Processeurs Haswell-E & Broadwell-E / Socket LGA2011-3 [Topic Unique] - Processeur - Hardware
Marsh Posté le 29-06-2014 à 12:24:53
Les tests en français :
http://www.hardware.fr/articles/92 [...] 5820k.html
http://www.comptoir-hardware.com/a [...] 5960x.html
http://www.tomshardware.fr/article [...] -2334.html
http://www.59hardware.net/articles [...] 16414.html
http://www.clubic.com/processeur/p [...] k-x99.html
http://www.ocaholic.ch/modules/sma [...] ang=french
http://www.cowcotland.com/articles [...] 5960x.html
Les tests en anglais :
http://www.anandtech.com/show/8426 [...] 20k-tested
http://techreport.com/review/26977 [...] r-reviewed
http://www.tomshardware.com/review [...] ,3918.html
http://www.bit-tech.net/hardware/2 [...] x-review/1
http://www.overclockers.com/intel- [...] cpu+review
http://hexus.net/tech/reviews/cpu/ [...] m-haswell/
http://www.hardwarecanucks.com/for [...] eview.html
http://www.pcper.com/reviews/Proce [...] sor-Review
http://www.legitreviews.com/asus-x [...] iew_149200
http://www.madshrimps.be/articles/ [...] iew-Part-I
http://www.eteknix.com/intel-core- [...] -gaming-5/
http://www.hitechlegion.com/review [...] sor-review
http://www.overclockersclub.com/re [...] e_edition/
http://hothardware.com/Reviews/Int [...] lE-Debuts/
http://www.overclock3d.net/reviews [...] 9_deluxe/1
http://www.guru3d.com/articles_pag [...] iew,1.html
http://www.bjorn3d.com/2014/08/cor [...] thusiasts/
http://www.vortez.net/articles_pag [...] l_e,1.html
http://www.hardocp.com/article/201 [...] 99_chipset
Les tests en langues diverses :
http://www.hardwareluxx.de/index.p [...] 5960x.html
http://www.computerbase.de/2014-08 [...] ll-e-test/
http://www.pcgameshardware.de/Core [...] e-1134186/
http://www.tweakpc.de/hardware/tes [...] 99/s01.php
http://www.technic3d.com/review/cp [...] ssor/1.htm
http://www.golem.de/news/intel-cor [...] 08893.html
http://lab501.ro/procesoare-chipse [...] 0x-review/
http://pclab.pl/art58628.html
http://nl.hardware.info/reviews/55 [...] jk-8-cores
Comparos mobales
http://nl.hardware.info/reviews/55 [...] -haswell-e
Marsh Posté le 29-06-2014 à 12:24:59
BROADWELL-E
http://www.hardware.fr/news/14643/ [...] -tete.html
http://www.comptoir-hardware.com/a [...] 6950x.html
http://www.59hardware.net/articles [...] 17987.html
http://www.cowcotland.com/articles [...] 6950x.html
http://www.ginjfo.com/dossiers/tes [...] n-20160531
http://www.tomshardware.com/review [...] ,4587.html
http://www.tweaktown.com/reviews/7 [...] index.html
http://www.pcper.com/reviews/Proce [...] l-E-Review
https://www.overclockers.com/intel- [...] pu-review/
http://hexus.net/tech/reviews/cpu/ [...] broadwell/
http://www.kitguru.net/components/ [...] pu-review/
http://www.bit-tech.net/hardware/2 [...] e-review/1
http://www.legitreviews.com/intel- [...] ked_181875
http://www.vortez.net/articles_pag [...] iew,1.html
http://www.guru3d.com/articles-pag [...] iew,1.html
http://hothardware.com/reviews/int [...] -e-arrives
http://www.overclock3d.net/reviews [...] u_review/1
http://www.overclockersclub.com/re [...] ell_e_cpu/
http://www.reviewstudio.net/2399-i [...] -e-is-here
http://www.computerbase.de/2016-05 [...] 800k-test/
http://www.pcgameshardware.de/Broa [...] t-1196801/
http://www.hardwareluxx.de/index.p [...] rosse.html
http://www.golem.de/news/core-i7-6 [...] 21130.html
http://nl.hardware.info/reviews/67 [...] -peperduur
http://tweakers.net/reviews/4579/b [...] cores.html
http://lab501.ro/procesoare-chipse [...] 50x-review
http://www.sweclockers.com/test/22 [...] roadwell-e
http://pc.watch.impress.co.jp/docs [...] 59797.html
http://www.jagatreview.com/2016/05 [...] uk-gaming/
Marsh Posté le 30-06-2014 à 00:52:54
Pour un budget de 600 euros (carte-mère + processeur) et sachant que je compte brancher 10 disques durs de 6To, mieux vaut--il une carte à base de Chipset Z97 moyen-de-gamme comme la Gigabyte GA-Z97X-G1 Gaming et un processeur 4Ghz Devil's Canyon Haswell-Refresh-K i7-4790K ou plutôt attendre septembre et opter pour une carte à base de Chipset Wellsburg-X (X99) bas-de-gamme comme la Gigabyte GA-X99-UP4 et un processeur 3.3Ghz Intel i7-5820K 6C/12T ?
