Test IntelProcessor Diagnostic: CPU Frequency Fail
Test IntelProcessor Diagnostic: CPU Frequency Fail - Processeur - Hardware
Marsh Posté le 10-02-2016 à 14:09:33
Depuis peu, mon PC surchauffe lorsque je joue :-(
Du coup je me suis lancer dans la quête de trouver pourquoi.
Et j'ai trouver cela sans résoudre le problème.
J'ai réalisé le Diagnotisque Intel Processor et il échoue lors du test CPU Frequency.
Si l'un de vous peu me guider :-)
Voici le Resultat du test ci dessous:
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 10/02/2016 12:49:53
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Wed Feb 10 12:49:54 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Wed Feb 10 12:49:54 2016
Total Time:  seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 10 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Processor Information: Intel64 Family 6 Model 42 Stepping 7
Number of Physical Cores: 2
Number of Logical Cores: 4
Installed System Memory: 8 GB
Operating System: Microsoft Windows 7 Édition Familiale Premium 64 bits
Graphics Information: NVIDIA GeForce GT 630M
System Product: JV51_HR
System BIOS: V1.19
System Serial Number: NXRV3EF005211106293400
--- IPDT64 - End Time: 10/02/2016 12:49:55
--- IPDT64 - Result: Fail
--- IPDT64 - Start Time: 10/02/2016 12:50:12
Processor 1
Start Time: Wed Feb 10 12:50:12 2016
Test Result - PASS
End Time: Wed Feb 10 12:50:12 2016
Temperature Test
Test Result - PASS
Received: 8 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:50:13
--- IPDT64 - Start Time: 10/02/2016 12:50:25
Processor 1
Start Time: Wed Feb 10 12:50:26 2016
Test Result - PASS
End Time: Wed Feb 10 12:50:26 2016
Temperature Test
Test Result - PASS
Received: 12 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:50:26
--- IPDT64 - Start Time: 10/02/2016 12:51:09
Processor 1
Start Time: Wed Feb 10 12:51:10 2016
Test Result - PASS
End Time: Wed Feb 10 12:51:10 2016
Temperature Test
Test Result - PASS
Received: 11 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:51:10
--- IPDT64 - Start Time: 10/02/2016 12:53:18
Processor 1
Start Time: Wed Feb 10 12:53:18 2016
Test Result - PASS
End Time: Wed Feb 10 12:53:18 2016
Temperature Test
Test Result - PASS
Received: 13 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:53:18
--- IPDT64 - Start Time: 10/02/2016 12:58:08
Processor 1
Start Time: Wed Feb 10 12:58:08 2016
Test Result - PASS
End Time: Wed Feb 10 12:58:08 2016
Temperature Test
Test Result - PASS
Received: 28 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:58:09
--- IPDT64 - Start Time: 10/02/2016 12:58:17
Processor 1
Start Time: Wed Feb 10 12:58:17 2016
Test Result - PASS
End Time: Wed Feb 10 12:58:17 2016
Temperature Test
Test Result - PASS
Received: 31 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 12:58:17
--- IPDT64 - Start Time: 10/02/2016 13:02:38
Processor 1
Start Time: Wed Feb 10 13:02:38 2016
Test Result - PASS
End Time: Wed Feb 10 13:02:38 2016
Temperature Test
Test Result - PASS
Received: 39 degrees below max
Test Result - PASS
System Information
System BIOS: V1.19
--- IPDT64 - End Time: 10/02/2016 13:02:38
--- IPDT64 - Start Time: 10/02/2016 13:34:16
Processor 1
Start Time: Wed Feb 10 13:34:17 2016
Test Result - PASS
End Time: Wed Feb 10 13:34:17 2016
Temperature Test
Test Result - PASS
Received: 50 degrees below max
End Time: Wed Feb 10 13:34:22 2016
Total Time:  seconds: 5
Start Time: Wed Feb 10 13:34:22 2016
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 13:34:23
--- IPDT64 - Start Time: 10/02/2016 13:35:08
Processor 1
Start Time: Wed Feb 10 13:35:08 2016
Test Result - PASS
End Time: Wed Feb 10 13:35:08 2016
Temperature Test
Test Result - PASS
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 13:35:08
--- IPDT64 - Start Time: 10/02/2016 13:58:39
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Wed Feb 10 13:58:39 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String:        Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
End Time: Wed Feb 10 13:58:40 2016
Total Time:  seconds: 1
Start Time: Wed Feb 10 13:58:40 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 26 degrees below max
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 13:58:41
--- IPDT64 - Start Time: 10/02/2016 13:59:24
Processor 1
Start Time: Wed Feb 10 13:59:24 2016
Test Result - PASS
End Time: Wed Feb 10 13:59:24 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 21 degrees below max
End Time: Wed Feb 10 13:59:25 2016
Start Time: Wed Feb 10 13:59:25 2016
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 13:59:25
--- IPDT64 - Start Time: 10/02/2016 14:00:18
Processor 1
Start Time: Wed Feb 10 14:00:18 2016
Test Result - PASS
End Time: Wed Feb 10 14:00:18 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 16 degrees below max
End Time: Wed Feb 10 14:00:19 2016
Start Time: Wed Feb 10 14:00:19 2016
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 14:00:19
--- IPDT64 - Start Time: 10/02/2016 14:00:24
Processor 1
Start Time: Wed Feb 10 14:00:24 2016
Test Result - PASS
End Time: Wed Feb 10 14:00:24 2016
Test Result - PASS
Temperature Test
Test Result - PASS
Received: 17 degrees below max
Test Result - PASS
System Information
System BIOS: V1.21
--- IPDT64 - End Time: 10/02/2016 14:00:25
