Nforce 3 [The topic ] Nf3-250 dispo - Carte mère - Hardware
Marsh Posté le 03-05-2004 à 20:59:21
Nf3 250
CPU
Supports 64bit Athlon64(Socket754) processor
Chipset
nVIDIA® nForce3 250Gb
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport @800MHz, running at up to 6400MB/s
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
- Supports six memory banks 266/333/400 DDR, using three 184-pin DDR DIMMs
- Supports a maximum memory size up to 3GB
- Supports 2.5v DDR SDRAM DIMM
Slots
- One AGP (Accelerated Graphics Port) slot
- AGP specification compliant
- Supports AGP 3.0 8x
- Five 32-bit Master PCI Bus slots, one orange slot reserve as communication slot.
- Support 3.3V/5V PCI bus Interface
On-Board IDE
- An IDE controller on the nVIDIA® nForce3 250Gb MCP chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA 66/100/133 operation modes
- Can connect up to 4 IDE devices
NV RAID (Software)
- Support up to 4SATA plus 2 ATA133 Hard drive
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133+SATA H/D or 2 SATA H/D
-- Opt: FIS2R support 4SATA+ IDE w/RAID 0,1,0+1, connect up to 4 SATA and 2 IDE Harddrive
-- Opt: FSR support 2SATA+IDE w/RAID 0,1,0+1, connect up to 2 SATA and 2 IDE Harddrive
USB Interface
- 8 USB ports
- Controlled by nForce3 250Gb
- 4 ports in the rear I/O, 4 ports via the external bracket
Ethernet
- Gigabit Ethernet: IEEE 802.3 NVIDIA MAC for 1000BASE-T/Gigabit/Fast Ethernet/Ethernet
- IEEE 1394: Supports up to 3 * 1394 ports (via external bracket). Transfer rate is up to
400Mbps
Audio Chip integrated (5.1 ch H/W audio)
- Direct Sound AC97 audio
- 8 ch analog output
- Digital SPDIF out signal through META I/O
On-Board Peripherals
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port (COMA )
- 1 parallel port supporting SPP/EPP/ECP mode
- 1 IrDA connector for SIR/ASKIR/HPSIR
- 1 Audio jack(5-in-1), coaxial/fibre SPDIF out
- 1 D-Bracket2 pinheader
- 3 IEEE1394a
- On-Board 10/100 Ethernet
Image en gros plan :
http://www.tbreak.com/forums/attac [...] entid=9134
Test de la carte : http://www.hardocp.com/article.html?art=NjA3
http://www.msicomputer.com/product [...] m&class=mb
Un test d'Hardocp :
Home theatre sound with professional-grade storage
This Athlon 64, nForce 3 motherboard distinguished itself from other solutions of the same
platform by adopting the best features to date. Just name it: 8-channel audio, 6 Serial ATA,
intelligent features for BIOS and audio setup, and a full lineup of unique and innovative
designs.
AMD Athlon 64 Processor
The AMD Athlon 64 processor is based on AMD64 technology, which represents the landmark
introduction of the industry's first x86-64 technology. This next-generation processor
provides a dramatic leap forward in compatibility, performance, investment protection, and
reduced total cost of ownership and development. AMD Cool 'n' Quiet technology enables
processor frequency and voltage switching to reduce power and fan speed."
6 Serial ATA ports
K8N-E Deluxe integrates 6 Serial ATA ports for your storage needs. Serial ATA is the next
generation ATA specification that provides scalable performance for today and tomorrow. With
up to 150MB/s data transfer rate, Serial ATA is faster than current Parallel ATA, while
providing 100% software compatibility.
Dual RAID
The nForce3 250Gb chipset incorporated two Serial ATA and two parallel connectors with
RAID 0, RAID 1, RAID 0+1 and JBOD functions while the Silicon Image controller provides
another four Serial ATA connectors for RAID 0, RAID 1, RAID 0+1, RAID 5, and JBOD functions.
The K8N-E Deluxe is the ideal solution to enhance hard disk performance and data back up
protection without the cost of add-on cards.
