Nero 8, gravure impossible fonction disc at once - Matériels & problèmes divers - Hardware
Marsh Posté le 21-12-2010 à 18:11:45
je rajoute le fichier Log si des fois ca peut aider
1K22-0867-0795-66M4-5624-0677-****
8K24-4225-1105-EKK5-5000-0021-****
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
Recorder: <HL-DT-ST DVDRAM GSA-T20N>Version: WR02 - HA 1 TA 0 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <HL-DT-ST DVDRAM GSA-T20N >Version: WR02 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-T20N E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1918MB (1964580kB)
Free physical memory: 1063MB (1088924kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.12.2010
Compilation ISO
18:01:14 #1 SPTI -1169 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1169)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x04
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 0F 04 04 00 80
18:01:20 #2 SPTI -1135 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x71 00 03 00 00 00 00 0A 35 2D 03 0F 0C
18:01:20 #3 Phase 101 File dlgbrnst.cpp, Line 1764
Formatting disc failed
18:01:20 #4 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
18:01:20 #5 CDR -1135 File ThreadedTransferInterface.cpp, Line 1742
Write error
E: HL-DT-ST DVDRAM GSA-T20N
18:01:20 #6 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1742
Could not perform start of Disc-at-once
18:01:20 #7 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
18:01:20 #8 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 2.4x (3 324 Ko/s)
18:01:20 #9 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:01:22 #10 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
18:01:22 #11 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Marsh Posté le 21-12-2010 à 11:56:23
Bonjour à tous et à toutes,
Je n'ai jamais eu de soucis sur mon pc pour graver avec Nero 8 des DVD et la depuis hierpour une raison X, cette sale bête ne veut plus graver
Problème de gravure avec Disk at once ca me met.
J'ai téléchargé Nero 10 tout installé et tout le tralala et même problème (donc j'ai viré nero 10 depuis)
en farfouillant sur le net j'ai vu 2/3 que je ne comprend pas et je n'ai pu solutionner mon problème.
Dans gestionnaire de périphériques, controleur de stockage, A29VB611 IDE Controller à un panneau jaune attention et il ne veut pas se mettre à jour
je sais pas si ca à un lien ou pas.
Pour info je ne peux pas graver en autre chose que disck at once car c'est grisé.
Ca me gonfle un peu que du jour au lendemain pouf ca marche plus
si vous pouviez m'aider ce serait génial.
point par point aussi si possible
merci d'avance
