
Bios rev 2.1 Actuellement F13
Pour flasher utiliser : @ Bios 2.03
MEMOIRES COMPATIBLE :
Mémoires RAM :
A-data 4*1 Go PC6400 (5-5-5-15) : yoleouf
Corsair Value 2*1 Go (5-5-5-15) : yoleouf
Corsair Value 2*1 Go PC6400 (5-5-5-15) @ 1.7v : tibow2
Corsair DHX 2*1 Go PC6400 (5-5-5-18) (mais pas avec le Gemin II !) : yoleouf
Corsair Twinx 2*1 Go PC6400 Cas 4 : reinel
Corsair XMS 2*1 Go PC6400 : rapetout
Crucial Ballistix Tracer 2*1 Go PC5300 (3-3-3-12) : yoleouf
Crucial Ballistix Tracer 2*1 Go PC6400 (4-4-4-12) @ 2.2v puce D9 : Fluff-, DKman, kwaio
Crucial Ballistix Tracer 2*1 Go PC6400 (4-4-4-12) @ 420 @ 2.2v :raptor-swat
Crucial Ballistix 2*1 Go PC8500 (5-5-5-15) @ 2.2v : Montano5
Gskill 2*1 Go PC6400 HK 4-4-3-5 (tient 4-4-4-12 @ 500 @ 2.2v) : Arker37
Gskill 2*1 Go PC6400 HZ : Mr Oizo Bis
Gskill 2*1 Go PC6400 PK mais faut mettre les bon timmings : funky 83, kazekami
Gskill 4*1 Go PC6400 PK (Configuration manuelle aux spec constructeurs : 4-4-4-12 @ 2.0V @ 400MHz) : Fouge
Gskill 2*1 Go PC8500 PI Cas 5 : cobain_addict
Gskill 2*1 Go PC8500 PK (5-5-5-15) @ 2.1v : reinel
Gskill 2*1 Go PC8000 1066mhz @ 1050Mhz cas 5-5-5-15 : hypershade
Kingston Hyper X 2*1 Go PC6400 : 10-david
OCZ Platinum 2*2 Go PC8500 (tient 5-5-5-18 @ 545 @ 2.1v) : matthiman
OCZ Sli Ready 2*1 Go PC8500 (5-5-5-15 @ 2.1v) : Montano5
OCZ Reaper 2*2 Go PC8500 (5-5-5-15 @ 2.1v) : emeralfish
Samsung 2*512 Mo PC4200 + Kingston 2*512 Mo PC4200 : kakal33
TeamGroup Elite 2*1 Go PC6400 : thxman007
Transcend 2*1 Go PC6400 Cas 4 : repie65
Transcend aXeram 2*1 Go PC6400 Cas 4 : duaman
Rappel des différentes appellations pour la DDRII:
Le FSB affiché est le FSB par defaut
PC4200 = FSB 266 = DDR2-533
PC5300 = FSB 333 = DDR2-666
PC6400 = FSB 400 = DDR2-800
PC8000 = FSB 500 = DDR2-1000
PC8500 = FSB 533 = DDR2-1066
PC8800 = FSB 550 = DDR2-1100
PC9200 = FSB 575 = DDR2-1150
PC9600 = FSB 600 = DDR2-1200
VENTIRAD COMPATIBLE :
Arctic Cooling Freezer 7 Pro : Arker37
Cooler Master GEMIN II 2*12 cm : yoleouf, Arker37, tibow2
Cooler Master Hyper 212 : quart-temps (Attention lui c'est sur une P35C-DS3R)
Cooler Master Hyper TX2 : rapetout
Noctua NH-U12F passe sans problème sur la carte : Negueu
Noctua NH U12 + 2*12 cm : yoleouf, cobain_addict
Noctua NH U12P : raptor-swat, hypershade
OCZ Vendetta : duaman
Scythe Infinity (
Scythe Ninja : ingmar
Scythe Mugen 2 : tamamanquitaime
Thermalright HR-01 Plus + Scythe Slipstream : Fluff-
Thermalright SI120 + adaptateur 775 (heatpipe vers le bas) : funky 83
Thermalright Ultima 90 + 12 cm Coolink swif 1202 : Verson-i3
Thermalright Ultra 120 extreme : boobeer, Mr Oizo Bis, Montano5
Zalman CNPS 7000 B Al-Cu/Cu : yoli
Zalman 9500LED : camille31140
Zalman 9700LED : 10-david
Zalman CNPS 9700 NT : guiton
Xigmatek HDT-S1283 : Matthiman
Message édité par arker37 le 07-09-2009 à 16:09:13
L.O.L : Sylche || W.O.T : Sylche || MH3U : Sylche
