[Topic Officiel] LITEON LDW-400D (DVD +R/-R)
LITEON LDW-400D (DVD +R/-R) [Topic Officiel] - Disque dur - Hardware
Marsh Posté le 29-04-2003 à 12:21:02
Enfin il est là depuis le temps que nous l'attendions !
http://images1.newegg.com/productimage/27-106-911-04.JPG
http://images2.newegg.com/productimage/27-106-911-03.JPG
300? conseillé pour le prix de lancement
? 4X Max DVD-R and +R Write, 2X Max DVD-RW Rewrite, 2.4X Max DVD+RW Rewrite,
 and 8X Max DVD-ROM Reading
? 24X Max CD-R Write, 10X Max CD-RW Rewrite and 32X Max CD-ROM Reading
? Conforms to DVD Specifications and DVD+R/+RW 4.7GB Basic Format Specifications
? Support DVD DAO, Incremental Recording, Restricted Overwrite, Sequential Write and
? Random Access Write
? Conforms to Orange Book Part 2, 3, Volume 2: High Speed & MMC2 commands
? Support  CD Fixed Packet, Variable Packet, TAO, SAO, DAO, Raw Mode Burning
 & Over-Burn Write
? Support Windows-XP requirement for DVD devices
? Operational in both Horizontal and Vertical Installation
? Plug & Play (with Emergency manual eject)
Specifications
 Speed :
 Media DVD-R/+R DVD-RW DVD+RW CD-R CD-RW
       Writing
 4X 2X 2.4X 24X (Z-CLV) 10X
 Media DVD-ROM CD-ROM
       Reading 8X 32X (CAV)
  *  Maximum drive performance is achieved with supported media.  Results may
      vary with non-supported media.
 Interface : E-IDE Connector
 Transfer Mode : Support up to Ultra-DMA Mode2   33.3MB/sec (UDMA-33)
 Access time : 250ms (typical on DVD disc), 300ms (typical on CD disc)
 Buffer Size : 8 MB
 Disc Formats : ALL formats of CD and DVD family, with dimension of 12cm or 8cm
 Compatibility : Windows 98SE/ME/2000/XP
 MTBF(Life) : 100,000 Hours
 Environment : (Temperture)
       Operating    5℃ to 40℃ ; Relative Humidity: 10% to 80% (non-condensing)
       Storage -40℃ to 60℃ ; Relative Humidity: 10% to 95% (non-condensing)
 Front Panel: Eject Button, Status LED and Emergency Manual Eject Hole
 Connectors: DC Power Connector, ATA Connector (IDE), Maseter/Slave/CSEL Selection
  Jumpers, Analog Audio Output Connector.
 Dimension : 146.0(W) x 41.4(H) x 192 (D)  mm
 Weight : 1100g (typical)
Message édité par bobdennard le 01-05-2003 à 18:46:07
Marsh Posté le 29-04-2003 à 12:25:19
il commence tout juste à être dispo dans le monde !
Mais pour le prix c'est un peu plus cher voir :
http://www.qualitron.com/qualitron [...] m=LT33301R
Enfin ils doivent se sucrer vu qu'ils ont peut être les premiers exemplaires dispo
Marsh Posté le 29-04-2003 à 12:29:20
c est clair qu ils se sucrent grave puisqu il est annnce a un prix publique de 300$ soit 280 ? environ... :ouch:
-=Liens utiles sur Software & Réseaux= -=Installation automatisée de Windows 2000-XP-2003=- =Modérateur sur www.altirigos.com =-
Marsh Posté le 29-04-2003 à 12:30:47
à 250? je reflechis à l'acheter à 200? je fonce :D
Marsh Posté le 29-04-2003 à 12:35:53
Marsh Posté le 29-04-2003 à 12:37:00
[:wipeout_tt]
Marsh Posté le 29-04-2003 à 12:40:27
il devait soit disant casser les prix en 2 et arriver a 200?
