Lire un rapport RAID (HP Array Diagnostic Utility)
Lire un rapport RAID (HP Array Diagnostic Utility) - Disque dur - Hardware
Marsh Posté le 20-07-2011 à 20:18:01
Comment savoir quelles sont les informations utiles pour se dire que tout va bien (ou mal) dans ce rapport "HP Array Diagnostic Utility"?
C'est du Raid 1
[quote]Array Diagnostic Utility Version 7.70.12.0
Array Diagnostic Utility Inspection Report Version 7.70.12.0
Date/Time:          Friday, July 15, 2011 12:32:24PM
Computer Model:     HP Server
SLOT SUMMARY:
   Slot Num  Slot Type  Array Controllers and Host Adapters Detected
   SLOT 0    PCI        Smart Array E200i Controller
SLOT 0 Smart Array E200i Controller ERROR REPORT:
   No problems detected
SUBSYSTEM INFORMATION:
   Chassis Serial Num:              GB87097XNR
   This Controller
      Array Serial Number:          QL72MU3854
      Cache Serial Number:          P9A3A0B9SU3214
   Other Controller
      Array Serial Number:          Not Available
      Cache Serial Number:          Not Available
CONTROLLER IDENTIFICATION:
   Configured Logical Drives: 1
   Configuration Signature:   0xa0029fc3
   Controller Firmware Rev:   1.20
   Controller ROM Revision:
   Controller Hardware Rev:   0x00
   Boot Block Version:        1.20
   Board ID:                  0x3211103c
   Cable or Config Error:     0x00 (No)
   Invalid Host RAM Address:  No
   CPU Revision:              0x00
   CPU to PCI ASIC Rev:       0x00
   Cache Controller ASIC Rev: 0x00
   PCI to Host ASIC Rev:      0x00
   Marketing Revision:        0x41 (Rev A)
   Expand Disable Code:       0x01
   Protocol Chip Count:       1
   Enclosure Count:           3
   Max SCSI IDs per Bus:      0
   Big Drive Map:             0x000c 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   Big Ext Drive Map:         0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   Big Non-Disk Drive Map:    0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   Fibre Chip Count:          0
   Recovery ROM Inactive
   Image Revision:
   Recovery ROM Active Image
   Flags Status:              0x00
   Battery PIC Rev:           0x20
LOGICAL DRIVE IDENTIFICATION:
   Logical Drive 1:
      Sector Size:              512
      Sectors Available:        143305920
      Fault Tolerance Mode:     Mirroring
      Logical Param Table:      cyl=17562 heads=255 sec/track=32 xlate sig=0x0
      BIOS Disabled:            No
LOGICAL DRIVE CONFIGURATION:
   Logical Drive 1:
      Mapping Scheme:           Multiple Block
      Physical Drives:          2 (number not valid after drive movement)
         This Logical Drive:    2 (excluding spare drives)
      Distribution Factor:      256
      Operating System:         64768
      Controller Order:         0
      Additional Information:   0
      Offset to Data:           0
      Int 13h Support Enabled:  Yes
      Sectors on Volume:        143305920
      Sectors per Drive:        143305920
      Big Drive Assignment Map: 0x000c 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
      Big Spare Assignment Map: 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
      Array Accelerator is enabled for this logical drive.
LOGICAL DRIVE STATUS:
   Logical Drive 1:
      Drive Status:           OK
      Blocks to Rebuild:      0
      Blocks Re-mapped:
      Spare Status Flags:     0x00
      Spare to Replaced Map:  See Big Spare to Replace Map:
      Media Was Exchanged:    No
      Cache Failure:          No
      Expand Failure:         0x00
      Unit Flags:             0x10
      Big Remap Count:        All Counts Zero
      Big Drive Failure Map:     0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
      Big Replacement Drive Map: 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
      Big Active Spare Map:      0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
      Big Spare to Replace Map:  No spares have replaced any drives
      Big Spare Marked OK Map:   0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
MONITOR AND PERFORMANCE DATA:
   Port 1I, Box 1, Bay 2
      Factory:     Serial #, Firmware Rev, and Mfg/Model #:
         33 4c 42 31 4a 45 38 36 30 30 30 30 39 37 33 31      3LB1JE8600009731
         30 34 41 44 48 50 44 37 00 00 00 00 48 50 20 20      04ADHPD7....HP
         20 20 20 20 44 47 30 37 32 41 38 42 35 34 20 20          DG072A8B54
         20 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00          ............
