Probleme sauvegarde serveur !!! - Matériels & problèmes divers - Hardware
Marsh Posté le 27-08-2007 à 09:19:19
il nous faut plus d'info concernant les log de ta sauvegarde!
pourquoi n'a-t'il pas sauvegarder les dernier 2Go, pê la capacité de ta cartouche n'est-elle pas suffisante! auquel cas les 800Go c'est en compressé? si non effectue la compression durant la sauvegarde
Marsh Posté le 27-08-2007 à 09:37:44
Salut lunehurlante34 !
Voici le log de HP Storage Works, comme tu peux le voir, il n'arrive pas a backuper certains fichiers en cours d'utilisation !!!
Sais tu comment resoudre ceci ?
http://rapidshare.com/files/515556 [...] g.htm.html
Activity Log for Backup Local Machine
Storage Server: ERPBACKUP Generated on: 27-Aug-2007 03:31 PM
Version: Data Protector Express 3.10-sp3 Generated by: Admin
Contents
1. Summary
2. Timing
3. Activity
4. Disaster Recovery
5. Devices
6. Media
7. Hosts
8. Objects
Summary
Job name Backup Local Machine
Job Type Backup
Product Data Protector Express 3.10-sp3 - 21824
Logging Mode Failed Objects Only
Backup mode Full
Auto verify mode Full verify
Write mode Overwrite all media
Span mode Restart file
Change mode Prompt for another media
Pass type Backup
Selected: 166882 objects, 42.40 GB
Completed: 166842 objects, 40.22 GB (94%)
Failed: 40 objects, 2.18 GB (5%)
Pass type Auto Verify
Selected: 166842 objects, 40.22 GB
Completed: 166793 objects, 40.14 GB (99%)
Failed: 49 objects, 86 MB (0%)
Completed: 166793 objects, 40.14 GB (94%)
Failed: 89 objects, 2.26 GB (5%)
Timing
Start Backup Time: 20-Aug-2007 09:00 PM
End Backup Time: 21-Aug-2007 01:39 AM
Start Verify Time: 21-Aug-2007 01:40 AM
End Verify Time: 21-Aug-2007 05:36 AM
Start Backup Objects Time: 20-Aug-2007 09:04 PM
Elapsed Backup Objects Time: 4 hours,34 minutes,30 seconds
End Backup Objects Time: 21-Aug-2007 01:39 AM
Start Verify Objects Time: 21-Aug-2007 01:40 AM
Elapsed Verify Objects Time: 3 hours,53 minutes
End Verify Objects Time: 21-Aug-2007 05:33 AM
Start Task Time: 20-Aug-2007 09:00 PM
Elapsed Task Time: 8 hours,35 minutes,45 seconds
End Task Time: 21-Aug-2007 05:36 AM
Activity
Network\TAOLIGHTERP\Data Protector Express Catalog
The object Data Protector Express Catalog has been backed up to the media Home\Admin\Backup Local Machine - Rotation Media\Daily Rotation Media\Daily Set 4\Daily Set 4.