AI Audio (8-channel Audio)
The ALC850 has eight channels of 16-Bit DAC, a stereo 16-Bit ADC, and an AC97 2.3
compatible multi-channel audio designed for PC multimedia systems. The CODEC can also
automatically detect and identify what types of peripherals are plugged into the audio I/O
jacks and notifies users of inappropriate connection. No more confusion of Line-in, Line-out
and Mic jacks.
IEEE 1394 interface
IEEE 1394 interface provides high speed digital interface for audio/video appliances such
as digital television, digital video camcorders, storage peripherals & other PC portable
devices.
ASUS AI BIOS
CrashFree BIOS2
Whenever BIOS gets corrupted, ASUS CrashFree BIOS 2 allows users to reboot the computer
and perform an smart auto-recovery procedure through the motherboard support CD.
Q-fan 2
A voice warning design during POST notifies users of any system errors, which means no
more complicated LED messages!
PostRepoter
This unique technology intelligently and automatically adjusts CPU and Chassis fan speeds
according to system load and temperature, enabling users to work in a distraction-free
environment with minimal noise.
AI Overclocking
ASUS K8N-E Deluxe offers robust overclocking options to maximize your system performance.
-- SFS (Stepless Frequency Selection) from 200MHz up to 250MHz at 1MHz increment
-- CPU, Memory and AGP voltage adjustable
-- ASUS C.P.R.(CPU Parameter Recall)
ASUS MyLogo2
You can convert your favorite photo into a 256-color boot logo for a more colorful and
vivid image on your screen.
Multi-language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy
as possible.
Instant music
Through this unique feature, K8N-E Deluxe is conveniently designed to allow users to enjoy
their favorite music without the need to enter Windows.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more
DOS-based flash utility and bootable diskette required.
When the system hangs due to overclocking failure, there is no need to open the case to
clear the CMOS data. Just simply restart the system, the BIOS would show the previous setting
and then users can amend the CPU setting again.
8 USB 2.0 ports support
USB 2.0 is the latest connectivity standard for next generation components and
peripherals. Backward compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer
speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
http://usa.asus.com/products/mb/so [...] rview.htm#
DISPO : http://www.materiel.net/details.ph [...] GA-K8NSNXP
http://www.giga-byte.com/MotherBoa [...] NSNXP.htm#
Chipset
1. NVIDIA nForce3 250 Platform Processor
2. Super I/O: ITE IT8712F chip
3. Integrated peripherials
1. Silicon Image sil3512 controller
2. GigaRAID ATA 133 RAID controller
3. T.I. IEEE1394b controller
4. Marvell 8001 Gigabit Ethernet controller
5. ICS 1883 LAN PHY chip
6. Realtek ALC850 Audio AC'97 Codec Memory
1. Type: DDR400/ 333/ 266- 184pin
2. Max capacity: Up to 3GB by 3 DIMM slots
Internal I/O Connectors
1. 4 x Serial ATA connector
2. 4 x UDMA ATA 133/100/66 Bus Master IDE connectors
3. 1 x FDD connector
4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
5. 2 x IEEE 1394b connectors (supports 3 ports)
6. S/P DIF input/output pin header
7. 3 x cooling fan pin headers
8. CD/AUX in
9. 1 x Game/Midi connector
Expansion Slots
1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
2. 5 x PCI slots (PCI 2.3 compliant)
3. 1 x DPS slots
Rear Panel I/O
1. PS/2 Keyboard / Mouse
2. 2 x USB 2.0/1.1 ports
3. 2 x RJ45 ports
4. 2 x COM ports
5. 1 x LPT
6. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
1. CPU FSB / Multiplier / Vcore Voltage adjustable via BIOS
2. AGP Voltage / Clock adjustable via BIOS
3. DIMM Voltage / Clock adjustable via BIOS Power
