Asrock K7S8X /e/e+ (SIS 746FX/748) [TOPIC] - Carte mère - Hardware
Marsh Posté le 09-07-2003 à 00:24:14
OVERCLOCKING
Un petit voltmod de la mémoire ou encore du chipset -> http://www.ocworkbench.com/2003/as [...] e_mods.htm
Et oui, certaine personne overclocke leurs cpu avec cette carte :
K7S8X rev 1
Chaced : XP1700+ 1463 (11*133) @ 1826 (11*166)
K7S8XE rev 3
computersmsa : XPM 2600+ "AXMG2600FQQ4C" @ 2592 (15*172) / 1.84v
Victorsab33 : Duron 800 (8*100) @ 920 (8*115) / 1.71V
K7S8XE+
Marko-Piteur : Duron 1600 "MIUHB0336TPMW" @ (12*200) 2400 / 1,84v
Beep Beep Ami Bios ?
1 short DRAM refresh failure The programmable interrupt timer or programmable interrupt controller has probably failed
2 short Memory parity error A memory parity error has occurred in the first 64K of RAM. The RAM IC is probably bad
3 short Base 64K memory failure A memory failure has occurred in the first 64K of RAM. The RAM IC is probably bad
4 short System timer failure The system clock/timer IC has failed or there is a memory error in the first bank of memory
5 short Processor error The system CPU has failed
6 short Gate A20 failure The keyboard controller IC has failed, which is not allowing Gate A20 to switch the processor to protected mode. Replace the keyboard controller
7 short Virtual mode processor exception error The CPU has generated an exception error because of a fault in the CPU or motherboard circuitry
8 short Display memory read/write error The system video adapter is missing or defective
9 short ROM checksum error The contents of the system BIOS ROM does not match the expected checksum value. The BIOS ROM is probably defective and should be replaced
10 short CMOS shutdown register read/write error The shutdown for the CMOS has failed
11 short Cache error The L2 cache is faulty
1 long, 2 short Failure in video system An error was encountered in the video BIOS ROM, or a horizontal retrace failure has been encountered
1 long, 3 short Memory test failure A fault has been detected in memory above 64KB
1 long, 8 short Display test failure The video adapter is either missing or defective
2 short POST Failure One of the hardware testa have failed
1 long POST has passed all tests
Marsh Posté le 11-07-2003 à 15:55:23
ça a l'air tout bon ça
super topic en perspective merci d'avance
Marsh Posté le 11-07-2003 à 16:04:40
Scorpy a écrit : ça a l'air tout bon ça |
Si quelqu'un a des problemes, des astuces pour cette carte mere, je suis preneur
Marsh Posté le 13-07-2003 à 19:08:44
Le controlle de temperature/ventil permet :
-Controlle temperature Cpu et Chassi
-Controlle ventillo Cpu et Chassi
-Controlle voltage +12V, +5V, +3V, Vcore
avec quel prog peut on voir/paramétrés toutes ces belles choses?
Marsh Posté le 18-07-2003 à 12:11:25
Scorpy a écrit : Le controlle de temperature/ventil permet : |
la puce de controlle est une Winbond W83697HF donc, elle est gérée par speedfan, www.almico.com mais, il ne reconnait pas le SIS746FX. sinon, MBM n'a pas de probleme http://mbm.livewiredev.com/comp/asrock.html
Marsh Posté le 19-07-2003 à 23:41:26
Elle fait la dual-DDram?
Je vais faire une upgrade de ram et je sais pas si j'ai interet a mettre 2 * 256 ou 1 * 512 de ddr 333
Marsh Posté le 19-07-2003 à 23:47:58
Au fait quel est l'interet de mettre de de la ddr400 si le fsb depasse pas 333?
Marsh Posté le 20-07-2003 à 21:36:10
Fabre a écrit : Elle fait la dual-DDram? |
Non, c'est de la simple DDR, et de toute façon, elle n'a pas de carte graphique intégrée.
Donc il faut mieux 1*512
Sinon, elle supporte la DDR400, de ce fait, on peut un peut overclocker un 166Mhz (333) ou encore poussé les CAS de latences.
Du genre, une barette DDR 400 avec des CAS lent passera en DDR 333 en CAS rapide...
