graphic bench problem - Matériels & problèmes divers - Hardware
Marsh Posté le 23-01-2003 à 21:07:26
powerstrip pour verifier les frequences GPU et RAM.
Marsh Posté le 23-01-2003 à 21:27:01
arf powerstrip t sur? pcq moi il m'indique des fréquences un peu bizarre je trouve
Marsh Posté le 23-01-2003 à 21:28:10
| Sekin a écrit : arf powerstrip t sur? pcq moi il m'indique des fréquences un peu bizarre je trouve |
c'est à dire?
Marsh Posté le 23-01-2003 à 21:28:20
Donne nous ce qu'il te dit ![]()
Marsh Posté le 23-01-2003 à 21:41:03
iagnostic report - generated on 23/01/2003
PowerStrip build - 366
Windows build - v.5.0.2195.2.Service Pack 3
DirectX build - v.5.1.2600.881 built by: Lab06_N(mmbuild)
OpenGL renderer - (n/a)
System board
CPU speed - 1535 MHz
Type - VIA VT8367/VT8233A-A7V333
BIOS - Award Bios, 10/29/2002
AGP aperture - 32 MB
AGP transfer mechanism - DMA
AGP non-local memory - 124,8 MB
AGP driving value - 9Ah (N-ctrl=9, P-ctrl=10)
AGP revision - 2.00
AGP transfer rates supported - 1x, 2x, 4x
Current AGP transfer rate - 4x
Sideband addressing - Enabled
Fast write protocol - (n/a)
AGP texturing - Enabled
Graphics card #1
Identity - RADEON 9700/9500 Series
Memory clock - 270,00 MHz
Engine clock - 276,75 MHz
IRQ - 16, shared
AGP revision - 2.00
Display driver - ati2dvag.dll, v.6.13.10.6218
DirectX driver - ati2dvag.dll, v.6.13.10.6218
Attached monitor - NOKIA 447ZiPlus (Nokia Display Products Oy)
Monitor caps (1) - 1280x1024, 72kHz, 150Hz
Device enumeration
RADEON 9700/9500 Series (4E451002h) - using IRQ16
ATI Display controller (4E651002h)
AsusTek CPU-to-PCI/AGP bridge (30991106h)
VIA PCI-to-PCI/AGP bridge (B0991106h)
Realtek Ethernet controller (813910ECh) - using IRQ16
Creative Labs Audio device (00041102h) - using IRQ17
Creative Labs Input controller (70031102h)
Creative Labs Firewire bus (40011102h) - using IRQ18
D-Link Ethernet controller (802910ECh) - using IRQ18
AsusTek PCI-to-ISA bridge (31471106h)
AsusTek IDE controller (05711106h)
AsusTek Universal serial bus (USB) (30381106h) - using IRQ21
jsais pas pk mais j'ai l'impression de m'etre fait avoir nan?
Marsh Posté le 23-01-2003 à 21:45:33
| Sekin a écrit : |
T'as bien une 9700 "non pro"
La 9700 est a 275/270 et la 9700 Pro a 325/310.
Marsh Posté le 23-01-2003 à 21:47:42
ben vi j'ai une pro et le pire dans tout ca c que jsuis déja allé changer une fois mon ancienne.
et encore pire c qu'ils ne vendent meme pas de radeon 9700 128ddr dans leur magasin.
ils se foutent vraiment de la gueule des gens.
pfffff vais les engueuler
et me demander un écran tft en dédomagement olollllll
non mé jpaye assez cher pis ils me refourguent un carte rien a voir
Marsh Posté le 23-01-2003 à 21:50:08
Tu l'avais payee combien ?
Marsh Posté le 23-01-2003 à 21:51:08
470 euro un truc du genre.
mais sur la facture c bien mis radeon 9700 pro ![]()
Marsh Posté le 23-01-2003 à 21:52:37
Et c'est bien le prix d'une 9700 Pro aussi ![]()
Marsh Posté le 23-01-2003 à 21:59:37
ben au départ ils m'avaient filé une radeon 9700 pro de connect 3d pis la c une point of view pis jtrouvais pas de trace d'une radeon 9700 sauf sur un site de vente en hollande
vais leurs montrer preuves a l'appuis
mais t'es bien sur de powerstrip hein? que j'aie pas l'air con devant le mec lol
Marsh Posté le 23-01-2003 à 22:05:33
Tu peux faire des benchs si tu veux etre sur.
Par exemple les benchs theoriques de 3D Mark 2001 et tu compares avec les scores du test de Marc : http://www.hardware.fr/articles/449/page3.html
Ou tu compares avec d'autres tests.
Fait gaffe, ton CPU est bien plus leger que celui du test, donc compare pas avec un test ou le CPU est important meme en haute resolution (comme UT 2003 ou Comanche 4 par exemple).
Marsh Posté le 23-01-2003 à 22:09:41
C'est peut etre moi qui est pas bien compris mais il me semble que tu as une simple 9700...
Marsh Posté le 23-01-2003 à 22:13:47
Oui c'est ca. Mais c'est que le magasin lui a normalement vendu une 9700 Pro d'ou probleme ![]()
Marsh Posté le 23-01-2003 à 22:15:22
ben pour t'avouer j'ai remarqué une légere baisse de résultats de 3dmark je penssait que c'était du a mes paramétrages lol
ben apparement non
pffff demain a la premiere heure je retourne changer cette carte.
Point of View ATI Radeon 9700 128MB DDR TV-OUT DVI 275/270 345,00
Point of View ATI Radeon 9700 PRO 128MB DDR TV-OUT DVI 325/310 459,00
regarde c ds le magasin en hollande.
pire sur ma boite ya meme pas mis l'étiquette PRO a coté du 9700 128mb
http://www.sweclockers.com/html/re [...] hp?page=13
Marsh Posté le 23-01-2003 à 21:06:39
hellooooo ,
enfait c tout con ma question lol
je possede une radeon 9700 'pro'.
enfait j'aimerai vérifier si c bien une pro ou pas.
je trouve pas de programe pour faire un tit bench du core et de la vitesse de la ram.
comme ca jserai fixé une fois pour toute
thxxxx