1. ATX power connector and ATX 12V connector
2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
http://www.giga-byte.com/MotherBoa [...] 8NSNXP.htm
DISPO : http://www.docmicro.com/pieces/des [...] piece=4277
For Socket-754 based AMD Athlon 64 processors
nVidia nForce3 250GB Host Controller
1 Floppy drive controller - 2 serial ports - 1 parallel port
AGP 8x for 1.5v graphics cards, 6 PCI slots
2 standard IDE ports for ATA-133, backwards compatible with ATA-100/66
2 S-ATA ports from onboard nVidia host controller with RAID
nVRAID for combined P-ATA and S-ATA RAID
4 extra S-ATA ports from Silicon Image Sil-3114 controller with RAID 0,1,and 10
(only on 8KDA3+)
3 DDR SDRAM banks for Maximum 3 GB memory DDR333/400
4 USB 2.0 ports, 4 extra by optional USB back-panel cables
Multiphase power solution for increased stability, including 12v supply adaptation for CPU
8 channel Onboard sound from Realtek ALC850 Audio with Digital SPDIF and Automatic Jack
Sensing feature (8KDA3+ adds optical output)
On-chip Gigabit Ethernet 1000Mbps providing faster throughput than standard PCI Gigabit
chips
Hardware Firewall for internet protection against hackers
Onboard P80P diagnostics LED
Standard ATX format 305mm x 245mm x 40mm, ATX S
Form Factor
* ATX(305mm x 244mm)
CPU
* Supports the new generation of AMD Socket754 Athlon 64 CPU
* Processor interface via 6.4GB/s Hyper Transport bus
Chipset
* NVIDIA nForce3 250
Main Memory
* Three 184-pin DDR DIMMs up to 2GB
* Supports DDR266/333/400 modules
Expansion Slots
* One AGP slot for both 4X/8X AGP
* Five 32-Bit PCI slots (v2.2 compatible)
* One CMR(Chaintech Mulmedia Riser) for Chaintech Multimedia Card (CMC7.1)
Audio Subsystem
* 24bit resolution audio format support
* 7.1 Channel speaker audio supports
* Sampling rates up to 96KHz
* Multi-channel AC-link supported alternatively
* Support S/PDIF out
Video Subsystem
* 4X/8X AGP
UltraDMA IDE Ports
* Build-in nForce3 250 supports 2 ATA66/100/133 IDE ports
FDD
* One FDD connector supports up to 2.88MB
Embedded USB Controller
* Build-in nForce3 250 supports total 6 USB2.0 ports with High-Speed Device@480 Mb/s
Transfer Rate
Embedded system monitoring
* 2 temperature sensing for CPU and system
* 3 Fan speed monitoring (CPU, system and Chipset)
http://www.chaintechusa.com/tw/eng [...] &PISNo=266
- Chipset Nforce3-250
- Compatible processeur AMD 64 Socket-754
- DDR 200/266/333/400 jusqu'à 2Go
- Puce audio CMEDIA 9761A avec SPDIF : 5.1 canaux
- 8 ports USB 2.0
- 2 IDE UltraDMA 100/133
- 2 S-ATA 150 RAID NVIDIA
- 1 slot AGP 8x/4x
- 5 slots PCI
- 1 slot CMR
- 1 connecteur LAN : 10/100
- Livré avec le value pack 2003 : Norton Antivirus, ProMagic, Image It et le logiciel de monitoring DIGIDOC
nF3 250Gb INFINITY with nVidias latest nForce3 250Gb chipset for AMD Athlon 64 754-pin CPU.
nForce3-250Gb
AMD Athlon64 754pin
1xHyper Transport 1600MHz
3 DDR, DDR400, 5 PCI, 1 AGP-8X
8ch AC'97
2 PATA-133 + 4 SATA RAID 0/1/0+1/JBOD
Marvell 88E1111 Gigabit PHY
2 Ports
(1 Rear+ 1 Optional)
8 USB 2.0
(4 Rear+ 4 Optional)
ATX 305x245
http://www.tbreak.com/forums/showthread.php?p=221625
Article sur le shuttle :
http://www.clubic.com/ar/2391-1.html
Computex 2003 nForce3
http://www.nforcershq.com/forum/viewtopic.php?t=31835
Marsh Posté le 03-05-2004 à 21:31:21
des que le Nforce 3 250GB va sortir ainsi que les cpu socket 939, ca va etre une merveille
Marsh Posté le 03-05-2004 à 21:33:35
la grosse différnce est surtout que le nforce 3 250 gère le dual DDR et pas le 150 ![]()
Marsh Posté le 03-05-2004 à 21:34:49
bon je suis un peu casse de ma journee, j'ai decide presque sur un coup de tete de faire ca alors c très incomplet. Je vais m'y mettre plus mardi et mercredi, mais j'attends votre aide.
