Ralentissement général de l'ordinateur dès le bios - Matériels & problèmes divers - Hardware
Marsh Posté le 02-12-2007 à 22:24:37
1. Vérifies l'état smart du disque dur avec Speedfan:
http://www.clubic.com/telecharger- [...] edfan.html
2. Fais un test mémoire avec memtest86:
http://www.depannetonpc.net/fiches [...] mtest.html
Marsh Posté le 03-12-2007 à 02:55:12
Merci, voilà déjà les résultats pour speedfan ça a l'air ok, je ferai memtest demain.
Je remarque aussi que dans l'onglet "readings" de speedfan, j'ai 127°C pour "AUX" avec une petite flamme à côté, est-ce possible que ça soit le ventilo qui ait lâché ?
Your hard disk is a ST3200822A with firmware 3.01.
The average temperature for this hard disk is 36C (MIN=25C MAX=49C) and yours is 27C.
Your hard disk's S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
Your hard disk is not below any attribute threshold. This is good.
Your hard disk was never below any attribute threshold. This is good.
Your hard disk is now being compared to real data used to define normal values for your specific hard disk model. This way, the analysis can automatically use proper operating ranges. The images give you an idea of how each attribute is within such range. Current and raw values are shown for easier reference for experienced users. There are 1742 hard disk models in the current archive.
   Attribute  	Current  	Raw  	Overall
 	Raw Read Error Rate  56  208355644  Good
 	Spin Up Time  96  0  Normal
 	Start/Stop Count  100  954  Very good
 	Reallocated Sector Count  100  0  Very good
 	Seek Error Rate  84  253616042  Very good
 	Power On Hours Count  90  8943  Good
 	Spin Retry Count  100  0  Very good
 	Power Cycle Count  100  962  Very good
 	Hardware ECC Recovered  56  208355644  Good
 	Current Pending Sector  100  0  Very good
 	Offline Uncorrectable Sector Count  100  0  Very good
 	Ultra DMA CRC Error Rate  200  0  Very good
 	Write Error Rate  100  0  Very good
 	TA Increase Count  100  0  Very good
All of the attributes of your hard disk have normal values. This is good.
The overall fitness for this drive is 95%.
The overall performance for this drive is 95%.
Marsh Posté le 03-12-2007 à 18:30:35
on attend le résultat de memtest86+
sinon tu peux te lancer dans le flash du bios si tu n'a aucune erreur de Ram...
Marsh Posté le 04-12-2007 à 02:14:40
Bonjour, j'ai fait le test de ram, résultat très négatif !
Quand je boot, memtest se lance, fais quelques tests puis passe à "Moving inversions" et plante, n'affichant que la partie inférieure de l'écran, le haut est noir.
Voici ce que le bas affiche :
        Test     Error
Lowest Error Address: 0000000000000 - 0.0MB           0         56
Highest Error Address: 000ffffffffff - 4095.9MB            1         24
    Bits in Error Mask: 0001fffc                                  2         40
Bits in Error: Total: 15 Min: 0 Max: 14 Avg: 8 7           3         56
etc..
Errors per Memory Slot:                   84208028           6         104
        7         120
                               2: 0                                     8          136
                               3: 0        538982199               9          152
J'ai essayé de changer mes 2 barrettes de slots (j'ai 4 slots sur ma P5K), ne mettre qu'une barrette, que l'autre, rien n'y fait.
Pourtant Windows se charge (en 5 minutes environ) mais tout est très lent, comme si le processeur était à fond, mais non il est à 1%.
Mes 2 barrettes auraient grillé en même temps ??
Marsh Posté le 05-12-2007 à 22:43:52
oui mes barettes sont des kingston achetées récemment et c'est impossible qu'elles aient grillé ttes les deux au même moment.
Au démarrage il m'arrivait d'avoir un message sur le CMOS, J'ai flashé mon bios, sans succès.
J'ai enlevé la pile de la carte mère, remise, sans succès.
De temps en temps au bios j'ai un message qui me dit que l' "overclocking has failed" alors que je n'ai pas overclocké mon proc...
Comment savoir si c'est ma carte mère qui a un problème ? Et si oui, à quel niveau ?
