Installation de W2K sur serveur Primergy 470 bi-proc : Ca coince ... - Matériels & problèmes divers - Hardware
Marsh Posté le 18-02-2005 à 11:07:48
essaye de mettre à jour le bios :
http://download.fujitsu-siemens.co [...] ze=1073665
DESCRIPTION FOR BIOS UPDATE (D1031) 10311080.EXE
Date: 19.10.2000
Version: 4.06 1.08
Manufacturer: Sonstige
Comment:
Changes.txt for BIOS 4.06 Rel.1.08.1031 FW FW 1.3.1.101 28.08.00
BIOS 1.07A
- Added microcode update for Pentium III Coppermine cC0(CPUID=686).
Changes.txt for BIOS 4.06 Rel.1.07.1031 FW FW 1.3.1.101 12.07.00
BIOS 1.06A
- Added CPU frequencies up to 1GHz to the CPU frequency table.
&nb...
More Information Maximize comment
Comment:
BIOS 1.07A
BIOS 1.06A
Change maximum frequency to 1GHz in DMI structure 4.
- Fixed a problem in memory size computation of DMI routines.
DMI showed wrong memory size for the last memory module with 2GB RAM with modules
which have 2 rows.
Changes.txt for BIOS 4.06 Rel.1.06.1031 FW FW 1.3.1.101 13.03.00
FW FW 1.3.1.101 Changes
- Solved problems with Redundant Power Supply (Rev. 03) while Power On.
Changes.txt for BIOS 4.06 Rel.1.06.1031 FW FW 1.3.1.100 17.02.00
BIOS 1.05B
- Multi Boot Mode: max. 8 IPL devices (Boot devices) are fully supported.
If there are more IPL devices in the system they will be ignored.
- Changed default boot order to:
ATAPI CD-ROM
DISKETTE
HARD DISK
- Support of Japanese 3 mode floppy (otherwise BIOS API hangs when called in protected mode)
- Included P6 Update Code for Pentium P3 (CPU-ID 683) Coppermine cB0 Step
- WINDOWS 2000 support: Change in MP-table for multi processor systems was necessary
(This made WINDOWS 2000 hang on certain configurations).
- ROMPILOT SW update: some problems with ROMPILOT are fixed, which cause sporadic malfunction of system.
- Changed LOGO string from "SIEMENS AG" to "FUJITSU SIEMENS"
Changes.txt for BIOS 4.06 Rel.1.05.1031 FW FW 1.3.1.100 10.11.99
BIOS 1.04E
- ROM Pilot Support included
- New onboard SCSI BIOS 4.15.04 included (necessary for future NetWare SYMBIOS HAM driver)
- Support for PIII (Coppermine)
FW FW 1.3.1.100 Changes
- Change of Version Identification string
- Support of PIII Copermine - ensure that FW 100 is flashed before the installation of Coppermine Processor
- Change of Fan regulation algorithmus to support cold environment
- Change in fan prefailure algorithmus including support of different power supplies
Changes.txt for BIOS Vers. 4.06 Rel.1.03.1031
- Pentium III support, feature to disable serial number
- Support new memory modules based on 256Mbit technology
- Y2000 support with "Active BIOS" feature
- Disable IDE-Controller with RTDS Disk after RTDS has booted.
Changes.txt for BIOS 1.02.1031
- Added BIOS setup item to disable new BIOS Boot Option:
" Multiboot for HD`s". After disable of "Multiboot for HD`s"
the boot order will be related to the scan order for the boot
devices, which is the boot order used in previous systems
(compatibility boot order).
- Added new BIOS setup option to select the boot VGA controller.
- Change due to Real Time Clock value may be corrupted after
correctable ECC Memory failure.
- Changed Security state table, after "Discard Changes & Exit"
password is required for booting the system.
- Change for Pager/VT100 Support, without this change Server may hang.
- Added additional year 2000 support (some year 200 test programs
require this change)
- Added support for DMA capable CD-ROM drives
- Numbers of DIMM Moduls start with one instaead of zero
Note : Check ServerView Agent revision.
With BIOS 1.02 following agents are reqired to identify the PRIMERGY 470:
Windows NT ServerView Agents 2.20
NetWare ServerView Agents 2.21
Changes.txt for BIOS Vers. 4.06 Rel.1.01.1031
- Support for 2 GB DRAM memory to the System and the Recovery BIOS added.