Marsh Posté le 03-05-2004 à 21:36:34
pour mon aide regarde le post précédent ![]()
Marsh Posté le 03-05-2004 à 21:38:41
eh eh pas mal, mais on va essayer de faire un peu plus exhaustif ! Avec ton aide j'en suis sur...
Marsh Posté le 03-05-2004 à 21:41:37
bin je pourrais pas t'aider beaucoup plus
je me suis pas trop tenu au courant ![]()
Marsh Posté le 03-05-2004 à 21:46:32
On sait jamais si tu achetes le Nf3, si tu tombes sur un info, bref, c'est pour (presque) tout le monde comme ça. Autrement tant pis
Marsh Posté le 07-05-2004 à 20:25:16
Un petit comparatif :
Xbitlabs a comparé 4 chipsets pour Athlon64 avec les cartes mères suivantes :
- Chaintech Zenith ZNF3-250 (nForce3 250)
- Chaintech Zenith ZNF3-150 (nForce3 150)
- ABIT KV8-MAX3 (VIA K8T800)
- ECS 755-A2 (SiS755)
http://www.xbitlabs.com/articles/c [...] 3-250.html
Marsh Posté le 11-05-2004 à 17:38:40
merci pour le up je fais pas ça pour moi tout seul au moins ![]()
Marsh Posté le 11-05-2004 à 17:56:38
| sylbuzz a écrit : la grosse différnce est surtout que le nforce 3 250 gère le dual DDR et pas le 150 |
c'est pas le chipset qui gere le dual mais le proc ! et ce sont les FX et les futur A64 socket 939 qui le gerent
edit: -> Trajan : j'ai remarque ds les caract des mobos une erreur
pour l'asus SK8N y a pas de southbridge et encore moins de Via sur une mobo ac chip nvidia
Marsh Posté le 11-05-2004 à 18:02:13
le NF2 est déja pas stable et y en a ki vont se geter sur le nf3 ![]()
Marsh Posté le 11-05-2004 à 18:33:29
Dj-Brabus merci bien je regarde ca.
ps MickeyNox pour les trolls trouve une autre poire, j'ai pas de temps a perdre.
Marsh Posté le 13-05-2004 à 21:07:52
Petite question j'ai pas vu de date sur le site n'y ici j'aimerais savoir quand les premieres mobo avec chipsets nforce 3 sont prévues.
Marsh Posté le 13-05-2004 à 21:14:50
Y'a un Nfroce 3 prévu avec CG intégré... parce que j'mattais ca pour changermaCM et ma CG en même temps... (Vieille TI 4200)
Marsh Posté le 13-05-2004 à 21:21:09
ouais mais faut voir ce qu'elle vaut la cg.
Sinon je suppose qu'on peut en mettre une autre à la place ?
Marsh Posté le 13-05-2004 à 22:12:31
Les cartes a base de Nf3 sont dispo depuis un moment, malheureusement c'est le Nf3-150, pour le Nf3-250 c'est prevu pour fin du mois pour certaines, mais la chaintech est sortie en théorie. Pour ce qui est du chip graphique intégré, je sais pas quand vont sortir ces modèles là. Tous les modèles que j'ai trouvé en sont dépourvus ce me semble...
Marsh Posté le 13-05-2004 à 22:46:58
Pour les premieres cartes dispo :
Chaintech ZNF3-250 199 et VNF3-250 109.
