Comment puis je savoir - Carte mère - Hardware
Marsh Posté le 15-10-2002 à 23:47:41
Relève des numéros que tu trouves quelque part sur la CM, n'importe ou, et passe à la moulinette google ... ? ?
A+ Nrv ![]()
Marsh Posté le 15-10-2002 à 23:48:32
Jetway...
Hop:
993-AN (VIA Slot1 + Socket 370)
 FEATURES
 Support Intel Pentium II / III And CeleronTM Slot 1 PPGA / FCPGA Processor
 Support Socket 370 For Intel CeleronTM PPGA / FCPGA Processor
 VIA 82C693A , 82C596B APOLLO Pro -133 AGPset
 Support 66/75/83/100/112/124/133/150 MHz Bus Frequency For CPU Host Clock
 Support Ultra DMA 66 Mode
 Support 3 Banks of DRAM From 8Mbyte to 1.5GByte Main Memory
 PC'99 Ready & PC'99 Colorful I/O Ports Design
 Support USB Controller & PS/2 Mouse , Standard IR (infrared) Functio
 Provide extra " three-wire" fans connectors
 Y2K Compliant
 ACPI Supporting For OS Directed Power Management
 Moden Ring remote wake up
Power Button Ride (Instant off or Delay 4 second power off)
RTC alarm wake up
Wake on LAN For OS
Support software suspend & power off (Windows 95 or Windows98)
SPECIFICATION
 Processor
 Intel PentiumÒ II / III , CeleronTM Slot1 Processor Optimized For 100 / 133 MHz FSB
Socket 370 For Intel CeleronTM PPGA Processor
Can't Use Slot1 And Socket 370 Processor Together
 Chipset
 VIA 82C693A / 82C596B APOLLO Pro -133 Chipset
 CPU Bus Frequency
 Support Jumper Select 66.7/100/133 MHZ CPU Bus Frequency Default Selection
CPU Bus Frequency , Choose 66 / 75 / 83 / 100 / 103 / 112 / 124 / 133 /150 MHZ
in BIOS Setup
DIP Switch Selection CPU Ratio From 2X to 8X
 AGP SLOT
 Support AGP VGA Card for 533Mbytes/sec data transfer rate and 66MHz Bus clock
improve graphic function
 Expansion Slot
 Four 32-bit PCI Bus Master Slots
One AMR (Audio/Modem Riser) Slot
 System Memory
 Support 3 Banks of SDRAM From 8MByte to 1.5GByte
3 X 168-pins DIMM Scockets (3.3V)
Support EDO (66MHz Only) & SDRAM (66MHz/100MHz/133MHz)
Support ECC or Parity Check
 On Board IDE
 Support 2 X IDE Connectors for up to 4 IDE Drives
Support PIO Mode 3 and Mode 4 and Bus Master IDE DMA, Mode 4 Timing for
up to 16M Bytes/s
Support " Ultra DMA 66 " Synchronous DMA Mode transfer rate up to 66M Bytes/s
Support LS-120 / ZIP Device
 On Board Ultra I/O
2 X USB Connectors
1 X Standard IR Connector (SIR)
2 X Serial Ports (16550 Fast UART Compatible)
1 X Parallel Port (EPP and ECP Capabilities)
1 X Floppy Disk Connector (Supports 2 Floppy Drives)
1 X PS2 Mouse / PS2 Keyboard Connector
2 X Three Wire FAN Connector (Include CPU FAN)
 On Board USB
 2 X USB Ports Connector
Support USB Keyboard & USB Mouse
 Power Saving
 ACPI/APM Power Management
Modem Ring Remote Wake up
RTC Alarm Wake up
Support Software Suspend & Power off (Windows 95/98)
Wake on LAN For OS
Support Power Button Ride (Instant off or Delay 4 second power off)
 Power Supply
 Support 20-pin ATX power supply (ATX-PW)
 BIOS
 Award BIOS , Support DMI , Green , P&P Function
2MByte Flash ROM
Support Full Screen Logo
 Dimension
 ATX Form Factor with 30.5cm X 19cm
Marsh Posté le 15-10-2002 à 23:48:52
c'est fait, c'est la première chose que j'ai fait mais elle me sort toutes les marques.
