Crash PC carte TNT Leadtek Winfast DTV1000S
Crash PC carte TNT Leadtek Winfast DTV1000S - Matériels & problèmes divers - Hardware
Marsh Posté le 16-11-2007 à 21:22:36
je viens d'acquérir une carte TNT Leadtek Winfast DTV1000S. En effet, lors d'un changement de chaine ou lors de l'arrêt du programme, le PC redémarre. J'ai effectué le maximum de mise à jour possible mais le (gros) problème demeure. Savez-vous comment régler ce problème.
Merci beaucoup.
Sylvain.
PS : ci-dessous un dxdiag qui peut être utile
System Information
Time of this report: 11/16/2007, 21:19:11
       Machine name: TITANIUM
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
           Language: French (Regional Setting: French)
System Manufacturer: NVIDIA
       System Model: AWRDACPI
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: AMD Athlon(tm) XP 2000+,  MMX,  3DNow, ~1.7GHz
             Memory: 512MB RAM
          Page File: 837MB used, 410MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: RADEON 9250
     Manufacturer: ATI Technologies Inc.
        Chip type: RADEON 9250 AGP (0x5960)
         DAC type: Internal DAC(400MHz)
       Device Key: Enum\PCI\VEN_1002&DEV_5960&SUBSYS_59601002&REV_01
   Display Memory: 128.0 MB
     Current Mode: 1024 x 768 (32 bit) (60Hz)
          Monitor: Écran Plug-and-Play
  Monitor Max Res: 1600,1200
      Driver Name: ati2dvag.dll
   Driver Version: 6.14.0010.6614 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 5/3/2006 17:51:00, 258048 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: ati2mtag.sys
    Mini VDD Date: 5/3/2006 17:50:42, 1540608 bytes
Device Identifier: {D7B71EE2-1A20-11CF-646A-6A79A0C2CB35}
        Vendor ID: 0x1002
        Device ID: 0x5960
        SubSys ID: 0x59601002
      Revision ID: 0x0001
      Revision ID: 0x0001
      Video Accel: ModeMPEG2_C ModeMPEG2_D
 Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBLineReplicate
                   {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: NVIDIA(R) nForce(TM) Audio
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: NFORCE_VAD
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: nvapu.sys
         Driver Version: 6.14.0462.0000 (English)
            WHQL Logo'd: Yes
          Date and Size: 4/13/2005 12:34:02, 414464 bytes
            Other Files:
        Driver Provider: NVIDIA Corporation
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 200, 100000
Static/Strm HW Mix Bufs: 52, 49
 Static/Strm HW 3D Bufs: 48, 48
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
            Description: Lecture sur modem n° 0 (émulé)
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID: 1
             Product ID: 81
                   Type: Émulé
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
               Registry: OK
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xCC0
            Description: Enreg. sur modem n° 0 (émulé)
  Default Sound Capture: No
  Default Voice Capture: No
            Driver Name:
         Driver Version:
      Driver Attributes:
          Date and Size:
              Cap Flags: 0x20
           Format Flags: 0x0
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  NVIDIA(R) nForce(TM) Audio, Software (Kernel Mode), Output, DLS, Internal
                  Mappeur MIDI Microsoft [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SynthÚ. SW table de sons GS Mic [Émulé], Hardware (Not Kernel Mode), Output, No DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Microsoft Wireless Intellimouse Explorer® 1.0A
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0059
        FF Driver: n/a
      Device Name: HID compliant keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC30E
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 00:08:44, 57600 bytes
| Driver: usbd.sys, 8/24/2001 15:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Périphérique clavier PIH
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 23:45:14, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 01:45:12, 25216 bytes
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:55:12, 40840 bytes
+ Souris HID
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 23:37:26, 23680 bytes
| Driver: mouhid.sys, 8/24/2001 15:00:00, 12288 bytes
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Connexion au réseau local - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 Kbit/s
Voxware SC06 6,4 Kbit/s
Voxware SC03 3,2 Kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 0.1 GB
Total Space: 20.6 GB
File System: NTFS
      Model: HDS728080PLAT20
      Drive: D:
 Free Space: 12.3 GB
Total Space: 73.2 GB
File System: NTFS
      Model: WDC WD800BB-00DKA0
      Drive: E:
 Free Space: 0.0 GB
Total Space: 57.9 GB
File System: NTFS
      Drive: F:
      Model: JLMS DVD-ROM LTD-165H
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (French), 8/3/2004 23:59:54, 49536 bytes
      Drive: G:
      Model: HL-DT-ST DVDRAM GSA-4165B
System Devices
     Name: WinFast DTV1000 S