         00 00 00 00                                          ....
      Since Power: Serial #, Firmware Rev, and Mfg/Model #:
         00 00 00 00                                          ....
      Serial Number Control:     0x0054
      Firmware Revision Control: 0x0248
      Mfg/Model Number Control:  0x0268
                 Factory          Since Power      Threshold        Control
      Serv. Time 002170c6         000007ca         00000000         2104
      Read Blks  0000000b564e0820 00000000044ef667                  0108
      Hrd Read   00000000         00000000         00000000         2104
      Rtry Read  00000000         00000000         00000000         2104
      ECC Read   0000000000000000 0000000000000000 0000000000000000 2108
      Write Blks 0000000194f3dc78 00000000007143fb                  0108
      Hrd Write  00000000         00000000         00000000         2104
      Rtry Write 00000000         00000000         00000000         2104
      Seeks      0000000000000000 0000000000000000                  0808
      Seek Errs  0000000000000000 0000000000000000 0000000000000000 0808
      Spin Cyls  00000000         00000000         00000000         2104
      Spin Time  0000             0000             0000             2202
      Test 1     0000             0000             0000             0802
      Test 2     0000             0000             0000             0802
      Test 3     0000             0000             0000             0802
      Test 4     0000             0000             0000             0802
      Spare Blks ffffffff         ffffffff                          0a04
      Re-mapped  00000000         00000000         00000000         2504
      DRQ Tmots  0000             0000             0000             0802
      Timeouts   0000             0000             0000             2102
      Rebuilds   0001             0000             0000             2102
      Spn Retrs  ffff             ffff             0000             2902
      Fl Rd Recv 0000             0000             0000             2102
      Fl Wt Recv 0000             0000             0000             2102
      Format Err 0000             0000             0000             2102
      POST Err   0000             0000             0000             0802
      Drv Nt Ry  00000000         00000000         00000000         2104
      Reallc Abt 00000000         00000000         00000000         0804
      IRQ Gltchs 00000000         00000000         00000000         0804
      Bus Flts   00000000         00000000         00000000         2104
      Hot Plgs   00000000         00000000         00000000         2104
      Tk Rwt Err ffff             ffff             0000             2902
      Rmp Wt Err 0000             0000             0000             2102
      Bg Fw Rev  0000000000000000 0000000000000000                  0848
      Med Flrs   0000             0000             0000             2102
      Hrdw Errs  0000             0000             0000             2102
      Abt Cmd Fl 0000             0000             0000             2102
      Spn Up Fl  0000             0000             0000             2102
      Bd Tgt Cnt 0000             0000             0000             2102
      Pred Fails 00000000         00000000         00000000         2104
      DRIVE ERROR LOG:
         Error Log Header:
            Parameter Length    = 0x14
            Entry Size          = 0x0040
            Current Entry       = 0x21
            Total Errors Logged = 0x000000a1
         Error Log Data:
SCSI  CAM   Sense  Sense
Stat  Stat  Key    Code    Qual   Block(Vl)       Time       Op   Info
02    04    06     29      02     00000000(0)     001e46ea   00   0000
02    04    06     29      02     00000000(0)     001e76a5   00   0000
02    04    06     29      02     00000000(0)     001ebd39   00   0000
02    04    06     29      02     00000000(0)     001ebd45   00   0000
02    04    06     29      02     00000000(0)     001ebd4b   00   0000
02    04    06     29      02     00000000(0)     001ebd50   00   0000
02    04    06     29      02     00000000(0)     001ebd66   00   0000
02    04    06     29      02     00000000(0)     001ebde2   00   0000
02    04    06     29      02     00000000(0)     001ebde8   00   0000
02    04    06     29      02     00000000(0)     001ec591   00   0000
02    04    06     29      02     00000000(0)     001ec5a4   00   0000
02    04    06     29      02     00000000(0)     001ec7e0   00   0000
02    04    06     29      02     00000000(0)     001f5b1c   00   0000
02    04    06     29      02     00000000(0)     001f5b8c   00   0000
02    04    06     29      02     00000000(0)     001f7065   00   0000
02    04    06     29      02     00000000(0)     001f8235   00   0000
02    04    06     29      02     00000000(0)     001f87d5   00   0000
02    04    06     29      02     00000000(0)     001f87f1   00   0000
02    04    06     29      02     00000000(0)     001fac09   00   0000
02    04    06     29      02     00000000(0)     001fbbbd   00   0000
   Port 1I, Box 1, Bay 1
         33 4c 42 31 4a 45 4c 38 30 30 30 30 39 37 33 31      3LB1JEL800009731
         31 34 55 4a 48 50 44 37 00 00 00 00 48 50 20 20      14UJHPD7....HP
         00 00 00 00                                          ....
