A7V600-X / pseudo Athlon XP3000+ /DDR400 (cpuz inside) [BIOS Help] - Matériels & problèmes divers - Hardware
Marsh Posté le 08-03-2009 à 19:39:56
Hello, cela a bien l air d un Barton L2 512 mo, il y a eu 2 barton 3000+ un a 166 mhz et 1 a 200 mhz.......
http://www.x86-guide.com/fr/cpu/AM [...] no383.html
Marsh Posté le 08-03-2009 à 19:45:54
Merci Chriskenobody
Ok Au pire c'est un a 166mhz?
Dans ce cas comment configurer le bios pour le CPU et le timing de la RAM?
pour info:
  CPU-Z version 1.50
Processors Information
Processor 1 (ID = 0)
Number of cores  1 (max 1)
Number of threads	1 (max 1)
Name  	AMD Athlon XP
Codename  Barton
Specification  AMD Athlon(TM) XP 3000+
Package  	Socket A (462)
CPUID  	6.A.0
Extended CPUID  7.A
Core Stepping
Technology  0.13 um
Core Speed  1293.7 MHz (13.0 x 99.5 MHz)
Rated Bus speed  199.0 MHz
Instructions sets	MMX (+), 3DNow! (+), SSE
L1 Data cache  64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache	64 KBytes, 2-way set associative, 64-byte line size
L2 cache  512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control  no
Features
K7 Thermal sensor	yes
Chipset
Northbridge  VIA KT600 rev. 80
Southbridge  VIA VT8237 rev. 00
Graphic Interface	AGP
AGP Revision  3.0
AGP Transfer Rate	8x
AGP SBA  	supported, enabled
Memory Type  DDR
Memory Size  1024 MBytes
Memory Frequency	132.9 MHz (FSB + 33 MHz)
CAS#  	2.0
RAS# to CAS#  3
RAS# Precharge  2
Cycle Time (tRAS)	6
Memory SPD
DIMM #1
General
Memory type  DDR
Manufacturer (ID)	Kingston (7F98000000000000)
Size  	512 MBytes
Max bandwidth  PC3200 (200 MHz)
Part number  K
Serial number  68249581
Manufacturing date	Week 51/Year 00
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Nominal Voltage  2.50 Volts
EPP  	no
XMP  	no
Timings table
Frequency (MHz)  133	166	200
CAS#  	2.0	2.5	3.0
RAS# to CAS# delay	2	3	3
RAS# Precharge  2	3	3
TRAS  	6	7	8
DIMM #2
General
Memory type  DDR
Size  	512 MBytes
Part number  K
Serial number  6F189B01
Manufacturing date	Week 41/Year 05
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
EPP  	no
XMP  	no
Timings table
CAS#  	2.0	2.5	3.0
TRAS  	6	7	8
Monitoring
Mainboard Model  A7V600-X (0x1E9 - 0xAA8D0A)
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0	1.74 Volts [0x6D] (CPU VCORE)
Voltage sensor 2	3.30 Volts [0xCE] (+3.3V)
Voltage sensor 3	4.97 Volts [0xB9] (+5V)
Voltage sensor 4	12.16 Volts [0xBE] (+12V)
Voltage sensor 7	5.00 Volts [0xBA] (+5V VCCH)
Voltage sensor 8	3.30 Volts [0xCE] (VBAT)
Temperature sensor 0	39°C (102°F) [0x27] (TMPIN0)
Temperature sensor 1	37°C (98°F) [0x25] (TMPIN1)
Fan sensor 0  3771 RPM [0xB3] (FANIN0)
Marsh Posté le 08-03-2009 à 19:51:56
http://www.clubic.com/article-1508 [...] arton.html
 c est pas le lien que je voulais mettre......bon il peut toujours servir
Marsh Posté le 08-03-2009 à 20:03:59
Re merci, mais avec ce que j'ai déjà essayé et qui ne marche pas,  j'en suis à chercher LA BONNE config du bios
quitte a en essayer plusieurs avec l'aide de quelqu'un!
Par exemple je vois la Vcore a 1.75, alors que ce CPU devrait être à 1.65!
Bref Re A l'aide
[edit po grave pour le lien ;-)  ]
Marsh Posté le 08-03-2009 à 20:18:05
Marsh Posté le 08-03-2009 à 22:47:01
Re je viens de configurer le bios comme indiqué..... = Ecran bleu!
(13 x 166/33 + vore1.70 et 1.65 + memoire auto)
[edit]
Bon je crois que je viens de trouver une config....stable mais pas rapide...
Passage en réglage manuel et réglages suivants:
-CPU: 13x166/33 et fsb 333
-vcore auto, il reste affiché sous cpuz  à 1.74 ?! et sous le bios 1.62
-Enfin et surtout la DDR:  réglage manuel : 166 (2.5/3/3/7) donc "syncro" FSB:DRAM=1:1
Je pige pas pourquoi la mémoire ne peut pas être réglée sur 200mhz (3-3-3-8) et je ne sais pas si la fonction dual ram est sur ON....
bref si cela reste stable.... ben ca ira
Merci à chriskenoby pour son aide.
Marsh Posté le 08-03-2009 à 18:40:53
[BIOS] A7V600-X / pseudo Athlon XP3000+ /DDR400
Cette machine est très lente et instable.
Actuellement la seule config du bios qui fonctionne est celle par défaut… les autres plantent. (voir CPUZ)
Il y a 2 piéges...
1-Le CPU est de ceux qui pouvaient être vendus pour une fréquence supérieure ou un truc du style, il est dailleur destické (pas de réference) et je doute que se soit un "vrai" XP3000+ (2167 ou 2600) mais bon je le savais à l'achat.
2-certain bios asus délirent sur la reconnaissance de ce processeur.
BREF A L'AIDE
Je n’arrive pas à configurer correctement les valeurs :
CPU SPEED [1300-1733-2167-2600]
CPU Freq Mult [5.5 – 22.5]
CPU External Freq [100/33 – 255/40]
Memory Freq [auto – 266- 333- 400]
Vcore Settig [1.6 – 1.85]
Je cherche AUSSI les valeurs de timing de la Ram! (PC3200 400 / 2 barrettes kingston)
HELP cela fait deux jours que je tourne en rond sur cette machine e travail !!!!
Pour info les valeurs de AMD pour les CPU :
Message édité par yepii le 08-03-2009 à 18:59:27
