plantage écrans bleu !!!!!! - Matériels & problèmes divers - Hardware
Marsh Posté le 18-07-2009 à 13:45:18
*** ERROR: Module load completed but symbols could not be loaded for windbg.exe
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Debugging Tools for Windows (x86)\dbgeng.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\Program Files\Debugging Tools for Windows (x86)\dbghelp.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\MPR.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\COMCTL32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\ole32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\VERSION.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\msvcrt.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\ADVAPI32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\RPCRT4.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\GDI32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\SHLWAPI.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\Secur32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\kernel32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\SHELL32.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\USER32.dll -
Marsh Posté le 18-07-2009 à 14:34:03
j'ai aussi une erreur avec minidump avec nv4_disp.dll ( nv4_disp+b6749 )
Marsh Posté le 18-07-2009 à 13:33:02
Je décris ma config: Windows xp pro Sp2,
Tour: Antec
Carte mère: Asus P5K Pro
Proc: intel Q6600
Ram: 4x1Go pc2 8500 Crucial ballistix
Carte Graphique: Asus 8800Gt 512 mo
Alim: Cooler master 600w
Lecteur: Graveur Dvd pionner
2 DD: 1 maxtor 260go et 1 seagate 120go
j'ai joué recement a un jeux qui s'appelle day of defeat source, j'ai eu plantage écrans bleu et sa redémarre, j'ai déjà eu ce plantage au par avant,
simplement j'ai fais le test avec debugging tools for windows sa me donne ceci.
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
CommandLine: "C:\Program Files\Debugging Tools for Windows (x86)\windbg.exe"
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
ModLoad: 01000000 01096000 windbg.exe
ModLoad: 7c910000 7c9c9000 ntdll.dll
ModLoad: 7c800000 7c905000 C:\WINDOWS\system32\kernel32.dll
ModLoad: 77da0000 77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
ModLoad: 77e50000 77ee2000 C:\WINDOWS\system32\RPCRT4.dll
ModLoad: 77fc0000 77fd1000 C:\WINDOWS\system32\Secur32.dll
ModLoad: 77ef0000 77f38000 C:\WINDOWS\system32\GDI32.dll
ModLoad: 7e390000 7e420000 C:\WINDOWS\system32\USER32.dll
ModLoad: 77be0000 77c38000 C:\WINDOWS\system32\msvcrt.dll
ModLoad: 02000000 02386000 C:\Program Files\Debugging Tools for Windows (x86)\dbgeng.dll
ModLoad: 03000000 03121000 C:\Program Files\Debugging Tools for Windows (x86)\dbghelp.dll
ModLoad: 77bd0000 77bd8000 C:\WINDOWS\system32\VERSION.dll
ModLoad: 774a0000 775dd000 C:\WINDOWS\system32\ole32.dll
ModLoad: 7c9d0000 7d1f4000 C:\WINDOWS\system32\SHELL32.dll
ModLoad: 77f40000 77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
ModLoad: 77390000 77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\COMCTL32.dll
ModLoad: 71a60000 71a72000 C:\WINDOWS\system32\MPR.dll
(1464.1468): Break instruction exception - code 80000003 (first chance)
eax=00191eb4 ebx=7ffda000 ecx=00000002 edx=00000004 esi=00191f48 edi=00191eb4
eip=7c91120e esp=0006fb20 ebp=0006fc94 iopl=0 nv up ei pl nz na po nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000202
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!DbgBreakPoint:
7c91120e cc int 3
j'ai formater il y a 1 semaine, j'avais déjà ces problèmes d'erreurs si vous pouviez m'aider merci.
j'ai déjà tester mes mémoire etc...
Message édité par lecorse26 le 18-07-2009 à 13:33:51