Marsh Posté le 20-07-2003 à 21:40:21
un cht'tit conseil pour ceux qui ont des pbs de performance de la RAM : update du bios !!
je suis passé au dernier bios en date, et mes perfs mémoires se sont nettement améliorées sous sandra (je n'ai pu le constater que dans les benchs, paske c pas moi ki me sers de cette machine...)
Marsh Posté le 20-07-2003 à 21:43:27
elle est en concurrence avec l'asus a7v8x-x
http://www.monsieurprix.com/listin [...] 50990.html
plus chère de quelques euros
Marsh Posté le 20-07-2003 à 22:00:36
Blazkowicz a écrit : elle est en concurrence avec l'asus a7v8x-x |
oui, mais c'est pas du VIA
Marsh Posté le 20-07-2003 à 22:16:34
J'ai un athlon xp 2400 non oc qui monte a 52 degré en full load
Ca vaut le coup d'augmenter le fsb?
En sachant que y a pas encore de bios qui permette de changer le multiplicateur, j'ai cru comprendre que pour ce proc l'ideal c 12.5 x 166
Marsh Posté le 20-07-2003 à 22:19:49
En parlant de bios la version 1.70 me rebootait le pc au bout de qlq minutes, et la beta 1.71 m'indiquait une temp de 36 degré en Idle, contrairement au 49 constaté avec les versions 1.50 et 1.90
Marsh Posté le 20-07-2003 à 22:21:26
Fabre a écrit : Au fait quel est l'interet de mettre de de la ddr400 si le fsb depasse pas 333? |
les perfs augmentent légérement avec l'augmentation de la vitesse de la ram. Le comportement n'est pas le même qu'avec un nF2, qui lui donne le meilleur de lui-même en mode synchrone...
Marsh Posté le 20-07-2003 à 22:24:18
ReplyMarsh Posté le 20-07-2003 à 22:37:26
chaced a écrit : |
si je raisonnais comme toi je dirais
"et toi t'as une ATI dans ton deuxième PC "
Marsh Posté le 20-07-2003 à 22:47:37
Blazkowicz a écrit : |
Et bientot aussi dans mon premier pc
Marsh Posté le 21-07-2003 à 20:40:24
un lien vers un bios modé... http://pc-chat.kicks-ass.net/downl [...] ile&id=281
g essayé, mais g pas vu de différence (en même temps, g pas trop regardé !!!)
qqn d'autre pour faire des tests plus poussés ???
Marsh Posté le 21-07-2003 à 20:51:31
c'est bien SIS maintenant ou c'est toujours comme y'a qq années?
Marsh Posté le 21-07-2003 à 20:52:17
splurf a écrit : c'est bien SIS maintenant ou c'est toujours comme y'a qq années? |
c comme partout : y'a du bon...et du moins bon !!
mais en l'occurrence, chuis ravi de la K7S8X !!
Marsh Posté le 21-07-2003 à 23:15:38
Gum a écrit : Elle a l'air bien intéressante cette carte |
ben si tu cherches la stabilité avant tout, fonce !!!!
pour les perfs, y'a mieux, mais c plus cher !!! et souvent moins stable...
pour l'o/c, elle est clairement pas faite pour, mais j'arrive à faire tourner mon 2600+@2700+
Marsh Posté le 21-07-2003 à 23:58:12
matlu a écrit : |
Normal si tu prends un cpu a FSB 166Mhz, sur le 1700+, je l'ai simplement passé de 11 * 133 @ 11*166
Marsh Posté le 21-07-2003 à 23:59:19
chaced a écrit : |
joli score !!
mais je vais t'avouer ke g pas essayé plus de 30 sec : cette config étant à mon tit frère, g po envie de faire des bêtises avec !!!
Marsh Posté le 22-07-2003 à 00:27:36
J'ai flash la version 1.90 advanced de geekster
Pas remarqué de difference.
Si un germanophile pouvais aller faire un tour sur www.geekster.info et nous expliquer quelle est la difference entre la 1.90 asrock et la 1.90 advanced de geekster
Marsh Posté le 22-07-2003 à 00:30:57
matlu a écrit : |
sur mon A7n8x, il passait au voltage d'origine en 12.5*172, mais sur l'asrock, je n'ai pas forcé, c'est le pc de mes parents, et il sert pour de la bureautique et du net, donc, les perfs n'ont pas beaucoup d'importance
Marsh Posté le 22-07-2003 à 00:44:29
Fabre a écrit : J'ai flash la version 1.90 advanced de geekster |
moi je suis googlephile donc -> http://216.239.37.104/translate_c? [...] uage_tools
Et d'apres ce que google dit, ça optimise les perfs mémoires, du genre sous sandra ou seti...
