Raccordement PC=>TV: probleme de "driver" - Matériels & problèmes divers - Hardware
Marsh Posté le 03-08-2007 à 16:33:13
| tinker a écrit : |
Pourtant en suivant le lien est en regardant les cartes supportées par ce driver :
GeForce2 MX, GeForce2 MX 100, GeForce2 MX 200, GeForce2 MX 400, GeForce3, GeForce3 Ti 200, GeForce3 Ti 500, GeForce4 MX 420, GeForce4 MX 440, GeForce4 MX 440-SE, GeForce4 MX 440 with AGP8X, GeForce4 MX440SE with AGP8X, GeForce4 MX 460, GeForce2 MX Integrated graphics, GeForce4 MX Integrated graphics, GeForce4 MX 4000, GeForce4 Ti 4200, GeForce4 TI 4200 with AGP8X, GeForce4 Ti 4400, GeForce4 Ti 4600, GeForce4 Ti 4800, GeForce4 Ti 4800 SE, GeForce FX 5100, GeForce FX 5200, GeForce FX 5200LE, GeForce FX 5200 Ultra, GeForce FX 5500, GeForce FX 5600, GeForce FX 5600 Ultra, GeForce FX 5600SE, GeForce FX 5600XT, GeForce FX 5700, GeForce FX 5700VE, GeForce FX 5700 Ultra, GeForce FX 5700LE, GeForce FX 5800, GeForce FX 5800 Ultra, GeForce FX 5900, GeForce FX 5900 Ultra, GeForce FX 5900XT, GeForce FX 5900ZT, GeForce FX 5950 Ultra, GeForce PCX 5300, GeForce PCX 5750, GeForce PCX 5900, GeForce 6100 nForce 400, GeForce 6100 nForce 405, GeForce 6100 nForce 420, GeForce 6100, GeForce 6150 LE, GeForce 6150, GeForce 6200, GeForce 6200 LE, GeForce 6200 with TurboCache, GeForce 6200SE with TurboCache, GeForce 6500, GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce 6600 GT, GeForce 6610 XL, GeForce 6700 XL, GeForce 6800, GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GS, GeForce 6800 GT, GeForce 6800 Ultra, GeForce 6800 Ultra, GeForce 7100 GS, GeForce 7300 LE, GeForce 7300 SE, GeForce 7300 GS, GeForce 7300 GT, GeForce 7500 LE, GeForce 7600 GS, GeForce 7600 GT, GeForce 7800 GS, GeForce 7800 GT, GeForce 7800 GTX, GeForce 7800 GTX 512, GeForce 7900 GS, GeForce 7900 GTO, GeForce 7900 GT, GeForce 7900 GTX, GeForce 7950 GX2, Quadro2 MXR, Quadro DCC, Quadro4 200 NVS, Quadro4 400 NVS, Quadro4 380 XGL, Quadro4 500 XGL, Quadro4 550 XGL, Quadro4 580 XGL, Quadro4 700 XGL, Quadro4 750 XGL, Quadro4 780 XGL, Quadro4 900 XGL, Quadro4 980 XGL, Quadro FX 330, Quadro FX 350, Quadro FX 500, Quadro FX 540, Quadro FX 550, Quadro FX 560, Quadro FX 600, Quadro FX 700, Quadro FX 1000, Quadro FX 1100, Quadro FX 1300, Quadro FX 1400, Quadro FX 1500, Quadro FX 2000, Quadro FX 3000, Quadro FX 3000G, Quadro FX 3400, Quadro FX 3450, Quadro FX 3500, Quadro FX 4000 SDI, Quadro FX 4400, Quadro FX 4400G, Quadro FX 4500, Quadro FX 4500 SDI, Quadro FX 4500 X2, Quadro FX 5500, Quadro FX 5500 SDI, Quadro NVS, Quadro NVS with AGP8X, Quadro NVS 200, Quadro NVS 210s, Quadro NVS 280, Quadro NVS 280 SD, Quadro NVS 400, Quadro NVS 440, Quadro NVS 280 PCI, Quadro NVS 285
Marsh Posté le 03-08-2007 à 16:38:06
EDIT : avais mal lue ton post.
essayes un driver moins récent au cas où.
Marsh Posté le 03-08-2007 à 16:54:17
oui +1
Marsh Posté le 02-08-2007 à 23:09:37
Bonjour, j'espere posté sur le bon forum.
Voilà, j'ai relié mon PC a mon ordi de cette façon:
PC@prise S-Video<->connecteur S-video<->connecteur jaune vidéo<->prise jaune video de la télé
Je sais je n'aurai pas le son mais je m'en fiche je ne veux que la video.
Je sais en principe comment faire puisque celà fonctionne sur l'ordi de mon pere, mais sur le mien qui est plus vieux, je n'y arrive pas.
Déjà, pas de menu nView dans Panneau de config=>Affichage=>Parametres=>Avancé:
Ce qui complique bien les choses...
Ma carte est une GeForce 2 MX400 (ouais ça date, mais que voulez-vous on a pas tous les moyens de changer d'ordi aussi facilement...)
J'ai alors essayé de mettre à jour les drivers en allant sur le site de nVidia, ils m'ont aiguillé vers ce pilote:
http://www.nvidia.fr/object/winxp_2k_94.24_fr.html
Donc je fais comme ils disent, je desinstalle les drivers nommé Windows Display j'sais pas trop quoi là, j'installe les nouveaux drivers après avoir redemarré et là ils me disent: "The NVIDIA Setup program couldt not locate any drivers that are compatible with your current hardware. Setup will exit."
Là ça commence doucement à me faire ch***.
Je vais voir sur internet sur ce qui se dit sur ce probleme et je trouve une solution: passer par le gestionnaire de peripherique et installer manuellement les pilotes. Bon entre nous je trouve pas ça normal que cet ordi soit pas foutu d'installer son pilote normalement alors qu'il ait soit disant fait pour... Bref c'est installé, je me dis génial je vais peut etre enfin avoir l'onglet manquant, j'y vais, et là surprise, toujours pas donglet...
Je vais donc sur l'icone Gestionnaire de Bureau nVidia dans Panneau de config. Il existait déjà avant donc je me dis que LUI a peut-être été amelioré, mais malheureusement le pilote installé ne lui a toujours pas donné une once d'utilité, dommage...
Enfin j'entend parler du logiciel TVTool qui permet de gérer tout ce barda, je le télécharge, je linstalle et je l'ouvre, et là, monsieur me dit en gros que je n'ai pas les bons drivers, qu'il faut que j'installe nVidia Detonator je ne sais pas trop quoi. J'essaie donc de trouver ce "Detonator". Le site de nVidia ne m'aidant pas sur ce sujet, je suis obligé de passer par d'autres sites, j'en trouve un.
Je le télécharge, je l'installe, evidemment ça ne marche pas (normal) et ça me remet le message "The NVIDIA Setup program bla bla bla". Je refait la manip pour l'installer manuellement mais je vois à un moment donné de cette installation manuelle que dans la liste des cartes graphiques prises en compte par ce driver, ne figurait pas la mienne. Je décide d'en arreter là et de passer mes nerfs sur ce sujet en esperant que vous saurez m'aider!
Merci d'avance