         00 00 00 00                                          ....
      Serv. Time 00217698         000007ca         00000000         2104
      Read Blks  00000004aad6537e 0000000003f1f935                  0108
      Write Blks 00000001971e22ef 00000000007143fb                  0108
      DRIVE ERROR LOG:
         Error Log Header:
            Entry Size          = 0x0040
            Current Entry       = 0x20
            Total Errors Logged = 0x000000a0
         Error Log Data:
02    04    06     29      02     00000000(0)     001ebdb5   00   0000
02    04    06     29      02     00000000(0)     001ebdbb   00   0000
02    04    06     29      02     00000000(0)     001ec564   00   0000
02    04    06     29      02     00000000(0)     001ec577   00   0000
02    04    06     29      02     00000000(0)     001ecb1c   00   0000
02    04    06     29      02     00000000(0)     001ecb76   00   0000
02    04    06     29      02     00000000(0)     001ecdb2   00   0000
02    04    06     29      02     00000000(0)     001f60ee   00   0000
02    04    06     29      02     00000000(0)     001f615e   00   0000
02    04    06     29      02     00000000(0)     001f7637   00   0000
02    04    06     29      02     00000000(0)     001f8807   00   0000
02    04    06     29      02     00000000(0)     001f8da7   00   0000
02    04    06     29      02     00000000(0)     001f8dc3   00   0000
02    04    06     29      02     00000000(0)     001fb1db   00   0000
02    04    06     29      02     00000000(0)     001fc18f   00   0000
02    04    06     29      02     00000000(0)     001fc196   00   0000
SURFACE ANALYSIS STATUS:
   Time remaining to start: 12 secs.
   Surface analysis delay:  15 secs.
   Enclosure 1:
                 Big
      Drive ID   Current Block
         00      0x00000000
         01      0x00000000
         02      0x02606f00
         03      0x02606f00
         04      0x00000000
         05      0x00000000
         06      0x00000000
         07      0x00000000
         08      0x00000000
         09      0x00000000
         10      0x00000000
         11      0x00000000
         12      0x00000000
         13      0x00000000
         14      0x00000000
         15      0x00000000
   Enclosure 2:
                 Big
         00      0x00000000
         01      0x00000000
         02      0x00000000
         03      0x00000000
         04      0x00000000
         05      0x00000000
         06      0x00000000
         07      0x00000000
         08      0x00000000
         09      0x00000000
         10      0x00000000
         11      0x00000000
         12      0x00000000
         13      0x00000000
         14      0x00000000
         15      0x00000000
   Enclosure 3:
                 Big
         00      0x00000000
         01      0x00000000
         02      0x00000000
         03      0x00000000
         04      0x00000000
         05      0x00000000
         06      0x00000000
         07      0x00000000
         08      0x00000000
         09      0x00000000
         10      0x00000000
         11      0x00000000
         12      0x00000000
         13      0x00000000
         14      0x00000000
         15      0x00000000
                    Big                                   Surface     Surface
   Logical  Big     Inconsistent  Blocks      Controller  Analysis    Analysis
   Drive    Status  Block         Reassigned  Resets      Passes      Pass Time
         1   0x01   0x00000000             0     21               18        8578
         2   0x00   0x00000000             0      0                0           0
         3   0x00   0x00000000             0      0                0           0
         4   0x00   0x00000000             0      0                0           0