Disaster Recovery
Completed The boot track for the host TAOLIGHTERP has been written to Daily Set 4 in device HP C7438A (Serial Number HU106360SA)
Completed The boot track for the host TAOLIGHTERP has been written to Daily Set 4:1 in device HP C7438A (Serial Number HU106360SA)
Devices
Media
Completed: 166832 objects, 27.71 GB
Home\Admin\Backup Local Machine - Rotation Media\Daily Rotation Media\Daily Set 4\Daily Set 4:1
Completed: 10 objects, 12.50 GB
Hosts
TAOLIGHTERP
Objects
Network\TAOLIGHTERP\File Systems\C:\baan\eme
Error 4410: Object verify different Ver: 190
Network\TAOLIGHTERP\File Systems\C:\baan\eme\190
Error 4410: Object verify different Ver: taofx
Network\TAOLIGHTERP\File Systems\C:\baan\eme\190\taofx
Error 4410: Object verify different Ver: proc
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Bases
Error 4410: Object verify different Ver: av-i386-0607g.xml
Error 4410: Object verify different Ver: avp_x.set
Error 4410: Object verify different Ver: base035c.avc
Error 4410: Object verify different Ver: daily-ec.avc
Error 4410: Object verify different Ver: daily.avc
Error 4410: Object verify different Ver: dailyc.avc
Error 4410: Object verify different Ver: fa001.avc
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Data\Updater\Temporary Files\temporaryFolder\bases\av\avc\i386\ForDiff
Error 4410: Object verify different Ver: av-i386-0607g.xml.dif
Error 4410: Object verify different Ver: av-i386-0607g.krg
Error 4410: Object verify different Ver: av-i386-0607g.xml.klz
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Data\Updater\Temporary Files\temporaryFolder\index\6\ForDiff
Error 4410: Object verify different Ver: u0607g.xml.dif
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Data\Updater\Temporary Files\update\rollback\bases\av\avc\i386
Error 16: File not found Ver: av-i386-0607g.pbv
Error 16: File not found Ver: mail.avc
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Data\Updater\Temporary Files\update\rollback\index\6
Error 4410: Object verify different Ver: rollback.ini
Error 4410: Object verify different Ver: sfdb.dat
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Dskm
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP6\Report
Error 3013: Object is busy Bkp: detected.idx
Error 3013: Object is busy Bkp: detected.rpt
Error 3013: Object is busy Bkp: eventlog.rpt
Error 3013: Object is busy Bkp: report.rpt
Network\TAOLIGHTERP\File Systems\C:\Documents and Settings\All Users\Application Data\VMware
Error 3013: Object is busy Bkp: vmnetdhcp.leases
Network\TAOLIGHTERP\File Systems\C:\hp\hpsmh\data\cgi-bin\vcagent
Error 3013: Object is busy Bkp: vcagent.log
Network\TAOLIGHTERP\File Systems\C:\hp\hpsmh\logs
Error 3013: Object is busy Bkp: error_log
Error 3013: Object is busy Bkp: scache
Network\TAOLIGHTERP\File Systems\C:\Program Files\Baan\shared\tmp
Error 3013: Object is busy Bkp: BclmServer.792
Network\TAOLIGHTERP\File Systems\C:\Program Files\Baan\Worktop\cache\192.168.0.12\c_baan\b61tl\o
Error 4410: Object verify different Ver: prod
Network\TAOLIGHTERP\File Systems\C:\Program Files\Baan\Worktop\cache\192.168.0.12\c_baan\b61tl\o\prod
Error 4410: Object verify different Ver: erp
Network\TAOLIGHTERP\File Systems\C:\Program Files\Baan\Worktop\cache\localhost\c_baan\b61tl\o
Network\TAOLIGHTERP\File Systems\C:\Program Files\Baan\Worktop\cache\localhost\c_baan\b61tl\o\prod
Network\TAOLIGHTERP\File Systems\C:\Program Files\HP\Data Protector Express\config
Error 4410: Object verify different Ver: drboot.ini
Network\TAOLIGHTERP\File Systems\C:\Program Files\HP\Data Protector Express\temp
Error 4410: Object verify different Ver: boot.img
Network\TAOLIGHTERP\File Systems\C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Data
Error 3013: Object is busy Bkp: master.mdf
Error 3013: Object is busy Bkp: mastlog.ldf
Error 3013: Object is busy Bkp: model.mdf
Error 3013: Object is busy Bkp: modellog.ldf