Il est po encore dispo reellement mais a ce prix la c cher pour liteon je trouve  :heink:
Marsh Posté le 29-04-2003 à 12:48:02
quand il sortira en europ il sera au prix de 280? conseillé (je pense), tu comptes les bons prix des chinois, ça fait un peu  moins cher, puis avec un peu de temps le même pourcentage de baisse que le 52x24x52x 75? à sa sortie il me semble qui se trouve à 55? facilement maintenant !
Je suis optimiste mais avec un peu de bol un prix de 200? en europe pour dans quelques mois c'est peu être pas si faux :pt1cable:
Marsh Posté le 30-04-2003 à 20:00:52
Une rumeur très persistante sur les forum americain dit que le nouveau liteon serais simplement un Sony DW-U10A sous un autre nom. Ce qui est très probable vu que liteon on dit il y a quelque semaine, qu'il n'était pas capable de produire les laser multi-format en quantité que que ca serai probablement repoussé au 4e trimestre ou meme début 2004, et maintenant, il sorte un graveur qui resemble beaucoup au sony et qui a exactement les meme spec...
Je préfère la réputation de liteon que Sony alors je me tiens loins de ce petit nouveau
Marsh Posté le 30-04-2003 à 20:16:38
mouai rumeur et rumeur  :o
Marsh Posté le 30-04-2003 à 20:40:52
idem.
et sachant que le prix avoisinne celui du Sony. peut etre que c'est la meme mecanique.
Marsh Posté le 30-04-2003 à 20:47:00
un sony rebadgé ?
une merde alors...
Marsh Posté le 30-04-2003 à 20:59:39
Wonder_Link2 a écrit :
idem.
ca expliquerai également pk le prix de 150$ orriginal est rendu a 300$ (comme le sony)
Marsh Posté le 30-04-2003 à 21:32:24
snif va falloir encore attendre qu'elle poisse
Marsh Posté le 30-04-2003 à 23:14:21
pourquoi si c'est un sony c'est pas bien :??:
et cette info n'est pas sure si :??:
parceque moi je l'attendais ce graveur
Marsh Posté le 30-04-2003 à 23:42:34
kler arrete de cracher sur sony c un super graveur ya pas mieux pour le moment et tous les tests disent que la meca sony est super
Marsh Posté le 30-04-2003 à 23:46:24
tu va aprendre avec le temp que les tests de site sont très peu fiable et que tu trouve les vrai valeur d'une pièce dans les test et commantaire des gens qui en on un. j'ai apris ca avec une certain P4S8X de chez asus...
C sur que présentement, le sony est le meilleur.. mais la bare est pas haute
Marsh Posté le 01-05-2003 à 11:16:03
le liteon n'est qu'un sony rebadgé :( :
SONY
http://images2.newegg.com/productimage/27-131-205-04.JPG
LITEON
http://club.cdfreaks.com/showthrea [...] genumber=3
Marsh Posté le 01-05-2003 à 11:34:40
mouais... ce serais mieux de le voir le ventre a l'air pour voir si c les même pieces quand même..
parceque pour moi rien ne resemble plus au cul d'un graveur que le cul d'un autre graveru, presque :D
Marsh Posté le 01-05-2003 à 11:45:36
tu m'etonnes !
Marsh Posté le 01-05-2003 à 11:53:07
vous n'avez pas de bon yeux [:alarmclock1]
Marsh Posté le 01-05-2003 à 15:15:39
euh.. presque tous les lecteur ou graveur on le meme "derrière" c'Est pas vraiment une preuve.. mais c'Est vrai que la construction est identique et c'st exactement les meme spec.
Marsh Posté le 01-05-2003 à 15:25:31
ben si je regarde bien l'arriere de tout mes lecteur/graveurs etc... je vois plein de petites différences. aucun n'est identique.
la tout est identique, jusqu'aux trou dans le pcb à gauche... si c'est pas louche comme truc.
moi je dis ils ont sortit ce graveur qui est un sony parceque pour l'instant ils avaient pas les possibilité d'en faire un eux même.
Marsh Posté le 01-05-2003 à 15:47:56
j'avoue..