         5   0x00   0x00000000             0      0                0           0
         6   0x00   0x00000000             0      0                0           0
         7   0x00   0x00000000             0      0                0           0
         8   0x00   0x00000000             0      0                0           0
         9   0x00   0x00000000             0      0                0           0
        10   0x00   0x00000000             0      0                0           0
        11   0x00   0x00000000             0      0                0           0
        12   0x00   0x00000000             0      0                0           0
        13   0x00   0x00000000             0      0                0           0
        14   0x00   0x00000000             0      0                0           0
        15   0x00   0x00000000             0      0                0           0
        16   0x00   0x00000000             0      0                0           0
        17   0x00   0x00000000             0      0                0           0
        18   0x00   0x00000000             0      0                0           0
        19   0x00   0x00000000             0      0                0           0
        20   0x00   0x00000000             0      0                0           0
        21   0x00   0x00000000             0      0                0           0
        22   0x00   0x00000000             0      0                0           0
        23   0x00   0x00000000             0      0                0           0
        24   0x00   0x00000000             0      0                0           0
        25   0x00   0x00000000             0      0                0           0
        26   0x00   0x00000000             0      0                0           0
        27   0x00   0x00000000             0      0                0           0
        28   0x00   0x00000000             0      0                0           0
        29   0x00   0x00000000             0      0                0           0
        30   0x00   0x00000000             0      0                0           0
        31   0x00   0x00000000             0      0                0           0
        32   0x00   0x00000000             0      0                0           0
ACCELERATOR STATUS:
   Logical Drive Disable Map: 0x00000000
   Read Cache Size:           48 MBytes
   Posted Write Size:         48 MBytes
   Disable Flag:              0x00
   Status:                    0x00000001
   Disable Code:              0x0000
   Total Memory Size:         128 MBytes
   Battery Count:             1
   Battery Status:            0x0001
   Parity Read Errors:        0000
   Parity Write Errors:       0000
   Error Log:                 N/A
   Failed Batteries:          0x0000
   Board Present:             Yes
   Accelerator Failure Map:   0x00000000
   Max Error Log Entries:     12
   NVRAM Load Status:         0x00
   Memory Size Shift Factor:  0x0a
   Non Battery Backed Memory: 0 MBytes
   Memory State:              0x00
PHYSICAL DRIVE IDENTIFICATION:
      Vendor Id:           HP
      Product Id:          DG072A8B54
      Product Rev:         HPD7
      Vendor Specific:     3LB1JE86    SEAGATE
      Serial Number:       3LB1JE860000973104AD
      SCSI Inquiry Header: 00 00 05 12 8b 00 00 02
      Device Supports:     Tagged Command Queueing
      Drive Type:          0x02 SAS
      Block Size:          512 bytes/sector
      Total Blocks:        143374738 sectors/disk
      Reserved Blocks:     65536 reserved sectors/disk
      SCSI Inquiry Bits:   0x02
      Stamped for M&P:     yes
      Last Failure Reason: 0x00 (Drive has not failed)
      Phys Drive Flags:    0x01 0x25 0xa0 0x00
                           Drive present and operational
                           S.M.A.R.T. Supported
                           S.M.A.R.T. Enabled