Le premier (sur socket LGA 1150) est finalement peu "overclockable", peut-être 4,5Ghz mais guère plus.
Le second (sur Socket LGA2011-3) pourrait être overclockable à au moins 3,8Ghz…
Dans les 2 cas, en conditions de stabilité maximale.
Est-ce que le déficit de 18% en terme de vitesse sur un cœur est compensé par les 6 cœurs ? Et bien tout dépendra des logiciels…
Certains softs profitent d'un surplus de cœurs et à l'avenir, c'est ce que les développeurs semblent privilégier, non ?
Même pour certains jeux alors que la cible est clairement équipée en 4 cœurs voire moins…
Pour ma part, c'est pour de la photo (DXO est très consommateur de ressources), de la vidéo 4K et un peu de jeux…
Marsh Posté le 30-06-2014 à 02:18:55
À priori tu auras plus de perfs sur le 7i 5820k. Maintenant penses que même si il rentre dans ton budget "CM+proc" (ce qui n'est pas sûr), il faudra mettre bien plus cher pour la ram (ddr4 vs ddr3).
Marsh Posté le 30-06-2014 à 03:58:09
le prix des 2 config sera proche et c'est ce qui est étrange !
Car si on trouve des cartes Z97 à 100 €, dès qu'on veut un truc fiable et avec plein d'entrées, on dépasse les 200 roros !
Soit le prix d'une carte X79 actuellement ! Et les premiers prix X99 ne devraient guère coûter plus !
En E-ATX plus haut-de-gamme, les prix dépasseront le Z97, bien entendu…
Pour les processeurs sur LGA2011, l'actuelle entrée de gamme n'est pas intéressante, c'est un 4 cœurs et il ne tient pas la comparaison avec l'i7-4770K (et donc encore moins avec son remplaçant).
Mais la prochaine entrée de gamme sera en 6 cœurs et ses performances valent l'i7-4770K ou le dépassent quand les applications sont optimisées multi-cœurs !
Reste le prix de la RAM en effet !
32 Go de DDR-3 1600 ou 16Go de DDR-4 1800 facilement overclockable à 2400Mhz ?
Quitte à ajouter ensuite 16Go quand les prix seront plus sages.
La RAM varie tellement, les prix sont actuellement orientés à la baisse.
D'ici 1 an, on pourrait trouver des kits DDR-4 au prix de la DD-R3 il y a 6 mois…
sauf si survient un tremblement de terre comme celui de Kobé ![]()
Marsh Posté le 16-07-2014 à 16:24:26
ReplyMarsh Posté le 16-07-2014 à 17:04:37
Drap histoire de suivre ce qu'il se fera quoi, meme si on sait déjà.
Non je ne craquerais plus, promis.
Marsh Posté le 18-07-2014 à 13:58:00
| mum1989 a écrit : un indice sur les prix : |
Dommage que le 8 coeurs soit si peu cadencé pour un proc extreme. Le 5820K est quant à lui très intéressant. Peut être sera t'il le successeur de mon 3930K qui fait encore très bien son boulot.
Marsh Posté le 22-07-2014 à 18:24:59
Encore quelques jours et le topic sera en chantier depuis 1 mois.
Bref, a-t-on de nouvelles infos ? ![]()
Marsh Posté le 22-07-2014 à 18:29:52
Je suis en train de le reprendre et non, pas de nouvelles infos.
Marsh Posté le 24-07-2014 à 16:59:29
| synefil a écrit : Pour un budget de 600 euros (carte-mère + processeur) et sachant que je compte brancher 10 disques durs de 6To, mieux vaut--il une carte à base de Chipset Z97 moyen-de-gamme comme la Gigabyte GA-Z97X-G1 Gaming et un processeur 4Ghz Devil's Canyon Haswell-Refresh-K i7-4790K ou plutôt attendre septembre et opter pour une carte à base de Chipset Wellsburg-X (X99) bas-de-gamme comme la Gigabyte GA-X99-UP4 et un processeur 3.3Ghz Intel i7-5820K 6C/12T ? |
On en sait encore rien du tout, et je vois pas en quoi Haswell E serait moins bon en OC qu'un Haswell 4 coeurs... il faut juste avoir le refroidissement en conséquence car ça chauffe plus avec deux coeurs en plus.
