Infos CG - Carte mère - Hardware
Marsh Posté le 28-11-2005 à 21:23:35
Features
    * m-ATX Form Factor with PC99 color connector
    * Support Accelerated Graphic Port (AGP) Add-On Card
    * Support AMD ® PGA Socket A Duron/Athlon  processors at 200/266MHz System Bus Frequencies
    * Chip Integrated Audio
    * PC Alert System Hardware Monitor
    * Support DMI (Desktop Management Interface) through BIOS
    * LAN Wake Up Function
    * Modem (Internal/External) Ring Wake Up Function
    * Support PCI 2.2
    * Suspend to RAM/Disk
Specifications
CPU
    * Socket A for AMD ® Duron/Athlon processor
    * Support 600MHz up to 1.5GHz processor
Chipset
    * VIA ® VT8366 chipset. (552 BGA)
      » FSB @200/266MHz
      » AGP 4x and high bandwidth Vlink host controller
      » Advanced ECC memory controller support PC100/133 SDRAM and PC200/266 DDR technology
    * VIA ® VT8233 chipset. (376 BGA)
      » High bandwidth Vlink client controller
      » Integrated faster Ethernet controller
      » Direct sound ready AC97 digital audio controller
      » Ultra DMA 33/66/100 master mode EIDE controller
      » Support both ACPI and legacy APM power management
Clock Generator : 100MHz/133MHz clocks are supported
Main Memory
    * Support four memory banks using two 184-pin DDR DIMM
    * Support a maximum memory size of 2GB
    * Support 2.5v SDRAM DIMM
Slots
    * One (Accelerated Graphics Port) AGP slot
      » AGP specification compliant
      » Support AGP 2.0 1x/2x/4x
    * One CNR (Communication Network Riser) slot
    * Three 32-bit Master PCI Bus slots
    * Supports 3.3v/5v PCI bus Interface
On-Board IDE
    * Dual Channel master mode IDE controller on the VIA ® VT8233 Chipset provides
    * IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 33/66/100 operation modes
    * Can connect up to four IDE devices
Audio : Chip Integrated
             » Direct Sound AC97 Audio
ON-Board Peripherals
    * 1 floppy port supports 2 FDD with 360K, 720K, 1.2M,1.44M and 2.88Mbytes
    * 2 serial ports (COMA + COM B)
    * 1 parallel port supports SPP/EPP/ECP mode
    * 6 USB ports (2 Rear Connectors/ 2 USB Front Pin Headers -4 ports)
    * 1 IrDA connector for SIR/CIR/ASKIR/HPSIR
    * 1 Audio/Game port
BIOS
    * The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
    * The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Dimension : ATX Form Factor: 24.3cm x 23.4cm
Mounting : 6 mounting holes
PS :
- CG = Carte Graphique
- CM = Carte mère
Le speaker se branche en bas a droite de la carte, c'est indiqué dessus normalement, jete un oeil
Marsh Posté le 28-11-2005 à 21:29:26
Le speaker comporte 4 tiges , et je ne vois a aucun endroit 4 tiges sur la carte mére.....
Marsh Posté le 28-11-2005 à 21:34:39
normalement il se branche a l'endroit ou tu branches les led power, hdd, ainsi que le bouton power et reset, il doit resté de la place
Marsh Posté le 28-11-2005 à 22:36:21
Petite question , n'y a t-il pas de risque a faire tourner une alim sans carte mére , juste en shuntant les pins???
Marsh Posté le 03-12-2005 à 03:28:52
Autre question....comment connaitre le socket de son processeur ???*
Marsh Posté le 03-12-2005 à 04:03:46
| Citation : Autre question....comment connaitre le socket de son processeur ???* |
sur le cpu,il y a son nom..c'est comme ça qu'on sait sur quel socket il va
Marsh Posté le 04-12-2005 à 02:23:41
J'ai regardé et j'ai rien trouvé.
sinon mon processeur est amd athlon 2000 si ca peut aider
Marsh Posté le 04-12-2005 à 14:20:08
y-t-il un chiffre qui corresponde au socket a , par excemple 462 .
Marsh Posté le 04-12-2005 à 19:50:14
Il faut donc que j'achete forcement une carte mére socket a ( ou 462 )
Marsh Posté le 04-12-2005 à 19:53:31
ou que t'achète un athlon 64 dual core sur socket 939 avec une nouvelle carte graphique (pci-e)
Marsh Posté le 04-12-2005 à 20:05:30
euh....non lol ! de toute facon je veux juste refaire ce pc pour pouvoir a counter strike, jeu qui ne demande pas beaucoup et surfer sans probleme sur le net !
Et le 939 , c le C ?
je m'informe un peu car j'en ai marre de rien comprendre
Marsh Posté le 05-12-2005 à 20:34:09
Comment savoir si j'ai une agp 8x ou 4x ?? comment connaitre son voltage , 3.3 v , 1.5v ?? ps: c'est une radeon 9000
Marsh Posté le 05-12-2005 à 21:14:52
la 9000 (direct x 8.1?) est en agp 8x..mais "backward" compatible avec les cartes mère agp 4x..en gros,si tu met une carte 3d agp 8x sur une carte mère agp 4x,tu vas perdre environ 3-5% en performance..mais vu la marde qu'est la radeon 90..ça changera rien
et c'est du .8v (compatible 1.5v)
Marsh Posté le 05-12-2005 à 21:26:25
Oki, merci!
Ca fait un peu bouillit comme topic mais je pose totut ici pour ne pas encombrer de trop le site....
Qu'est ce qui vaut environ le meme prix pour les memes "performances" qu'une k7s8xe ???
ou peut-on acheter du bon matos informatique sans soucis et a des prix plutot "bas"
Marsh Posté le 05-12-2005 à 21:35:36
une a7n8x non deluxe (ou la a7n8x-x mais sans dual channel)
et pour ce qui est du "matos"..j'habite au québec donc..ça va être dur de répondre
Marsh Posté le 05-12-2005 à 21:48:40
rien d'autre ?
De tte facon je pense qu'une carte a 35£ ~ suffit puisque c'est juste pour counter strike + le net ! je remet sur pied ce pc juste pour dire de rentabiliser mes neons + tour tuning.
Marsh Posté le 28-11-2005 à 21:03:56
Lu tous ....
Je cherche un recapitulatif de cette carte , car j'ai perdu le manuel et j'aimerais avoir des infos : nombres de bip tt ca quoi, ma carte :MSI ms 6382 version 2
Merci Beaucoup