Marsh Posté le 14-05-2004 à 11:50:27
LA différence de prix est allucinante pour deux model à 250Go! lol
Marsh Posté le 14-05-2004 à 13:28:34
| Trajan a écrit : Pour les premieres cartes dispo : |
La ZNF3 c'est pas un chipset 150 pro qu'elle a ?
Sinon je comptais me racheter une config debut juillet et je comptais sur le nf3 250Gb donc je voulais savoir si d'ici la y aura des cartes interessantes rapport qualité/prix.
Marsh Posté le 14-05-2004 à 18:16:34
C'est bien du Nf3-250 d'après ce que j'ai trouvé. Sinon, les cartes sortent progressivement, je pense que pour juillet c'est un peu juste...je pense pas que toutes les cartes seront sorties. Il faut savoir ce que tu veux, la chaintech a l'air sympa, mais perso je suis plus pour Asus. Je pense faire evoluer mon matos en septembre, d'ici là j'espère que le panel de cartes sorties sera plus large.
Marsh Posté le 16-05-2004 à 09:59:13
La solution raid Nforce 3 meilleure solution raid selon Tweaktown
http://www.tweaktown.com/document. [...] 3&dPage=11
Marsh Posté le 28-05-2004 à 18:57:47
| kalys- a écrit : La ZNF3 c'est pas un chipset 150 pro qu'elle a ? |
Ben je viens de recevoir la mienne et le chipset est bien un 250.
Installation assez facile sauf la cbox.. Les nappes IDE sont ronde, c'est joli, on se dit que ca va faire propre, mais avec tous les fils de la cbox, c'est le bordel avant la fin...
Sinon, avec l'AMD64 3000+, le couple à l'air de bien s'attendre. Le ventilo standard est assez silencieux, mais Chaintech à ajouté un ventilo pour les composants de la carte mère plutot bruyant... Dommage
Marsh Posté le 29-05-2004 à 20:52:45
COmme tu dis dommage pour le bruit. Pour le firewall ca se passe comment ?
Marsh Posté le 29-05-2004 à 21:11:09
ouais dis nous tout
Sinon j'ai vu la Asus SK8N
elle est bien ?
qqun la testée ?
Marsh Posté le 29-05-2004 à 21:37:15
ReplyMarsh Posté le 29-05-2004 à 22:01:26
les connecteurs SATA sont vraiment mal placés sur certaines cartes mere ![]()
Marsh Posté le 30-05-2004 à 16:49:18
| Trajan a écrit : COmme tu dis dommage pour le bruit. Pour le firewall ca se passe comment ? |
Ben pour le bruit j'ai viré completement le radex... Enfin je crois que ca s'appele comme ca!!
Le FW je l'ai pas testé..
Marsh Posté le 30-05-2004 à 20:36:58
Je vais peut etre changer de PC (ca depend de mon boulot et de ma presence en france
Je possede actuellement une A7N8X avec un XP 2400+ et une R9800Pro, le tout avec 2 barettes de 512Mo Samsung.
J'ai acheté ca, y a pas loin de 2 ans maintenant (sauf la CG, c'etait il y a un an).
Je me demandais si ca valais le coup de passer en Athlon 64?
Quid des problemes de compatibilités avec les cartes graphique? (j'ai des soucis avec mon ASUS et ma R9800Pro cf: http://forum.hardware.fr/forum2.ph [...] =0&subcat= ).
Je me penchais vers une MSI K8N Neo Platinum et un Athlon 64 3200+ ou 3400+.
La plateforme Athlon64+nforce vaut elle le coup? (du point de vu utilisateur et non pas benchmark pur)
Je ne suis pas un partisan nVidia (je suis même un taliban Ati depuis 10 ans) mais le chipset (nforce2 principalement) a fait remonter cette societe dans mon estime. Je me demandais si c'etait pareil pour l'athlon 64
Marsh Posté le 31-05-2004 à 17:30:24
Pour voir si ca vaut le coup, ca depends de ce que tu lui demande!!!
J'avais une Nforce 2 avant, maintenant Nforce 3. Et j'en suis plutot satisfait...