également la photo posté ici n'est pas bonne:
Amusez vous a comparer:
LE LITEON
LE SONY
http://www.venus.dti.ne.jp/~xtv/bunkai/u10a_1.jpg
apart le collent liteonit (qui sois dit en passant est tres facile a enlevé et a remettre) il n'y a aucune différence
Message édité par vric le 01-05-2003 à 15:49:49
Marsh Posté le 02-05-2003 à 12:56:24
bah le sony que j'utilise au taff ne resemble pas a celui-ci  :o
Marsh Posté le 02-05-2003 à 12:58:50
Ah bah je me disais aussi que la facade ressemblait très très très très fortement à une facade Sony :o
Marsh Posté le 09-05-2003 à 19:27:53
C'est celui là le Sony non ?
http://www.hardware.fr/medias/photos_news/00/06/IMG0006057.jpg
Marsh Posté le 09-05-2003 à 19:56:06
Juste une question en passant,ça existe des graveur dvd en scsi?
Marsh Posté le 10-05-2003 à 23:34:28
ca c le DRU-500A.. le liteon est un Sony DW-U10A
Marsh Posté le 11-05-2003 à 00:22:36
drapal
« Le verbe "aimer" est le plus compliqué de la langue. Son passé n'est jamais simple, son présent n'est qu'imparfait et son futur toujours conditionnel. » Jean Cocteau
Marsh Posté le 11-05-2003 à 17:36:45
:love:
Marsh Posté le 11-05-2003 à 17:55:42
Marsh Posté le 11-05-2003 à 18:56:27
pkoi vous vous interessez a ce model, c'est juste un sony :/
liteon on en reparleras quand ils sortiront leurs propres modeles avec leurs mecaniques :o
Marsh Posté le 12-05-2003 à 00:01:17
idem.
Marsh Posté le 12-05-2003 à 01:39:14
4e trimestre ou début 2004 pour le multi liteon (le vrai)
il devrais sortir un +rw cette été
Marsh Posté le 12-05-2003 à 02:45:30
arf ..
donc pour le moment SONY DRU 510 rulez...???
mais il me semble que lite on n est pas le seul constructeur asiatique qui comptait faire baisser les prix au 2 nd semestre 2003....
que font ils donc ??
arg mon porte feuille !! :fou:
Marsh Posté le 12-05-2003 à 04:38:00
ze_neosushi a écrit :
arf ..
en gros, la production de laser multi format a pas augmenté comme prévue, donc le prix a pas baissé
TDK NEC et Toshiba (reste a vérifié pour Toshiba) font des Multi-Format également. TDK semble le meilleur selon les critique professionel (est ce que ca vaux quelque chose ?)
Message édité par vric le 12-05-2003 à 04:38:20
Marsh Posté le 12-05-2003 à 11:50:49
Arf il faut donc prendre le Sony ?
Sinon le NEC vient bien de sortir non ?
Marsh Posté le 12-05-2003 à 16:15:54
ou bien tu t'informe un peu et tu fait un choix entre +RW et -RW... Personne n'a vraiment besoin des deux. les DVD Multi-format on été inventé pour que les personnes qui sont incapable de faire un choix (ou de s'informer) achete un graveur.
90% de ceux qui on des Multi-Format, utilise seulement 1 des 2 format (très souvent le -R)
pour le NEC, je crois l'avoir vu disponible en europe.. en Amerique, il n'est pas disponible encore. Sinon je crois qu'au Japon c'Est dispo  :D
et pour de ce qui est de l'avenir, Microsoft vien de supporté le format DVD-RW ce mois ci, donc plus de favoritisme pour le +rw comme avant (ridicule de favorisé un format qui a seulement 30% des ventes total)
Message édité par vric le 12-05-2003 à 16:17:12
Marsh Posté le 12-05-2003 à 16:43:35
Je suis à 100 % pour le -R à cause du prix :D
Sinon le +RW a certains avantages mais pas justifier par rapport au prix.
Bref je m'étais dis qu'un multi à 250 ? ça serait le pied mais à première vu faut pas éspérer avant fin 2003.