                           Configured as part of Logical Drive
                           Drive write cache is currently disabled
                           Drive write cache setting is changeable and safe
      Physical Connector:  1I (controller connector attached to drive)
      Physical Box on Bus: 1 (number of the physical enclosure in which drive resides)
      Physical Bay in Box: 2 (number of the physical drive bay in the enclosure)
      MODE SENSE:
         Header:   00 de 00 10 00 00 00 08 00 00 00 00 00 00 02 00
         Page 01:  81 0a e4 0b ff 00 00 00 05 00 ff ff
         Page 02:  82 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00
         Page 03:  83 16 28 ec 00 00 00 14 00 00 02 be 02 00 00 01
                   00 b4 00 6c 40 00 00 00
         Page 04:  84 16 00 c7 bc 04 00 00 00 00 00 00 00 00 00 00
                   00 00 00 00 27 31 00 00
         Page 07:  87 0a 04 0b ff 00 00 00 00 00 ff ff
         Page 08:  88 12 00 00 ff ff 00 00 00 00 ff ff 00 20 00 00
                   00 00 00 00
         Page 09:  89 0e 0c 00 00 00 00 00 00 00 00 00 00 08 00 00
         Page 0a:  8a 0a 00 10 00 00 00 00 00 00 06 18
         Page 0c:  8c 16 80 00 00 0f 00 00 00 00 00 00 00 c7 bb 03
                   00 00 00 00 00 00 10 08
         Page 18:  18 06 06 00 00 00 00 00
         Page 19:  99 06 06 00 07 d0 00 00
         Page 1a:  9a 0a 00 00 00 00 00 05 00 00 00 04
         Page 1c:  9c 0a 11 04 00 00 0b b8 00 00 00 02
         Page 00:  80 06 00 00 0f 00 00 00
      Vendor Id:           HP
      Product Rev:         HPD7
      Vendor Specific:     3LB1JEL8    SEAGATE
      Serial Number:       3LB1JEL80000973114UJ
                           S.M.A.R.T. Enabled
      Physical Bay in Box: 1 (number of the physical drive bay in the enclosure)
      MODE SENSE:
                   00 00 00 00
CONTROLLER PARAMETERS:
   LED Control:               0x00
   Command List Verification: On
   Backed-out Write drives:   0
   Stripes for Parity:        0
   Distribution Mode:         0x00
   Maximum Driver Requests:   0x00ff
   Elevator Trend Count:      0x0032
   Disable Elevator:          0x00
   Force Scan Complete:       0x00
   Synch/Asynch Mode:         Auto Detect
   Force Narrow:              No
   Rebuild Priority:          0
   Expand Priority:           0
   SDB ASIC Fix:              0x00
   PDIP Burst Disable:        0x00
   Software Name:
   Hardware Name:
Enclosure 1 PARAMETERS:
   Inquiry Data Valid:    No
   Hot Plug Counts:
      All counts are zero
   Fan Alert Count:       0x0000
   Alarm Status:          0x00 (No Alarms)
   Temperature Status:    0x00
   Valid Alarm Bits:      0x00
   Alarm Count:           0000
   Specific Counts:       00000 00000 00000 00000 00000 00000 00000 00000
   Connection Info:       0x0002
   SCSI Device Rev:       0x00
   Fan Status:            0x0000
   More Inquiry Data:
        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00       ................
   SCSI Device Type:      0x3c103832 (unknown)
   Interrupt Count:       00000000
   Ultra Bus Faults:      0x00000000
   SCSI Initiator ID:     0
   SCSI Target ID:        0
   Chassis Serial Number: Not Available
   Big Inst Drive Map:    0x000c 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   Big Bus Map:           0x000f 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   More Connection Info:  0x00 (Single-Ended SCSI bus enabled)
   Extended Powersupply / Fan Information not available on this unit
Enclosure 2 PARAMETERS:
   Hot Plug Counts:
      All counts are zero
   Alarm Count:           0000
   Fan Status:            0x0000
   More Inquiry Data:
   SCSI Target ID:        0
   Physical Connector:    2I (controller connector attached to drive)
   Big Inst Drive Map:    0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
