Flash... comment? - Carte mère - Hardware
Marsh Posté le 14-05-2003 à 17:47:09
salut
j'avais pigé ca
mais c'est cette partie:
<command> function definition:
cc: clear CMOS; cp: clear PnP;
cd: clear DMI.
/sn: No Original BIOS Backup. If this option is chosen:
Be sure your new BIOS is compatible with your MB. If not, the system
are damaged.
/sy: Backup Original BIOS to Disk File.
Examples:
AWDFLASH ****.BIN /py/sn/cd/cp
fo ke je tape koi??
Marsh Posté le 14-05-2003 à 18:04:20
rien, c'est pour eviter qu'il te pose des questions avant le flashage. tapes simplement "AWDFLASH KD7_V38.BIN" et ca ira tres bien
Marsh Posté le 14-05-2003 à 17:25:36
salut
S"
je veux flasher mon bios pour qu'un Xp 2000 soit reconnu
voila le liser moi du zip contenant les fichiers pour le flash
je pige pas tout...
K7V8366A KuDoz 7 BIOS V3.8LCP release note
This disk contains three files:KD7_V38.BIN,README.TXT and AWDFLASH.EXE
1.The checksum of KD7_V38.BIN is 7C66(Hex);
2. How to use AWDFLASH.EXE utility:
This is a flash memory write/read utility.
IMPORTANT NOTE:
The AWDFLASH utility could not correctly run in windows (virtual 8086)
MS-DOS mode. It must be proceeded with the following steps:
1.Create a bootable system floppy diskette by typing "FORMAT A
from the dos prompt under DOS6.XX or WINDOWS9X environment.
2.Boot system with diskette.
3.Then run the AWDFLASH utility.
Usage:
AWDFLASH [BIOSfile1] [BIOSfile2] [/<sw>[/<sw>...]]
BIOSfile1: New BIOS Name For FLASH Programming
BIOSfile2: BIOS File For Backing-up the Original BIOS
cd: clear DMI.
are damaged.
Examples:
Warning:
Avoid power-off incidently in upgrading procedure, or system would fail
to reboot!
UPDATE DATE:03/27/2003
en gros une fois sous DOS on fait koi? on tape koi?