Marsh Posté le 31-05-2004 à 18:27:58
J'ai regardé les specs de la Chaintech ZNF3-250
Or sur leur site (bien lent d'ailleurs) j'ai vu que le contrôleur RAID était pas celui du NF3
. Il en ont rajouté un autre le Sli3114 SATA RAID.
Quelqu'un peut il confirmer si il possède cette carte. Peut-on utiliser celui du NF3 quand même ?
C'est quand même con.
http://www.chaintech.com.tw/tw/eng [...] &PISNo=266
Marsh Posté le 31-05-2004 à 18:53:51
J'utilise bien le Sli3114 Raid...
Les options Bios pour celui intégré dans NF3 ne sont pas présentes... Mais c'est pas grave
Marsh Posté le 31-05-2004 à 19:33:47
Ben un peu si, le raid nvidia est cense etre plus performant...il va en outre equiper les nouveaux chipsets Nforce 2 ultra 400 nouvelle version d'ici peu.
Marsh Posté le 03-05-2004 à 20:59:09
Support du nForce 3 dans les drivers Nvidia Linux
Ati a mis à jour avant-hier en version 3.9.0 les drivers destinés à Linux pour ses chipsets 3D Radeon. Aujourd'hui, c'est Nvidia qui met à jour les drivers Linux pour ses chipsets nForce. Ces nouveaux drivers Nvidia en version 1.0-0274 et 1.0-0275 sont destinés aux distributions 32 bit et 64 bit de Linux et ont comme principale nouveauté le support des chipsets nForce 3. En effet, seuls les chipsets nForce 1 et nForce 2 étaint jusqu'à présent supportés. Les autres nouveautés intéressantes sont l'ajout d'un panneau de configuration pour gérer les fonctionnalités audio, la correction d'un bug avec le pilote réseau et enfin, le support de l'architecture 64 bit d'Intel (x86-64) et plus seulement de l'architecture 64 bit d'Amd (AMD64).
http://www.touslesdrivers.com/inde [...] _code=1451
Les premières cartes NF 250 disponibles :
http://www.pcinpact.com/actu/news/14167.htm
http://www.nvidia.fr/page/nf3.html
le nVidia a frappé fort avec la solution native. Il est rapide et combiné avec les disques SATA les plus rapides sur le marché que vous allez avoir un des ordinateur les plus rapide en performances disques. Les autres controleurs ne sont pas mauvais, c'est juste qu'ils sont ont laissé en arrière par le manque de largeur de bande disponible par le bus PCI vieillissant.
source : http://www.tweaktown.com/document. [...] 3&dPage=11
La satisfaction des utilisateurs dordinateurs de bureau en environnement professionnel dépend
toujours plus des performances globales des systèmes, dun débit réseau élevé et de fonctions
de streaming et multimédia variées.
»more information
Les processeurs MCP (Media and Communications Processors) NVIDIA nForce3 apportent aux
ordinateurs professionnels, portables et de bureau des technologies de pointe et des
performances inégalées.
»more information
Interface bus I/O AMD à la pointe du progrès qui fournit le meilleur débit
continu800MO/sentre les processeurs de la plate-forme NVIDIA. Il garantit lacheminement le
plus rapide qui soit des données et informations à travers le système.
Assure une expérience immédiate exceptionnelle pour tous les utilisateurs en fournissant les
fonctions les plus perfectionnées du secteur dans le domaine du graphisme, du son, de la
vidéo, de la communication, du stockage et de la sécurité. Un même pilote pour tous les
produits : performances et fonctions bénéficient ainsi de mises à jour pendant toute la durée
de vie du produit.
Cette technologie de stockage de la prochaine génération permet de disposer de disques durs
faciles à installer, extrêmement performants et peu gourmands côté consommation.
Gigabit Ethernet NVIDIA
La meilleure performance Gigabit Ethernet du secteur, élimine les goulets détranglement et
améliore lefficacité et la performance générales du système.