Marsh Posté le 22-07-2003 à 11:10:12
qq remarques sur le 1er post :
la K7s5a c'etait du sis735 et la K7s6a su sis745...
sinon l'histoire de l'agp a 3.3v qui crame la cm ca fait un peu peur quand meme...
c'est bien les cg agp 1 qui etaient a 3.3v non ?
Marsh Posté le 22-07-2003 à 11:18:43
mogg a écrit : qq remarques sur le 1er post : |
Merci, je corrige l'histoire du Sis 735
Sinon, c'est bien les 1ere AGP 2x qui sont dangereuses, reconnaisable par 1 seul ergot
Les AGP 4x en ont 2 :
Marsh Posté le 22-07-2003 à 11:26:37
il faudrait inclure la K7S8XE ici aussi je pense
même carte équipée du SiS748, apportant le support du FSB 200
Marsh Posté le 22-07-2003 à 11:30:52
biniou a écrit : il faudrait inclure la K7S8XE ici aussi je pense |
Je viens de lire les specs chez Asrock, et la seule différence, c'est le support officiel FSB 200, tout le reste est identique a la petite soeur K7s8x
Marsh Posté le 02-08-2003 à 12:18:29
Euh le fsb 200 est aussi dispo sur la K7S8X d'aprés la notice.
Quel différence alors finalement avec la E ?
Marsh Posté le 08-08-2003 à 12:16:32
Le FSB ya pa moyen de le monter a 180Mhz ???
Ou c'est vraiment limité a 166mhz pile ...
Sinon la version E, elle monte a 200mhz en FSB sur ???
Marsh Posté le 08-08-2003 à 17:27:34
oui la E est prévue pour...
La K7s8x tout court peut étre car y a un jumper pour passer le bus en 200. Now perosnne n' a testé avec un chtit 3200+
Marsh Posté le 13-08-2003 à 18:14:37
g une E elle monte en 200mhz!!!!
Seul pb, on peux pas changé les coefficient...
Marsh Posté le 14-08-2003 à 02:14:06
wi on peut pa changé le coef ..
Ca c'est tres chiant ..
Je vien d'acheté la Carte aujourdhui ...
je suis a 11x181 ===> Ca roxx !! @ 1,6V (1700+ JIUHB POWAAA !!)
Demain j'essaie plus haut ..
par contre !! on peut changer le Vcore ?
Marsh Posté le 09-07-2003 à 00:23:58
Asrock K7S8X / e / e+
site sur la carte -> >>>>>> http://www.asrockfrance.com/k7s8x/ <<<<<<
Le forum spécialisé -> http://www.asrockfrance.com/forum/
Compatibilité materielle -> http://ginie.homeftp.net/asrock/
Voici un petit topic sur cette carte mère pas chère de chez Asrock.
NOTE D'INSTALLATION, ne pas brancher les periphs IDE lors de l'install, allumer le pc, aller dans le bios, sauver, puis etteindre et ensuite brancher les IDE. Ceci evitera de venir vous plaindre que votre mobo ne démarre pas.
Asus ne pouvant pas se permettre de faire des cartes mères pas chères, ils ont créé Asrock, pour pouvoir contrer Elite.
Bien sur la fameuse K7s5a (Sis 735) embête asus, il sort donc un nom pour sa nouvelle asrock assez proche de la carte mere phare d'elite, mais avec la touche Asus, le 8x, ce qui nous fait K7S8X
http://www.ocworkbench.com/2003/as [...] 7s8x-1.htm
Cette carte mere est basé sur le chipset Sis 746FX, mais, de quoi est capable ce chipset ?