Device ID: PCI\VEN_1131&DEV_7130&SUBSYS_6655107D&REV_01\4&3B1D9AB8&0&4040
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (French), 8/4/2004 00:54:30, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 130048 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (French), 8/3/2004 23:15:22, 140928 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (French), 8/3/2004 23:08:04, 48640 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:55:04, 23552 bytes
   Driver: C:\WINDOWS\system32\kstvtune.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 61952 bytes
   Driver: C:\WINDOWS\system32\ksxbar.ax, 5.03.2600.2180 (English), 8/4/2004 00:55:04, 43008 bytes
   Driver: C:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 91648 bytes
   Driver: C:\WINDOWS\system32\vidcap.ax, 5.01.2600.2180 (English), 8/4/2004 00:55:04, 28672 bytes
   Driver: C:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.2180 (French), 8/4/2004 00:54:44, 54784 bytes
   Driver: C:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.2180 (French), 8/4/2004 00:54:30, 47616 bytes
   Driver: C:\WINDOWS\system32\msh263.drv, 5.01.2600.2180 (French), 8/4/2004 00:55:04, 294912 bytes
   Driver: C:\WINDOWS\system32\msyuv.dll, 5.03.2600.2180 (English), 8/4/2004 00:54:36, 17408 bytes
   Driver: C:\WINDOWS\system32\BdaPlgIn.ax, 5.03.2600.2180 (French), 8/4/2004 00:55:04, 18432 bytes
   Driver: C:\WINDOWS\system32\MSDvbNP.ax, 6.05.2600.2180 (English), 8/4/2004 00:55:04, 56832 bytes
   Driver: C:\WINDOWS\system32\PsisRndr.ax, 6.05.2600.2180 (English), 8/4/2004 00:55:04, 33280 bytes
   Driver: C:\WINDOWS\system32\PsisDecd.dll, 6.05.2600.2640 (English), 3/25/2005 22:43:49, 363520 bytes
   Driver: C:\WINDOWS\system32\drivers\BdaSup.sys, 5.03.2600.2180 (English), 8/3/2004 23:10:14, 11776 bytes
   Driver: C:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.0000 (English), 8/23/2001 17:47:20, 8192 bytes
   Driver: C:\WINDOWS\system32\drivers\3xHybrid.sys, 1.03.0003.0005 (English), 7/30/2007 16:02:10, 702336 bytes
   Driver: C:\WINDOWS\system32\NXPMV32.dll, 1.00.0000.0001 (English), 7/13/2007 12:28:36, 104992 bytes
     Name: NVIDIA nForce2 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EF&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&05
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EE&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&02
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01ED&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&03
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EC&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&04
   Driver: n/a
     Name: NVIDIA nForce2 Ultra 400 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EB&SUBSYS_0C1710DE&REV_C1\3&13C0B0C5&0&01
   Driver: n/a
     Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01E8&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&F0
   Driver: n/a
     Name: Pont CPU hôte standard PCI
Device ID: PCI\VEN_10DE&DEV_01E0&SUBSYS_00000000&REV_C1\3&13C0B0C5&0&00
   Driver: n/a
     Name: Pont PCI vers PCI standard PCI
Device ID: PCI\VEN_10DE&DEV_006C&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&40
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (French), 8/4/2004 01:37:06, 68608 bytes
     Name: NVIDIA(R) nForce(TM) Audio Codec Interface
Device ID: PCI\VEN_10DE&DEV_006A&SUBSYS_1C02147B&REV_A1\3&13C0B0C5&0&30
   Driver: C:\WINDOWS\system32\drivers\nvax.sys, 6.14.0462.0000 (English), 4/13/2005 12:32:42, 53376 bytes
   Driver: C:\WINDOWS\system32\drivers\nvarm.sys, 6.14.0462.0000 (English), 4/13/2005 12:34:22, 66688 bytes
   Driver: C:\WINDOWS\system32\drivers\nvmcp.sys, 6.14.0462.0000 (English), 4/13/2005 12:34:22, 937984 bytes
   Driver: C:\WINDOWS\system32\drivers\nvapu.sys, 6.14.0462.0000 (English), 4/13/2005 12:34:02, 414464 bytes
   Driver: C:\WINDOWS\system32\nvack.dll, 6.14.0462.0000 (English), 4/13/2005 12:34:24, 7680 bytes
   Driver: C:\WINDOWS\system32\nvasio.dll, 6.14.0462.0000 (English), 4/13/2005 12:34:26, 30208 bytes
   Driver: C:\WINDOWS\system32\nvopenal.dll, 6.14.0462.0000 (English), 4/13/2005 12:34:24, 54272 bytes
   Driver: C:\WINDOWS\system32\OpenAL32.dll, 6.14.0462.0000 (English), 4/13/2005 12:34:22, 21504 bytes
   Driver: C:\WINDOWS\system32\ALut.dll, 6.14.0462.0000 (English), 4/13/2005 12:34:22, 5120 bytes
   Driver: C:\WINDOWS\system32\NVCOAD.DLL, 1.00.0000.0017 (English), 4/4/2005 19:00:26, 32256 bytes
     Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_10DE&DEV_0068&SUBSYS_1C02147B&REV_A4\3&13C0B0C5&0&12
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:38, 26624 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:44, 142976 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (French), 8/4/2004 01:54:44, 77312 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:44, 57600 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:54:28, 7168 bytes
     Name: Contrôleur hôte USB OpenHCD standard
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_1C02147B&REV_A4\3&13C0B0C5&0&11