Véritable pare-feu haute performance de niveau réseau, NVIDIA Firewall protège votre PC contre
les intrusions en filtrant le trafic non-autorisé. Intégré dans les MCP NVIDIA nForce3 avec
NVIDIA Gigabit Ethernet, ce produit offre des fonctions dinspection de trafic
professionnelles ainsi que des fonctions de gestion avancées (configuration, monitorage et
accès à distance) faciles à utiliser et à configurer grâce à lassistant convivial fourni.
La technologie réseau de NVIDIA fournit un débit optimal pour les transferts sur le réseau
tout en minimisant lutilisation de lUC. Facile à gérer et stable, la solution
dinterconnexion de NVIDIA débouche sur une performance réseau améliorée et des frais de
propriété généraux réduits.
Un comparatif :
Un test Nf3 sur clubic :
http://www.clubic.com/ar/2746-1.html
Un test Nf3 Hfr :
http://www.hardware.fr/articles/490/page1.html
Fiche produit Nforce 3 :
http://www.nvidia.fr/object/PO_nf3_fr.html
Nf3 150
# Format ATX
# Socket 940
# Chipset nVidia nForce3 Pro-150
# Bus 800 Mhz
# Chipset audio Realtek ALC650 - 5.1
# Contrôleur USB 2.0
# Contrôleur Firewire
# Contrôleur LAN Realtek 8201
# Contrôleur Promise 20378
# 4 supports DIMM 184 broches
# Compatible DRAM DDR PC2700
# Capacité Max 8 Gb
# BIOS Jumperless
# 5 slots PCI 32-bit
# 1 slot AGP 8X
# 3 connecteurs double canaux UltraDMA/133
# 2 connecteurs SerialATA/150 compatible Raid
# 1 connecteur floppy 1.2 / 1.44 Mo
# 1 port parallèle EPP / ECP
# 1 port série 16550 UART
# 1 port clavier mini-DIN
# 1 port souris mini-DIN
# 1 port audio AC'97
# 2 ports réseau RJ45
# 1 port Firewire
# 1 port SPDIF
# 4 ports USB 2.0
# Garantie 3 ans
# Format ATX
# Socket 754
# Chipset nVidia nForce3-150
# Bus 800 Mhz
# Chipset audio Via Envy-24
# Contrôleur Firewire VIA VT6306
# Contrôleur LAN Gigabit Broadcom GbE
# Contrôleur Raid Silicon Image Sil3114
# 3 supports DIMM 184 broches
# Compatible DRAM DDR PC3200
# Capacité Max 3 Gb
# BIOS Jumperless
# 1 slot AGP 8X
# 1 slot CMR
# 4 connecteurs SerialATA/150 compatible Raid 0,1,5,10
# 2 ports série 16550 UART
# 1 port réseau RJ45
# 4 ports USB 2.0
# Garantie 2 ans
# Format ATX
# Socket 754
# Bus 800 Mhz
# Chipset audio Realtek ALC658 - 5.1
# Contrôleur LAN Gigabit Realtek 8110S
# Contrôleur Raid Silicon Image sil3512
# Capacité Max 3 Gb
# BIOS Jumperless
# 1 slot AGP 8X
# 2 connecteurs double canaux UltraDMA/133
# 2 connecteurs double canaux UltraDMA/133 Compatible Raid
# 4 ports USB 2.0
# Garantie 2 ans
# Format ATX
# Socket 754
# Bus 800 Mhz
# Contrôleur LAN 10/100 Realtek 8201
# Contrôleur Silicon Image sil3512
# Contrôleur GigaRAID ATA133
# Capacité Max 3 Gb
# BIOS Jumperless
# 1 slot AGP 8X
# 4 connecteurs double canaux UltraDMA/133
# 1 port SPDIF
# 4 ports USB 2.0
# Garantie 2 ans
# Format ATX
# Socket 940
# Bus 800 Mhz
# Capacité Max 3 Gb
# BIOS Jumperless
# 1 slot AGP 8X
# 1 port SPDIF
# 4 ports USB 2.0
# Garantie 2 ans
Message édité par trajan le 13-06-2004 à 18:32:48