Marsh Posté le 25-07-2014 à 22:35:46
L'extreme edition serait vendu 1100 $ donc entre 1000 et 1100 € chez nous
Marsh Posté le 26-07-2014 à 18:59:02
5820k > all , moi qui ai pris un 4930k a 530e j'me prends une douille ![]()
Marsh Posté le 28-07-2014 à 00:35:07
Haswell-E décapsulé :
http://www.ocdrift.com/intel-core- [...] erial-tim/
Marsh Posté le 28-07-2014 à 21:54:59
A propos de décapsulage, l'IHS sera t-il soudé au PCB ? ou alors rebelotte pour de la pâte thermique bas de gamme sur un proco à 1000 boules ![[:alarmclock1] [:alarmclock1]](https://forum-images.hardware.fr/images/perso/alarmclock1.gif)
EDIT : il semblerait qu'on revienne à la bonne vieille soudure d'après l'article du lien.
Marsh Posté le 01-08-2014 à 16:05:53
Le site chinois parle d'un post facebook de MSI.
Du coup je l'ai trouvé : https://www.facebook.com/MSI.Europe (c'est en haut de la page au moment où j'écris ça ... désolé je maitrise très mal FB donc je ne sais pas comment avoir un lien permanent vers le post)
Tout ce qu'on a , en gros, c'est une photo.
Le reste de l'article chinois ne dit malheureusement pas grand chose d'intéressant d'après Google Translate : x99 = 40 lignes pcie, on voit 8 slots ddr4 et 1 m2 (bon l'info pour le m2 est bonne à prendre, personnellement je suis incapable de le voir sur la CM, je ne sais même pas à quoi ça ressemble)
Marsh Posté le 02-08-2014 à 22:16:27
Drapal
Bon les premiers prix de DDR4-2133 AData sont tombés: 70 et 140€ pour les 8 et 16Go.
Marsh Posté le 04-08-2014 à 14:32:29
http://www.tomshardware.fr/article [...] 54060.html
Les prix DDR4 de Giulietta26 seraient HT. Ça nous fait 84€ les 8Go et 169€ les 16Go. Selon la photo, les 16Go sont un kit 2x8. (en cherchant un peu je trouve ceci : http://www.anandtech.com/show/8315 [...] l15-udimms => le kit 8Go est un 2x4)
Marsh Posté le 07-08-2014 à 19:18:53
| aze555666 a écrit : http://www.tomshardware.fr/article [...] 54060.html |
Meaculpa
j'ai relayé trop vite l'info, par contre quand je vois l'article de ce jour sur les prix des autres barrettes
Marsh Posté le 08-08-2014 à 16:42:25
Le prix de la DDR4 ne serait pas si élevé :
www.nextinpact.com/breve/89149-ddr [...] r-4-go.htm
Marsh Posté le 08-08-2014 à 22:37:16
Effectivement
Bon du coup la Crucial est un peu plus chère que la Adata (1ere annoncée, pas la 2800 hors de prix).
Chez LDLC (lien dans la news nextimpact) ils ont 1x4 2x4 1x8 et 2x8 pour respectivement 49, 98, 95 et 190 €, en Crucial "de base".
Du coup, pour le fun, j'ai comparé en DDR3 les différentes gammes de Crucial. Ici pour la liste des kits 2x4Go 1600Mhz. On est à 10€/Go pour la mémoire "de base", à peine plus cher pour les Ballistix Sport, Sport XT, Sport VLP, Tactical, et on monte à 12€/Go pour la Ballistix Smart Tracer.
Bref les différences en DDR3 ne sont pas bien méchantes, et si ils nous sortent des Ballistix rapidement en DDR4 on peut s'attendre à un prix pas tellement plus élevé que celui de la "de base" cité ci-dessus.
Par contre la question que je me pose est : pourquoi ont-ils autant de gammes, surtout avec si peu de différences de prix ?! À part le radiateur, quelle différence entre "de base", "ballistix sport", "ballistix tactical", "ballistix elite", "ballistix smart tracer", "ballistix sport xt", "ballistix sport vlp" ? Et tant qu'on y est, quelle différence entre "OB" et "RG", entre rien et "SR" (dans les deux cas, prix égal sur gamme égale) ?