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:38, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_1C02147B&REV_A4\3&13C0B0C5&0&10
     Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_0066&SUBSYS_1C02147B&REV_A1\3&13C0B0C5&0&20
   Driver: C:\WINDOWS\system32\DRIVERS\NVENET.sys, 4.14.0001.0416 (English), 1/29/2004 01:45:00, 93764 bytes
   Driver: C:\WINDOWS\system32\NVCOE.DLL, 1.00.0000.0014 (English), 1/29/2004 02:22:00, 31744 bytes
     Name: NVIDIA nForce2 ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_0065&SUBSYS_1C02147B&REV_A2\3&13C0B0C5&0&48
   Driver: n/a
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0064&SUBSYS_1C02147B&REV_A2\3&13C0B0C5&0&09
   Driver: n/a
     Name: Pont ISA standard PCI
Device ID: PCI\VEN_10DE&DEV_0060&SUBSYS_00000000&REV_A4\3&13C0B0C5&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (French), 8/24/2001 15:00:00, 36224 bytes
Device ID: PCI\VEN_1002&DEV_5960&SUBSYS_59601002&REV_01\4&102AC5BC&0&00F0
   Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6614 (French), 5/3/2006 17:50:42, 1540608 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 5/3/2006 17:10:35, 40960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 5/3/2006 18:09:33, 28080 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 10/14/2005 15:10:12, 58560 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 2/8/2006 21:44:05, 929 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 2/8/2006 21:44:05, 1114674 bytes
   Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6614 (English), 5/3/2006 17:51:00, 258048 bytes
   Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0313 (English), 5/3/2006 17:09:20, 282624 bytes
   Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 5/3/2006 17:45:14, 26112 bytes
   Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0399 (English), 5/3/2006 17:35:25, 2693280 bytes
   Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0099 (English), 5/3/2006 17:29:13, 1408000 bytes
   Driver: C:\WINDOWS\system32\atiicdxx.dat, 4/28/2006 21:05:14, 127614 bytes
   Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 5/3/2006 17:43:14, 53248 bytes
   Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 5/3/2006 17:15:10, 17408 bytes
   Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 16:01:04, 24064 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4132 (English), 5/3/2006 17:43:46, 413696 bytes
   Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4132 (English), 5/3/2006 17:44:55, 61440 bytes
   Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2498 (English), 5/3/2006 17:45:35, 114688 bytes
   Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 5/3/2006 17:45:22, 77824 bytes
   Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2500 (English), 5/3/2006 17:45:07, 41984 bytes
   Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0035 (French), 5/3/2006 17:15:58, 151552 bytes
   Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2314.20173 (French), 5/3/2006 17:12:26, 286720 bytes
   Driver: C:\WINDOWS\system32\atifglpf.xml, 1/26/2006 01:48:03, 6005 bytes
   Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5819 (English), 5/3/2006 17:18:04, 5033984 bytes
   Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1072 (English), 5/3/2006 17:21:20, 6684672 bytes
   Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 5/3/2006 17:54:10, 307200 bytes
     Name: RADEON 9250 - Secondary
Device ID: PCI\VEN_1002&DEV_5940&SUBSYS_59611002&REV_01\4&102AC5BC&0&01F0
DirectX Components
   ddraw.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 French Final Retail 8/24/2001 15:00:00 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 229888 bytes
dpmodemx.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 24064 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/24/2001 15:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:50 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:50 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:52:58 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:52:58 3584 bytes
 dpvoice.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 213504 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:50 83456 bytes
  dpvvox.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 116736 bytes
  dpvacm.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 60928 bytes
dpserial.dll: 5.00.2134.0001 French Final Retail 8/24/2001 15:00:00 54032 bytes
  dinput.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 165376 bytes
 dinput8.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 187904 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/24/2001 15:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 French Final Retail 8/24/2001 15:00:00 395264 bytes
     joy.cpl: 5.03.2600.2180 French Final Retail 8/4/2004 01:55:04 70144 bytes
   gcdef.dll: 5.01.2600.0000 French Final Retail 8/24/2001 15:00:00 77824 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:05:42 35328 bytes
  dsound.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 72192 bytes