Marsh Posté le 02-12-2007 à 21:10:52
Mon ordinateur a eu une sorte d' "attaque" hier, j'ai du le redémarrer, il a récuper quelques fichiers avec CHKDSK et depuis il marche très lentement. le lancement de windows met quelques minutes, le lancement d'applications est très lent également. Même le bios se charge plus lentement. J'ai jeté un coup d'oeil au rapport Everest mais je n'arrive pas à voir ce que ça peut être.
Pouvez vous m'aider svp ?
Voici le résumé du rapport Everest :
Ordinateur:
Type de système PC multiprocesseur ACPI
Système d'exploitation Microsoft Windows XP Professional
Service Pack du système Service Pack 2
Internet Explorer 7.0.5730.13
DirectX 4.09.00.0904 (DirectX 9.0c)
Nom du système MAISON (Maison)
Nom de l'utilisateur Nicolas
Adresse e-mail SMTP **********
Domaine de connexion MAISON
Date / Heure 2007-12-02 / 21:05
Carte mère:
Type de processeur DualCore Intel Pentium E2180, 2000 MHz (10 x 200)
Nom de la carte mère Asus P5K (3 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Chipset de la carte mère Intel Bearlake P35
Mémoire système 2048 Mo (DDR2-800 DDR2 SDRAM)
Type de BIOS AMI (07/03/07)
Port de communication Port de communication (COM1)
Moniteur:
Carte vidéo Radeon X1950 Series Secondary (256 Mo)
Carte vidéo Radeon X1950 Series (256 Mo)
Accélérateur 3D ATI Radeon X1950 XT (R580)
Moniteur LG Flatron L1720P (Digital) [17" LCD] (1403114551)
Multimédia:
Carte audio Realtek ALC883 @ Intel 82801IB ICH9 - High Definition Audio Controller
Stockage:
Contrôleur IDE Contrôleur IDE standard double canal PCI
Contrôleur de stockage SCSI/RAID Host Controller
Lecteur de disquettes Lecteur de disquettes
Disque dur ST3200822A (200 Go, 7200 RPM, Ultra-ATA/100)
Lecteur optique ET5067K YNB944L SCSI CdRom Device
État des disques durs SMART OK
Partitions:
C: (NTFS) 190771 Mo (7012 Mo libre)
Taille totale 190771 Mo (7012 Mo libre)
Entrée:
Clavier Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
Clavier Périphérique clavier PIH
Souris Souris à roulette USB Logitech
Souris Souris HID
Contrôleurs de jeu Pilote de joystick PC Microsoft
Réseau:
Adresse IP principale 127.0.0.1
Adresse MAC principale 00-0E-2E-51-E6-AA
Carte réseau (ZD1211)IEEE 802.11b+g USB Adapter
Périphériques:
Imprimante Auto HP DeskJet 815C sur SYLVIA
Imprimante Canon i320
Contrôleur FireWire VIA VT6306/6307 Fire II IEEE1394 Host Controller (PHY: VIA VT6307)
Contrôleur USB1 Intel 82801IB ICH9 - USB Universal Host Controller
Contrôleur USB2 Intel 82801IB ICH9 - USB2 Enhanced Host Controller
Périphérique USB (ZD1211)IEEE 802.11b+g USB Adapter #4
Périphérique USB Concentrateur USB générique
Périphérique USB Logitech QuickCam Express #7
Périphérique USB Périphérique d'interface utilisateur USB
Périphérique USB Périphérique USB composite
Périphérique USB Souris à roulette USB Logitech
DMI:
Distributeur du BIOS American Megatrends Inc.
Version du BIOS 0603
Fabricant du système System manufacturer
Nom du système P5K
Version du système System Version
Numéro de série du système System Serial Number
UUID du système A058A288-8DFED511-BE25001D-6035FACD
Fabricant de la carte mère ASUSTeK Computer INC.
Nom de la carte mère P5K
Version de la carte mère Rev 1.xx
Numéro de série de la carte mère MS6C78B34600941
Fabricant du châssis Chassis Manufacture
Version du châssis Chassis Version
Numéro de série du châssis Chassis Serial Number
Identifiant du châssis Asset-1234567890
Type du châssis Desktop Case
Sockets mémoire (Total/Libres) 4 / 2