- Memory modules can now automatically be disabled. This happens, if a
memory failure is detected while POST or an uncorrectable DRAM error
is found while operating system runtime. A system reset is necessary
after an uncorrectable DRAM error, to establish the new memory
configuration, which cannot bedone by the BIOS (Remark: The system will
automatically reset if ASR&R is enabled)
- Micro Code Support for Deschutes Slot 1 B0 step
Marsh Posté le 20-02-2005 à 22:54:30
Merci pour le BIOS
L'install a marche nickel, mais jeviens de constater que le modele que j'ai indique en lien est un PRIMERGY 470/S26361-K482-V753 alors que le mien est un PRIMERGY 470/S26361-K482-V915
Donc j'ai essaye de recuperer le bon BIOS, mais impossible d'acceder aux pages que tu as obtenues pour l'autre Driver.
Sinon pour l'install de W2K, ca a l'air d'aller. J'avais pas le temps d'aller jusqu'au bout, mais ca allait deja mieux qu'avant.
Marsh Posté le 21-02-2005 à 10:52:06
salut tu vas là :
http://www.fujitsu-siemens.com/sup [...] ads_1.html
tu prends Intel-Based Server > Primergy > Primergy 4xx > 470
aprés tu cliques sur ce que tu veux télécharger .
Siemens à Fait un joint-venture avec Fujitsu en Juin 1999, ils n'ont pas changés les anciens modèles
donc je pense que tu peux trouver des infos sur ton serveur avec son numéro de série (qui doit être marqué derrière en dessous d'un code barre)
Sinon tu n'as pas un cd SERVERSTART ? avec ça tu peux installer plus facilement ton serveur.
Marsh Posté le 21-02-2005 à 16:21:04
OK, merci pour le coup de main. En fait avec le PC sur lequel j'etais hier soir, impossible d'acceder a la liste des drivers pour le Primergy 470. Aujourd'hui, pas de probleme.
Sinon aucun CD n'a ete livre avec le serveur, j'ai juste recupere la bete toute nue.
Marsh Posté le 04-03-2005 à 22:38:34
slt
j ai le meme pb moi aussi
mais j ai aucune disquette moi
fin voila koi
j ai aussi un primergy 470
voila y a t il moyen d en parler sur msn?
Marsh Posté le 06-03-2005 à 11:18:52
sefix >
c'est quoi ton problème ? installation de windows ?
Marsh Posté le 10-03-2005 à 23:09:24
en fait je ne parviens pas a lui faire detecter le controleur scsi pour les 4 dd
t as pas les drivers de la carte qui conecte les dd scsi (pas la carte scsi pci )
merci a toi
Marsh Posté le 17-02-2005 à 22:56:03
Je suis entre en possession de ca (Cliquez pour obtenir les specs) :
Siemens Primergy 470
C'est gros, lourd et bruyant (tres), mais ca m'amuserait de le mettre en service.
J'ai tente d'installer W2K, mais rien a faire, il mange mes 4 disquettes d'install, execute le process correctement, mais quand il s'agit de demarrer la partie qui est sur le CD, plus rien.
Alors j'ai cherche des drivers. J'en ai trouve sur le net pour la carte SCSI de la bete (une LSI Logic, Inc. Integrated Symbios Logic SYM53C895 Wide Ultra2SCSI; PCI :W ). Mais la encore, ca marche pas. Le probleme c'est que quand W2K Setup demande la disquette driver et que je lui donne la mienne, il m'envoit un message d'erreur pour me dire qu'il trouve pas le fichier TXTSETUP.OEM. Effectivement, ce fichier n'est pas present sur ma disquette.
Pensant que le probleme venait du fait que W2K setup ne trouvait pas le CD SCSI, j'ai connecte une CD IDE sur le port IDE : meme resultat, il lit les 4 disquette et reste a la fin sur un ecran noir avec un prompteur qui clignotte.
J'ai donc essaye le CD bootable de WXP. Ca marche avec le CD IDE, mais meme resultat.
Je me suis dit, on va mettre un DD sur la meme nappe IDE comme ca WXP va s'installer sur le DD IDE ... Meme resultat que plus haut : ecran noir avec promteur qui clignotte.
Quelqu'un aurait une idee de ce qui peut clocher ?