1- Le SIS 746FX
-Support officiel DDR400
-Support officiel Cpu FSB 333 (166Mhz), Barton ready
-AGP 8x, compatible AGP 4x
-MuTIOL 1G : Interconnection propriétaire entre le Northbridge (746FX) et Southbridge (963L) de 1 Go/s
-Technologie HyperStreaming (gestion des priorités au sein des taches du chipset)
-Ata 133
-Audio Ac97 Hollywood 5.1
-Interface Lan 10/100Mb
-6 Ports USB 2.0 (4 directement sur l'K7S8X)
2- La K7S8X
Il existe 2 révisions sur cette carte, la rev1 décrite ci dessous et la rev3 qui remplace petit à petit la rev1 dans les boutiques. Voir "8- K7S8X/8XE Rev 3".
Attention, le support officiel de la DDR 400 (en asynchrone) est seulement exploitable sur une barette de ram.
-supports 1 DDR400 DIMM, Max. 1GB
-supports 2 DDR333 DIMM, Max. 2GB
-supports 3 DDR266 DIMM, Max. 3GB
NOTE : ça ne veut pas dire que l'on peut mettre qu'une seule barette PC3200, on peut tres bien en mettre 2 et faire tourner a 166Mhz avec des timmings plus agressif.
-Systeme Asrock COP (idem Asus COP), arret du cpu par surchauffe en lisant la sonde interne.
PS : Le controlleur de temperature est d'origine Winbond, et non Asus, ce qui devrait eviter d'afficher n'importe quoi en valeur
La carte dispose d'interface entrée sortie classique :
-AGP 4/8X : ATTENTION, il ne faut surtout pas utiliser de carte AGP 3.3v, sous risque de destruction de la carte mere. Il faut du 1.5V, ce qui est normalement suffisant pour toutes les cartes AGP4X.
Retour en 1999 : l'AGP4x apparait sur le TNT2 chez Nvidia ; le Rage128Pro chez ATi (/!\ car le Rage128 n'est que AGP2x, cf tableau récapitulatif ATi) ; le voodoo4&5 chez 3Dfx ; et le G400 chez Matrox.
Bon de toute façon, si il y a marqué Radeon ou Geforce, ça passe a coup sur
Il semblerait que la Rage 128 Pro ne fonctionne pas sur cette carte mere.
-Keyboard PS2 x1
-Mouse PS2 x1 (à la place du COM2 habituel)
-USB2.0 4 ports (directement sur la carte mere)
-Serial 1
-Parallel 1
-Game/MIDI 1
-LAN 1 x RJ45
-1 IRDA en interne.
-Audio I/O Line In/Line Out/Mic. (5.1 via surcharge de ces ports)
Information :
-> La majorité des bugs constatés sont liés à de la RAM de qualité médiocre. Tout comme l'alim, de préférence, évitez les nomanes.
->La doc est en plusieurs langue dont le Français et, pour une fois bien traduit.
->Si vous ne voulez pas démarrer votre pc au clavier ou a la souris, ce qui évite que le capteur optique reste allumé, il suffit de passé le jumper PS2_USB_PW (en haut a gauche) en position 1-2.
->Le cd avec les drivers contient une vidéo (en anglais) sur le montage des cartes mères, chose amusante, c'est un VCD qui passe dans les platines de salon (tésté sur Memorex 2020).
->Pourquoi il manque des composants sur le PCB ? Il manque les composants pour le port COM2 additionel ainsi que pour 2 Firewire.
->Puis je overclocker ? Oui, mais, la vitesse du PCI et AGP augmentera en meme temp que le FSB. Cependant, il y a des paliers (Choix avec Jumper), a 100, 133 et 166Mhz, les PCI et AGP retrouveront leurs fréquences d'origine. La rev3 offre plus de possibilités d'overcking avec l'hybrid booster.
->Comment forcer le changement de multiplicateur ? avec la rev3, il suffit de ce rendre a la page 14 du manuel http://www.asrock.com.tw/Drivers/M [...] UM_v31.pdf et avec 4 jumpers, on peut changer ce coefficient, si le cpu n'est pas bloqué, bien enttendu.
