Gravure difficile! [aide] - Matériels & problèmes divers - Hardware
Marsh Posté le 17-08-2002 à 12:15:01
Tu a peut être ton alim qui commence à fatigué. Essai avec une autre...
Marsh Posté le 17-08-2002 à 12:16:31
voilà le fichier log:
Nero Version: 5.5.6.4
Recorder: <Memorex Twelve MAXX 1032>Version: LSX2 - HA 0 TA 1 - 5.5.6.4
12:12:04 #11 Phase 24 File dlgbrnst.cpp, Line 1436
Caching of files started
12:12:09 #12 Phase 25 File dlgbrnst.cpp, Line 1436
Caching of files completed
12:12:09 #13 Phase 36 File dlgbrnst.cpp, Line 1436
Burn process started at 12x (1 800 KB/s)
12:12:09 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
12:12:09 #15 Text 0 File Mmc.cpp, Line 14709
Set BUFE: BURN-Proof -> ON
12:12:26 #16 SCSI -1106 File Cdrdrv.cpp, Line 1407
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0391EC28
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x00 0x96 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
12:12:26 #17 mmc -1106 File Writer.cpp, Line 321
Power calibration error
12:12:26 #18 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
12:12:27 #19 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
12:12:27 #20 CDR -201 File WriterStatus.cpp, Line 186
Invalid writestate
12:12:27 #21 TRANSFER -18 File WriterStatus.cpp, Line 186
Could not perform EndTrack
12:12:27 #22 SCSI -1176 File Cdrdrv.cpp, Line 1203
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
12:12:27 #23 mmc -1176 File WriterStatus.cpp, Line 225
Session fixation error
12:12:27 #24 TRANSFER -19 File WriterStatus.cpp, Line 225
Could not perform Fixation
12:12:27 #25 Text 0 File WriterStatus.cpp, Line 234
falling back to disc fixation
12:12:27 #26 SCSI -1176 File Cdrdrv.cpp, Line 1203
Sense Code: 0x72
Sense Qual: 0x04
12:12:27 #27 mmc -1176 File WriterStatus.cpp, Line 225
12:12:27 #28 TRANSFER -19 File WriterStatus.cpp, Line 225
12:12:27 #29 Phase 38 File dlgbrnst.cpp, Line 1436
Burn process failed at 12x (1 800 KB/s)
Marsh Posté le 17-08-2002 à 12:17:35
j'ai juste changer ma carte graphique d'une ATI RAGE FURY 128
à une GF4 TI4200, c'est quand meme pas elle qui bouffe tout ??
Marsh Posté le 17-08-2002 à 12:20:34
Cela vient de quoi ton DVD qui a rendu l'âme ?
J'te demande c'la parce que si ton alim commence à merder (surtansion) elle a p'être commencé avec le DVD et poursuit avec le graveur ![]()
Marsh Posté le 17-08-2002 à 12:21:30
Ta GF4 bouffe trop de ressource...
Donne ta config et type d'alim ?
Marsh Posté le 17-08-2002 à 12:25:34
le lecteur de DVD a commencé à partir apres le changement de la carte graphique.
Je l'ai testé sur un autre pc avec une alim toute neuve et puissante, mais il ne marche pas plus.
Quand a la gravure elle deconne depuis un peu plus longtemps, mais je mettais ça sur le dos de windows (ça faisait longtemps
qui etait installé, et generalement il tient pas la distance)
sinon le DVD, prend les cd, (c'est un slot-in) il les avale et les recrache quand j'appuis sur le bouton, donc c'est pas la partie mecanique, ensuite il est reconnu avec le bios, sous windows aussi, et le pseudo dos de windows.
Parcontre qu'il y est ou non un cd dedans, il ne le lit pas, d'ailleurs il ne detecte pas le cd apres l'insertion.
Marsh Posté le 17-08-2002 à 12:27:47
un duron 750 sur ABIT KT7, une alim 300W (mais acheté au debut quand on commençait à parler des alims plus ou moins de qualité)
je sais pas si elle les fait réellement!
là j'ai une carte reseau, une pctv aussi et un autre DD
Marsh Posté le 17-08-2002 à 12:28:56
euuuuh, "power calibration error", vois pas le rapport avec un pb d'alim.... cette étape consiste juste en l'étalonnage de la puissance du laser à utiliser, en fonction du support (il utilise une zone reservée du CDR pour ca....)
bref, pour moi, c soit un pb de support merdique (y crois pas trop), soit graveur a rendu l'âme
Marsh Posté le 17-08-2002 à 12:29:44
pour ton lecteur de DVD : t'as essayer de l'ouvrir et de le nettoyer ?
Marsh Posté le 17-08-2002 à 12:29:45
C'est la panne typique des lecteurs... Tu peut toujours essayer de nettoyer la lentille des fois c'la fonctionne.
Sinon elle est cuite
C'est quoi ton alim comme marque ?
Marsh Posté le 17-08-2002 à 12:35:11
Le mieux serait peut être d'essayer ton graveur sur une autre bécane...
Marsh Posté le 17-08-2002 à 13:14:19
est ce que ça ne pourrait pas etre nero?
parceque là je viens de graver mon backup sans "probleme"
avec Easy CD creator 4, bon le seul ennui que j'ai pu constater
c'est le niveau du cache qui passe de 100% à 1% puis remonte et ainsi de suite!
mais le cd est gravé pas de message d'erreur?? c'est étrangement bizarre tout ça
Marsh Posté le 17-08-2002 à 14:52:04
Fait gaffe NERO aime bien être tout seul comme logiciel de gravure
Marsh Posté le 17-08-2002 à 15:44:32
ouais mais je l'ai installé qu'apres, nero etait tout seul avant
Marsh Posté le 17-08-2002 à 12:10:31
voilà j'ai un gros probleme avec mon graveur, jusque là
je n'ai jamais eu de probleme avec lui, c'est un
memorex twelveMAX burnsproof IDE.
ça fait pas tres longtemps qu'il commence à me saouler, car il
ne veut plus graver!... mais je le garde parceque mon lecteur de DVD a rendu l'âme.
voilà ce qui se passe, je lance NERO je fais ma petite compil
(sauvegarde de quelques repertoires de mon DD) je lance la gravure (comme je l'ai toujours fais jusqu'ici)
il met en cache, et commence la gravure, mais stoppe directement
en me lançant à la tête un probleme electrique pas assez de puissance, qu'est ce que ça veut dire ce charabiat!!?
s'il n'avait pas assez de puissance, il foutrait un boxon avant non?
