3 BSOD sur XP nouvellement installé
3 BSOD sur XP nouvellement installé - Matériels & problèmes divers - Hardware
Marsh Posté le 08-10-2012 à 12:46:47
 J'ai eu plusieurs écran bleu différent en peu de temps et je n'arrive pas à en trouver la cause. Help merci :)
Ce que j'ai fais :
-Réinstallation en mettant les drivers constructeur.
-2 Tests de ram.
-2 Tests pour le disque dur un long,un court. 0x100000D1
-Changer la nappe de disque dur. 0x100000D1
-J'ai aussi changer le clavier
Pas d'overclock c'est un vieux packardbell ml2w d1521.
On Sun 07/10/2012 16:57:35 GMT your computer crashed
This was probably caused by the following module: ntoskrnl.exe (nt+0xA892)
Bugcheck code: 0xA (0x49507621, 0x2, 0x0, 0xFFFFFFFF804E63B9)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\ntoskrnl.exe
description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sun 07/10/2012 13:35:21 GMT your computer crashed
This was probably caused by the following module: acpi.sys (ACPI+0xB35E)
Bugcheck code: 0x100000D1 (0x2, 0xA, 0x0, 0x2)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\drivers\acpi.sys
description: Pilote ACPI pour NT
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
