Comment recuperer des drivers sur un pc [DRIVERS] - Matériels & problèmes divers - Hardware
Marsh Posté le 13-09-2003 à 18:07:19
| Vendeeman a écrit : Voici mon probleme: ma tante à recupérer une imprimante konica 7410 que mon pere lui a vendue. Sur son pc il avait les drivers Xp fournit par sa boite. Aujourd'hui ses drivers son introuvables sur le net et n'existe pas. Je voudrais savoir comment faire pour recuperer des driver d'imprimante sur un pc pr l'installer sur un autre |
7410 Print Driver Download
By choosing to download your selected file, you agree that Konica Australia PTY LTD cannot be held responsible for the results of installing this software on your PC. As software and hardware configurations can be subject to conflicts, it is advised to back up any important files prior to installation.
For more information or instructions, contact your local Konica service location.
BE SURE TO SELECT THE CORRECT FILE BEFORE DOWNLOADING THE DRIVER!
Windows 95 Drivers:
GDI Driver - Version 1.0 - Date Posted: 2/1/98 (7410GDI9.ZIP)
PCL Centronics Driver - Version 1.0 - Date Posted: 2/1/98 (7410PCL5.ZIP)
(PSDRV_2.ZIP)
PCL Driver Disk one of two: (7410PCL1.ZIP)
PCL Driver Disk two of two: (7410PCL2.ZIP)
TWAIN Driver Version 1.1 for Microsoft Windows 3.1 & Windows 95 (TW7410.ZIP)
(After download unzip TW7410.ZIP to a Disk. Run Setup from Disk Drive).
Windows 3.1x Drivers:
(7410D3-1.ZIP)
Windows NT, 2000 & XP Drivers
Please Note: There are no Konica print drivers available to support printing from Windows NT, 2000 & XP (at this time there are no plans to produce any), however depending on the Print option fitted to the 7410 (there were three Print Options available GDI, PCL & PCL Plus PS) printing may be possible by utilizing one of the drivers below.
To select a print driver for the 7410, the type of printer interface must be determined first. To determine the installed printer interface, perform the following:
1. Press [MENU], [7], [4] and [ENTER] twice to print the printer configuration. The printout will indicate the type of interface if PCL or PostScript. If the command is not accepted, a GDI interface is installed.
2. If a GDI interface is installed, no driver is available for Windows NT, 2000 & XP.
3. If PCL or PostScript is indicated, then select the HP LaserJet 4 PLUS for PCL or HP LaserJet 4/4M PLUS PS printer driver for PostScript.
Note:
1. The drivers in Step 3 above are available trough Windows NT, 2000 & XP.
2. As the drivers in Step 3 above were not created specifically for the 7410, print output cannot be guaranteed.
3. The 7410 was designed for use with Windows 3.1 & 95.
4. There is not Help Desk Support for print problems when using the drivers in Step 3 above to print from the Windows NT, 2000 & XP Operating Systems.
http://translate.google.com/transl [...] 8%26sa%3DG
Marsh Posté le 13-09-2003 à 17:59:09
Voilà en gros.
Merci d'avance a ceux qui s'interesseront à mon probleme