Error 3013: Object is busy Bkp: msdbdata.mdf
Error 3013: Object is busy Bkp: msdblog.ldf
Error 3013: Object is busy Bkp: tempdb.mdf
Error 3013: Object is busy Bkp: templog.ldf
Network\TAOLIGHTERP\File Systems\C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG
Error 3013: Object is busy Bkp: ERRORLOG
Error 3013: Object is busy Bkp: log_16.trc
Error 3013: Object is busy Bkp: SQLAGENT.OUT
Network\TAOLIGHTERP\File Systems\C:\Program Files\Microsoft SQL Server\MSSQL.2\OLAP\Log
Error 4410: Object verify different Ver: FlightRecorderBack.trc
Error 3013: Object is busy Bkp: FlightRecorderCurrent.trc
Error 3013: Object is busy Bkp: msmdsrv.log
Network\TAOLIGHTERP\File Systems\C:\Taowebtop\config\usercontexts
Error 4410: Object verify different Ver: baan
Error 3013: Object is busy Bkp: webtop.log
Network\TAOLIGHTERP\File Systems\C:\Taowebtop\tomcat\logs
Error 3013: Object is busy Bkp: localhost_admin_log.2007-08-16.txt
Error 3013: Object is busy Bkp: localhost_examples_log.2007-08-16.txt
Error 3013: Object is busy Bkp: localhost_log.2007-08-16.txt
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\security\Database
Error 4410: Object verify different Ver: secedit.sdb
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\security\logs
Error 4410: Object verify different Ver: winlogon.log
Error 4410: Object verify different Ver: edb.chk
Error 4410: Object verify different Ver: edb.log
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\system32\drivers
Error 3013: Object is busy Bkp: fidbox.dat
Error 3013: Object is busy Bkp: fidbox.idx
Error 3013: Object is busy Bkp: fidbox2.dat
Error 3013: Object is busy Bkp: fidbox2.idx
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\system32\LogFiles\HTTPERR
Error 3013: Object is busy Bkp: httperr1.log
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\system32\wbem\Logs
Error 4410: Object verify different Ver: wbemcore.lo_
Error 4410: Object verify different Ver: wbemcore.log
Network\TAOLIGHTERP\File Systems\C:\WINDOWS\system32\wbem\Repository\FS
Error 3013: Object is busy Bkp: INDEX.BTR
Error 3013: Object is busy Bkp: MAPPING.VER
Error 3013: Object is busy Bkp: MAPPING1.MAP
Error 3013: Object is busy Bkp: MAPPING2.MAP
Error 3013: Object is busy Bkp: OBJECTS.DATA
Error 3013: Object is busy Bkp: h323log.txt
Error 3013: Object is busy Bkp: WindowsUpdate.log
Network\TAOLIGHTERP\File Systems\D:\ERP_DATA
Error 3013: Object is busy Bkp: taoerpdb.ldf
Error 3013: Object is busy Bkp: taoerpdb.mdf
Marsh Posté le 27-08-2007 à 12:03:32
tu devrais esssayer d'arrêter les services qui utilise ces fichiers!
effectivement, j'avais eu à peu près le même probleme pour un de nos serveurs, une partie seulement des fichiers étaient sauvegardé,
donc dans un premier temps essaie de voir quels services utilisé tout ces fichiers, après fait un tache a partir d'un petit *.bat qui permettra d'arreter les service durant la sauvegarde et une deuxième tache qui permettra de les redémarré
Marsh Posté le 28-08-2007 à 03:10:25
Merci pour ton aide !
Mon probleme est de faire des backups compatible avec ODBR de hp !
Je vais essayer System EXEC de sysmantec en esperant que cela fonctionne !!!
Mulder
Marsh Posté le 27-08-2007 à 08:30:45
Bonjour a tous,
j'ai a l'heure actuelle un serveur HP DL 380.
Sur ce serveur est present des donnees tres importantes.
Pour assurer la securite de ces donnes, j'ai achete un systeme de sauvegarde par bande HP AT 72x10 Tape Autoloaderm qui me procure 800 go de capacite.
A l'heure actuelle, mon probleme est d'ordre logiciel. J'effectue les backup grace au logiciel HP. Mais celui-ci me manque 2 go de donnees. (Sauvegarde manquee).
Pouvez vous m'indiquer comment effectuer une sauvegarder fiable sur ces bandes ?
Sachant que je souhaiterais utiliser la fonction des lecteurs a bande HP qui permet de restaurer depuis le lecteur via le boot (One button recovery)
Merci a vous pour votre aide !
Mulder