  dmusic.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:54:24 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 9/23/2007 18:11:36 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 9/23/2007 18:11:23 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 9/23/2007 18:11:26 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 9/23/2007 18:11:27 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 9/23/2007 18:11:27 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 9/23/2007 18:11:28 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 9/23/2007 18:11:29 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 9/23/2007 18:11:30 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 9/23/2007 18:11:31 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 9/23/2007 18:11:32 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 9/23/2007 18:11:37 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:38 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:38 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:39 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:39 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:35 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:36 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 9/23/2007 18:11:35 223232 bytes
   dx7vb.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 619008 bytes
   dx8vb.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:24 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/24/2001 15:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:54:32 1028096 bytes
 wsock32.dll: 5.01.2600.2180 French Final Retail 8/4/2004 01:54:48 25088 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:54:22 70656 bytes
 devenum.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:24 59904 bytes
  dxmasf.dll: 6.04.0009.1133 French Final Retail 8/24/2006 13:17:20 500278 bytes
mciqtz32.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:30 35328 bytes
 mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:55:04 148992 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:54:34 14336 bytes
  encapi.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:26 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:38 192512 bytes
     qdv.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:38 279040 bytes
    qdvd.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:38 386048 bytes
   qedit.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:38 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:53:42 733696 bytes
  quartz.dll: 6.05.2600.2749 French Final Retail 8/30/2005 04:55:43 1293312 bytes
 strmdll.dll: 4.01.0000.3936 French Final Retail 8/24/2006 13:19:40 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:55:04 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:55:04 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:54:30 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:54:30 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:54:30 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:54:30 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:54:30 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:55:04 154624 bytes
mswebdvd.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:36 204800 bytes
      ks.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:15:22 140928 bytes
  ksproxy.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 130048 bytes
  ksuser.dll: 5.03.2600.2180 French Final Retail 8/4/2004 00:54:30 4096 bytes
  stream.sys: 5.03.2600.2180 French Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 French Final Retail 8/3/2004 22:58:40 5376 bytes
   mspqm.sys: 5.01.2600.2180 French Final Retail 8/3/2004 22:58:42 4992 bytes
 mskssrv.sys: 5.03.2600.2180 French Final Retail 8/3/2004 22:58:42 7552 bytes
  swenum.sys: 5.03.2600.2180 French Final Retail 8/4/2004 02:05:42 4352 bytes
   mstee.sys: 5.03.2600.2180 French Final Retail 8/3/2004 21:58:40 5504 bytes
 bdaplgin.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 18432 bytes
  bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 11776 bytes
  msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:55:04 56832 bytes
psisdecd.dll: 6.05.2600.2640 English Final Retail 3/25/2005 22:43:49 363520 bytes
 psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:55:04 33280 bytes
   ipsink.ax: 5.03.2600.2180 French Final Retail 8/3/2004 23:55:04 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:55:04 118272 bytes
  ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 10880 bytes
     mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 French Final Retail 8/4/2004 01:54:36 1433600 bytes
    slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 17024 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:55:04 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:54:36 17408 bytes
 kstvtune.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 61952 bytes
   ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:55:04 43008 bytes