J'aimerais bien savoir, histoire d'acheter le bon modèle le moment venu.
Marsh Posté le 08-08-2014 à 22:40:24
Il faudra voir comment se comporte les kits low-cost niveau overclocking.
Marsh Posté le 09-08-2014 à 02:01:50
Si je comprends bien les dernières news, la sortie des Haswell-E c'est pour la fin du mois et non pas mi-septembre comme on l'annonçait encore il y a quelques semaines
Marsh Posté le 09-08-2014 à 04:39:18
Curieux de voir les perf comparé à un xeon 2687w. J’espère que je vais pas trop pleurer
Marsh Posté le 09-08-2014 à 12:39:28
j'espere que les résultats en overclocking seront meilleurs que les haswell 1150.
Hate de voir les tests en tout cas! je pense que j'aurais enfin une bonne raison de changer mon i5 2500k.
Marsh Posté le 09-08-2014 à 12:45:14
J'ai hâte de voir le prix en € du 5930K sur des sites comme LDLC ou Topachat.
Le quadchannel est il une obligation ou conseillé?
Marsh Posté le 09-08-2014 à 12:49:33
| Giulietta26 a écrit : J'ai hâte de voir le prix en € du 5930K sur des sites comme LDLC ou Topachat. |
Conseillé , c'est un des avantages de la plateforme.
Marsh Posté le 09-08-2014 à 12:56:04
Merci.
Est ce réellement assuré que le LGA2011-3 serait compatible Broadwell-E??
Et si c'est le cas la compatibilité avec Skylake-E peut elle être envisagée??
Marsh Posté le 10-08-2014 à 23:19:23
| bugfx32 a écrit : Curieux de voir les perf comparé à un xeon 2687w. J’espère que je vais pas trop pleurer |
un bi 2687W quand même, ça me ferait mal
Dans l'absolu si t'as payé tes 2687W en retail au vu du prix du 5960X on n'est plus si loin donc .... seul regret sur le bi xeon, le manque de choix sur les cartes mères "pas que pro"
Marsh Posté le 29-06-2014 à 12:24:24
Bienvenue sur le topic LGA2011-3 !
Fiche récapitulative
Nom de code CPU : Haswell-E
Socket : LGA2011-3 ou R3
Finesse de gravure : 22nm HKMG Tri-gate
Taille die : 356mm²
Nombre de Cores : 6C/12T & 8C/16T
Fourchette de fréquences : 3.0/3.5GHz
Gamme de TDP : 140W
Date de lancement : 29 août 2014
Fourchette de prix : 379/570/999€
Contexte
Lancé en novembre 2011 pour accueillir la sortie de SB-E puis IB-E par la suite, le socket LGA2011 va donc céder sa place à son successeur, le LGA2011-3, dont le lancement coïncide avec l'arrivée de la variante workstation de Haswell (HW-E) et, plus tard, de Broadwell-E en 14nm.
Même si les deux dénominations semblent proches, du fait d'un nombre de pins équivalent, la présence de détrompeurs indique que les deux plateformes sont incompatibles.
Le LGA2011 a atteint son but : SB-E offre un niveau de performance important et IB-E a rectifié le tir niveau consommation tout en apportant quelques améliorations (légèrement meilleur IPC, meilleur IMC) malheureusement contrecarrées par une montée en fréquence plus laborieuse.
Pour l'arrivée de ce nouveau socket, Intel a de nouveau choisi 3 déclinaisons possibles mais alors que la génération précédente était composée de 1 processeur 4C/8T (i7-3820K/i7-4820K) et de 2 processeurs 6C/12T (i7-3930K/i7-4930K & i7-3960X/i7-4960X) l'on a désormais affaire à 2 processeurs 6C/12T (i7-5820K/i7-5930K) et 1 processeur 8C/16T (i7-5960X), premier vrai processeur 8 coeurs disponible en desktop.
L'absence d'un processeur 8C/16T dans la tranche 500-600€ est fort regrettable mais, sans concurrence dans les segments supérieurs à 250€, Intel dispose à sa guise de ses gammes et a donc modifié son plan d'action.
Ces nouveaux processeurs ainsi que les nouvelles cartes-mères, équipées pour la peine du nouveau chipset X99, sont attendus pour le mois de septembre 2014.
Specs, chipset
Vous pouvez trouver des détails sur l'architecture Haswell dans le topic HW
Message édité par Invite_Surprise le 04-06-2015 à 19:34:49
