problème de reconnaissance mémoire - votra aide svp - Carte mère - Hardware
Marsh Posté le 05-02-2006 à 04:30:10
bjour , cela peut etre une limitation du chipset .... quel est ton chipset ?
Marsh Posté le 05-02-2006 à 08:40:45
Bonjour, voici la réponse à ta question (en anglais) :
Question
I have install total 4GB memory on my motherboard. However, it can only recognize around 3.1GB or less. My friend's SLI board even less than 3GB. What's up? How should I do to recognize 4GB totally?
Answer
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Windows XP 32-bit version operating system.
If you install Windows XP 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met:
1. The memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture can support the memory swap function.
2. Windows XP Pro X64 Ed. (64-bit) or other OS which can address more than 4GB memory.
En gros il s'agit d'une limitation du chipset.
Marsh Posté le 05-02-2006 à 09:11:13
Menu démarrer>éxécuter>msconfig>boot ini>options avancés>tu coche MAXMEM et tu devrais voir apparaître 3072 >tu entres 4096 >Ok ,appliquer,OK + reboot
Marsh Posté le 05-02-2006 à 14:38:12
j'ai essayé ton aide olioops ,mais ca ne fonctionne pas ,maxmem n'est pas coché ,et quand je le coche ,je peux mettre 2048 au max, il ne me reconnait alors que 2 gigas
personne pour une autre solution ?
Marsh Posté le 06-02-2006 à 20:06:47
Il te suffit d'aller sur le site d'ASUS, rubrique SUPPORT, tu cherches la référence de ta carte mère, il y a une personne qui a posé la même question que toi; et le support a répondu : (cf mon post plus haut ...)
Marsh Posté le 06-02-2006 à 20:37:35
oui surment ta carte mere , essay de voir les caracteristique de ta carte mere sur internet
Marsh Posté le 05-02-2006 à 02:23:07
Bonjour a tous
je viens de me monter une nouvelle machine avec une carte mère asus a8n sli premium ,et j'ai un petit souci de reconnaissance de mes mémoire vives sous xp
j'ai en effet physiquement 4x 1 gigas de marque kinsgtion installés sur le pc (barette testée une par une et certifiées). Le bios au démarage me reconnait bien mes 4 gigas de mémoire , mais windows ne m'en reconnait que 3.
Qq'un peut t'il m'aider svp afin de faire en sorte que toue ma mémoire soit reconnu par mon windows xp pro
merci d'avance a tous pour votre aide