Marsh Posté le 15-10-2002 à 23:50:27
| NSV a écrit a écrit  : Jetway... Hop: 993-AN (VIA Slot1 + Socket 370) FEATURES Support Intel Pentium II / III And CeleronTM Slot 1 PPGA / FCPGA Processor Support Socket 370 For Intel CeleronTM PPGA / FCPGA Processor VIA 82C693A , 82C596B APOLLO Pro -133 AGPset Support 66/75/83/100/112/124/133/150 MHz Bus Frequency For CPU Host Clock Support Ultra DMA 66 Mode Support 3 Banks of DRAM From 8Mbyte to 1.5GByte Main Memory PC'99 Ready & PC'99 Colorful I/O Ports Design Support USB Controller & PS/2 Mouse , Standard IR (infrared) Functio Provide extra " three-wire" fans connectors Y2K Compliant ACPI Supporting For OS Directed Power Management Moden Ring remote wake up Power Button Ride (Instant off or Delay 4 second power off) RTC alarm wake up Wake on LAN For OS Support software suspend & power off (Windows 95 or Windows98) SPECIFICATION Processor Intel PentiumÒ II / III , CeleronTM Slot1 Processor Optimized For 100 / 133 MHz FSB Socket 370 For Intel CeleronTM PPGA Processor Can't Use Slot1 And Socket 370 Processor Together Chipset VIA 82C693A / 82C596B APOLLO Pro -133 Chipset CPU Bus Frequency Support Jumper Select 66.7/100/133 MHZ CPU Bus Frequency Default Selection CPU Bus Frequency , Choose 66 / 75 / 83 / 100 / 103 / 112 / 124 / 133 /150 MHZ in BIOS Setup DIP Switch Selection CPU Ratio From 2X to 8X AGP SLOT Support AGP VGA Card for 533Mbytes/sec data transfer rate and 66MHz Bus clock improve graphic function Expansion Slot Four 32-bit PCI Bus Master Slots One AMR (Audio/Modem Riser) Slot System Memory Support 3 Banks of SDRAM From 8MByte to 1.5GByte 3 X 168-pins DIMM Scockets (3.3V) Support EDO (66MHz Only) & SDRAM (66MHz/100MHz/133MHz) Support ECC or Parity Check On Board IDE Support 2 X IDE Connectors for up to 4 IDE Drives Support PIO Mode 3 and Mode 4 and Bus Master IDE DMA, Mode 4 Timing for up to 16M Bytes/s Support " Ultra DMA 66 " Synchronous DMA Mode transfer rate up to 66M Bytes/s Support LS-120 / ZIP Device On Board Ultra I/O PC'99 Colorful I/O Ports Design 2 X USB Connectors 1 X Standard IR Connector (SIR) 2 X Serial Ports (16550 Fast UART Compatible) 1 X Parallel Port (EPP and ECP Capabilities) 1 X Floppy Disk Connector (Supports 2 Floppy Drives) 1 X PS2 Mouse / PS2 Keyboard Connector 2 X Three Wire FAN Connector (Include CPU FAN) On Board USB 2 X USB Ports Connector Support USB Keyboard & USB Mouse Power Saving ACPI/APM Power Management Modem Ring Remote Wake up RTC Alarm Wake up Support Software Suspend & Power off (Windows 95/98) Wake on LAN For OS Support Power Button Ride (Instant off or Delay 4 second power off) Power Supply Support 20-pin ATX power supply (ATX-PW) BIOS Award BIOS , Support DMI , Green , P&P Function 2MByte Flash ROM Support Full Screen Logo Dimension ATX Form Factor with 30.5cm X 19cm  |
 Vs l'avez trouvé où ? Il n'y a pas un site où on trouve toutes les cartes mères ?
Marsh Posté le 15-10-2002 à 23:52:02
| foxtrotmikedelta a écrit a écrit  : |
 ... "AN 993 Slot 1" en param de recherche.
Marsh Posté le 16-10-2002 à 00:04:26
bon çà fait plaisir de voir que les djeunzz prennent la relève!
FACILE
 fô voir J'arrive après la bataille
bon du mixte slot1 socket 370 j'aurai dit à l'instinct jetway
NSV est  un cador
 à tous les deux
Marsh Posté le 15-10-2002 à 23:35:34
la marque et le modèle d'une mobo...
 Il y a une PIII 600EB dessus en socket. Sur la mobo il y a marqué 993 AN rev 1.2
C'est une mobo avec un support Slot 1 et socket !