 kswdmcap.ax: 5.03.2600.2180 French Final Retail 8/4/2004 00:55:04 91648 bytes
vfwwdm32.dll: 5.01.2600.2180 French Final Retail 8/4/2004 00:54:44 54784 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 French Final Retail 8/4/2004 01:54:48 51200 bytes
DirectShow Filters
Codecs flux de données WDM VBI:
Codec NABTS/FEC VBI,0x00200000,2,1,,5.03.2600.2180
Décodeur CC,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
InterVideo G726Dec DMO,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.06.0001.0004
CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,
CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,
FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,
FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,
Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,
Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,
Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,
OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,
Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,
Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,
Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,
Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,
Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,
Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,
Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,6.00.0006.0109
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0003.1045
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0003.1045
Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.02.0000.0027
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0003.1045
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,4.02.0000.0027
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
WinFast PSI Parser,0x00200000,0,0,WFPSI.ax,2.00.0002.0029
LeadTek Audio Decoder,0x00400000,1,1,WFDADC.ax,6.00.0000.3514
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
MPEG2 TS Source,0x00200000,0,1,iviMpeg2TsReader.ax,
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
Intervideo 3gFileSource,0x00200000,0,2,Source3g.ax,9.00.0000.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
Intervideo AMR Decoder,0x00200000,1,1,AmrDec.ax,8.01.0000.0000
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,4.02.0000.0027
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
InterVideo Demultiplexer,0x00200000,1,1,IVIdemux.ax,3.02.0055.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Genesis VBI Sink,0x00800000,1,0,GdiVbi.ax,5.05.0000.0019
Leadtek Image Process Filter,0x00200000,1,1,WFVMSK.ax,1.00.0000.0004
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
Leadtek Audio Decoder,0x00601000,1,1,WFADC.ax,3.05.0000.1501
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
RadLight APE DirectShow Filter,0x00600000,0,1,RLAPEDec.ax,1.00.0000.0004
Gretech Video Filter,0x00200000,1,1,GVF.ax,
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.02.0000.0027
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.02.0000.0027
Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WinFast TeleText Decoder,0x00200000,1,0,TTXDecoder.dll,1.00.0000.0003
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.02.0000.0027
LeadTek Demultiplexer,0x00200000,1,0,WFDDMUX.ax,1.00.0000.4801
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0121.0000
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.07.0121.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
LeadTek Audio Encoder,0x00200000,2,0,WFAENC.ax,2.00.0000.5101
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.02.0000.0027
Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.02.0000.0027
Leadtek MPEG Muxer,0x00200000,2,1,WFDMUX.ax,5.00.0000.3602
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
LeadTek DTV Video Decoder,0x00400000,2,3,WFDVSD.ax,6.00.0000.3431
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
Intervideo H.264 Decoder,0x00808000,1,1,iviH264.dll,2.02.0004.0002
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,4.02.0000.0027
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.02.0000.0027
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.06.0001.0004
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.02.0000.0027
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
Gretech Audio Filter,0x00200000,1,1,GAF.ax,
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,6.00.0088.0000
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.02.0000.0027
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
InterVideo PSIP/SI Filter,0x00200000,0,0,PsiDecod.ax,1.00.0000.0001
Microcrap MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,4.01.0000.3917
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,1.00.0000.0003
Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,
Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.02.0000.0027
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0121.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.00.0001.0003
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
