Plantage pendant la gravure d'un cd - Matériels & problèmes divers - Hardware
Marsh Posté le 12-04-2005 à 20:59:48
personne ..
j'ai maj nero et now j'ai ca comme log
lol
1A23-8071-5123-2608-1373-0056
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Nero Version: 6.6.0.8
Recorder:             <_NEC DVD_RW ND-3520A>    Version: 1.04 - HA 1 TA 1 - 6.6.0.8
 Adapter driver:      <atapi>                   HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <AOPEN    DVD1648/AAP     >Version: 1.05 - HA 1 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral       : Maxtor 6B120P0                   atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : AOPEN DVD1648/AAP                atapi Port 1 ID 0  DMA: On
CdRomPeripheral      : _NEC DVD_RW ND-3520A             atapi Port 1 ID 1  DMA: Off
=== CDRom-Device-Map ===
AOPEN DVD1648/AAP          D:   CDRom0
_NEC DVD_RW ND-3520A       E:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1023MB (1048048kB)
Free physical memory: 651MB (666748kB)
Memory in use       : 36 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.4.2005
CD Audio
20:09:37	#1 CDADOC -1 File Cdadoc.cpp, Line 1465
 Audio item log info:
 Audio document burn settings:
 Burn mode: DAO,
 CD Text: On,
 Cache disk or network files: No,
 Cache small files: No,
 Cache files smaller than 65536 bytes.
 Audio Multisession: No
 List of audio tracks:
 Track 01: Length: 62:56.62, Pause frames: 150, Filters: 0, Name: '201_va_-_energy_hardstyle_mixed_by_caffeine_and_ryan_b-2cd-2005-klf.mp3'.
 Total size: 62:58.62
20:09:37	#2 Text 0 File Reader.cpp, Line 127
 Reader running
20:09:37	#3 Text 0 File Writer.cpp, Line 122
 Writer _NEC     DVD_RW ND-3520A  running
20:09:37	#4 Text 0 File AudioCompilationImpl.cpp, Line 842
 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
 DRM: Beginning burn process.
20:09:37	#5 Text 0 File Burncd.cpp, Line 3153
 Turn on Disc-At-Once, using CD-R/RW media
20:09:38	#6 Text 0 File DlgWaitCD.cpp, Line 259
 Last possible write address on media:   359848 ( 79:59.73)
 Last address to be written:             283261 ( 62:58.61)
20:09:38	#7 Text 0 File DlgWaitCD.cpp, Line 271
 Write in overburning mode: NO (enabled: CD DVD)
20:09:38	#8 Text 0 File DlgWaitCD.cpp, Line 2316
 Recorder: _NEC DVD_RW ND-3520A;
    CDR code: 00 97 15 05; OSJ entry from: TDK Corporation
    ATIP Data:
      Special    Info [hex] 1: D0 00 A0, 2: 61 0F 05 (LI 97:15.05), 3: 4F 3B 4A (LO 79:59.74)
      Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
20:09:38	#9 Text 0 File DlgWaitCD.cpp, Line 433
 >>> Protocol of DlgWaitCD activities: <<<
20:09:38	#10 Text 0 File ThreadedTransferInterface.cpp, Line 830
 Setup items (after recorder preparation)
  0: TRM_AUDIO_NOPRE (201_va_-_energy_hardstyle_mixed_by_caffeine_and_ryan_b-2cd-2005-klf.mp3)
     2 indices, index0 (150) not provided
     original disc pos #0 + 283262 (283262) = #283262/62:56.62
     relocatable, disc pos for caching/writing not required/not required, no patch infos
     -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 283262 blocks [_NEC     DVD_RW ND-3520A]
20:09:38	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
 Prepare recorder [_NEC     DVD_RW ND-3520A] for write in CUE-sheet-DAO
 DAO infos:
  MCN: "             "
  TOCType: 0x00; Session Closed, disc fixated
  Tracks 1 to 1:
    1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800     666585024, ISRC ""
 DAO layout:
  __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
     -150 |  lead-in |   0 |    0x01 | 0x00
     -150 |        1 |   0 |    0x21 | 0x00
        0 |        1 |   1 |    0x21 | 0x00
   283262 | lead-out |   1 |    0x01 | 0x00
20:09:38	#12 Phase 36 File dlgbrnst.cpp, Line 1832
 Burn process started at 32x (4.800 Ko/s)
20:09:38	#13 Text 0 File ThreadedTransferInterface.cpp, Line 2609
 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
20:09:38	#14 Text 0 File Mmc.cpp, Line 16478
 StartDAO : CD-Text - On
20:09:38	#15 Text 0 File Mmc.cpp, Line 21235
 Set BUFE: Buffer underrun protection -> OFF
20:09:38	#16 Text 0 File Mmc.cpp, Line 16767
 CueData, Len=32
 21 00 00 41 00 00 00 00
 21 01 00 00 00 00 00 00
 21 01 01 00 00 00 02 00
 01 aa 01 01 00 3e 3a 3e
20:10:09	#17 Text 0 File Cdrdrv.cpp, Line 1287
 20:10:09.140 - _NEC DVD_RW ND-3520A\H1 T1 : Queue again later
20:10:10	#18 SCSI -1135 File Cdrdrv.cpp, Line 1435
 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0BAB0000
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x03 (KEY_MEDIUM_ERROR)
 Sense Code: 0x0C
 Sense Qual: 0x00
 CDB Data:   0x2A 0x00 0x00 0x00 0x06 0x1E 0x00 0x00 0x1B 0x00 0x00 0x00
 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x06 0x1F 0x0A
             0x00 0x00 0x00 0x00 0x0C 0x00
20:10:10	#19 CDR -1135 File Writer.cpp, Line 311
 Write error
20:10:14	#20 Text 0 File ThreadedTransfer.cpp, Line 228
 all writers idle, stopping conversion
20:10:14	#21 Text 0 File ThreadedTransfer.cpp, Line 222
 conversion idle, stopping reader
20:10:14	#22 Phase 38 File dlgbrnst.cpp, Line 1832
 Burn process failed at 32x (4.800 Ko/s)
20:10:14	#23 Text 0 File AudioCompilationImpl.cpp, Line 867
 DRM: DRM burn session terminated.
20:10:14	#24 Text 0 File AudioCompilationImpl.cpp, Line 896
 DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 12:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 3, 11, 1, size=99456 bytes, created 3/01/2005 11:33:44 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 11, 1, size=28928 bytes, created 3/01/2005 11:33:24 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 11, 1, size=8704 bytes, created 3/01/2005 11:33:46 (InCD4 driver for win NT/2K/XP)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 19/06/2003 13:05:04 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Marsh Posté le 12-04-2005 à 23:16:00
Si tu a deux lecteurs met le graveur en "esclave" et l'autre en "maitre". Sinon tu peu toujour chercher des drivers ou regarder si se que tu grave n'est pas protéjé.
Marsh Posté le 13-04-2005 à 13:24:33
j'ai gravé a partir du disque dur ca a foiré puis j'ai gravé a partir du cd rom ds lequel il y avait un cd graver ca a planter aussi ...
graveur deja mort ???
Marsh Posté le 13-04-2005 à 13:24:53
par contre j'ai installé far cry avec et la ca a ete sans probleme
Marsh Posté le 12-04-2005 à 19:05:54
Bonjour je viens de m'acheter un graveur dvd NEC 3520
j'ai voulu graver un bete cd audio vitesse: 32x arriver à 15 % il a planter il mit qu'il y a une erreur je recommence mais en 24x et la à 15% meme chose plantage .. encore une erreur
qu'elle est le probleme ?? je grave avec nero 6 merci