   Big Bus Map:           0x00f0 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
Enclosure 3 PARAMETERS:
   Hot Plug Counts:
      All counts are zero
   Alarm Count:           0000
   Connection Info:       0x0000
   Fan Status:            0x0000
   More Inquiry Data:
   SCSI Device Type:      0x00000000 (unknown)
   SCSI Target ID:        0
   Physical Connector:    0x0000 (controller connector attached to drive)
   Big Bus Map:           0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
MASTER BOOT RECORD (LOGICAL DRIVE 1)
      Logical Drive 1 (SCSI Port 1, Drive ID 2):
         Master Boot Record hex dump:
            33 c0 8e d0 bc 00 7c fb 50 07 50 1f fc be 1b 7c
            bf 1b 06 50 57 b9 e5 01 f3 a4 cb bd be 07 b1 04
            38 6e 00 7c 09 75 13 83 c5 10 e2 f4 cd 18 8b f5
            83 c6 10 49 74 19 38 2c 74 f6 a0 b5 07 b4 07 8b
            f0 ac 3c 00 74 fc bb 07 00 b4 0e cd 10 eb f2 88
            4e 10 e8 46 00 73 2a fe 46 10 80 7e 04 0b 74 0b
            80 7e 04 0c 74 05 a0 b6 07 75 d2 80 46 02 06 83
            46 08 06 83 56 0a 00 e8 21 00 73 05 a0 b6 07 eb
            bc 81 3e fe 7d 55 aa 74 0b 80 7e 10 00 74 c8 a0
            b7 07 eb a9 8b fc 1e 57 8b f5 cb bf 05 00 8a 56
            00 b4 08 cd 13 72 23 8a c1 24 3f 98 8a de 8a fc
            43 f7 e3 8b d1 86 d6 b1 06 d2 ee 42 f7 e2 39 56
            0a 77 23 72 05 39 46 08 73 1c b8 01 02 bb 00 7c
            8b 4e 02 8b 56 00 cd 13 73 51 4f 74 4e 32 e4 8a
            56 00 cd 13 eb e4 8a 56 00 60 bb aa 55 b4 41 cd
            13 72 36 81 fb 55 aa 75 30 f6 c1 01 74 2b 61 60
            6a 00 6a 00 ff 76 0a ff 76 08 6a 00 68 00 7c 6a
            01 6a 10 b4 42 8b f4 cd 13 61 61 73 0e 4f 74 0b
            32 e4 8a 56 00 cd 13 eb d6 61 f9 c3 54 61 62 6c
            65 20 64 65 20 70 61 72 74 69 74 69 6f 6e 20 6e
            6f 6e 20 76 61 6c 69 64 65 00 45 72 72 65 75 72
            20 6c 6f 72 73 20 64 75 20 63 68 61 72 67 65 6d
            65 6e 74 20 64 75 20 73 79 73 74 8a 6d 65 20 64
            27 65 78 70 6c 6f 69 74 61 74 69 00 53 79 73 74
            8a 6d 65 20 64 27 65 78 70 6c 6f 69 74 61 74 69
            6f 6e 20 61 62 73 65 6e 74 00 00 00 00 00 00 00
            00 00 00 00 00 2c 4a 7c b0 25 b0 25 00 00 80 01
            01 00 07 fe e0 ff 20 00 00 00 a0 8d af 02 00 00
            c1 ff 07 fe e0 ff c0 8d af 02 20 ff da 05 00 00
            00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa
PARTITION TABLES:
      SCSI Port 1, Drive ID 2:
            80 01 01 00 07 fe e0 ff 20 00 00 00 a0 8d af 02
               (Start C/H/S 0000/001/01, End 1023/254/32)
            00 00 c1 ff 07 fe e0 ff c0 8d af 02 20 ff da 05
               (Start C/H/S 1023/000/01, End 1023/254/32)
      SCSI Port 1, Drive ID 3:  ---> Same as above.
RIS DATA AREA:
   Port 1I, Box 1, Bay 2:
      RIS drive: 0x2
      RIS Copy 0:
         Drive id:          2
         RIS signature:     HPSA_RIS
         Physical Drives:   2
         Logical Drives:    1
         Physical Drive State: (00=OK, 01=bad or not present, 02=replacement)
            01 01 00 00 01 01 01 01 01 01 01 01 01 01 01 01
            01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01
         RIS version:       0026
         Logical Drive State:  (00=OK, 01=failed, 02=unused)
         RIS updates:       228
         Remap interrupted: 0
         Surface delay:     150
         Overheat delay:    0
         M&P delay:         60
         RIS hex dump:
            02 00 00 00 e9 a3 74 e3 48 50 53 41 5f 52 49 53
            00 1a 00 00 00 00 00 00 00 00 78 28 00 00 00 00
            00 00 01 00 00 ff 00 32 00 00 00 3c 00 00 00 00
            00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
            00 60 00 00 00 30 00 30 00 00 00 00 01 00 01 00
            00 00