->Lors du branchement de la mobo et du power led du boitier, si votre boitier dispose d'un connecteur 3 pins (seulement 2 sur l'asrock) il suffit de couper le connecteur en 2 voir ICI
3- Téléchargement
Les Bios : http://www.rhcf.com/sis-bin/ultima [...] 6;t=000002
Driver AGP : http://www.asrock.com/Drivers/SiS% [...] iS-AGP.zip
Driver Audio CMédia : http://www.asrock.com/Drivers/cmedia.zip
Driver Lan : http://www.asrock.com/Drivers/SiS% [...] iS-LAN.zip
Driver USB2 : http://www.asrock.com/Drivers/SiS% [...] SB_2.0.zip
Speedfan 4.09 : http://www.almico.com/speedfan.php
Changer les CAS de latence sous windows : http://www.ocworkbench.com/2003/ch [...] eak005.zip
4- les Tests sur le net
http://www.ocworkbench.com/2003/as [...] llery1.htm
5- et Linux ?
->Pour installer linux il faut désaciver l'IO APIC, en principe en passant la commande noapic au noyau.
Exemple pour installer Debian Woody : bf24 noapic
->Le Sata pour la K7S8Xe+ ?
Le controleur SATA integré à la K7S8XE+ est un SiS, non un Sii, bien qu'ils utilisent sensiblement la meme rom. Il est integré au southbridge SiS964.
La plupart des distribs installent avec un noyau <= 2.6.3, or le support pour ce controleur est apparu avec le 2.6.6.
Le driver est sata_sis, dans la rubrique SCSI et non IDE. Du coup les disques ou aray ne sont pas hd* mais sd*.
->Un exemple de .config pour le kernel : http://chaced.free.fr/debian/K7s8Xconfig
6- A quel prix
Moins de 40?
http://www.monsieurprix.com/listin [...] 50985.html
et même 32? à Montgallet pour la K7S8X, la XE autour de 45? et la XE+ autour de 55? en France. (Sur certains sites allemand, la 8X est à 28? et la XE+ à 46?...)
7- La K7S8XE
http://www.asrockamerica.com/Products/k7s8xe.htm
Elle est strictement identique a la K7S8X mais, dispose du SIS 748 qui ajoute le support officiel du FSB200
un Test en français la : http://www.informanews.net/scripts/article.php?id=78
Elle est dispo ici : http://www.monsieurprix.com/listin [...] 54343.html
8- K7S8X/8XE Rev 3
La révision3 des cartes apporte la même chose sur les 2 :
- une cure d'amégrissement (taille réduite à 30.5x19 cm au lieu de 30.5x24.5 cm). Cela entraine une modification du PCB, des ports IDE et connecteur ATX mieux placés, et 5 PCI au lieu de 6.
- des fonctions d'overclocking avec l'Hybrid Booster:
CPU Multiplier,
CPU Vcore adjustment (+10% ou rien),
CPU Frequency Stepless Control
ASRock U-COP, Boot Failure Guard (B.F.G)
9- La K7s8xe+
http://www.asrock.com.tw/product/product_k7s8xe%2B.htm
C'est une K7S8XE avec 2 ports USB2 en plus (du coup, le game port est déporté sur un bracket) et surtout le SATA :
"Serial ATA - 2x SATA connectors, 1.5Gb/s, RAID 0,1,JBOD, SATA HDD HotPlug"
Le bundle y gagne aussi, avec le Bonus Pack:
- Serial ATA cable x 2
- Serial ATA Y-type power cable x1
- Gameport bracket x1
Disponible ici : http://www.monsieurprix.com/listin [...] 62652.html
10- Résumé
Avant de commander une de ces cartes mères, assurez vous de bien recevoir une révision 3. Voici le rappel des grandes différences avec la KS78X :
La K78XE apporte le support officiel du FSB200 (ou 400 suivant les appélations, le bus EV6+ du K7 étant DDR)
La K78XE+ apporte le FSB200 et offre 2 ports SATA.
Pour mieux choisir entre l'une ou l'autre des versions, regarder le prix, et aussi le coût d'une carte SATA additionnelle (25? la noname raid chez MrPrix, mais pas forcément fournie avec les câbles)
11- Des photos
La K7s8x http://www.asrock.com/product/images/K7S8X-FACE.jpg
La K7s8xe http://www.asrock.com/product/images/K7S8XE-FACE.jpg
La K7s8xe+ http://www.asrock.com/product/imag [...] S-FACE.jpg
Le topic des photos : http://forum.hardware.fr/forum2.ph [...] 2637&cat=1
Message édité par chaced le 13-09-2004 à 22:41:05
CPU-Z | Timespy | Mes bd
