Ecran bleu même après reformatage - Matériels & problèmes divers - Hardware
MarshPosté le 23-04-2015 à 10:57:59
Depuis 2 semaines je suis confronté à un problème, j'ai des blue screen quand je lance seulement certaines applications:
- Google Chrome - League of Legend (un jeu)
ça vient du driver de ma carte graphique, voici les résultats de mon test avec "WhoCrashed":
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 21/04/2015 09:30:34 GMT your computer crashed crash dump file: C:\Windows\Minidump\042115-34913-01.dmp This was probably caused by the following module: atikmpag.sys (atikmpag+0x7B78) Bugcheck code: 0x116 (0xFFFFFA8009719010, 0xFFFFF8800A199B78, 0x0, 0x2) Error: VIDEO_TDR_ERROR file path: C:\Windows\system32\drivers\atikmpag.sys product: AMD driver company: Advanced Micro Devices, Inc. description: AMD multi-vendor Miniport Driver Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.). Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
On Tue 21/04/2015 09:30:34 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: atikmpag.sys (0xFFFFF8800A199B78) Bugcheck code: 0x116 (0xFFFFFA8009719010, 0xFFFFF8800A199B78, 0x0, 0x2) Error: VIDEO_TDR_ERROR file path: C:\Windows\system32\drivers\atikmpag.sys product: AMD driver company: Advanced Micro Devices, Inc. description: AMD multi-vendor Miniport Driver Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.). Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
On Mon 20/04/2015 16:35:03 GMT your computer crashed crash dump file: C:\Windows\Minidump\042015-34039-01.dmp This was probably caused by the following module: atikmpag.sys (atikmpag+0x7B78) Bugcheck code: 0x116 (0xFFFFFA8006289010, 0xFFFFF880047A9B78, 0x0, 0x2) Error: VIDEO_TDR_ERROR file path: C:\Windows\system32\drivers\atikmpag.sys product: AMD driver company: Advanced Micro Devices, Inc. description: AMD multi-vendor Miniport Driver Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed. A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.). Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
J'ai reformaté, mis les pilotes à jour, Tenter de télécharger un autre pilote depuis amd et son catalyst center qui cherche ma carte graphique et télécharge le driver qui est compatible avec mais, ça ne fonctionne pas la carte graphique ne le reconnait pas.
Je vous en pris aidez-moi je ne sais plus quoi faire .
Marsh Posté le 23-04-2015 à 10:57:59
- Google Chrome
product: AMD driver
product: AMD driver
product: AMD driver
Cordialement.