WinFast Data Transform filter,0x00200000,0,0,WFDT.ax,5.13.0001.2003
Avi Splitter,0x00600001,1,1,AviSplitter.ax,1.00.0000.0007
Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.00.0001.0003
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Leadtek TS Writer,0x00200000,1,0,TSDMP.ax,2.00.0001.0056
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0121.0000
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.02.0000.0027
AC3Filter,0x40000000,1,1,ac3filter.ax,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
InterVideo Navigator,0x00190000,0,3,Ivinav.ax,6.00.0088.0000
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.02.0000.0027
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Intervideo QT source,0x00200000,0,1,iviQTsource.ax,1.00.0000.0001
DTS/AC3 Source,0x00400000,0,1,dtsac3source.ax,1.00.0000.0001
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0003.1045
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.02.0000.0027
Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
WinFast Subtitle Decoder,0x00200000,1,0,DVBSbtle.ax,1.00.0000.0006
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2600.2180
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.02.0000.0027
Avi Source,0x00600001,0,0,AviSplitter.ax,1.00.0000.0007
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
Leadtek YUY2 DeInterlace,0x00200000,1,1,WFDIF.ax,3.00.0000.2207
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.02.0000.0027
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.02.0000.0027
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.02.0000.0027
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.02.0000.0027
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0121.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink MPEG Video Encoder(Leadtek),0x00200000,1,1,LeadtekVidEnc.ax,6.00.0001.3827
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.02.0000.0027
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.2180
InterVideo Subtitle,0x00200000,1,1,IVISubtitle.ax,1.00.0000.0000
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Périphériques de répartition Tree/Splitter WDM:
Convertisseur en T/site-à-site,0x00200000,1,1,,5.03.2600.2180
Transformateurs de répartition de données WDM:
Suppresseur d'écho acoustique (Noyau Microsoft),0x00000000,0,0,,
Synthétiseur de table de sons GC noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Synthétiseur DLS du noyau Microsoft,0x00200000,1,1,,5.03.2600.2180
Filtre de décodeur DRM (Noyau Microsoft),0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0003.1045
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.02.0000.0027
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Codec Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4  VKI  Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4  VKI  Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4  VKI  Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Vidéo 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
NVIDIA(R) nForce(TM) Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Enreg. sur modem n° 0,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Synthé. SW table de sons GS Mic,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques de capture de flux WDM:
NVIDIA(R) nForce(TM) Audio,0x00200000,5,5,,5.03.2600.2180
WinFast DTV1000 S BDA Analog Capture,0x00200000,4,0,,5.03.2600.2180
Périphériques de répartition de rendu WDM:
Filtres source BDA:
WinFast DTV1000 S BDA DVBT Tuner,0x00200000,2,0,,5.03.2600.2180
Filtres de rendu BDA:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBS Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PsisRndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2600.2180
Périphériques de distribution de flux WDM:
WinFast DTV1000 S BDA Analog Xbar,0x00200000,3,0,,5.03.2600.2180
Périphériques de répartition de mélangeur WDM:
Mélangeur audio Wave de noyau Microsoft,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Transformateurs de répartition de communications WDM:
Audio Renderers:
NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Lecture sur modem n° 0 (émulé),0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
Lecture sur modem n° 0,0x00200000,1,0,quartz.dll,6.05.2600.2749
Périphériques système répartis WDM:
NVIDIA(R) nForce(TM) Audio,0x00200000,15,6,,5.03.2600.2180
Composant récepteur BDA:
WinFast DTV1000 S BDA Digital Capture,0x00200000,2,0,,5.03.2600.2180
Détrameur décalage BDA,0x00600000,1,1,,5.03.2600.2180
Filtre BDA MPE,0x00600000,1,1,,5.03.2600.2180
Marsh Posté le 16-11-2007 à 21:32:48
Déjà avec un vrai OS ca marcherait surement mieux (titanium ca pue)
Sinon ton alim qui suit pas?
Memtest?
Marsh Posté le 21-11-2007 à 16:18:05
Ce que je ne comprends pas, c'ess que le tout marche parfaitement avec Poutchin TV mais pas avec Win Fast TV ce qui me gène car je souhaiterais pouvoir utiliser ma télécommande.
Marsh Posté le 21-11-2007 à 16:21:57
Pas de support ici pour les versions de XP warez.
| Un malentendu du cul | boum boum ! | La roulette
