[AVIS]kk'un a un ViewSonic 19" P90f
kk'un a un ViewSonic 19" P90f [AVIS] - Hardware
Marsh Posté le 16-06-2002 à 20:50:50
http://www.viewsonic.com/products/crt_p90f.htm
Features
0.24mm stripe pitch
This ultra-fine stripe pitch produces clear, crisp images with rich, vivid color, even at the highest resolutions.
1920 x 1440 maximum resolution
Displays a maximum resolution of 1920 x 1440 at 73Hz flicker-free refresh rate for easy-on-the-eyes viewing.
1920 x 1440 @ 73Hz
1800 x 1440 @ 73Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 101Hz
PerfectFlat® screen
Absolutely flat screen provides realistically proportioned, precise images with reduced reflection, image distortion and eye fatigue.
SuperContrast screen
Advanced glass filter with a low transmission rate assures bright, bold colors.
One-Touch Auto-Adjust function
Size and position automatically adjust with the touch of a button, filling the screen at any resolution.
OSD[/Power] lock function
When activated, user-controlled OSD/Power lock function prevents changes to monitor settings, maintaining an optimized image setting.
ARAG® screen treatment
This specially formulated anti-reflection, anti-glare screen treatment uses a multi-layer process to eliminate reflection while maintaining the highest image quality.
ViewSonic Wizard
This software provides user-friendly installation.
TCO'99 and ENERGY STAR® certified
PC and Mac® compatible
Three year limited warranty
24/7 free technical and customer support*
http://www.viewsonic.com/images/IMG_p90f_lrg.jpg
J'aurais voulu savoir ce qu'il vaut...
Message édité par spartacus le 16-06-2002 à 20:53:46
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 21:51:16
personne? je voulias savoir le quel du G90f ou du P90f prendre
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:10:40
c un nouveau model çà non ?
Marsh Posté le 16-06-2002 à 22:17:30
oui, il est nouveau, en 1024*1280 il est a 101Hz alors que le G30f est a 89Hz d'ou ma question le quel choisir? sachant que le P90f est 500frs plus cher.
Message édité par spartacus le 16-06-2002 à 22:17:55
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:18:37
si ce n'est pas un trinitron çà peut etre tres interessant car les lignes çà m'embete
Marsh Posté le 16-06-2002 à 22:21:00
c koi les specs du g30 ?
Marsh Posté le 16-06-2002 à 22:21:45
non c'est pas un trinitron c un perfectflat derivé du diamondtron je crois ( regardes le test de HFR sur les moniteur 19" et regardes le P95f, c le meme tube )
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:23:15
ah bah justeùment le p95f c un trinitron : il a les deux lignes
Marsh Posté le 16-06-2002 à 22:24:05
les spef du G30f
Features
0.21 horizontal dot pitch
0.25 diagonal dot pitch
1600 x 1200 maximum resolution
Displays a maximum resolution of 1600 x 1200 at 77Hz flicker-free refresh rate for easy-on-the-eyes viewing.
1600 x 1200 @ 77Hz
1280 x 1024 @ 89Hz
1024 x 768 @ 118Hz
PerfectFlat® screen
SuperClear® technology
SuperClear screen technology incorporates enhanced phosphor treatment and optimized glass filter to deliver vivid colors and image clarity.
OnView® controls
Screen adjustments are made via an on-screen menu using simple controls.
USB hub-compatible base
Base design allows easy integration of the optional ViewSonic USB (Universal Serial Bus) hub for convenient USB peripheral connection.
Plug & Play +
http://www.viewsonic.com/images/IMG_g90f_lrg.jpg
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:26:49
ya aps a hesiter: mais 500 balles de plus
ta vu la difference des rafraichissments c tres important
Marsh Posté le 16-06-2002 à 22:27:02
effectivment c un derivée du trinitron mais j'ais cru lire kke part que ct pas du Sony mais du mistsu avec en plus une pellicule de phospore pour une meilleur couleur.
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:28:25
oauis mais pour le moment j'ais que une pauvre GTS alors peut etre que utiliser les 500frs pour les mettre dans une GF3 ou une ti4200 aurait ete plus judicieu, t'en pense koi?
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 22:29:39
ok. en touyt cas ya les deux lignes: pour certains çà pose probleme, pour dautre pas de pb. Moi j'ai vu un sony et on mavait parlé des lignes alors je les ai vu par contre dans les jeux on les voit pas. Sinon çà me parait un bon choix. en fait c koi qui le differe du p95f et quel est son prix
Marsh Posté le 16-06-2002 à 22:56:27
upup
Marsh Posté le 16-06-2002 à 22:58:01
non sciceremrent car si on depense 3000 balle pour un ecran, autant en depenser 3500 car le rafraichissment c important et jouez en 1600 avec un 87 hertz c le luxe. Moi c mon avis... maintenant
Marsh Posté le 16-06-2002 à 22:59:34
ce qui difere les P90f du p95f ce sont les frequence...et le prix
un test ici http://www.hardware.fr/html/articl [...] 22&page=13
le p90f est dispo a 3000Frs chez clust.
pour les barre grise je m'en fou, je prefere avoir de belle couleur et un frequece elevée que de ne pas avoir de barres grise ( je pense la au tube Flatron )
PS: scuze pour le tps de reponse, je pouvais plus acceder au forum, plantage du serveur?
Message édité par spartacus le 16-06-2002 à 23:01:26
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 23:00:05
un ecran tu le gardera tres longtemps de plus. donc c pas de largent par les fenetre. Quand les jeux en hautes resolutions seeront monnaies courante bah taura un taux de rafrachissemment bon
Marsh Posté le 16-06-2002 à 23:02:22
j'ai été tres lontemps interessé par le p95 mais ya des gars qui se sont pleind de defauts ... je sais pas si c resolu. Pense à çà aussi. EN tout cas le p90 me parait bon rapport qualité prix çà c sur
Marsh Posté le 16-06-2002 à 23:03:52
moi pour linsatnt mon coup de coeur car je songe aussi au 19 pouce c pour çà que je susi interessé au topic c le LG 915 ft
Marsh Posté le 16-06-2002 à 23:04:20
bon je v me prendre ca alors je pense, un petit P90f, miam miam, je m'occupe de ca a la fin de la semaine et je reviendrai deonner mon avis dès reception
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 23:05:51
c koi les frequence du LG?
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 23:06:08
okay :) good luck et jespere que ten seras content ehehe ( au fait si tu compte te racheter une carte graph, vu la tailel de ton ecran, tu va jouer dans les ahutes resolution donc previligie les 128 mo meme si elels sont un peu inferieure aux 64 en perf. En haute resolution, elles reprennent l'avantage )
Marsh Posté le 16-06-2002 à 23:07:51
un ptit 89 en 1600 je crois
Marsh Posté le 16-06-2002 à 23:08:51
nop, presque
- Résolution de travail : 1280*1024 / 95Hz
- Résolution max. : 1600*1280 / 85 Hz
il est aussi 500Frs plus cher, hum pour moi 3500frs c trop qd meme.
Lone Wolf Rider
Marsh Posté le 16-06-2002 à 23:11:09
si tu parle du lg là tu t trompé attends je vais te passer celels que je sais
Marsh Posté le 16-06-2002 à 23:12:54
Marsh Posté le 16-06-2002 à 23:32:59
ché pas, ce sont les chiffre de clust pour le LG.
Lone Wolf Rider
Marsh Posté le 17-06-2002 à 00:05:00
http://www.lge.com/c_product/catal [...] ion=1,18,1
c bien 85 en 1600*1200
Message édité par spartacus le 17-06-2002 à 00:05:28
Lone Wolf Rider
Marsh Posté le 17-06-2002 à 00:11:32
oui c e quil disent mais je crois kon peut le monter à 89 mais pour quelques Hz ....
Marsh Posté le 20-06-2002 à 08:50:07
Il a un pitch de 0.24 en plus, ce qui est mieux que les 0.25 du P95F, à part la légère diff de fréquence, il est supèrieur ...
Marsh Posté le 20-06-2002 à 23:10:31
oauis c vrai et pi il parait que le p90f n'a pas de ligne (de meme que le G90f), tandis que le p95f en a lui, bref il me tarde de le recevoir :love:
Lone Wolf Rider
Marsh Posté le 20-06-2002 à 23:35:15
Viewsonic:on entend jamais de méchantes critiques à son sujet.
C'est des bons écrans mais parfois assez mal distribué en France.
